[U-Boot] [PATCH] test: py: Add cmd_echo dependency
There is missing dependency on echo command. Mark tests which requires echo.
test/py/tests/test_env.py | 8 ++++++++ test/py/tests/test_shell_basics.py | 4 ++++ 2 files changed, 12 insertions(+)
diff --git a/test/py/tests/test_env.py b/test/py/tests/test_env.py index 035dbf5cac4c..b7a76b31c304 100644 --- a/test/py/tests/test_env.py +++ b/test/py/tests/test_env.py @@ -157,6 +157,7 @@ def validate_set(state_test_env, var, value): response = state_test_env.u_boot_console.run_command('printenv %s' % var) assert response == ('%s=%s' % (var, value))
+@pytest.mark.buildconfigspec('cmd_echo') def test_env_echo_exists(state_test_env): """Test echoing a variable that exists."""
@@ -164,12 +165,14 @@ def test_env_echo_exists(state_test_env): value = state_test_env.env[var] validate_set(state_test_env, var, value)
+@pytest.mark.buildconfigspec('cmd_echo') def test_env_echo_non_existent(state_test_env): """Test echoing a variable that doesn't exist."""
var = state_test_env.set_var validate_empty(state_test_env, var)
+@pytest.mark.buildconfigspec('cmd_echo') def test_env_printenv_non_existent(state_test_env): """Test printenv error message for non-existant variables."""
@@ -179,6 +182,7 @@ def test_env_printenv_non_existent(state_test_env): response = c.run_command('printenv %s' % var) assert(response == '## Error: "%s" not defined' % var)
+@pytest.mark.buildconfigspec('cmd_echo') def test_env_unset_non_existent(state_test_env): """Test unsetting a nonexistent variable."""
@@ -186,6 +190,7 @@ def test_env_unset_non_existent(state_test_env): unset_var(state_test_env, var) validate_empty(state_test_env, var)
+@pytest.mark.buildconfigspec('cmd_echo') def test_env_set_non_existent(state_test_env): """Test set a non-existant variable."""
@@ -194,6 +199,7 @@ def test_env_set_non_existent(state_test_env): set_var(state_test_env, var, value) validate_set(state_test_env, var, value)
+@pytest.mark.buildconfigspec('cmd_echo') def test_env_set_existing(state_test_env): """Test setting an existant variable."""
@@ -202,6 +208,7 @@ def test_env_set_existing(state_test_env): set_var(state_test_env, var, value) validate_set(state_test_env, var, value)
+@pytest.mark.buildconfigspec('cmd_echo') def test_env_unset_existing(state_test_env): """Test unsetting a variable."""
@@ -209,6 +216,7 @@ def test_env_unset_existing(state_test_env): unset_var(state_test_env, var) validate_empty(state_test_env, var)
+@pytest.mark.buildconfigspec('cmd_echo') def test_env_expansion_spaces(state_test_env): """Test expanding a variable that contains a space in its value."""
diff --git a/test/py/tests/test_shell_basics.py b/test/py/tests/test_shell_basics.py index 702e5e27e002..f0def2759020 100644 --- a/test/py/tests/test_shell_basics.py +++ b/test/py/tests/test_shell_basics.py @@ -3,13 +3,16 @@ # SPDX-License-Identifier: GPL-2.0
# Test basic shell functionality, such as commands separate by semi-colons. +import pytest
+@pytest.mark.buildconfigspec('cmd_echo') def test_shell_execute(u_boot_console): """Test any shell command."""
response = u_boot_console.run_command('echo hello') assert response.strip() == 'hello'
+@pytest.mark.buildconfigspec('cmd_echo') def test_shell_semicolon_two(u_boot_console): """Test two shell commands separate by a semi-colon."""
@@ -28,6 +31,7 @@ def test_shell_semicolon_three(u_boot_console): assert response.strip() == '123' u_boot_console.run_command('setenv list')
+@pytest.mark.buildconfigspec('cmd_echo') def test_shell_run(u_boot_console): """Test the "run" shell command."""
test_hush_if_test.py also needs fixing for this. Perhaps you didn't notice this because those tests are already dependant on CONFIG_HUSH_PARSER which I assume you don't have enabled.
I don't believe this one actually depends on CONFIG_CMD_ECHO; it uses printenv rather than the echo command.
Same here.
Same here.
Same here.
Same here.
However, the other functions in the patch do need this mark.
Nit: There's a blank line between the file comment and import statements in other files.
Rather than marking each individual test in this file (and test_hush_if_test.py), perhaps apply the mark on a file/module level?
https://docs.pytest.org/en/latest/example/markers.html says to do this in global scope:
pytestmark = pytest.mark.buildconfigspec('cmd_echo')
yep - in my configuration hush is disabled that's why I didn't find it out. For hush only these two tests pass when echo is disable.
test_hush_if_test_setup test_hush_if_test_teardown
Also when you disable HUSH more tests failed.
removed
Same here.
removed
Same here.
removed
Same here.
removed
Same here.
You are right with that above. It was failing for me that's why I have added this but the reason for failure is different.
printenv is in cmd/nvedit.c which is enabled all the time obj-y += nvedit.o
That's why I will remove this completely.
Just a note there is
fixed.
yep that works too but I was checking setup_buildconfigspec and we don't have an option to mark whole file depends on cmd_echo but some tests in that file don't need to require it.
This is the same for env and dependency on hush. Where based on my tests only test_env_echo_exists and test_env_printenv_non_existent don't require hush.
Thanks, Michal
Michal Simek
Stephen Warren
