[U-Boot] [PATCH v6] Add imls utility command
This patch adds, under tools folder, a new command called imls. Its goal is the same of UBoot's imls but it can be used as Linux shell command. It reads from raw mtd partition and prints the list of the stored images.
Signed-off-by: Marco Stornelli marco.stornelli@gmail.com ---
Changes from v5: - Swapped 'c' with 's' option
tools/imls/Makefile | 106 ++++++++++++++++++++ tools/imls/README | 57 +++++++++++ tools/imls/imls.c | 270 +++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 433 insertions(+), 0 deletions(-) create mode 100644 tools/imls/Makefile create mode 100644 tools/imls/README create mode 100644 tools/imls/imls.c
diff --git a/tools/imls/Makefile b/tools/imls/Makefile new file mode 100644 index 0000000..d654658 --- /dev/null +++ b/tools/imls/Makefile @@ -0,0 +1,106 @@ +# +# (C) Copyright 2009 Marco Stornelli marco.stornelli@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +HOST_CFLAGS = -Wall -pedantic + +# Generated executable files +BIN_FILES-y += imls + +# Source files which exist outside the tools/imls directory +EXT_OBJ_FILES-y += lib_generic/crc32.o +EXT_OBJ_FILES-y += lib_generic/md5.o +EXT_OBJ_FILES-y += lib_generic/sha1.o +EXT_OBJ_FILES-y += common/image.o + +# Source files located in the tools/imls directory +OBJ_FILES-y += imls.o + +# Flattened device tree objects +LIBFDT_OBJ_FILES-y += fdt.o +LIBFDT_OBJ_FILES-y += fdt_ro.o +LIBFDT_OBJ_FILES-y += fdt_rw.o +LIBFDT_OBJ_FILES-y += fdt_strerror.o +LIBFDT_OBJ_FILES-y += fdt_wip.o + +# now $(obj) is defined +SRCS += $(addprefix $(SRCTREE)/,$(EXT_OBJ_FILES-y:.o=.c)) +SRCS += $(addprefix $(SRCTREE)/tools/,$(OBJ_FILES-y:.o=.c)) +SRCS += $(addprefix $(SRCTREE)/libfdt/,$(LIBFDT_OBJ_FILES-y:.o=.c)) +BINS := $(addprefix $(obj),$(sort $(BIN_FILES-y))) +LIBFDT_OBJS := $(addprefix $(obj),$(LIBFDT_OBJ_FILES-y)) + +# +# Use native tools and options +# Define __KERNEL_STRICT_NAMES to prevent typedef overlaps +# +CPPFLAGS = -idirafter $(SRCTREE)/include \ + -idirafter $(OBJTREE)/include2 \ + -idirafter $(OBJTREE)/include \ + -I $(SRCTREE)/libfdt \ + -I $(SRCTREE)/tools \ + -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES +CFLAGS = $(HOST_CFLAGS) $(CPPFLAGS) -O + +# No -pedantic switch to avoid libfdt compilation warnings +FIT_CFLAGS = -Wall $(CPPFLAGS) -O + +CC = $(CROSS_COMPILER)gcc +STRIP = $(CROSS_COMPILER)strip + +ifeq ($(MTD_VERSION),old) +CPPFLAGS += -DMTD_OLD +endif + +all: $(BINS) + +$(obj)imls: $(obj)imls.o $(obj)crc32.o $(obj)image.o $(obj)md5.o \ + $(obj)sha1.o $(LIBFDT_OBJS) + $(CC) $(CFLAGS) -o $@ $^ + $(STRIP) $@ + +# Some files complain if compiled with -pedantic, use FIT_CFLAGS +$(obj)image.o: $(SRCTREE)/common/image.c + $(CC) -g $(FIT_CFLAGS) -c -o $@ $< + +$(obj)imls.o: imls.c + $(CC) -g $(FIT_CFLAGS) -c -o $@ $< + +# Some of the tool objects need to be accessed from outside the tools/imls directory +$(obj)%.o: $(SRCTREE)/common/%.c + $(CC) -g $(FIT_CFLAGS) -c -o $@ $< + +$(obj)%.o: $(SRCTREE)/lib_generic/%.c + $(CC) -g $(CFLAGS) -c -o $@ $< + +$(obj)%.o: $(SRCTREE)/libfdt/%.c + $(CC) -g $(FIT_CFLAGS) -c -o $@ $< + +clean: + rm -rf *.o imls + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/tools/imls/README b/tools/imls/README new file mode 100644 index 0000000..63d639d --- /dev/null +++ b/tools/imls/README @@ -0,0 +1,57 @@ +# +# (C) Copyright 2009 Marco Stornelli marco.stornelli@gmail.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# The files in this directory are free software; you can redistribute +# them and/or modify them under the terms of the GNU General Public +# License as published by the Free Software Foundation; either +# version 2 of the License, or (at your option) any later version. +# +# These files are distributed in the hope that they will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +IMLS +------------- + +imls is an implementation of a Linux command line tool to access +to raw flash partitions and list images made with mkimage command. + +For building against older versions of the MTD headers (meaning before +v2.6.8-rc1) it is required to pass the argument "MTD_VERSION=old" to +make. + +Usage examples +-------------- + +1) Flash with sectors of 128KiB and 32 sectors: + +> imls -c 32 -s 131072 /dev/mtd0 +Searching... +Image Name: foo +Created: Fri Apr 10 18:11:30 2009 +Image Type: Intel x86 Linux Standalone Program (uncompressed) +Data Size: 10716 Bytes = 10.46 kB = 0.01 MB +Load Address: 00000000 +Entry Point: 00000000 + +2) Flash with sectors of 64KiB and 128 sectors and with a search offset of one +sector: + +> imls -o 1 -c 128 -s 65536 /dev/mtd0 +Searching... +Image Name: foo +Created: Fri Apr 10 18:11:30 2009 +Image Type: Intel x86 Linux Standalone Program (uncompressed) +Data Size: 10716 Bytes = 10.46 kB = 0.01 MB +Load Address: 00000000 +Entry Point: 00000000 diff --git a/tools/imls/imls.c b/tools/imls/imls.c new file mode 100644 index 0000000..583272a --- /dev/null +++ b/tools/imls/imls.c @@ -0,0 +1,270 @@ +/* + * (C) Copyright 2009 Marco Stornelli + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <fcntl.h> +#include <stdio.h> +#include <stdlib.h> +#include <stddef.h> +#include <string.h> +#include <sys/types.h> +#include <sys/ioctl.h> +#include <sys/stat.h> +#include <unistd.h> +#include <asm/page.h> + +#ifdef MTD_OLD +#include <stdint.h> +#include <linux/mtd/mtd.h> +#else +#define __user /* nothing */ +#include <mtd/mtd-user.h> +#endif + +#include <sha1.h> +#include <fdt.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <image.h> + +#define MIN(a, b) (((a) < (b)) ? (a) : (b)) + +extern unsigned long crc32(unsigned long crc, const char *buf, unsigned int len); +static void usage(void); +static int image_verify_header(char *ptr, int fd); +static int flash_bad_block(int fd, uint8_t mtd_type, loff_t start); + +char *cmdname; +char *devicefile; + +unsigned int sectorcount = 0; +int sflag = 0; +unsigned int sectoroffset = 0; +unsigned int sectorsize = 0; +int cflag = 0; + +int main (int argc, char **argv) +{ + int fd = -1, err = 0, readbyte = 0, j; + struct mtd_info_user mtdinfo; + char buf[sizeof(image_header_t)]; + int found = 0; + + cmdname = *argv; + + while (--argc > 0 && **++argv == '-') { + while (*++*argv) { + switch (**argv) { + case 'c': + if (--argc <= 0) + usage (); + sectorcount = (unsigned int)atoi(*++argv); + cflag = 1; + goto NXTARG; + case 'o': + if (--argc <= 0) + usage (); + sectoroffset = (unsigned int)atoi(*++argv); + goto NXTARG; + + case 's': + if (--argc <= 0) + usage (); + sectorsize = (unsigned int)atoi(*++argv); + sflag = 1; + goto NXTARG; + default: + usage (); + } + } +NXTARG: ; + } + + if (argc != 1 || cflag == 0 || sflag == 0) + usage(); + + devicefile = *argv; + + fd = open(devicefile, O_RDONLY); + if (fd < 0) { + fprintf (stderr, "%s: Can't open %s: %s\n", + cmdname, devicefile, strerror(errno)); + exit(EXIT_FAILURE); + } + + err = ioctl(fd, MEMGETINFO, &mtdinfo); + if (err < 0) { + fprintf(stderr, "%s: Cannot get MTD information: %s\n",cmdname, + strerror(errno)); + exit(EXIT_FAILURE); + } + + if (mtdinfo.type != MTD_NORFLASH && mtdinfo.type != MTD_NANDFLASH) { + fprintf(stderr, "%s: Unsupported flash type %u\n", + cmdname, mtdinfo.type); + exit(EXIT_FAILURE); + } + + if (sectorsize * sectorcount != mtdinfo.size) { + fprintf(stderr, "%s: Partition size (%d) incompatible with " + "sector size and count\n", cmdname, mtdinfo.size); + exit(EXIT_FAILURE); + } + + if (sectorsize * sectoroffset >= mtdinfo.size) { + fprintf(stderr, "%s: Partition size (%d) incompatible with " + "sector offset given\n", cmdname, mtdinfo.size); + exit(EXIT_FAILURE); + } + + if (sectoroffset > sectorcount - 1) { + fprintf(stderr, "%s: Sector offset cannot be grater than " + "sector count minus one\n", cmdname); + exit(EXIT_FAILURE); + } + + printf("Searching....\n"); + + for (j = sectoroffset; j < sectorcount; ++j) { + + if (lseek(fd, j*sectorsize, SEEK_SET) != j*sectorsize) { + fprintf(stderr, "%s: lseek failure: %s\n", + cmdname, strerror(errno)); + exit(EXIT_FAILURE); + } + + err = flash_bad_block(fd, mtdinfo.type, j*sectorsize); + if (err < 0) + exit(EXIT_FAILURE); + if (err) + continue; /* Skip and jump to next */ + + readbyte = read(fd, buf, sizeof(image_header_t)); + if (readbyte != sizeof(image_header_t)) { + fprintf(stderr, "%s: Can't read from device: %s\n", + cmdname, strerror(errno)); + exit(EXIT_FAILURE); + } + + if (fdt_check_header(buf)) { + /* old-style image */ + if (image_verify_header(buf, fd)) { + found = 1; + image_print_contents((image_header_t *)buf); + } + } else { + /* FIT image */ + fit_print_contents(buf); + } + + } + + close(fd); + + if(!found) + printf("No images found\n"); + + exit(EXIT_SUCCESS); +} + +void usage() +{ + fprintf (stderr, "Usage:\n" + " %s [-o offset] -s size -c count device\n" + " -o ==> number of sectors to use as offset\n" + " -c ==> number of sectors\n" + " -s ==> size of sectors (byte)\n", + cmdname); + + exit(EXIT_FAILURE); +} + +static int image_verify_header(char *ptr, int fd) +{ + int len, nread; + char *data; + uint32_t checksum; + image_header_t *hdr = (image_header_t *)ptr; + char buf[PAGE_SIZE]; + + if (image_get_magic(hdr) != IH_MAGIC) + return 0; + + data = (char *)hdr; + len = image_get_header_size(); + + checksum = image_get_hcrc(hdr); + hdr->ih_hcrc = htonl(0); /* clear for re-calculation */ + + if (crc32(0, data, len) != checksum) { + fprintf(stderr, + "%s: Maybe image found but it has bad header checksum!\n", + cmdname); + return 0; + } + + len = image_get_size(hdr); + checksum = 0; + + while (len > 0) { + nread = read(fd, buf, MIN(len,PAGE_SIZE)); + if (nread != MIN(len,PAGE_SIZE)) { + fprintf(stderr, + "%s: Error while reading: %s\n", + cmdname, strerror(errno)); + exit(EXIT_FAILURE); + } + checksum = crc32(checksum, buf, nread); + len -= nread; + } + + if (checksum != image_get_dcrc(hdr)) { + fprintf (stderr, + "%s: Maybe image found but it has corrupted data!\n", + cmdname); + return 0; + } + + return 1; +} + +/* + * Test for bad block on NAND, just returns 0 on NOR, on NAND: + * 0 - block is good + * > 0 - block is bad + * < 0 - failed to test + */ +static int flash_bad_block(int fd, uint8_t mtd_type, loff_t start) +{ + if (mtd_type == MTD_NANDFLASH) { + int badblock = ioctl(fd, MEMGETBADBLOCK, &start); + + if (badblock < 0) { + fprintf(stderr,"%s: Cannot read bad block mark: %s\n", + cmdname, strerror(errno)); + return badblock; + } + + if (badblock) { + return badblock; + } + } + + return 0; +}
Dear Marco,
Changes from v5:
Applie, thanks, but:
/home/wd/git/u-boot/work/.git/rebase-apply/patch:269: trailing whitespace. if (--argc <= 0) /home/wd/git/u-boot/work/.git/rebase-apply/patch:313: trailing whitespace. fprintf(stderr, "%s: Unsupported flash type %u\n", /home/wd/git/u-boot/work/.git/rebase-apply/patch:370: trailing whitespace. } /home/wd/git/u-boot/work/.git/rebase-apply/patch:437: trailing whitespace.
warning: 4 lines applied after fixing whitespace errors.
Please pay attention to the coding style!
Wolfgang Denk ha scritto:
Dear Marco,
Thank you very much Wolfgang.
Regards,
Marco
Marco
