[PATCH V2 0/3] arm: omap3: Make functions static when possible
A few functions are defined without being labeled as static to that file. In an effort to keep SPL as small as possible, one function needs to be moved into an #ifdef so it's only enabled when the calling function is available, and all of these can simply be marked as static.
Before: text data bss dec hex filename 50988 1053 1888 53929 d2a9 spl/u-boot-spl
After: text data bss dec hex filename 50972 1053 1888 53913 d299 spl/u-boot-spl
While not significant, a few bytes can be very helpful when SPL is limited.
Adam Ford (3): arm: omap3: Make try_unlock_memory() static arm: omap3: Make secureworld_exit() static arm: omap3: Make secure_unlock_mem() static
arch/arm/include/asm/arch-omap3/sys_proto.h | 2 -- arch/arm/mach-omap2/omap3/board.c | 21 +++++++++++---------- 2 files changed, 11 insertions(+), 12 deletions(-)
try_unlock_memory() is only used in one file, so make it static in that file,remove it from the sys_proto header file, and relocate it into the #ifdef section that call it. This will make it only built under the conditions when it is called, and it may help with some further optimization in the future.
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/include/asm/arch-omap3/sys_proto.h | 1 - arch/arm/mach-omap2/omap3/board.c | 17 +++++++++-------- 2 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap3/sys_proto.h b/arch/arm/include/asm/arch-omap3/sys_proto.h index 32ac033515..656f848a73 100644 --- a/arch/arm/include/asm/arch-omap3/sys_proto.h +++ b/arch/arm/include/asm/arch-omap3/sys_proto.h @@ -60,7 +60,6 @@ u32 is_running_in_sram(void); u32 is_running_in_flash(void); u32 get_device_type(void); void secureworld_exit(void); -void try_unlock_memory(void); u32 get_boot_type(void); void invalidate_dcache(u32); u32 wait_on_value(u32, u32, void *, u32); diff --git a/arch/arm/mach-omap2/omap3/board.c b/arch/arm/mach-omap2/omap3/board.c index 029bd54595..ef4fa80c7b 100644 --- a/arch/arm/mach-omap2/omap3/board.c +++ b/arch/arm/mach-omap2/omap3/board.c @@ -140,12 +140,20 @@ void secureworld_exit(void) __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 0":"=r"(i)); }
+void early_system_init(void) +{ + hw_data_init(); +} + +#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) && \ + !defined(CONFIG_SKIP_LOWLEVEL_INIT_ONLY) + /****************************************************************************** * Routine: try_unlock_sram() * Description: If chip is GP/EMU(special) type, unlock the SRAM for * general use. *****************************************************************************/ -void try_unlock_memory(void) +static void try_unlock_memory(void) { int mode; int in_sdram = is_running_in_sdram(); @@ -174,13 +182,6 @@ void try_unlock_memory(void) return; }
-void early_system_init(void) -{ - hw_data_init(); -} - -#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) && \ - !defined(CONFIG_SKIP_LOWLEVEL_INIT_ONLY) /****************************************************************************** * Routine: s_init * Description: Does early system init of muxing and clocks.
secureworld_exit() is only used in one file, so make it static to that file and remove it from sys_proto.h. This may help with some further optimization in the future.
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/include/asm/arch-omap3/sys_proto.h | 1 - arch/arm/mach-omap2/omap3/board.c | 2 +- 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap3/sys_proto.h b/arch/arm/include/asm/arch-omap3/sys_proto.h index 656f848a73..a6e9ff84aa 100644 --- a/arch/arm/include/asm/arch-omap3/sys_proto.h +++ b/arch/arm/include/asm/arch-omap3/sys_proto.h @@ -59,7 +59,6 @@ u32 is_running_in_sdram(void); u32 is_running_in_sram(void); u32 is_running_in_flash(void); u32 get_device_type(void); -void secureworld_exit(void); u32 get_boot_type(void); void invalidate_dcache(u32); u32 wait_on_value(u32, u32, void *, u32); diff --git a/arch/arm/mach-omap2/omap3/board.c b/arch/arm/mach-omap2/omap3/board.c index ef4fa80c7b..41d0d3ef69 100644 --- a/arch/arm/mach-omap2/omap3/board.c +++ b/arch/arm/mach-omap2/omap3/board.c @@ -114,7 +114,7 @@ void secure_unlock_mem(void) * configure secure registers and exit secure world * general use. *****************************************************************************/ -void secureworld_exit(void) +static void secureworld_exit(void) { unsigned long i;
secure_unlock_mem() is only used in one file, so make it static in that file. This may help with some further optimization in the future.
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/mach-omap2/omap3/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-omap2/omap3/board.c b/arch/arm/mach-omap2/omap3/board.c index 41d0d3ef69..a6c3141dbd 100644 --- a/arch/arm/mach-omap2/omap3/board.c +++ b/arch/arm/mach-omap2/omap3/board.c @@ -76,7 +76,7 @@ const struct gpio_bank *const omap_gpio_bank = gpio_bank_34xx; * Description: Setup security registers for access * (GP Device only) *****************************************************************************/ -void secure_unlock_mem(void) +static void secure_unlock_mem(void) { struct pm *pm_rt_ape_base = (struct pm *)PM_RT_APE_BASE_ADDR_ARM; struct pm *pm_gpmc_base = (struct pm *)PM_GPMC_BASE_ADDR_ARM;
I see some failures with this series. Can you take a look: https://source.denx.de/u-boot/custodians/u-boot-ti/-/jobs/254794
Thanks and regards, Lokesh
Adam Ford
Lokesh Vutla
