[PATCH 1/2] ARM: dts: stm32: Synchronize DHCOR DTs with Linux 5.15.12
Synchronize DH DHCOR DTs with Linux commit 25960cafa06e ("Linux 5.15.12"). There is no functional change to the resulting DTs. The eeprom0 alias is now reinstated in SoM u-boot dtsi, the PHY reset GPIO is reinstated in AV96 u-boot dtsi.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com --- arch/arm/dts/Makefile | 1 - arch/arm/dts/stm32mp157a-avenger96.dts | 8 - arch/arm/dts/stm32mp157a-dhcor-avenger96.dts | 38 ++ .../stm32mp15xx-dhcor-avenger96-u-boot.dtsi | 2 + arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts | 202 +------- arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi | 431 ++++++++++++++++++ arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi | 7 +- ...-io3v3.dtsi => stm32mp15xx-dhcor-som.dtsi} | 30 +- arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi | 8 + 9 files changed, 503 insertions(+), 224 deletions(-) delete mode 100644 arch/arm/dts/stm32mp157a-avenger96.dts create mode 100644 arch/arm/dts/stm32mp157a-dhcor-avenger96.dts create mode 100644 arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi rename arch/arm/dts/{stm32mp15xx-dhcor-io3v3.dtsi => stm32mp15xx-dhcor-som.dtsi} (91%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b3e2a9c9d77..03064632999 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1098,7 +1098,6 @@ dtb-$(CONFIG_ARCH_STI) += stih410-b2260.dtb
dtb-$(CONFIG_STM32MP15x) += \ stm32mp157a-dk1.dtb \ - stm32mp157a-avenger96.dtb \ stm32mp157a-icore-stm32mp1-ctouch2.dtb \ stm32mp157a-icore-stm32mp1-edimm2.2.dtb \ stm32mp157a-microgea-stm32mp1-microdev2.0.dtb \ diff --git a/arch/arm/dts/stm32mp157a-avenger96.dts b/arch/arm/dts/stm32mp157a-avenger96.dts deleted file mode 100644 index 9c165104fbe..00000000000 --- a/arch/arm/dts/stm32mp157a-avenger96.dts +++ /dev/null @@ -1,8 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) -/* - * Copyright (C) Linaro Ltd 2019 - All Rights Reserved - * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - */ - -/* This is kept for backward compatibility and will be removed */ -#include "stm32mp15xx-dhcor-avenger96.dts" diff --git a/arch/arm/dts/stm32mp157a-dhcor-avenger96.dts b/arch/arm/dts/stm32mp157a-dhcor-avenger96.dts new file mode 100644 index 00000000000..2e3c9fbb4eb --- /dev/null +++ b/arch/arm/dts/stm32mp157a-dhcor-avenger96.dts @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) +/* + * Copyright (C) Linaro Ltd 2019 - All Rights Reserved + * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + * Copyright (C) 2020 Marek Vasut marex@denx.de + * + * DHCOR STM32MP1 variant: + * DHCR-STM32MP157A-C065-R102-V18-SPI-C-01LG + * DHCOR PCB number: 586-100 or newer + * Avenger96 PCB number: 588-200 or newer + */ + +/dts-v1/; + +#include "stm32mp157.dtsi" +#include "stm32mp15xc.dtsi" +#include "stm32mp15xx-dhcor-som.dtsi" +#include "stm32mp15xx-dhcor-avenger96.dtsi" + +/ { + model = "Arrow Electronics STM32MP157A Avenger96 board"; + compatible = "arrow,stm32mp157a-avenger96", "dh,stm32mp157a-dhcor-som", + "st,stm32mp157"; +}; + +&m_can1 { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&m_can1_pins_b>; + pinctrl-1 = <&m_can1_sleep_pins_b>; + status = "disabled"; +}; + +&m_can2 { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&m_can2_pins_a>; + pinctrl-1 = <&m_can2_sleep_pins_a>; + status = "disabled"; +}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi index c96eba99c5e..6e6543b5e4a 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi @@ -21,6 +21,8 @@
ðernet0 { + phy-reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>; + mdio0 { ethernet-phy@7 { reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts index 0e860e5cf88..76ac5a873c1 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts +++ b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts @@ -7,206 +7,12 @@
/dts-v1/;
-#include "stm32mp15xx-dhcor-io1v8.dtsi" -#include "stm32mp15xx-dhcor-avenger96-u-boot.dtsi" +#include "stm32mp151.dtsi" +#include "stm32mp15xc.dtsi" +#include "stm32mp15xx-dhcor-som.dtsi" +#include "stm32mp15xx-dhcor-avenger96.dtsi"
/ { model = "Arrow Electronics STM32MP15xx Avenger96 board"; compatible = "arrow,stm32mp15xx-avenger96", "st,stm32mp15x"; - - aliases { - eeprom0 = &eeprom0; - ethernet0 = ðernet0; - mmc0 = &sdmmc1; - serial0 = &uart4; - serial1 = &uart7; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - led { - compatible = "gpio-leds"; - led1 { - label = "green:user0"; - gpios = <&gpioz 7 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - default-state = "off"; - }; - - led2 { - label = "green:user1"; - gpios = <&gpiof 3 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "mmc0"; - default-state = "off"; - }; - - led3 { - label = "green:user2"; - gpios = <&gpiog 0 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "mmc1"; - default-state = "off"; - }; - - led4 { - label = "green:user3"; - gpios = <&gpiog 1 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "none"; - default-state = "off"; - panic-indicator; - }; - - led5 { - label = "yellow:wifi"; - gpios = <&gpioz 3 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "phy0tx"; - default-state = "off"; - }; - - led6 { - label = "blue:bt"; - gpios = <&gpioz 6 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "bluetooth-power"; - default-state = "off"; - }; - }; - - sd_switch: regulator-sd_switch { - compatible = "regulator-gpio"; - regulator-name = "sd_switch"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <2900000>; - regulator-type = "voltage"; - regulator-always-on; - - gpios = <&gpioi 5 GPIO_ACTIVE_HIGH>; - gpios-states = <0>; - states = <1800000 0x1>, - <2900000 0x0>; - }; -}; - -ðernet0 { - status = "okay"; - pinctrl-0 = <ðernet0_rgmii_pins_c>; - pinctrl-1 = <ðernet0_rgmii_sleep_pins_c>; - pinctrl-names = "default", "sleep"; - phy-mode = "rgmii"; - max-speed = <1000>; - phy-handle = <&phy0>; - phy-reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>; - - mdio0 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "snps,dwmac-mdio"; - phy0: ethernet-phy@7 { - reg = <7>; - }; - }; -}; - -&i2c1 { /* X6 I2C1 */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins_b>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /delete-property/dmas; - /delete-property/dma-names; -}; - -&i2c2 { /* X6 I2C2 */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_c>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /delete-property/dmas; - /delete-property/dma-names; -}; - -&i2c4 { - eeprom0: eeprom@53 { - compatible = "atmel,24c02"; - reg = <0x53>; - pagesize = <16>; - }; -}; - -&sdmmc1 { - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_b>; - pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_b>; - pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_b>; - disable-wp; - st,sig-dir; - st,neg-edge; - st,use-ckin; - bus-width = <4>; - vmmc-supply = <&vdd_sd>; - vqmmc-supply = <&sd_switch>; - status = "okay"; -}; - -&sdmmc2 { - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_c>; - non-removable; - no-sd; - no-sdio; - st,neg-edge; - bus-width = <8>; - vmmc-supply = <&v3v3>; - mmc-ddr-3_3v; - status = "okay"; -}; - -&spi2 { - pinctrl-names = "default"; - pinctrl-0 = <&spi2_pins_a>; - status = "okay"; -}; - -&uart4 { - /* On Low speed expansion header */ - label = "LS-UART1"; - pinctrl-names = "default"; - pinctrl-0 = <&uart4_pins_b>; - status = "okay"; -}; - -&uart7 { - /* On Low speed expansion header */ - label = "LS-UART0"; - pinctrl-names = "default"; - pinctrl-0 = <&uart7_pins_a>; - status = "okay"; -}; - -&usbh_ehci { - phys = <&usbphyc_port0>; - phy-names = "usb"; - status = "okay"; -}; - -&usbotg_hs { - pinctrl-0 = <&usbotg_hs_pins_a>; - pinctrl-names = "default"; - phys = <&usbphyc_port1 0>; - phy-names = "usb2-phy"; - status = "okay"; -}; - -&usbphyc { - status = "okay"; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; -}; - -&usbphyc_port1 { - phy-supply = <&vdd_usb>; }; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi new file mode 100644 index 00000000000..6885948f302 --- /dev/null +++ b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi @@ -0,0 +1,431 @@ +// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) +/* + * Copyright (C) Linaro Ltd 2019 - All Rights Reserved + * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + * Copyright (C) 2020 Marek Vasut marex@denx.de + */ + +/* Avenger96 uses DHCOR SoM configured for 1V8 IO operation */ +#include "stm32mp15xx-dhcor-io1v8.dtsi" + +/ { + aliases { + ethernet0 = ðernet0; + mmc0 = &sdmmc1; + serial0 = &uart4; + serial1 = &uart7; + serial2 = &usart2; + spi0 = &qspi; + }; + + /* XTal Q1 */ + cec_clock: clk-cec-fixed { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <24000000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + hdmi-out { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con: endpoint { + remote-endpoint = <&adv7513_out>; + }; + }; + }; + + led { + compatible = "gpio-leds"; + led1 { + label = "green:user0"; + gpios = <&gpioz 7 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "off"; + }; + + led2 { + label = "green:user1"; + gpios = <&gpiof 3 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + default-state = "off"; + }; + + led3 { + label = "green:user2"; + gpios = <&gpiog 0 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc1"; + default-state = "off"; + }; + + led4 { + label = "green:user3"; + gpios = <&gpiog 1 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "none"; + default-state = "off"; + panic-indicator; + }; + }; + + sd_switch: regulator-sd_switch { + compatible = "regulator-gpio"; + regulator-name = "sd_switch"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <2900000>; + regulator-type = "voltage"; + regulator-always-on; + + gpios = <&gpioi 5 GPIO_ACTIVE_HIGH>; + gpios-states = <0>; + states = <1800000 0x1>, + <2900000 0x0>; + }; + + sound { + compatible = "audio-graph-card"; + label = "STM32MP1-AV96-HDMI"; + dais = <&sai2a_port>; + status = "okay"; + }; + + wlan_pwr: regulator-wlan { + compatible = "regulator-fixed"; + + regulator-name = "wl-reg"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + gpios = <&gpioz 3 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; +}; + +&adc { + pinctrl-names = "default"; + pinctrl-0 = <&adc12_ain_pins_b>; + vdd-supply = <&vdd>; + vdda-supply = <&vdda>; + vref-supply = <&vdda>; + status = "okay"; + + adc1: adc@0 { + st,adc-channels = <0 1 6>; + st,min-sample-time-nsecs = <5000>; + status = "okay"; + }; + + adc2: adc@100 { + st,adc-channels = <0 1 2>; + st,min-sample-time-nsecs = <5000>; + status = "okay"; + }; +}; + +ðernet0 { + status = "okay"; + pinctrl-0 = <ðernet0_rgmii_pins_c>; + pinctrl-1 = <ðernet0_rgmii_sleep_pins_c>; + pinctrl-names = "default", "sleep"; + phy-mode = "rgmii"; + max-speed = <1000>; + phy-handle = <&phy0>; + + mdio0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>; + reset-delay-us = <1000>; + + phy0: ethernet-phy@7 { + reg = <7>; + + rxc-skew-ps = <1500>; + rxdv-skew-ps = <540>; + rxd0-skew-ps = <420>; + rxd1-skew-ps = <420>; + rxd2-skew-ps = <420>; + rxd3-skew-ps = <420>; + + txc-skew-ps = <1440>; + txen-skew-ps = <540>; + txd0-skew-ps = <420>; + txd1-skew-ps = <420>; + txd2-skew-ps = <420>; + txd3-skew-ps = <420>; + }; + }; +}; + +&gpioa { + gpio-line-names = "", "", "", "", + "", "", "", "", + "", "", "", "AV96-K", + "AV96-I", "", "AV96-A", ""; +}; + +&gpiob { + gpio-line-names = "", "", "", "", + "", "AV96-J", "", "", + "", "", "", "AV96-B", + "", "AV96-L", "", ""; +}; + +&gpioc { + gpio-line-names = "", "", "", "AV96-C", + "", "", "", "", + "", "", "", "", + "", "", "", ""; +}; + +&gpiod { + gpio-line-names = "", "", "", "", + "", "", "", "", + "AV96-D", "", "", "", + "", "", "AV96-E", "AV96-F"; +}; + +&gpiof { + gpio-line-names = "", "", "", "", + "", "", "", "", + "", "", "", "", + "AV96-G", "AV96-H", "", ""; +}; + +&i2c1 { /* X6 I2C1 */ + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins_b>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /delete-property/dmas; + /delete-property/dma-names; +}; + +&i2c2 { /* X6 I2C2 */ + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins_c>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /delete-property/dmas; + /delete-property/dma-names; +}; + +&i2c4 { + hdmi-transmitter@3d { + compatible = "adi,adv7513"; + reg = <0x3d>, <0x4d>, <0x2d>, <0x5d>; + reg-names = "main", "edid", "cec", "packet"; + clocks = <&cec_clock>; + clock-names = "cec"; + + avdd-supply = <&v3v3>; + dvdd-supply = <&v3v3>; + pvdd-supply = <&v3v3>; + dvdd-3v-supply = <&v3v3>; + bgvdd-supply = <&v3v3>; + + interrupts = <9 IRQ_TYPE_EDGE_FALLING>; + interrupt-parent = <&gpiog>; + + status = "okay"; + + adi,input-depth = <8>; + adi,input-colorspace = "rgb"; + adi,input-clock = "1x"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + adv7513_in: endpoint { + remote-endpoint = <<dc_ep0_out>; + }; + }; + + port@1 { + reg = <1>; + adv7513_out: endpoint { + remote-endpoint = <&hdmi_con>; + }; + }; + + port@2 { + reg = <2>; + adv7513_i2s0: endpoint { + remote-endpoint = <&sai2a_endpoint>; + }; + }; + }; + }; +}; + +<dc { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <<dc_pins_d>; + pinctrl-1 = <<dc_sleep_pins_d>; + status = "okay"; + + port { + #address-cells = <1>; + #size-cells = <0>; + + ltdc_ep0_out: endpoint@0 { + reg = <0>; + remote-endpoint = <&adv7513_in>; + }; + }; +}; + +&sai2 { + clocks = <&rcc SAI2>, <&rcc PLL3_Q>, <&rcc PLL3_R>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&sai2a_pins_c>; + pinctrl-1 = <&sai2a_sleep_pins_c>; + clock-names = "pclk", "x8k", "x11k"; + status = "okay"; + + sai2a: audio-controller@4400b004 { + #clock-cells = <0>; + dma-names = "tx"; + clocks = <&rcc SAI2_K>; + clock-names = "sai_ck"; + status = "okay"; + + sai2a_port: port { + sai2a_endpoint: endpoint { + remote-endpoint = <&adv7513_i2s0>; + format = "i2s"; + mclk-fs = <256>; + }; + }; + }; +}; + +&sdmmc1 { + pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_b>; + pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_b>; + pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_b>; + cd-gpios = <&gpioi 8 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; + disable-wp; + st,sig-dir; + st,neg-edge; + st,use-ckin; + bus-width = <4>; + vmmc-supply = <&vdd_sd>; + vqmmc-supply = <&sd_switch>; + status = "okay"; +}; + +&sdmmc2 { + pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_c>; + pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_c>; + pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_c>; + bus-width = <8>; + mmc-ddr-1_8v; + no-sd; + no-sdio; + non-removable; + st,neg-edge; + vmmc-supply = <&v3v3>; + vqmmc-supply = <&vdd_io>; + status = "okay"; +}; + +&sdmmc3 { + pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-0 = <&sdmmc3_b4_pins_b>; + pinctrl-1 = <&sdmmc3_b4_od_pins_b>; + pinctrl-2 = <&sdmmc3_b4_sleep_pins_b>; + broken-cd; + non-removable; + st,neg-edge; + bus-width = <4>; + vmmc-supply = <&wlan_pwr>; + status = "okay"; + + #address-cells = <1>; + #size-cells = <0>; + brcmf: bcrmf@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + }; +}; + +&spi2 { + pinctrl-names = "default"; + pinctrl-0 = <&spi2_pins_a>; + cs-gpios = <&gpioi 0 0>; + status = "disabled"; + /delete-property/dmas; + /delete-property/dma-names; +}; + +&uart4 { + /* On Low speed expansion header */ + label = "LS-UART1"; + pinctrl-names = "default"; + pinctrl-0 = <&uart4_pins_b>; + status = "okay"; +}; + +&uart7 { + /* On Low speed expansion header */ + label = "LS-UART0"; + pinctrl-names = "default"; + pinctrl-0 = <&uart7_pins_a>; + uart-has-rtscts; + status = "okay"; +}; + +/* Bluetooth */ +&usart2 { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&usart2_pins_a>; + pinctrl-1 = <&usart2_sleep_pins_a>; + st,hw-flow-ctrl; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + max-speed = <3000000>; + shutdown-gpios = <&gpioz 6 GPIO_ACTIVE_HIGH>; + }; +}; + +&usbh_ehci { + phys = <&usbphyc_port0>; + phy-names = "usb"; + status = "okay"; +}; + +&usbotg_hs { + pinctrl-0 = <&usbotg_hs_pins_a>; + pinctrl-names = "default"; + phy-names = "usb2-phy"; + phys = <&usbphyc_port1 0>; + status = "okay"; + vbus-supply = <&vbus_otg>; +}; + +&usbphyc { + status = "okay"; +}; + +&usbphyc_port0 { + phy-supply = <&vdd_usb>; +}; + +&usbphyc_port1 { + phy-supply = <&vdd_usb>; +}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi index 75435424d67..75172314d7a 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi @@ -1,12 +1,12 @@ // SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) /* + * Copyright (C) Linaro Ltd 2019 - All Rights Reserved + * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org * Copyright (C) 2020 Marek Vasut marex@denx.de */
-#include "stm32mp15xx-dhcor-io3v3.dtsi" - / { - /* Enpirion EP3A8LQI U2 on the 1V8 IO DHCOR */ + /* Enpirion EP3A8LQI U2 on the DHCOR */ vdd_io: regulator-buck-io { compatible = "regulator-fixed"; regulator-name = "buck-io"; @@ -20,5 +20,4 @@
&pwr_regulators { vdd-supply = <&vdd_io>; - vdd_3v3_usbfs-supply = <&vdd_usb>; }; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-io3v3.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-som.dtsi similarity index 91% rename from arch/arm/dts/stm32mp15xx-dhcor-io3v3.dtsi rename to arch/arm/dts/stm32mp15xx-dhcor-som.dtsi index 94cf80dbede..44ecc470858 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-io3v3.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-som.dtsi @@ -4,9 +4,7 @@ * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org * Copyright (C) 2020 Marek Vasut marex@denx.de */ -/dts-v1/;
-#include "stm32mp157.dtsi" #include "stm32mp15-pinctrl.dtsi" #include "stm32mp15xxac-pinctrl.dtsi" #include <dt-bindings/gpio/gpio.h> @@ -23,6 +21,14 @@ }; };
+&crc1 { + status = "okay"; +}; + +&dts { + status = "okay"; +}; + &i2c4 { pinctrl-names = "default"; pinctrl-0 = <&i2c4_pins_a>; @@ -35,7 +41,7 @@ pmic: stpmic@33 { compatible = "st,stpmic1"; reg = <0x33>; - interrupts-extended = <&exti 55 IRQ_TYPE_EDGE_FALLING>; + interrupts-extended = <&gpioa 0 IRQ_TYPE_EDGE_FALLING>; interrupt-controller; #interrupt-cells = <2>; status = "okay"; @@ -53,7 +59,7 @@
vddcore: buck1 { regulator-name = "vddcore"; - regulator-min-microvolt = <800000>; + regulator-min-microvolt = <1200000>; regulator-max-microvolt = <1350000>; regulator-always-on; regulator-initial-mode = <0>; @@ -92,7 +98,6 @@ regulator-min-microvolt = <2900000>; regulator-max-microvolt = <2900000>; interrupts = <IT_CURLIM_LDO1 0>; - interrupt-parent = <&pmic>; };
v2v8: ldo2 { @@ -100,7 +105,6 @@ regulator-min-microvolt = <2800000>; regulator-max-microvolt = <2800000>; interrupts = <IT_CURLIM_LDO2 0>; - interrupt-parent = <&pmic>; };
vtt_ddr: ldo3 { @@ -114,7 +118,6 @@ vdd_usb: ldo4 { regulator-name = "vdd_usb"; interrupts = <IT_CURLIM_LDO4 0>; - interrupt-parent = <&pmic>; };
vdd_sd: ldo5 { @@ -122,7 +125,6 @@ regulator-min-microvolt = <2900000>; regulator-max-microvolt = <2900000>; interrupts = <IT_CURLIM_LDO5 0>; - interrupt-parent = <&pmic>; regulator-boot-on; };
@@ -131,7 +133,6 @@ regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; interrupts = <IT_CURLIM_LDO6 0>; - interrupt-parent = <&pmic>; regulator-enable-ramp-delay = <300000>; };
@@ -143,20 +144,17 @@ bst_out: boost { regulator-name = "bst_out"; interrupts = <IT_OCP_BOOST 0>; - interrupt-parent = <&pmic>; };
vbus_otg: pwr_sw1 { regulator-name = "vbus_otg"; interrupts = <IT_OCP_OTG 0>; - interrupt-parent = <&pmic>; regulator-active-discharge = <1>; };
vbus_sw: pwr_sw2 { regulator-name = "vbus_sw"; interrupts = <IT_OCP_SWOUT 0>; - interrupt-parent = <&pmic>; regulator-active-discharge = <1>; }; }; @@ -173,6 +171,12 @@ status = "disabled"; }; }; + + eeprom@53 { + compatible = "atmel,24c02"; + reg = <0x53>; + pagesize = <16>; + }; };
&iwdg2 { @@ -194,7 +198,7 @@ #size-cells = <0>; status = "okay";
- flash0: spi-flash@0 { + flash0: flash@0 { compatible = "jedec,spi-nor"; reg = <0>; spi-rx-bus-width = <4>; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi index 71375510b4a..338b674368a 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi @@ -15,6 +15,11 @@
/ { u-boot,dm-pre-reloc; + + aliases { + eeprom0 = &eeprom0; + }; + config { dh,ddr3-coding-gpios = <&gpiog 0 0>, <&gpiog 1 0>; dh,som-coding-gpios = <&gpioz 7 0>, <&gpiof 3 0>; @@ -28,6 +33,9 @@ &i2c4 { u-boot,dm-pre-reloc; u-boot,dm-spl; + + eeprom0: eeprom@53 { + }; };
&i2c4_pins_a {
Synchronize DH DHCOM DTs with Linux commit 25960cafa06e ("Linux 5.15.12"). There is no functional change to the resulting DTs. The eeprom0 alias and PHY reset GPIO are now reinstated in SoM u-boot dtsi.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com --- arch/arm/dts/stm32mp15xx-dhcom-drc02.dts | 162 +------- arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi | 165 ++++++++ .../dts/stm32mp15xx-dhcom-pdk2-u-boot.dtsi | 4 + arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts | 14 +- arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi | 325 +++++++++++++++ .../dts/stm32mp15xx-dhcom-picoitx-u-boot.dtsi | 6 +- arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts | 88 +--- arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi | 147 +++++++ ...-dhcom.dtsi => stm32mp15xx-dhcom-som.dtsi} | 387 +++++++++++------- arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi | 43 +- 10 files changed, 917 insertions(+), 424 deletions(-) create mode 100644 arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi create mode 100644 arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi create mode 100644 arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi rename arch/arm/dts/{stm32mp15xx-dhcom.dtsi => stm32mp15xx-dhcom-som.dtsi} (56%)
diff --git a/arch/arm/dts/stm32mp15xx-dhcom-drc02.dts b/arch/arm/dts/stm32mp15xx-dhcom-drc02.dts index 4948ccd4014..1ef9ac29cea 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-drc02.dts +++ b/arch/arm/dts/stm32mp15xx-dhcom-drc02.dts @@ -2,166 +2,14 @@ /* * Copyright (C) 2020 Marek Vasut marex@denx.de */ +/dts-v1/;
-#include "stm32mp15xx-dhcom.dtsi" +#include "stm32mp151.dtsi" +#include "stm32mp15xc.dtsi" +#include "stm32mp15xx-dhcom-som.dtsi" +#include "stm32mp15xx-dhcom-drc02.dtsi"
/ { model = "DH Electronics STM32MP15xx DHCOM DRC02"; compatible = "dh,stm32mp15xx-dhcom-drc02", "st,stm32mp1xx"; - - aliases { - serial0 = &uart4; - serial1 = &usart3; - serial2 = &uart8; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&adc { - status = "disabled"; -}; - -&dac { - status = "disabled"; -}; - -&gpiob { - /* - * NOTE: On DRC02, the RS485_RX_En is controlled by a separate - * GPIO line, however the STM32 UART driver assumes RX happens - * during TX anyway and that it only controls drive enable DE - * line. Hence, the RX is always enabled here. - */ - usb-hub { - gpio-hog; - gpios = <8 0>; - output-high; - line-name = "rs485-rx-en"; - }; -}; - -&gpiod { - gpio-line-names = "", "", "", "", - "", "", "", "", - "", "", "", "Out1", - "Out2", "", "", ""; -}; - -&gpioi { - gpio-line-names = "In1", "", "", "", - "", "", "", "", - "In2", "", "", "", - "", "", "", ""; - - /* - * NOTE: The USB Hub on the DRC02 needs a reset signal to be - * pulled high in order to be detected by the USB Controller. - * This signal should be handled by USB power sequencing in - * order to reset the Hub when USB bus is powered down, but - * so far there is no such functionality. - */ - usb-hub { - gpio-hog; - gpios = <2 0>; - output-high; - line-name = "usb-hub-reset"; - }; -}; - -&i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; - - eeprom@50 { - compatible = "atmel,24c04"; - reg = <0x50>; - pagesize = <16>; - }; -}; - -&i2c5 { /* TP7/TP8 */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c5_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; -}; - -&sdmmc3 { - /* - * On DRC02, the SoM does not have SDIO WiFi. The pins - * are used for on-board microSD slot instead. - */ - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc3_b4_pins_a>; - pinctrl-1 = <&sdmmc3_b4_od_pins_a>; - pinctrl-2 = <&sdmmc3_b4_sleep_pins_a>; - cd-gpios = <&gpioi 10 GPIO_ACTIVE_HIGH>; - disable-wp; - st,neg-edge; - bus-width = <4>; - vmmc-supply = <&v3v3>; - vqmmc-supply = <&v3v3>; - mmc-ddr-3_3v; - status = "okay"; -}; - -&spi1 { - pinctrl-names = "default"; - pinctrl-0 = <&spi1_pins_a>; - cs-gpios = <&gpioz 3 0>; - /* Use PIO for the display */ - /delete-property/dmas; - /delete-property/dma-names; - status = "disabled"; /* Enable once there is display driver */ - /* - * Note: PF3/GPIO_A , PD6/GPIO_B , PG0/GPIO_C , PC6/GPIO_E are - * also connected to the display board connector. - */ -}; - -&usart3 { - pinctrl-names = "default"; - pinctrl-0 = <&usart3_pins_a>; - status = "okay"; -}; - -/* - * Note: PI3 is UART1_RTS and PI5 is UART1_CTS on DRC02 (uart4 of STM32MP1), - * however the STM32MP1 pinmux cannot map them to UART4 . - */ - -&uart8 { /* RS485 */ - pinctrl-names = "default"; - pinctrl-0 = <&uart8_pins_a>; - rts-gpios = <&gpioe 6 GPIO_ACTIVE_HIGH>; - status = "okay"; -}; - -&usbh_ehci { - phys = <&usbphyc_port0>; - status = "okay"; -}; - -&usbphyc { - status = "okay"; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; - vdda1v1-supply = <®11>; - vdda1v8-supply = <®18>; }; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi new file mode 100644 index 00000000000..4b10b013ffd --- /dev/null +++ b/arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi @@ -0,0 +1,165 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2020 Marek Vasut marex@denx.de + */ + +#include <dt-bindings/input/input.h> +#include <dt-bindings/pwm/pwm.h> + +/ { + aliases { + serial0 = &uart4; + serial1 = &usart3; + serial2 = &uart8; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&adc { + status = "disabled"; +}; + +&dac { + status = "disabled"; +}; + +&gpiob { + /* + * NOTE: On DRC02, the RS485_RX_En is controlled by a separate + * GPIO line, however the STM32 UART driver assumes RX happens + * during TX anyway and that it only controls drive enable DE + * line. Hence, the RX is always enabled here. + */ + rs485-rx-en-hog { + gpio-hog; + gpios = <8 0>; + output-low; + line-name = "rs485-rx-en"; + }; +}; + +&gpiod { + gpio-line-names = "", "", "", "", + "", "", "DHCOM-B", "", + "", "", "", "DRC02-Out1", + "DRC02-Out2", "", "", ""; +}; + +&gpioi { + gpio-line-names = "DRC02-In1", "DHCOM-O", "DHCOM-H", "DHCOM-I", + "DHCOM-R", "DHCOM-M", "", "", + "DRC02-In2", "", "", "", + "", "", "", ""; + + /* + * NOTE: The USB Hub on the DRC02 needs a reset signal to be + * pulled high in order to be detected by the USB Controller. + * This signal should be handled by USB power sequencing in + * order to reset the Hub when USB bus is powered down, but + * so far there is no such functionality. + */ + usb-hub-hog { + gpio-hog; + gpios = <2 0>; + output-high; + line-name = "usb-hub-reset"; + }; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins_a>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /* spare dmas for other usage */ + /delete-property/dmas; + /delete-property/dma-names; + status = "okay"; + + eeprom@50 { + compatible = "atmel,24c04"; + reg = <0x50>; + pagesize = <16>; + }; +}; + +&i2c4 { + touchscreen@49 { + status = "disabled"; + }; +}; + +&i2c5 { /* TP7/TP8 */ + pinctrl-names = "default"; + pinctrl-0 = <&i2c5_pins_a>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /* spare dmas for other usage */ + /delete-property/dmas; + /delete-property/dma-names; +}; + +&sdmmc3 { + /* + * On DRC02, the SoM does not have SDIO WiFi. The pins + * are used for on-board microSD slot instead. + */ + /delete-property/broken-cd; + cd-gpios = <&gpioi 10 GPIO_ACTIVE_HIGH>; + disable-wp; +}; + +&spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&spi1_pins_a>; + cs-gpios = <&gpioz 3 0>; + /* Use PIO for the display */ + /delete-property/dmas; + /delete-property/dma-names; + status = "disabled"; /* Enable once there is display driver */ + /* + * Note: PF3/GPIO_A , PD6/GPIO_B , PG0/GPIO_C , PC6/GPIO_E are + * also connected to the display board connector. + */ +}; + +&usart3 { + pinctrl-names = "default"; + pinctrl-0 = <&usart3_pins_a>; + status = "okay"; +}; + +/* + * Note: PI3 is UART1_RTS and PI5 is UART1_CTS on DRC02 (uart4 of STM32MP1), + * however the STM32MP1 pinmux cannot map them to UART4 . + */ + +&uart8 { /* RS485 */ + linux,rs485-enabled-at-boot-time; + pinctrl-names = "default"; + pinctrl-0 = <&uart8_pins_a>; + rts-gpios = <&gpioe 6 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&usbh_ehci { + phys = <&usbphyc_port0>; + status = "okay"; +}; + +&usbphyc { + status = "okay"; +}; + +&usbphyc_port0 { + phy-supply = <&vdd_usb>; +}; + +&usbphyc_port1 { + phy-supply = <&vdd_usb>; +}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-pdk2-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-pdk2-u-boot.dtsi index 12f89b33987..2324926f9df 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-pdk2-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-pdk2-u-boot.dtsi @@ -4,3 +4,7 @@ */
#include "stm32mp15xx-dhcom-u-boot.dtsi" + +&usbotg_hs { + dr_mode = "peripheral"; +}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts b/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts index 52a77c41231..e2e01e2146c 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts +++ b/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts @@ -2,18 +2,14 @@ /* * Copyright (C) 2019 Marek Vasut marex@denx.de */ +/dts-v1/;
-#include "stm32mp15xx-dhcom.dtsi" +#include "stm32mp151.dtsi" +#include "stm32mp15xc.dtsi" +#include "stm32mp15xx-dhcom-som.dtsi" +#include "stm32mp15xx-dhcom-pdk2.dtsi"
/ { model = "STMicroelectronics STM32MP15xx DHCOM Premium Developer Kit (2)"; compatible = "dh,stm32mp15xx-dhcom-pdk2", "st,stm32mp15x"; - - aliases { - serial0 = &uart4; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; }; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi new file mode 100644 index 00000000000..fbf3826933e --- /dev/null +++ b/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi @@ -0,0 +1,325 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2019-2020 Marek Vasut marex@denx.de + */ + +#include <dt-bindings/input/input.h> +#include <dt-bindings/pwm/pwm.h> + +/ { + aliases { + serial0 = &uart4; + serial1 = &usart3; + serial2 = &uart8; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + clk_ext_audio_codec: clock-codec { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + }; + + display_bl: display-bl { + compatible = "pwm-backlight"; + pwms = <&pwm2 3 500000 PWM_POLARITY_INVERTED>; + brightness-levels = <0 16 22 30 40 55 75 102 138 188 255>; + default-brightness-level = <8>; + enable-gpios = <&gpioi 0 GPIO_ACTIVE_HIGH>; + power-supply = <®_panel_bl>; + status = "okay"; + }; + + gpio-keys-polled { + compatible = "gpio-keys-polled"; + poll-interval = <20>; + + /* + * The EXTi IRQ line 3 is shared with ethernet, + * so mark this as polled GPIO key. + */ + button-0 { + label = "TA1-GPIO-A"; + linux,code = <KEY_A>; + gpios = <&gpiof 3 GPIO_ACTIVE_LOW>; + }; + + /* + * The EXTi IRQ line 6 is shared with touchscreen, + * so mark this as polled GPIO key. + */ + button-1 { + label = "TA2-GPIO-B"; + linux,code = <KEY_B>; + gpios = <&gpiod 6 GPIO_ACTIVE_LOW>; + }; + + /* + * The EXTi IRQ line 0 is shared with PMIC, + * so mark this as polled GPIO key. + */ + button-2 { + label = "TA3-GPIO-C"; + linux,code = <KEY_C>; + gpios = <&gpiog 0 GPIO_ACTIVE_LOW>; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + + button-3 { + label = "TA4-GPIO-D"; + linux,code = <KEY_D>; + gpios = <&gpiod 12 GPIO_ACTIVE_LOW>; + wakeup-source; + }; + }; + + led { + compatible = "gpio-leds"; + + led-0 { + label = "green:led5"; + gpios = <&gpioc 6 GPIO_ACTIVE_HIGH>; + default-state = "off"; + status = "disabled"; + }; + + led-1 { + label = "green:led6"; + gpios = <&gpiod 11 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + led-2 { + label = "green:led7"; + gpios = <&gpioi 2 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + led-3 { + label = "green:led8"; + gpios = <&gpioi 3 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + }; + + panel { + compatible = "edt,etm0700g0edh6"; + backlight = <&display_bl>; + power-supply = <®_panel_bl>; + + port { + lcd_panel_in: endpoint { + remote-endpoint = <&lcd_display_out>; + }; + }; + }; + + reg_panel_bl: regulator-panel-bl { + compatible = "regulator-fixed"; + regulator-name = "panel_backlight"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <®_panel_supply>; + }; + + reg_panel_supply: regulator-panel-supply { + compatible = "regulator-fixed"; + regulator-name = "panel_supply"; + regulator-min-microvolt = <24000000>; + regulator-max-microvolt = <24000000>; + }; + + sound { + compatible = "audio-graph-card"; + routing = + "MIC_IN", "Capture", + "Capture", "Mic Bias", + "Playback", "HP_OUT"; + dais = <&sai2a_port &sai2b_port>; + status = "okay"; + }; +}; + +&cec { + pinctrl-names = "default"; + pinctrl-0 = <&cec_pins_a>; + status = "okay"; +}; + +&i2c2 { /* Header X22 */ + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins_a>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /* spare dmas for other usage */ + /delete-property/dmas; + /delete-property/dma-names; + status = "okay"; +}; + +&i2c5 { /* Header X21 */ + pinctrl-names = "default"; + pinctrl-0 = <&i2c5_pins_a>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /* spare dmas for other usage */ + /delete-property/dmas; + /delete-property/dma-names; + + sgtl5000: codec@a { + compatible = "fsl,sgtl5000"; + reg = <0x0a>; + #sound-dai-cells = <0>; + clocks = <&clk_ext_audio_codec>; + VDDA-supply = <&v3v3>; + VDDIO-supply = <&vdd>; + + sgtl5000_port: port { + #address-cells = <1>; + #size-cells = <0>; + + sgtl5000_tx_endpoint: endpoint@0 { + reg = <0>; + remote-endpoint = <&sai2a_endpoint>; + frame-master = <&sgtl5000_tx_endpoint>; + bitclock-master = <&sgtl5000_tx_endpoint>; + }; + + sgtl5000_rx_endpoint: endpoint@1 { + reg = <1>; + remote-endpoint = <&sai2b_endpoint>; + frame-master = <&sgtl5000_rx_endpoint>; + bitclock-master = <&sgtl5000_rx_endpoint>; + }; + }; + + }; + + touchscreen@38 { + compatible = "edt,edt-ft5406"; + reg = <0x38>; + interrupt-parent = <&gpioc>; + interrupts = <6 IRQ_TYPE_EDGE_FALLING>; /* GPIO E */ + }; +}; + +<dc { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <<dc_pins_b>; + pinctrl-1 = <<dc_sleep_pins_b>; + status = "okay"; + + port { + lcd_display_out: endpoint { + remote-endpoint = <&lcd_panel_in>; + }; + }; +}; + +&sai2 { + clocks = <&rcc SAI2>, <&rcc PLL3_Q>, <&rcc PLL3_R>; + clock-names = "pclk", "x8k", "x11k"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&sai2a_pins_b &sai2b_pins_b>; + pinctrl-1 = <&sai2a_sleep_pins_b &sai2b_sleep_pins_b>; + status = "okay"; + + sai2a: audio-controller@4400b004 { + #clock-cells = <0>; + dma-names = "tx"; + clocks = <&rcc SAI2_K>; + clock-names = "sai_ck"; + status = "okay"; + + sai2a_port: port { + sai2a_endpoint: endpoint { + remote-endpoint = <&sgtl5000_tx_endpoint>; + format = "i2s"; + mclk-fs = <512>; + dai-tdm-slot-num = <2>; + dai-tdm-slot-width = <16>; + }; + }; + }; + + sai2b: audio-controller@4400b024 { + dma-names = "rx"; + st,sync = <&sai2a 2>; + clocks = <&rcc SAI2_K>, <&sai2a>; + clock-names = "sai_ck", "MCLK"; + status = "okay"; + + sai2b_port: port { + sai2b_endpoint: endpoint { + remote-endpoint = <&sgtl5000_rx_endpoint>; + format = "i2s"; + mclk-fs = <512>; + dai-tdm-slot-num = <2>; + dai-tdm-slot-width = <16>; + }; + }; + }; +}; + +&timers2 { + /* spare dmas for other usage (un-delete to enable pwm capture) */ + /delete-property/dmas; + /delete-property/dma-names; + status = "okay"; + pwm2: pwm { + pinctrl-0 = <&pwm2_pins_a>; + pinctrl-names = "default"; + status = "okay"; + }; + timer@1 { + status = "okay"; + }; +}; + +&usart3 { + pinctrl-names = "default"; + pinctrl-0 = <&usart3_pins_a>; + status = "okay"; +}; + +&uart8 { + pinctrl-names = "default"; + pinctrl-0 = <&uart8_pins_a &uart8_rtscts_pins_a>; + uart-has-rtscts; + status = "okay"; +}; + +&usbh_ehci { + phys = <&usbphyc_port0>; + status = "okay"; +}; + +&usbotg_hs { + dr_mode = "otg"; + pinctrl-0 = <&usbotg_hs_pins_a>; + pinctrl-names = "default"; + phy-names = "usb2-phy"; + phys = <&usbphyc_port1 0>; + vbus-supply = <&vbus_otg>; + status = "okay"; +}; + +&usbphyc { + status = "okay"; +}; + +&usbphyc_port0 { + phy-supply = <&vdd_usb>; +}; + +&usbphyc_port1 { + phy-supply = <&vdd_usb>; +}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-picoitx-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-picoitx-u-boot.dtsi index 3cac663d987..5bc6698f87f 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-picoitx-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-picoitx-u-boot.dtsi @@ -11,4 +11,8 @@ }; };
-/delete-node/ &ksz8851; +/delete-node/ &ks8851; + +&usbotg_hs { + dr_mode = "peripheral"; +}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts b/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts index 59d13713d88..06770b47873 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts +++ b/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts @@ -2,92 +2,14 @@ /* * Copyright (C) 2020 Marek Vasut marex@denx.de */ +/dts-v1/;
-#include "stm32mp15xx-dhcom.dtsi" +#include "stm32mp157.dtsi" +#include "stm32mp15xc.dtsi" +#include "stm32mp15xx-dhcom-som.dtsi" +#include "stm32mp15xx-dhcom-picoitx.dtsi"
/ { model = "DH Electronics STM32MP15xx DHCOM PicoITX"; compatible = "dh,stm32mp15xx-dhcom-picoitx", "st,stm32mp1xx"; - - aliases { - serial0 = &uart4; - serial1 = &usart3; - serial2 = &uart8; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&adc { - status = "disabled"; -}; - -&dac { - status = "disabled"; -}; - -&gpioa { - /* - * NOTE: The USB Port on the PicoITX needs a PWR_EN signal to enable - * port power. This signal should be handled by USB power sequencing - * in order to turn on port power when USB bus is powered up, but so - * far there is no such functionality. - */ - usb-port-power { - gpio-hog; - gpios = <13 0>; - output-low; - line-name = "usb-port-power"; - }; -}; - -&i2c2 { /* On board-to-board connector (optional) */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; -}; - -&i2c5 { /* On board-to-board connector */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c5_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; -}; - -&usart3 { - pinctrl-names = "default"; - pinctrl-0 = <&usart3_pins_a>; - status = "okay"; -}; - -&uart8 { - pinctrl-names = "default"; - pinctrl-0 = <&uart8_pins_a>; - status = "okay"; -}; - -&usbh_ehci { - phys = <&usbphyc_port0>; - status = "okay"; -}; - -&usbphyc { - status = "okay"; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; - vdda1v1-supply = <®11>; - vdda1v8-supply = <®18>; }; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi new file mode 100644 index 00000000000..ba816ef8b9b --- /dev/null +++ b/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi @@ -0,0 +1,147 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2020 Marek Vasut marex@denx.de + */ + +#include <dt-bindings/input/input.h> +#include <dt-bindings/pwm/pwm.h> + +/ { + aliases { + serial0 = &uart4; + serial1 = &usart3; + serial2 = &uart8; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + led { + compatible = "gpio-leds"; + + led-0 { + label = "yellow:led"; + gpios = <&gpioi 3 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + }; +}; + +&adc { + status = "disabled"; +}; + +&dac { + status = "disabled"; +}; + +&fmc { + status = "disabled"; +}; + +&gpioa { + /* + * NOTE: The USB Port on the PicoITX needs a PWR_EN signal to enable + * port power. This signal should be handled by USB power sequencing + * in order to turn on port power when USB bus is powered up, but so + * far there is no such functionality. + */ + usb-port-power-hog { + gpio-hog; + gpios = <13 0>; + output-low; + line-name = "usb-port-power"; + }; +}; + +&gpioc { + gpio-line-names = "", "", "", "", + "", "", "PicoITX-In1", "", + "", "", "", "", + "", "", "", ""; +}; + +&gpiod { + gpio-line-names = "", "", "", "", + "", "", "DHCOM-B", "", + "", "", "", "PicoITX-Out1", + "PicoITX-Out2", "", "", ""; +}; + +&gpiog { + gpio-line-names = "PicoITX-In2", "", "", "", + "", "", "", "", + "DHCOM-L", "", "", "", + "", "", "", ""; +}; + +&i2c2 { /* On board-to-board connector (optional) */ + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins_a>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /* spare dmas for other usage */ + /delete-property/dmas; + /delete-property/dma-names; +}; + +&i2c5 { /* On board-to-board connector */ + pinctrl-names = "default"; + pinctrl-0 = <&i2c5_pins_a>; + i2c-scl-rising-time-ns = <185>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + /* spare dmas for other usage */ + /delete-property/dmas; + /delete-property/dma-names; +}; + +&ksz8851 { + status = "disabled"; +}; + +&usart3 { + pinctrl-names = "default"; + pinctrl-0 = <&usart3_pins_a>; + status = "okay"; +}; + +&uart8 { + pinctrl-names = "default"; + pinctrl-0 = <&uart8_pins_a &uart8_rtscts_pins_a>; + status = "okay"; +}; + +&usbh_ehci { + phys = <&usbphyc_port0>; + status = "okay"; +}; + +&usbh_ohci { + phys = <&usbphyc_port0>; + status = "okay"; +}; + +&usbotg_hs { + dr_mode = "otg"; + pinctrl-0 = <&usbotg_hs_pins_a>; + pinctrl-names = "default"; + phy-names = "usb2-phy"; + phys = <&usbphyc_port1 0>; + vbus-supply = <&vbus_otg>; + status = "okay"; +}; + +&usbphyc { + status = "okay"; +}; + +&usbphyc_port0 { + phy-supply = <&vdd_usb>; +}; + +&usbphyc_port1 { + phy-supply = <&vdd_usb>; +}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-som.dtsi similarity index 56% rename from arch/arm/dts/stm32mp15xx-dhcom.dtsi rename to arch/arm/dts/stm32mp15xx-dhcom-som.dtsi index a1d1b8dec76..8c41f819f77 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-som.dtsi @@ -1,11 +1,8 @@ // SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) /* - * Copyright (C) 2019 Marek Vasut marex@denx.de + * Copyright (C) 2019-2020 Marek Vasut marex@denx.de */ -/dts-v1/;
-#include "stm32mp157.dtsi" -#include "stm32mp15xc.dtsi" #include "stm32mp15-pinctrl.dtsi" #include "stm32mp15xxaa-pinctrl.dtsi" #include <dt-bindings/gpio/gpio.h> @@ -13,8 +10,10 @@
/ { aliases { - eeprom0 = &eeprom0; ethernet0 = ðernet0; + ethernet1 = &ksz8851; + rtc0 = &hwrtc; + rtc1 = &rtc; };
memory@c0000000 { @@ -22,6 +21,48 @@ reg = <0xC0000000 0x40000000>; };
+ reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + mcuram2: mcuram2@10000000 { + compatible = "shared-dma-pool"; + reg = <0x10000000 0x40000>; + no-map; + }; + + vdev0vring0: vdev0vring0@10040000 { + compatible = "shared-dma-pool"; + reg = <0x10040000 0x1000>; + no-map; + }; + + vdev0vring1: vdev0vring1@10041000 { + compatible = "shared-dma-pool"; + reg = <0x10041000 0x1000>; + no-map; + }; + + vdev0buffer: vdev0buffer@10042000 { + compatible = "shared-dma-pool"; + reg = <0x10042000 0x4000>; + no-map; + }; + + mcuram: mcuram@30000000 { + compatible = "shared-dma-pool"; + reg = <0x30000000 0x40000>; + no-map; + }; + + retram: retram@38000000 { + compatible = "shared-dma-pool"; + reg = <0x38000000 0x10000>; + no-map; + }; + }; + ethernet_vio: vioregulator { compatible = "regulator-fixed"; regulator-name = "vio"; @@ -30,20 +71,45 @@ gpio = <&gpiog 3 GPIO_ACTIVE_LOW>; regulator-always-on; regulator-boot-on; + vin-supply = <&vdd>; }; };
-&cec { - pinctrl-names = "default"; - pinctrl-0 = <&cec_pins_a>; +&adc { + vdd-supply = <&vdd>; + vdda-supply = <&vdda>; + vref-supply = <&vdda>; status = "okay"; + + adc1: adc@0 { + st,min-sample-time-nsecs = <5000>; + st,adc-channels = <0>; + status = "okay"; + }; + + adc2: adc@100 { + st,adc-channels = <1>; + st,min-sample-time-nsecs = <5000>; + status = "okay"; + }; };
-&dcmi { +&crc1 { status = "okay"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&dcmi_pins_a>; - pinctrl-1 = <&dcmi_sleep_pins_a>; +}; + +&dac { + pinctrl-names = "default"; + pinctrl-0 = <&dac_ch1_pins_a &dac_ch2_pins_a>; + vref-supply = <&vdda>; + status = "okay"; + + dac1: dac@1 { + status = "okay"; + }; + dac2: dac@2 { + status = "okay"; + }; };
&dts { @@ -53,12 +119,12 @@ ðernet0 { status = "okay"; pinctrl-0 = <ðernet0_rmii_pins_a>; - pinctrl-1 = <ðernet0_rmii_pins_sleep_a>; + pinctrl-1 = <ðernet0_rmii_sleep_pins_a>; pinctrl-names = "default", "sleep"; phy-mode = "rmii"; max-speed = <100>; phy-handle = <&phy0>; - phy-reset-gpios = <&gpioh 15 GPIO_ACTIVE_LOW>; + st,eth-ref-clk-sel;
mdio0 { #address-cells = <1>; @@ -67,16 +133,112 @@
phy0: ethernet-phy@1 { reg = <1>; + /* LAN8710Ai */ + compatible = "ethernet-phy-id0007.c0f0", + "ethernet-phy-ieee802.3-c22"; + clocks = <&rcc ETHCK_K>; + reset-gpios = <&gpioh 3 GPIO_ACTIVE_LOW>; + reset-assert-us = <500>; + reset-deassert-us = <500>; + smsc,disable-energy-detect; + interrupt-parent = <&gpioi>; + interrupts = <11 IRQ_TYPE_LEVEL_LOW>; }; }; };
-&i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; +&fmc { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&fmc_pins_b>; + pinctrl-1 = <&fmc_sleep_pins_b>; status = "okay"; + + ksz8851: ethernet@1,0 { + compatible = "micrel,ks8851-mll"; + reg = <1 0x0 0x2>, <1 0x2 0x20000>; + interrupt-parent = <&gpioc>; + interrupts = <3 IRQ_TYPE_LEVEL_LOW>; + bank-width = <2>; + + /* Timing values are in nS */ + st,fmc2-ebi-cs-mux-enable; + st,fmc2-ebi-cs-transaction-type = <4>; + st,fmc2-ebi-cs-buswidth = <16>; + st,fmc2-ebi-cs-address-setup-ns = <5>; + st,fmc2-ebi-cs-address-hold-ns = <5>; + st,fmc2-ebi-cs-bus-turnaround-ns = <5>; + st,fmc2-ebi-cs-data-setup-ns = <45>; + st,fmc2-ebi-cs-data-hold-ns = <1>; + st,fmc2-ebi-cs-write-address-setup-ns = <5>; + st,fmc2-ebi-cs-write-address-hold-ns = <5>; + st,fmc2-ebi-cs-write-bus-turnaround-ns = <5>; + st,fmc2-ebi-cs-write-data-setup-ns = <45>; + st,fmc2-ebi-cs-write-data-hold-ns = <1>; + }; +}; + +&gpioa { + gpio-line-names = "", "", "", "", + "", "", "DHCOM-K", "", + "", "", "", "", + "", "", "", ""; +}; + +&gpiob { + gpio-line-names = "", "", "", "", + "", "", "", "", + "DHCOM-Q", "", "", "", + "", "", "", ""; +}; + +&gpioc { + gpio-line-names = "", "", "", "", + "", "", "DHCOM-E", "", + "", "", "", "", + "", "", "", ""; + status = "okay"; +}; + +&gpiod { + gpio-line-names = "", "", "", "", + "", "", "DHCOM-B", "", + "", "", "", "DHCOM-F", + "DHCOM-D", "", "", ""; +}; + +&gpioe { + gpio-line-names = "", "", "", "", + "", "", "DHCOM-P", "", + "", "", "", "", + "", "", "", ""; +}; + +&gpiof { + gpio-line-names = "", "", "", "DHCOM-A", + "", "", "", "", + "", "", "", "", + "", "", "", ""; +}; + +&gpiog { + gpio-line-names = "DHCOM-C", "", "", "", + "", "", "", "", + "DHCOM-L", "", "", "", + "", "", "", ""; +}; + +&gpioh { + gpio-line-names = "", "", "", "", + "", "", "", "DHCOM-N", + "DHCOM-J", "DHCOM-W", "DHCOM-V", "DHCOM-U", + "DHCOM-T", "", "DHCOM-S", ""; +}; + +&gpioi { + gpio-line-names = "DHCOM-G", "DHCOM-O", "DHCOM-H", "DHCOM-I", + "DHCOM-R", "DHCOM-M", "", "", + "", "", "", "", + "", "", "", ""; };
&i2c4 { @@ -89,6 +251,11 @@ /delete-property/dmas; /delete-property/dma-names;
+ hwrtc: rtc@32 { + compatible = "microcrystal,rv8803"; + reg = <0x32>; + }; + pmic: stpmic@33 { compatible = "st,stpmic1"; reg = <0x33>; @@ -146,6 +313,7 @@
vdda: ldo1 { regulator-name = "vdda"; + regulator-always-on; regulator-min-microvolt = <2900000>; regulator-max-microvolt = <2900000>; interrupts = <IT_CURLIM_LDO1 0>; @@ -168,8 +336,6 @@
vdd_usb: ldo4 { regulator-name = "vdd_usb"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; interrupts = <IT_CURLIM_LDO4 0>; };
@@ -191,24 +357,23 @@ vref_ddr: vref_ddr { regulator-name = "vref_ddr"; regulator-always-on; - regulator-over-current-protection; };
- bst_out: boost { + bst_out: boost { regulator-name = "bst_out"; interrupts = <IT_OCP_BOOST 0>; - }; + };
vbus_otg: pwr_sw1 { regulator-name = "vbus_otg"; interrupts = <IT_OCP_OTG 0>; - }; + };
- vbus_sw: pwr_sw2 { + vbus_sw: pwr_sw2 { regulator-name = "vbus_sw"; interrupts = <IT_OCP_SWOUT 0>; - regulator-active-discharge; - }; + regulator-active-discharge = <1>; + }; };
onkey { @@ -225,21 +390,20 @@ }; };
- eeprom0: eeprom@50 { + touchscreen@49 { + compatible = "ti,tsc2004"; + reg = <0x49>; + vio-supply = <&v3v3>; + interrupts-extended = <&gpioh 15 IRQ_TYPE_EDGE_FALLING>; + }; + + eeprom@50 { compatible = "atmel,24c02"; reg = <0x50>; pagesize = <16>; }; };
-&i2c5 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c5_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; -}; - &ipcc { status = "okay"; }; @@ -250,8 +414,12 @@ };
&m4_rproc { + memory-region = <&retram>, <&mcuram>, <&mcuram2>, <&vdev0vring0>, + <&vdev0vring1>, <&vdev0buffer>; mboxes = <&ipcc 0>, <&ipcc 1>, <&ipcc 2>; mbox-names = "vq0", "vq1", "shutdown"; + interrupt-parent = <&exti>; + interrupts = <68 1>; status = "okay"; };
@@ -260,42 +428,6 @@ vdd_3v3_usbfs-supply = <&vdd_usb>; };
-&pinctrl { - ethernet0_rmii_pins_a: rmii-0 { - pins1 { - pinmux = <STM32_PINMUX('G', 13, AF11)>, /* ETH1_RMII_TXD0 */ - <STM32_PINMUX('G', 14, AF11)>, /* ETH1_RMII_TXD1 */ - <STM32_PINMUX('B', 11, AF11)>, /* ETH1_RMII_TX_EN */ - <STM32_PINMUX('A', 1, AF11)>, /* ETH1_RMII_REF_CLK */ - <STM32_PINMUX('A', 2, AF11)>, /* ETH1_MDIO */ - <STM32_PINMUX('C', 1, AF11)>; /* ETH1_MDC */ - bias-disable; - drive-push-pull; - slew-rate = <2>; - }; - pins2 { - pinmux = <STM32_PINMUX('C', 4, AF11)>, /* ETH1_RMII_RXD0 */ - <STM32_PINMUX('C', 5, AF11)>, /* ETH1_RMII_RXD1 */ - <STM32_PINMUX('A', 7, AF11)>; /* ETH1_RMII_CRS_DV */ - bias-disable; - }; - }; - - ethernet0_rmii_pins_sleep_a: rmii-sleep-0 { - pins1 { - pinmux = <STM32_PINMUX('G', 13, ANALOG)>, /* ETH1_RMII_TXD0 */ - <STM32_PINMUX('G', 14, ANALOG)>, /* ETH1_RMII_TXD1 */ - <STM32_PINMUX('B', 11, ANALOG)>, /* ETH1_RMII_TX_EN */ - <STM32_PINMUX('A', 2, ANALOG)>, /* ETH1_MDIO */ - <STM32_PINMUX('C', 1, ANALOG)>, /* ETH1_MDC */ - <STM32_PINMUX('C', 4, ANALOG)>, /* ETH1_RMII_RXD0 */ - <STM32_PINMUX('C', 5, ANALOG)>, /* ETH1_RMII_RXD1 */ - <STM32_PINMUX('A', 1, ANALOG)>, /* ETH1_RMII_REF_CLK */ - <STM32_PINMUX('A', 7, ANALOG)>; /* ETH1_RMII_CRS_DV */ - }; - }; -}; - &qspi { pinctrl-names = "default", "sleep"; pinctrl-0 = <&qspi_clk_pins_a &qspi_bk1_pins_a>; @@ -305,7 +437,7 @@ #size-cells = <0>; status = "okay";
- flash0: mx66l51235l@0 { + flash0: flash@0 { compatible = "jedec,spi-nor"; reg = <0>; spi-rx-bus-width = <4>; @@ -324,14 +456,19 @@ };
&sdmmc1 { - pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-names = "default", "opendrain", "sleep", "init"; pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_a>; pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_a>; pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_a>; + pinctrl-3 = <&sdmmc1_b4_init_pins_a &sdmmc1_dir_init_pins_a>; cd-gpios = <&gpiog 1 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; disable-wp; st,sig-dir; st,neg-edge; + st,use-ckin; + st,cmd-gpios = <&gpiod 2 0>; + st,ck-gpios = <&gpioc 12 0>; + st,ckin-gpios = <&gpioe 4 0>; bus-width = <4>; vmmc-supply = <&vdd_sd>; status = "okay"; @@ -352,75 +489,33 @@ };
&sdmmc2 { - pinctrl-names = "default"; + pinctrl-names = "default", "opendrain", "sleep"; pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_a>; + pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_a>; + pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_a>; non-removable; no-sd; no-sdio; - st,sig-dir; st,neg-edge; bus-width = <8>; vmmc-supply = <&v3v3>; + vqmmc-supply = <&v3v3>; + mmc-ddr-3_3v; status = "okay"; };
-&spi1 { - pinctrl-names = "default"; - pinctrl-0 = <&spi1_pins_a>; - status = "disabled"; -}; - -&timers2 { - /* spare dmas for other usage (un-delete to enable pwm capture) */ - /delete-property/dmas; - /delete-property/dma-names; - status = "disabled"; - pwm { - pinctrl-0 = <&pwm2_pins_a>; - pinctrl-names = "default"; - status = "okay"; - }; - timer@1 { - status = "okay"; - }; -}; - -&timers6 { +&sdmmc3 { + pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-0 = <&sdmmc3_b4_pins_a>; + pinctrl-1 = <&sdmmc3_b4_od_pins_a>; + pinctrl-2 = <&sdmmc3_b4_sleep_pins_a>; + broken-cd; + st,neg-edge; + bus-width = <4>; + vmmc-supply = <&v3v3>; + vqmmc-supply = <&v3v3>; + mmc-ddr-3_3v; status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; - timer@5 { - status = "okay"; - }; -}; - -&timers8 { - /delete-property/dmas; - /delete-property/dma-names; - status = "disabled"; - pwm { - pinctrl-0 = <&pwm8_pins_a>; - pinctrl-names = "default"; - status = "okay"; - }; - timer@7 { - status = "okay"; - }; -}; - -&timers12 { - /delete-property/dmas; - /delete-property/dma-names; - status = "disabled"; - pwm { - pinctrl-0 = <&pwm12_pins_a>; - pinctrl-names = "default"; - status = "okay"; - }; - timer@11 { - status = "okay"; - }; };
&uart4 { @@ -428,29 +523,3 @@ pinctrl-0 = <&uart4_pins_a>; status = "okay"; }; - -&usbh_ehci { - phys = <&usbphyc_port0>; - phy-names = "usb"; - status = "okay"; -}; - -&usbotg_hs { - dr_mode = "peripheral"; - phys = <&usbphyc_port1 0>; - phy-names = "usb2-phy"; - vbus-supply = <&vbus_otg>; - status = "okay"; -}; - -&usbphyc { - status = "okay"; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; -}; - -&usbphyc_port1 { - phy-supply = <&vdd_usb>; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi index 5b2b09bcfb9..f09f4290f62 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi @@ -9,6 +9,8 @@ #include "stm32mp15-ddr3-dhsom-2x2Gb-1066-binG.dtsi" #include "stm32mp15-ddr3-dhsom-2x4Gb-1066-binG.dtsi"
+/delete-node/ &ksz8851; + / { aliases { i2c1 = &i2c2; @@ -18,7 +20,8 @@ mmc1 = &sdmmc2; spi0 = &qspi; usb0 = &usbotg_hs; - ethernet1 = &ksz8851; + eeprom0 = &eeprom0; + ethernet1 = &ks8851; };
config { @@ -30,28 +33,34 @@ dh,ddr3-coding-gpios = <&gpioz 6 0>, <&gpioz 7 0>; };
- led { - red { - label = "error"; - gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; - default-state = "off"; - status = "okay"; - }; - - blue { - default-state = "on"; - }; - }; - /* This is actually on FMC2, but we do not have bus driver for that */ - ksz8851: ks8851mll@64000000 { + ks8851: ks8851mll@64000000 { compatible = "micrel,ks8851-mll"; reg = <0x64000000 0x20000>; }; };
+ðernet0 { + phy-reset-gpios = <&gpioh 3 GPIO_ACTIVE_LOW>; + /delete-property/ st,eth-ref-clk-sel; +}; + +ðernet0_rmii_pins_a { + pins1 { + pinmux = <STM32_PINMUX('G', 13, AF11)>, /* ETH1_RMII_TXD0 */ + <STM32_PINMUX('G', 14, AF11)>, /* ETH1_RMII_TXD1 */ + <STM32_PINMUX('B', 11, AF11)>, /* ETH1_RMII_TX_EN */ + <STM32_PINMUX('A', 1, AF11)>, /* ETH1_RMII_REF_CLK */ + <STM32_PINMUX('A', 2, AF11)>, /* ETH1_MDIO */ + <STM32_PINMUX('C', 1, AF11)>; /* ETH1_MDC */ + }; +}; + &i2c4 { u-boot,dm-pre-reloc; + + eeprom0: eeprom@50 { + }; };
&i2c4_pins_a { @@ -61,6 +70,10 @@ }; };
+&phy0 { + /delete-property/ reset-gpios; +}; + &pinctrl { /* These should bound to FMC2 bus driver, but we do not have one */ pinctrl-0 = <&fmc_pins_b &mco2_pins_a>;
Hi Marek,
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Hi Marek
- Copyright (C) 2020 Marek Vasut marex@denx.de
*/ +/dts-v1/;
- aliases {
serial0 = &uart4;
serial1 = &usart3;
serial2 = &uart8;
- chosen {
-&adc {
-&dac {
-&gpiob {
- usb-hub {
gpio-hog;
gpios = <8 0>;
output-high;
-&gpiod {
"", "", "", "Out1",
"Out2", "", "", "";
-&gpioi {
"In2", "", "", "",
- usb-hub {
gpio-hog;
gpios = <2 0>;
output-high;
-&i2c2 {
- status = "okay";
- status = "okay";
- eeprom@50 {
reg = <0x50>;
pagesize = <16>;
- status = "okay";
-&sdmmc3 {
- disable-wp;
- st,neg-edge;
- bus-width = <4>;
- mmc-ddr-3_3v;
- status = "okay";
-&spi1 {
-&usart3 {
- status = "okay";
- Note: PI3 is UART1_RTS and PI5 is UART1_CTS on DRC02 (uart4 of STM32MP1),
- status = "okay";
-&usbh_ehci {
- status = "okay";
-&usbphyc {
- status = "okay";
-&usbphyc_port0 {
- aliases {
serial0 = &uart4;
serial1 = &usart3;
serial2 = &uart8;
- chosen {
+&adc {
+&dac {
+&gpiob {
- rs485-rx-en-hog {
gpio-hog;
gpios = <8 0>;
output-low;
+&gpiod {
+&gpioi {
- gpio-line-names = "DRC02-In1", "DHCOM-O", "DHCOM-H", "DHCOM-I",
- usb-hub-hog {
gpio-hog;
gpios = <2 0>;
output-high;
+&i2c2 {
- status = "okay";
- status = "okay";
- eeprom@50 {
reg = <0x50>;
pagesize = <16>;
+&i2c4 {
- touchscreen@49 {
- status = "okay";
+&sdmmc3 {
- /delete-property/broken-cd;
- disable-wp;
+&spi1 {
+&usart3 {
- status = "okay";
- linux,rs485-enabled-at-boot-time;
- status = "okay";
+&usbh_ehci {
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
+&usbotg_hs {
- Copyright (C) 2019 Marek Vasut marex@denx.de
*/ +/dts-v1/;
- aliases {
serial0 = &uart4;
- chosen {
- Copyright (C) 2019-2020 Marek Vasut marex@denx.de
- aliases {
serial0 = &uart4;
serial1 = &usart3;
serial2 = &uart8;
- chosen {
- clk_ext_audio_codec: clock-codec {
#clock-cells = <0>;
- display_bl: display-bl {
status = "okay";
- gpio-keys-polled {
button-0 {
button-1 {
button-2 {
- gpio-keys {
button-3 {
wakeup-source;
- led {
led-0 {
led-1 {
led-2 {
led-3 {
- panel {
port {
- reg_panel_bl: regulator-panel-bl {
- reg_panel_supply: regulator-panel-supply {
- sound {
routing =
status = "okay";
+&cec {
- status = "okay";
- status = "okay";
- status = "okay";
- status = "okay";
- sgtl5000: codec@a {
reg = <0x0a>;
#size-cells = <0>;
reg = <0>;
reg = <1>;
- touchscreen@38 {
reg = <0x38>;
+<dc {
- pinctrl-0 = <<dc_pins_b>;
- pinctrl-1 = <<dc_sleep_pins_b>;
- status = "okay";
- port {
+&sai2 {
- clocks = <&rcc SAI2>, <&rcc PLL3_Q>, <&rcc PLL3_R>;
- clock-names = "pclk", "x8k", "x11k";
- pinctrl-0 = <&sai2a_pins_b &sai2b_pins_b>;
- pinctrl-1 = <&sai2a_sleep_pins_b &sai2b_sleep_pins_b>;
- status = "okay";
- sai2a: audio-controller@4400b004 {
#clock-cells = <0>;
dma-names = "tx";
status = "okay";
sai2a_port: port {
format = "i2s";
mclk-fs = <512>;
- sai2b: audio-controller@4400b024 {
dma-names = "rx";
status = "okay";
sai2b_port: port {
format = "i2s";
mclk-fs = <512>;
+&timers2 {
- status = "okay";
- pwm2: pwm {
status = "okay";
- timer@1 {
status = "okay";
+&usart3 {
- status = "okay";
+&uart8 {
- pinctrl-0 = <&uart8_pins_a &uart8_rtscts_pins_a>;
- uart-has-rtscts;
- status = "okay";
+&usbh_ehci {
- status = "okay";
+&usbotg_hs {
- dr_mode = "otg";
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
+&usbotg_hs {
*/ +/dts-v1/;
- aliases {
serial0 = &uart4;
serial1 = &usart3;
serial2 = &uart8;
- chosen {
-&adc {
-&dac {
-&gpioa {
- usb-port-power {
gpio-hog;
gpios = <13 0>;
output-low;
- status = "okay";
- status = "okay";
-&usart3 {
- status = "okay";
-&uart8 {
- status = "okay";
-&usbh_ehci {
- status = "okay";
-&usbphyc {
- status = "okay";
-&usbphyc_port0 {
- aliases {
serial0 = &uart4;
serial1 = &usart3;
serial2 = &uart8;
- chosen {
- led {
led-0 {
+&adc {
+&dac {
+&fmc {
+&gpioa {
- usb-port-power-hog {
gpio-hog;
gpios = <13 0>;
output-low;
+&gpioc {
+&gpiod {
+&gpiog {
- gpio-line-names = "PicoITX-In2", "", "", "",
- status = "okay";
- status = "okay";
+&ksz8851 {
+&usart3 {
- status = "okay";
+&uart8 {
- status = "okay";
+&usbh_ehci {
- status = "okay";
+&usbh_ohci {
- status = "okay";
+&usbotg_hs {
- dr_mode = "otg";
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
-/dts-v1/;
/ { aliases {
ethernet0 = ðernet0;eeprom0 = &eeprom0;
rtc0 = &hwrtc;
rtc1 = &rtc;
memory@c0000000 {
- reserved-memory {
#size-cells = <1>;
ranges;
no-map;
no-map;
no-map;
no-map;
no-map;
no-map;
- ethernet_vio: vioregulator { compatible = "regulator-fixed"; regulator-name = "vio";
};vin-supply = <&vdd>;
-&cec {
+&adc {
- vdd-supply = <&vdd>;
- vdda-supply = <&vdda>;
- vref-supply = <&vdda>; status = "okay";
- adc1: adc@0 {
status = "okay";
- adc2: adc@100 {
status = "okay";
+&dac {
- pinctrl-0 = <&dac_ch1_pins_a &dac_ch2_pins_a>;
- status = "okay";
- dac1: dac@1 {
status = "okay";
- dac2: dac@2 {
status = "okay";
- pinctrl-1 = <ðernet0_rmii_sleep_pins_a>; pinctrl-names = "default", "sleep"; phy-mode = "rmii"; max-speed = <100>; phy-handle = <&phy0>;
st,eth-ref-clk-sel;
/* LAN8710Ai */
}; };interrupts = <11 IRQ_TYPE_LEVEL_LOW>;
-&i2c2 {
+&fmc {
- pinctrl-0 = <&fmc_pins_b>;
- pinctrl-1 = <&fmc_sleep_pins_b>; status = "okay";
- ksz8851: ethernet@1,0 {
bank-width = <2>;
+&gpioa {
+&gpiob {
+&gpioc {
- status = "okay";
+&gpiod {
+&gpioe {
+&gpiof {
- gpio-line-names = "", "", "", "DHCOM-A",
+&gpiog {
- gpio-line-names = "DHCOM-C", "", "", "",
+&gpioh {
+&gpioi {
- gpio-line-names = "DHCOM-G", "DHCOM-O", "DHCOM-H", "DHCOM-I",
- hwrtc: rtc@32 {
reg = <0x32>;
- pmic: stpmic@33 { compatible = "st,stpmic1"; reg = <0x33>;
@@ -146,6 +313,7 @@
@@ -168,8 +336,6 @@
bst_out: boost {
}; vbus_otg: pwr_sw1 { regulator-name = "vbus_otg"; interrupts = <IT_OCP_OTG 0>;
vbus_sw: pwr_sw2 {
onkey {
- touchscreen@49 {
reg = <0x49>;
- eeprom@50 { compatible = "atmel,24c02"; reg = <0x50>; pagesize = <16>; };
-&i2c5 {
- status = "okay";
&m4_rproc {
- memory-region = <&retram>, <&mcuram>, <&mcuram2>, <&vdev0vring0>,
mboxes = <&ipcc 0>, <&ipcc 1>, <&ipcc 2>; mbox-names = "vq0", "vq1", "shutdown";<&vdev0vring1>, <&vdev0buffer>;
- interrupt-parent = <&exti>;
- interrupts = <68 1>; status = "okay";
-&pinctrl {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <2>;
pins2 {
bias-disable;
pins1 {
- flash0: flash@0 { compatible = "jedec,spi-nor"; reg = <0>; spi-rx-bus-width = <4>;
&sdmmc1 {
- pinctrl-names = "default", "opendrain", "sleep", "init"; pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_a>; pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_a>; pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_a>;
- pinctrl-3 = <&sdmmc1_b4_init_pins_a &sdmmc1_dir_init_pins_a>; cd-gpios = <&gpiog 1 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; disable-wp; st,sig-dir; st,neg-edge;
- st,use-ckin;
- st,cmd-gpios = <&gpiod 2 0>;
- st,ck-gpios = <&gpioc 12 0>;
- st,ckin-gpios = <&gpioe 4 0>; bus-width = <4>; vmmc-supply = <&vdd_sd>; status = "okay";
&sdmmc2 {
- pinctrl-names = "default", "opendrain", "sleep"; pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_a>;
- pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_a>;
- pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_a>; non-removable; no-sd; no-sdio;
- mmc-ddr-3_3v; status = "okay";
-&spi1 {
-&timers2 {
- pwm {
status = "okay";
- timer@1 {
status = "okay";
- broken-cd;
- st,neg-edge;
- bus-width = <4>;
- timer@5 {
status = "okay";
-&timers8 {
- pwm {
status = "okay";
- timer@7 {
status = "okay";
-&timers12 {
- pwm {
status = "okay";
- timer@11 {
status = "okay";
-&usbh_ehci {
- status = "okay";
-&usbotg_hs {
- status = "okay";
-&usbphyc {
- status = "okay";
-&usbphyc_port0 {
-&usbphyc_port1 {
eeprom0 = &eeprom0;
config {
- led {
red {
label = "error";
status = "okay";
blue {
- ks8851: ks8851mll@64000000 { compatible = "micrel,ks8851-mll"; reg = <0x64000000 0x20000>; };
+ðernet0 {
- phy-reset-gpios = <&gpioh 3 GPIO_ACTIVE_LOW>;
- /delete-property/ st,eth-ref-clk-sel;
- pins1 {
+&phy0 {
- /delete-property/ reset-gpios;
Applied to u-boot-stm/master
Thanks Patrice
Hi Marek
*/ +/dts-v1/;
- aliases {
serial0 = &uart4;
serial1 = &usart3;
serial2 = &uart8;
- chosen {
-&adc {
-&dac {
-&gpiob {
- usb-hub {
gpio-hog;
gpios = <8 0>;
output-high;
-&gpiod {
"", "", "", "Out1",
"Out2", "", "", "";
-&gpioi {
"In2", "", "", "",
- usb-hub {
gpio-hog;
gpios = <2 0>;
output-high;
-&i2c2 {
- status = "okay";
- status = "okay";
- eeprom@50 {
reg = <0x50>;
pagesize = <16>;
- status = "okay";
-&sdmmc3 {
- disable-wp;
- st,neg-edge;
- bus-width = <4>;
- mmc-ddr-3_3v;
- status = "okay";
-&spi1 {
-&usart3 {
- status = "okay";
- status = "okay";
-&usbh_ehci {
- status = "okay";
-&usbphyc {
- status = "okay";
-&usbphyc_port0 {
- aliases {
serial0 = &uart4;
serial1 = &usart3;
serial2 = &uart8;
- chosen {
+&adc {
+&dac {
+&gpiob {
- rs485-rx-en-hog {
gpio-hog;
gpios = <8 0>;
output-low;
+&gpiod {
+&gpioi {
- usb-hub-hog {
gpio-hog;
gpios = <2 0>;
output-high;
+&i2c2 {
- status = "okay";
- status = "okay";
- eeprom@50 {
reg = <0x50>;
pagesize = <16>;
+&i2c4 {
- touchscreen@49 {
- status = "okay";
+&sdmmc3 {
- disable-wp;
+&spi1 {
+&usart3 {
- status = "okay";
- status = "okay";
+&usbh_ehci {
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
+&usbotg_hs {
*/ +/dts-v1/;
- aliases {
serial0 = &uart4;
- chosen {
- aliases {
serial0 = &uart4;
serial1 = &usart3;
serial2 = &uart8;
- chosen {
#clock-cells = <0>;
status = "okay";
button-0 {
button-1 {
button-2 {
- gpio-keys {
button-3 {
wakeup-source;
- led {
led-0 {
led-1 {
led-2 {
led-3 {
- panel {
port {
- sound {
routing =
status = "okay";
+&cec {
- status = "okay";
- status = "okay";
- status = "okay";
- status = "okay";
reg = <0x0a>;
#size-cells = <0>;
reg = <0>;
reg = <1>;
- touchscreen@38 {
reg = <0x38>;
+<dc {
- status = "okay";
- port {
+&sai2 {
- status = "okay";
#clock-cells = <0>;
dma-names = "tx";
status = "okay";
sai2a_port: port {
format = "i2s";
mclk-fs = <512>;
dma-names = "rx";
status = "okay";
sai2b_port: port {
format = "i2s";
mclk-fs = <512>;
+&timers2 {
- status = "okay";
- pwm2: pwm {
status = "okay";
- timer@1 {
status = "okay";
+&usart3 {
- status = "okay";
+&uart8 {
- uart-has-rtscts;
- status = "okay";
+&usbh_ehci {
- status = "okay";
+&usbotg_hs {
- dr_mode = "otg";
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
+&usbotg_hs {
*/ +/dts-v1/;
- aliases {
serial0 = &uart4;
serial1 = &usart3;
serial2 = &uart8;
- chosen {
-&adc {
-&dac {
-&gpioa {
- usb-port-power {
gpio-hog;
gpios = <13 0>;
output-low;
- status = "okay";
- status = "okay";
-&usart3 {
- status = "okay";
-&uart8 {
- status = "okay";
-&usbh_ehci {
- status = "okay";
-&usbphyc {
- status = "okay";
-&usbphyc_port0 {
- aliases {
serial0 = &uart4;
serial1 = &usart3;
serial2 = &uart8;
- chosen {
- led {
led-0 {
+&adc {
+&dac {
+&fmc {
+&gpioa {
gpio-hog;
gpios = <13 0>;
output-low;
+&gpioc {
+&gpiod {
+&gpiog {
- status = "okay";
- status = "okay";
+&ksz8851 {
+&usart3 {
- status = "okay";
+&uart8 {
- status = "okay";
+&usbh_ehci {
- status = "okay";
+&usbh_ohci {
- status = "okay";
+&usbotg_hs {
- dr_mode = "otg";
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
-/dts-v1/;
/ { aliases {
rtc0 = &hwrtc;
rtc1 = &rtc;
memory@c0000000 {
- reserved-memory {
#size-cells = <1>;
ranges;
no-map;
no-map;
no-map;
no-map;
no-map;
no-map;
-&cec {
+&adc {
- adc1: adc@0 {
status = "okay";
- adc2: adc@100 {
status = "okay";
+&dac {
- status = "okay";
- dac1: dac@1 {
status = "okay";
- dac2: dac@2 {
status = "okay";
st,eth-ref-clk-sel;
/* LAN8710Ai */
-&i2c2 {
+&fmc {
bank-width = <2>;
+&gpioa {
+&gpiob {
+&gpioc {
- status = "okay";
+&gpiod {
+&gpioe {
+&gpiof {
+&gpiog {
+&gpioh {
+&gpioi {
- hwrtc: rtc@32 {
reg = <0x32>;
@@ -146,6 +313,7 @@
@@ -168,8 +336,6 @@
bst_out: boost {
vbus_sw: pwr_sw2 {
onkey {
- touchscreen@49 {
reg = <0x49>;
-&i2c5 {
- status = "okay";
&m4_rproc {
-&pinctrl {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <2>;
pins2 {
bias-disable;
pins1 {
&sdmmc1 {
- st,use-ckin;
&sdmmc2 {
-&spi1 {
-&timers2 {
- pwm {
status = "okay";
- timer@1 {
status = "okay";
- broken-cd;
- st,neg-edge;
- bus-width = <4>;
- timer@5 {
status = "okay";
-&timers8 {
- pwm {
status = "okay";
- timer@7 {
status = "okay";
-&timers12 {
- pwm {
status = "okay";
- timer@11 {
status = "okay";
-&usbh_ehci {
- status = "okay";
-&usbotg_hs {
- status = "okay";
-&usbphyc {
- status = "okay";
-&usbphyc_port0 {
-&usbphyc_port1 {
eeprom0 = &eeprom0;
config {
- led {
red {
label = "error";
status = "okay";
blue {
+ðernet0 {
- pins1 {
+&phy0 {
Thanks Patrice
Hi Marek,
Synchronize DH DHCOR DTs with Linux commit 25960cafa06e ("Linux 5.15.12"). There is no functional change to the resulting DTs. The eeprom0 alias is now reinstated in SoM u-boot dtsi, the PHY reset GPIO is reinstated in AV96 u-boot dtsi.
arch/arm/dts/Makefile | 1 - arch/arm/dts/stm32mp157a-avenger96.dts | 8 - arch/arm/dts/stm32mp157a-dhcor-avenger96.dts | 38 ++ .../stm32mp15xx-dhcor-avenger96-u-boot.dtsi | 2 + arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts | 202 +------- arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi | 431 ++++++++++++++++++ arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi | 7 +- ...-io3v3.dtsi => stm32mp15xx-dhcor-som.dtsi} | 30 +- arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi | 8 + 9 files changed, 503 insertions(+), 224 deletions(-) delete mode 100644 arch/arm/dts/stm32mp157a-avenger96.dts create mode 100644 arch/arm/dts/stm32mp157a-dhcor-avenger96.dts create mode 100644 arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi rename arch/arm/dts/{stm32mp15xx-dhcor-io3v3.dtsi => stm32mp15xx-dhcor-som.dtsi} (91%)
Thanks Patrick
Hi Marek
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b3e2a9c9d77..03064632999 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1098,7 +1098,6 @@ dtb-$(CONFIG_ARCH_STI) += stih410-b2260.dtb
dtb-$(CONFIG_STM32MP15x) += \ stm32mp157a-dk1.dtb \
- stm32mp157a-avenger96.dtb \ stm32mp157a-icore-stm32mp1-ctouch2.dtb \ stm32mp157a-icore-stm32mp1-edimm2.2.dtb \ stm32mp157a-microgea-stm32mp1-microdev2.0.dtb \
diff --git a/arch/arm/dts/stm32mp157a-avenger96.dts b/arch/arm/dts/stm32mp157a-avenger96.dts deleted file mode 100644 index 9c165104fbe..00000000000 --- a/arch/arm/dts/stm32mp157a-avenger96.dts +++ /dev/null @@ -1,8 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) -/*
- Copyright (C) Linaro Ltd 2019 - All Rights Reserved
- Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org
-/* This is kept for backward compatibility and will be removed */ -#include "stm32mp15xx-dhcor-avenger96.dts" diff --git a/arch/arm/dts/stm32mp157a-dhcor-avenger96.dts b/arch/arm/dts/stm32mp157a-dhcor-avenger96.dts new file mode 100644 index 00000000000..2e3c9fbb4eb --- /dev/null +++ b/arch/arm/dts/stm32mp157a-dhcor-avenger96.dts @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) +/*
- DHCOR STM32MP1 variant:
- DHCR-STM32MP157A-C065-R102-V18-SPI-C-01LG
- DHCOR PCB number: 586-100 or newer
- Avenger96 PCB number: 588-200 or newer
+/dts-v1/;
+#include "stm32mp157.dtsi" +#include "stm32mp15xc.dtsi" +#include "stm32mp15xx-dhcor-som.dtsi" +#include "stm32mp15xx-dhcor-avenger96.dtsi"
- model = "Arrow Electronics STM32MP157A Avenger96 board";
- compatible = "arrow,stm32mp157a-avenger96", "dh,stm32mp157a-dhcor-som",
"st,stm32mp157";
+&m_can1 {
- pinctrl-0 = <&m_can1_pins_b>;
- pinctrl-1 = <&m_can1_sleep_pins_b>;
+&m_can2 {
- pinctrl-0 = <&m_can2_pins_a>;
- pinctrl-1 = <&m_can2_sleep_pins_a>;
+}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi index c96eba99c5e..6e6543b5e4a 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi @@ -21,6 +21,8 @@
ðernet0 {
- phy-reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>;
- mdio0 { ethernet-phy@7 { reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>;
diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts index 0e860e5cf88..76ac5a873c1 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts +++ b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts @@ -7,206 +7,12 @@
/dts-v1/;
-#include "stm32mp15xx-dhcor-io1v8.dtsi" -#include "stm32mp15xx-dhcor-avenger96-u-boot.dtsi" +#include "stm32mp151.dtsi" +#include "stm32mp15xc.dtsi" +#include "stm32mp15xx-dhcor-som.dtsi" +#include "stm32mp15xx-dhcor-avenger96.dtsi"
/ { model = "Arrow Electronics STM32MP15xx Avenger96 board"; compatible = "arrow,stm32mp15xx-avenger96", "st,stm32mp15x";
- aliases {
eeprom0 = &eeprom0;
mmc0 = &sdmmc1;
serial0 = &uart4;
serial1 = &uart7;
- chosen {
- led {
led1 {
label = "green:user0";
gpios = <&gpioz 7 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
led2 {
label = "green:user1";
gpios = <&gpiof 3 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "mmc0";
led3 {
label = "green:user2";
gpios = <&gpiog 0 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "mmc1";
led4 {
label = "green:user3";
gpios = <&gpiog 1 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "none";
panic-indicator;
led5 {
label = "yellow:wifi";
gpios = <&gpioz 3 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "phy0tx";
led6 {
label = "blue:bt";
linux,default-trigger = "bluetooth-power";
- sd_switch: regulator-sd_switch {
compatible = "regulator-gpio";
regulator-name = "sd_switch";
regulator-type = "voltage";
gpios = <&gpioi 5 GPIO_ACTIVE_HIGH>;
gpios-states = <0>;
states = <1800000 0x1>,
<2900000 0x0>;
-ðernet0 {
- status = "okay";
- pinctrl-0 = <ðernet0_rgmii_pins_c>;
- pinctrl-1 = <ðernet0_rgmii_sleep_pins_c>;
- phy-mode = "rgmii";
- max-speed = <1000>;
- phy-handle = <&phy0>;
- mdio0 {
#size-cells = <0>;
compatible = "snps,dwmac-mdio";
phy0: ethernet-phy@7 {
reg = <7>;
-&i2c1 { /* X6 I2C1 */
- pinctrl-0 = <&i2c1_pins_b>;
- status = "okay";
-&i2c2 { /* X6 I2C2 */
- pinctrl-0 = <&i2c2_pins_c>;
- status = "okay";
-&i2c4 {
- eeprom0: eeprom@53 {
reg = <0x53>;
pagesize = <16>;
-&sdmmc1 {
- pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_b>;
- pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_b>;
- pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_b>;
- disable-wp;
- st,sig-dir;
- st,neg-edge;
- st,use-ckin;
- bus-width = <4>;
- vmmc-supply = <&vdd_sd>;
- vqmmc-supply = <&sd_switch>;
- status = "okay";
-&sdmmc2 {
- pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_c>;
- non-removable;
- no-sd;
- no-sdio;
- st,neg-edge;
- bus-width = <8>;
- mmc-ddr-3_3v;
- status = "okay";
-&spi2 {
- pinctrl-0 = <&spi2_pins_a>;
- status = "okay";
-&uart4 {
- /* On Low speed expansion header */
- label = "LS-UART1";
- pinctrl-0 = <&uart4_pins_b>;
- status = "okay";
-&uart7 {
- label = "LS-UART0";
- pinctrl-0 = <&uart7_pins_a>;
- status = "okay";
-&usbh_ehci {
- status = "okay";
-&usbotg_hs {
- pinctrl-0 = <&usbotg_hs_pins_a>;
- status = "okay";
-&usbphyc {
- status = "okay";
-&usbphyc_port0 {
-&usbphyc_port1 {
}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi new file mode 100644 index 00000000000..6885948f302 --- /dev/null +++ b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi @@ -0,0 +1,431 @@ +// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) +/*
+/* Avenger96 uses DHCOR SoM configured for 1V8 IO operation */ +#include "stm32mp15xx-dhcor-io1v8.dtsi"
- aliases {
mmc0 = &sdmmc1;
serial0 = &uart4;
serial1 = &uart7;
serial2 = &usart2;
spi0 = &qspi;
- /* XTal Q1 */
- cec_clock: clk-cec-fixed {
#clock-cells = <0>;
- chosen {
- hdmi-out {
compatible = "hdmi-connector";
type = "a";
port {
hdmi_con: endpoint {
remote-endpoint = <&adv7513_out>;
- led {
led1 {
led2 {
led3 {
led4 {
panic-indicator;
gpios-states = <0>;
<2900000 0x0>;
- sound {
label = "STM32MP1-AV96-HDMI";
dais = <&sai2a_port>;
status = "okay";
- wlan_pwr: regulator-wlan {
regulator-name = "wl-reg";
enable-active-high;
+&adc {
- pinctrl-0 = <&adc12_ain_pins_b>;
- status = "okay";
- adc1: adc@0 {
st,adc-channels = <0 1 6>;
status = "okay";
- adc2: adc@100 {
st,adc-channels = <0 1 2>;
status = "okay";
+ðernet0 {
- status = "okay";
- mdio0 {
#size-cells = <0>;
reset-delay-us = <1000>;
reg = <7>;
rxc-skew-ps = <1500>;
rxdv-skew-ps = <540>;
rxd0-skew-ps = <420>;
rxd1-skew-ps = <420>;
rxd2-skew-ps = <420>;
rxd3-skew-ps = <420>;
txc-skew-ps = <1440>;
txen-skew-ps = <540>;
txd0-skew-ps = <420>;
txd1-skew-ps = <420>;
txd2-skew-ps = <420>;
txd3-skew-ps = <420>;
+&gpioa {
"", "", "", "AV96-K",
"AV96-I", "", "AV96-A", "";
+&gpiob {
"", "AV96-J", "", "",
"", "", "", "AV96-B",
"", "AV96-L", "", "";
+&gpioc {
- gpio-line-names = "", "", "", "AV96-C",
+&gpiod {
"AV96-D", "", "", "",
"", "", "AV96-E", "AV96-F";
+&gpiof {
"AV96-G", "AV96-H", "", "";
+&i2c1 { /* X6 I2C1 */
- status = "okay";
+&i2c2 { /* X6 I2C2 */
- status = "okay";
+&i2c4 {
- hdmi-transmitter@3d {
compatible = "adi,adv7513";
reg = <0x3d>, <0x4d>, <0x2d>, <0x5d>;
reg-names = "main", "edid", "cec", "packet";
clocks = <&cec_clock>;
clock-names = "cec";
avdd-supply = <&v3v3>;
dvdd-supply = <&v3v3>;
pvdd-supply = <&v3v3>;
dvdd-3v-supply = <&v3v3>;
bgvdd-supply = <&v3v3>;
interrupts = <9 IRQ_TYPE_EDGE_FALLING>;
interrupt-parent = <&gpiog>;
status = "okay";
adi,input-depth = <8>;
adi,input-colorspace = "rgb";
adi,input-clock = "1x";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
adv7513_in: endpoint {
remote-endpoint = <<dc_ep0_out>;
port@1 {
reg = <1>;
adv7513_out: endpoint {
remote-endpoint = <&hdmi_con>;
port@2 {
reg = <2>;
adv7513_i2s0: endpoint {
+<dc {
- pinctrl-0 = <<dc_pins_d>;
- pinctrl-1 = <<dc_sleep_pins_d>;
- status = "okay";
- port {
#size-cells = <0>;
ltdc_ep0_out: endpoint@0 {
reg = <0>;
remote-endpoint = <&adv7513_in>;
+&sai2 {
- pinctrl-0 = <&sai2a_pins_c>;
- pinctrl-1 = <&sai2a_sleep_pins_c>;
- status = "okay";
#clock-cells = <0>;
dma-names = "tx";
status = "okay";
sai2a_port: port {
remote-endpoint = <&adv7513_i2s0>;
format = "i2s";
mclk-fs = <256>;
+&sdmmc1 {
- cd-gpios = <&gpioi 8 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
- disable-wp;
- st,sig-dir;
- st,neg-edge;
- st,use-ckin;
- bus-width = <4>;
- status = "okay";
+&sdmmc2 {
- pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_c>;
- pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_c>;
- bus-width = <8>;
- mmc-ddr-1_8v;
- no-sd;
- no-sdio;
- non-removable;
- st,neg-edge;
- vqmmc-supply = <&vdd_io>;
- status = "okay";
+&sdmmc3 {
- pinctrl-0 = <&sdmmc3_b4_pins_b>;
- pinctrl-1 = <&sdmmc3_b4_od_pins_b>;
- pinctrl-2 = <&sdmmc3_b4_sleep_pins_b>;
- broken-cd;
- non-removable;
- st,neg-edge;
- bus-width = <4>;
- vmmc-supply = <&wlan_pwr>;
- status = "okay";
- #address-cells = <1>;
- #size-cells = <0>;
- brcmf: bcrmf@1 {
reg = <1>;
compatible = "brcm,bcm4329-fmac";
+&spi2 {
- cs-gpios = <&gpioi 0 0>;
+&uart4 {
- status = "okay";
+&uart7 {
- uart-has-rtscts;
- status = "okay";
+/* Bluetooth */ +&usart2 {
- pinctrl-0 = <&usart2_pins_a>;
- pinctrl-1 = <&usart2_sleep_pins_a>;
- st,hw-flow-ctrl;
- status = "okay";
- bluetooth {
compatible = "brcm,bcm43438-bt";
max-speed = <3000000>;
shutdown-gpios = <&gpioz 6 GPIO_ACTIVE_HIGH>;
+&usbh_ehci {
- status = "okay";
+&usbotg_hs {
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
+}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi index 75435424d67..75172314d7a 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi @@ -1,12 +1,12 @@ // SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) /*
-#include "stm32mp15xx-dhcor-io3v3.dtsi"
- /* Enpirion EP3A8LQI U2 on the 1V8 IO DHCOR */
- /* Enpirion EP3A8LQI U2 on the DHCOR */ vdd_io: regulator-buck-io { compatible = "regulator-fixed"; regulator-name = "buck-io";
@@ -20,5 +20,4 @@
&pwr_regulators { vdd-supply = <&vdd_io>;
- vdd_3v3_usbfs-supply = <&vdd_usb>;
}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-io3v3.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-som.dtsi similarity index 91% rename from arch/arm/dts/stm32mp15xx-dhcor-io3v3.dtsi rename to arch/arm/dts/stm32mp15xx-dhcor-som.dtsi index 94cf80dbede..44ecc470858 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-io3v3.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-som.dtsi @@ -4,9 +4,7 @@
*/ -/dts-v1/;
-#include "stm32mp157.dtsi" #include "stm32mp15-pinctrl.dtsi" #include "stm32mp15xxac-pinctrl.dtsi" #include <dt-bindings/gpio/gpio.h> @@ -23,6 +21,14 @@ }; };
+&crc1 {
- status = "okay";
+&dts {
- status = "okay";
&i2c4 { pinctrl-names = "default"; pinctrl-0 = <&i2c4_pins_a>; @@ -35,7 +41,7 @@ pmic: stpmic@33 { compatible = "st,stpmic1"; reg = <0x33>;
interrupts-extended = <&exti 55 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller; #interrupt-cells = <2>; status = "okay";interrupts-extended = <&gpioa 0 IRQ_TYPE_EDGE_FALLING>;
@@ -53,7 +59,7 @@
vddcore: buck1 { regulator-name = "vddcore";
regulator-min-microvolt = <800000>;
regulator-min-microvolt = <1200000>; regulator-max-microvolt = <1350000>; regulator-always-on; regulator-initial-mode = <0>;
@@ -92,7 +98,6 @@ regulator-min-microvolt = <2900000>; regulator-max-microvolt = <2900000>; interrupts = <IT_CURLIM_LDO1 0>;
interrupt-parent = <&pmic>; }; v2v8: ldo2 {
@@ -100,7 +105,6 @@ regulator-min-microvolt = <2800000>; regulator-max-microvolt = <2800000>; interrupts = <IT_CURLIM_LDO2 0>;
interrupt-parent = <&pmic>; }; vtt_ddr: ldo3 {
@@ -114,7 +118,6 @@ vdd_usb: ldo4 { regulator-name = "vdd_usb"; interrupts = <IT_CURLIM_LDO4 0>;
interrupt-parent = <&pmic>; }; vdd_sd: ldo5 {
@@ -122,7 +125,6 @@ regulator-min-microvolt = <2900000>; regulator-max-microvolt = <2900000>; interrupts = <IT_CURLIM_LDO5 0>;
interrupt-parent = <&pmic>; regulator-boot-on; };
@@ -131,7 +133,6 @@ regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; interrupts = <IT_CURLIM_LDO6 0>;
interrupt-parent = <&pmic>; regulator-enable-ramp-delay = <300000>; };
@@ -143,20 +144,17 @@ bst_out: boost { regulator-name = "bst_out"; interrupts = <IT_OCP_BOOST 0>;
interrupt-parent = <&pmic>; }; vbus_otg: pwr_sw1 { regulator-name = "vbus_otg"; interrupts = <IT_OCP_OTG 0>;
interrupt-parent = <&pmic>; regulator-active-discharge = <1>; }; vbus_sw: pwr_sw2 { regulator-name = "vbus_sw"; interrupts = <IT_OCP_SWOUT 0>;
@@ -173,6 +171,12 @@ status = "disabled"; }; };
- eeprom@53 {
reg = <0x53>;
pagesize = <16>;
&iwdg2 { @@ -194,7 +198,7 @@ #size-cells = <0>; status = "okay";
- flash0: spi-flash@0 {
diff --git a/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi index 71375510b4a..338b674368a 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi @@ -15,6 +15,11 @@
/ { u-boot,dm-pre-reloc;
- aliases {
eeprom0 = &eeprom0;
- config { dh,ddr3-coding-gpios = <&gpiog 0 0>, <&gpiog 1 0>; dh,som-coding-gpios = <&gpioz 7 0>, <&gpiof 3 0>;
@@ -28,6 +33,9 @@ &i2c4 { u-boot,dm-pre-reloc; u-boot,dm-spl;
&i2c4_pins_a {
Thanks Patrice
Patrice CHOTARD
Patrick DELAUNAY
