[U-Boot] [U-boot] DFU tools copyright
Hi, experts: I found DFU tool code had been put in drivers/dfu directory. Previously, it was owned by Samsung Electronics.
Because it has been merged into uboot library. So, it could be used or released by every ARM SOC vendor?
Best wishes,
Could you be more specific here?
All DFU related files have following headers: /* * g_dnl.c -- USB Downloader Gadget * * Copyright (C) 2012 Samsung Electronics * Lukasz Majewski l.majewski@samsung.com * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA */
Which clearly states that the code is GPL v2+. The code is "open", you can modify it and use with your product if you provide your's product source code when requested.
Yes, it can as long as this vendor sticks to GPL v2 license. This mean (with some simplification :-) ) that this vendor needs to publish source code for his product.
Best wishes, _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hello.
- g_dnl.c -- USB Downloader Gadget
- Copyright (C) 2012 Samsung Electronics
- Lukasz Majewski l.majewski@samsung.com
Which reminds about an issue I brought up before. Your DFU implementation is heavily based on the original DFU code Harald Welte wrote. The state machine even still have the same fixmes and comments but you removed his, and maybe others, copyright here.
As you definitely not wrote the code from scratch you should keep the original copyright intact and not only placing the Samsung copyright here.
regards Stefan Schmidt
On Thu, 04 Jul 2013 22:08:12 +0100, Stefan Schmidt wrote:
Hello.
You are right here. The state machine was only slightly modified by us.
I will update the f_dfu.c file accordingly to bring back proper credits.
I'm sorry for the situation - it was not intentional.
regards Stefan Schmidt _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hello.
Hello.
Cool. The patchset I sent April 2012 which was for reference only should have the correct credits in the old_dfu.c file. http://lists.denx.de/pipermail/u-boot/2012-April/121864.html
No worries. This was not meant to blame anyone. Just something that needs correction. Just took the change to remind about it. :)
The DFU's state machine original implementation author and copyright were missing.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com --- drivers/usb/gadget/f_dfu.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/usb/gadget/f_dfu.c b/drivers/usb/gadget/f_dfu.c index e3fa0e3..6adf15c 100644 --- a/drivers/usb/gadget/f_dfu.c +++ b/drivers/usb/gadget/f_dfu.c @@ -5,6 +5,10 @@ * authors: Andrzej Pietrasiewicz andrzej.p@samsung.com * Lukasz Majewski l.majewski@samsung.com * + * Based on OpenMoko u-boot: drivers/usb/usbdfu.c + * (C) 2007 by OpenMoko, Inc. + * Author: Harald Welte laforge@openmoko.org + * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or
Hello.
- authors: Andrzej Pietrasiewicz andrzej.p@samsung.com
Lukasz Majewski <l.majewski@samsung.com>
- Based on OpenMoko u-boot: drivers/usb/usbdfu.c
- (C) 2007 by OpenMoko, Inc.
- Author: Harald Welte laforge@openmoko.org
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
-- 1.7.10.4
You missed Haralds personal copyright from 2006. + * based on existing SAM7DFU code from OpenPCD: + * (C) Copyright 2006 by Harald Welte <hwelte at hmw-consulting.de>
While he was working on this for OpenMoko which gives them the copyright he did work on this code before which means his own copyright does also apply.
--- Changes for v2: - Add the whole Harald's development history --- drivers/usb/gadget/f_dfu.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/usb/gadget/f_dfu.c b/drivers/usb/gadget/f_dfu.c index e3fa0e3..d7ae0c0 100644 --- a/drivers/usb/gadget/f_dfu.c +++ b/drivers/usb/gadget/f_dfu.c @@ -5,6 +5,13 @@ * authors: Andrzej Pietrasiewicz andrzej.p@samsung.com * Lukasz Majewski l.majewski@samsung.com * + * Based on OpenMoko u-boot: drivers/usb/usbdfu.c + * (C) 2007 by OpenMoko, Inc. + * Author: Harald Welte laforge@openmoko.org + * + * based on existing SAM7DFU code from OpenPCD: + * (C) Copyright 2006 by Harald Welte <hwelte at hmw-consulting.de> + * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or
Hello.
Acked-by: Stefan Schmidt stefan@datenfreihafen.org
Changes for v2:
- based on existing SAM7DFU code from OpenPCD:
- (C) Copyright 2006 by Harald Welte <hwelte at hmw-consulting.de>
-- 1.7.10.4
Lukasz Majewski
Stefan Schmidt
TigerLiuļ¼ viatech.com.cn
