[PATCH v2] mkimage: FIT ciphering bug fixes
The v2 series addresses review comments from Philippe Reynes: * Use FIT_CIPHER_NODENAME instead of hard coding "cipher" * Simplify handling of FDT_ERR_NOSPACE * Simplify detection of previously ciphered data
The last two points are possible as I overlooked that the retry loop handling ENOSPC in fit_handle_file() reloads the original FIT before retrying.
From: Patrick Oppenlander patrick.oppenlander@gmail.com
Previously mkimage would process any node matching the regex cipher.* and apply the ciphers to the image data in the order they appeared in the FDT. This meant that data could be inadvertently ciphered multiple times.
Switch to processing a single cipher node which exactly matches FIT_CIPHER_NODENAME.
Signed-off-by: Patrick Oppenlander patrick.oppenlander@gmail.com Reviewed-by: Philippe Reynes philippe.reynes@softathome.com --- tools/image-host.c | 57 ++++++++++++++++++---------------------------- 1 file changed, 22 insertions(+), 35 deletions(-)
diff --git a/tools/image-host.c b/tools/image-host.c index 9a83b7f675..dd7ecc4b60 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -323,15 +323,15 @@ err: static int fit_image_setup_cipher(struct image_cipher_info *info, const char *keydir, void *fit, const char *image_name, int image_noffset, - const char *node_name, int noffset) + int noffset) { char *algo_name; char filename[128]; int ret = -1;
if (fit_image_cipher_get_algo(fit, noffset, &algo_name)) { - printf("Can't get algo name for cipher '%s' in image '%s'\n", - node_name, image_name); + printf("Can't get algo name for cipher in image '%s'\n", + image_name); goto out; }
@@ -340,16 +340,16 @@ static int fit_image_setup_cipher(struct image_cipher_info *info, /* Read the key name */ info->keyname = fdt_getprop(fit, noffset, FIT_KEY_HINT, NULL); if (!info->keyname) { - printf("Can't get key name for cipher '%s' in image '%s'\n", - node_name, image_name); + printf("Can't get key name for cipher in image '%s'\n", + image_name); goto out; }
/* Read the IV name */ info->ivname = fdt_getprop(fit, noffset, "iv-name-hint", NULL); if (!info->ivname) { - printf("Can't get iv name for cipher '%s' in image '%s'\n", - node_name, image_name); + printf("Can't get iv name for cipher in image '%s'\n", + image_name); goto out; }
@@ -428,8 +428,7 @@ int fit_image_write_cipher(void *fit, int image_noffset, int noffset, static int fit_image_process_cipher(const char *keydir, void *keydest, void *fit, const char *image_name, int image_noffset, - const char *node_name, int node_noffset, - const void *data, size_t size, + int node_noffset, const void *data, size_t size, const char *cmdname) { struct image_cipher_info info; @@ -440,7 +439,7 @@ fit_image_process_cipher(const char *keydir, void *keydest, void *fit, memset(&info, 0, sizeof(info));
ret = fit_image_setup_cipher(&info, keydir, fit, image_name, - image_noffset, node_name, node_noffset); + image_noffset, node_noffset); if (ret) goto out;
@@ -482,7 +481,7 @@ int fit_image_cipher_data(const char *keydir, void *keydest, const char *image_name; const void *data; size_t size; - int node_noffset; + int cipher_node_offset;
/* Get image name */ image_name = fit_get_name(fit, image_noffset, NULL); @@ -497,32 +496,20 @@ int fit_image_cipher_data(const char *keydir, void *keydest, return -1; }
- /* Process all hash subnodes of the component image node */ - for (node_noffset = fdt_first_subnode(fit, image_noffset); - node_noffset >= 0; - node_noffset = fdt_next_subnode(fit, node_noffset)) { - const char *node_name; - int ret = 0; - - node_name = fit_get_name(fit, node_noffset, NULL); - if (!node_name) { - printf("Can't get node name\n"); - return -1; - }
- if (IMAGE_ENABLE_ENCRYPT && keydir && - !strncmp(node_name, FIT_CIPHER_NODENAME, - strlen(FIT_CIPHER_NODENAME))) - ret = fit_image_process_cipher(keydir, keydest, - fit, image_name, - image_noffset, - node_name, node_noffset, - data, size, cmdname); - if (ret) - return ret; + /* Process cipher node if present */ + cipher_node_offset = fdt_subnode_offset(fit, image_noffset, + FIT_CIPHER_NODENAME); + if (cipher_node_offset == -FDT_ERR_NOTFOUND) + return 0; + if (cipher_node_offset < 0) { + printf("Failure getting cipher node\n"); + return -1; } - - return 0; + if (!IMAGE_ENABLE_ENCRYPT || !keydir) + return 0; + return fit_image_process_cipher(keydir, keydest, fit, image_name, + image_noffset, cipher_node_offset, data, size, cmdname); }
On Thu, Jul 30, 2020 at 02:22:13PM +1000, patrick.oppenlander@gmail.com wrote:
Also replace fdt_delprop/fdt_setprop with fdt_setprop as fdt_setprop can replace an existing property value.
Signed-off-by: Patrick Oppenlander patrick.oppenlander@gmail.com --- tools/image-host.c | 19 ++++++++++--------- 1 file changed, 10 insertions(+), 9 deletions(-)
diff --git a/tools/image-host.c b/tools/image-host.c index dd7ecc4b60..b4603c5f01 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -399,23 +399,24 @@ int fit_image_write_cipher(void *fit, int image_noffset, int noffset, { int ret = -1;
- /* Remove unciphered data */ - ret = fdt_delprop(fit, image_noffset, FIT_DATA_PROP); - if (ret) { - printf("Can't remove data (err = %d)\n", ret); - goto out; - } - - /* Add ciphered data */ + /* Replace data with ciphered data */ ret = fdt_setprop(fit, image_noffset, FIT_DATA_PROP, data_ciphered, data_ciphered_len); + if (ret == -FDT_ERR_NOSPACE) { + ret = -ENOSPC; + goto out; + } if (ret) { - printf("Can't add ciphered data (err = %d)\n", ret); + printf("Can't replace data with ciphered data (err = %d)\n", ret); goto out; }
/* add non ciphered data size */ ret = fdt_setprop_u32(fit, image_noffset, "data-size-unciphered", size); + if (ret == -FDT_ERR_NOSPACE) { + ret = -ENOSPC; + goto out; + } if (ret) { printf("Can't add unciphered data size (err = %d)\n", ret); goto out;
Hi Patrick,
Regards, Philippe
- if (ret) {
- goto out;
- /* Replace data with ciphered data */
- if (ret == -FDT_ERR_NOSPACE) {
- ret = -ENOSPC;
- goto out;
if (ret) {
- printf("Can't replace data with ciphered data (err = %d)\n", ret);
goto out; }
- ret = -ENOSPC;
- goto out;
if (ret) { printf("Can't add unciphered data size (err = %d)\n", ret); goto out; -- 2.27.0
On Thu, Jul 30, 2020 at 02:22:14PM +1000, patrick.oppenlander@gmail.com wrote:
Previously, mkimage -F could be run multiple times causing already ciphered image data to be ciphered again.
Signed-off-by: Patrick Oppenlander patrick.oppenlander@gmail.com --- tools/image-host.c | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/tools/image-host.c b/tools/image-host.c index b4603c5f01..e5417beee5 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -482,7 +482,7 @@ int fit_image_cipher_data(const char *keydir, void *keydest, const char *image_name; const void *data; size_t size; - int cipher_node_offset; + int cipher_node_offset, len;
/* Get image name */ image_name = fit_get_name(fit, image_noffset, NULL); @@ -497,6 +497,19 @@ int fit_image_cipher_data(const char *keydir, void *keydest, return -1; }
+ /* + * Don't cipher ciphered data. + * + * If the data-size-unciphered property is present the data for this + * image is already encrypted. This is important as 'mkimage -F' can be + * run multiple times on a FIT image. + */ + if (fdt_getprop(fit, image_noffset, "data-size-unciphered", &len)) + return 0; + if (len != -FDT_ERR_NOTFOUND) { + printf("Failure testing for data-size-unciphered\n"); + return -1; + }
/* Process cipher node if present */ cipher_node_offset = fdt_subnode_offset(fit, image_noffset,
Hi Patrick,
Regards, Philippe
- int cipher_node_offset, len;
- Don't cipher ciphered data.
- If the data-size-unciphered property is present the data for this
- image is already encrypted. This is important as 'mkimage -F' can be
- run multiple times on a FIT image.
- if (fdt_getprop(fit, image_noffset, "data-size-unciphered", &len))
- if (len != -FDT_ERR_NOTFOUND) {
- printf("Failure testing for data-size-unciphered\n");
- return -1;
/* Process cipher node if present */ cipher_node_offset = fdt_subnode_offset(fit, image_noffset, -- 2.27.0
On Thu, Jul 30, 2020 at 02:22:15PM +1000, patrick.oppenlander@gmail.com wrote:
Philippe REYNES
