[U-Boot] [RESPIN PATCH v3 1/4] dm: pci: Optimize pci_uclass_post_bind()
If there is no pci device listed in the device tree, don't bother scanning the device tree.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
--- Simon, I see the following v2 patches were applied, but don't see you replied the patch thread to mention it's been applied. - x86: fsp: Call fsp_init_phase_pci() in pci_uclass_post_probe() - fdtdec: Fix possible infinite loop in fdtdec_get_pci_vendev() - dm: pci: Save devfn without bus number in pci_uclass_child_post_bind()
I assume these patches look good, so I don't include those patches in the v3 series. Let me know if there is any issue.
Changes in v3 respin: - Fix typo of 'tree'
Changes in v3: - Rebase on u-boot-x86/master - Drop v2 patches which were already applied
drivers/pci/pci-uclass.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 2d12344..b25298f 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -632,6 +632,13 @@ error: static int pci_uclass_post_bind(struct udevice *bus) { /* + * If there is no pci device listed in the device tree, + * don't bother scanning the device tree. + */ + if (bus->of_offset == -1) + return 0; + + /* * Scan the device tree for devices. This does not probe the PCI bus, * as this is not permitted while binding. It just finds devices * mentioned in the device tree.
Hi Bin,
They are fine, thanks.
Changes in v3:
- If there is no pci device listed in the device tree,
- don't bother scanning the device tree.
- if (bus->of_offset == -1)
Since this is a special case for PCI I think it is best that this check goes here instead of dm_scan_fdt_node().
- Scan the device tree for devices. This does not probe the PCI bus,
- as this is not permitted while binding. It just finds devices
- mentioned in the device tree.
-- 1.8.2.1
Bin Meng
