[U-Boot] [PATCH 1/6] zynqmp: Add support for emulation platform - Veloce
Add support for Veloce - zynqmp emulation platform. Platform doesn't support SDHCI.
arch/arm/cpu/armv8/zynqmp/clk.c | 3 +++ arch/arm/cpu/armv8/zynqmp/cpu.c | 2 ++ arch/arm/include/asm/arch-zynqmp/hardware.h | 1 + board/xilinx/zynqmp/zynqmp.c | 8 ++++++-- 4 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/zynqmp/clk.c b/arch/arm/cpu/armv8/zynqmp/clk.c index 0af619d92fde..9147fa749507 100644 --- a/arch/arm/cpu/armv8/zynqmp/clk.c +++ b/arch/arm/cpu/armv8/zynqmp/clk.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/arch/clk.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h>
@@ -16,6 +17,8 @@ unsigned long get_uart_clk(int dev_id) u32 ver = zynqmp_get_silicon_version();
switch (ver) { + case ZYNQMP_CSU_VERSION_VELOCE: + return 96000; case ZYNQMP_CSU_VERSION_EP108: return 25000000; } diff --git a/arch/arm/cpu/armv8/zynqmp/cpu.c b/arch/arm/cpu/armv8/zynqmp/cpu.c index 11958fea6f11..60d7d20e17c8 100644 --- a/arch/arm/cpu/armv8/zynqmp/cpu.c +++ b/arch/arm/cpu/armv8/zynqmp/cpu.c @@ -20,6 +20,8 @@ unsigned int zynqmp_get_silicon_version(void) gd->cpu_clk = get_tbclk();
switch (gd->cpu_clk) { + case 0 ... 1000000: + return ZYNQMP_CSU_VERSION_VELOCE; case 50000000: return ZYNQMP_CSU_VERSION_QEMU; } diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 3df3147fc4c3..188b5c2144af 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -84,6 +84,7 @@ struct apu_regs { /* Board version value */ #define ZYNQMP_CSU_VERSION_SILICON 0x0 #define ZYNQMP_CSU_VERSION_EP108 0x1 +#define ZYNQMP_CSU_VERSION_VELOCE 0x2 #define ZYNQMP_CSU_VERSION_QEMU 0x3
#endif /* _ASM_ARCH_HARDWARE_H */ diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 1325bca5e552..e38948426d70 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -56,14 +56,18 @@ int board_mmc_init(bd_t *bd) { int ret = 0;
+ u32 ver = zynqmp_get_silicon_version(); + + if (ver != ZYNQMP_CSU_VERSION_VELOCE) { #if defined(CONFIG_ZYNQ_SDHCI) # if defined(CONFIG_ZYNQ_SDHCI0) - ret = zynq_sdhci_init(ZYNQ_SDHCI_BASEADDR0); + ret = zynq_sdhci_init(ZYNQ_SDHCI_BASEADDR0); # endif # if defined(CONFIG_ZYNQ_SDHCI1) - ret |= zynq_sdhci_init(ZYNQ_SDHCI_BASEADDR1); + ret |= zynq_sdhci_init(ZYNQ_SDHCI_BASEADDR1); # endif #endif + }
return ret; }
Add support for EMMC bootmode.
arch/arm/include/asm/arch-zynqmp/hardware.h | 3 ++- board/xilinx/zynqmp/zynqmp.c | 1 + 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 188b5c2144af..87792c21a5d0 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -45,7 +45,8 @@ struct iou_scntr {
/* Bootmode setting values */ #define BOOT_MODES_MASK 0x0000000F -#define SD_MODE 0x00000005 +#define SD_MODE 0x00000003 +#define EMMC_MODE 0x00000006 #define JTAG_MODE 0x00000000
#define ZYNQMP_RPU_BASEADDR 0xFF9A0000 diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index e38948426d70..f5ff64d988e5 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -83,6 +83,7 @@ int board_late_init(void)
switch (bootmode) { case SD_MODE: + case EMMC_MODE: setenv("modeboot", "sdboot"); break; default:
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Enable the i2c driver for ZynqMP Also enable the eeprom for read and writes to eeprom on ZynqMP ZynqMP uses the same i2c controller as in Zynq
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/include/asm/arch-zynqmp/hardware.h | 3 +++ include/configs/xilinx_zynqmp.h | 23 +++++++++++++++++++++++ 2 files changed, 26 insertions(+)
diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 87792c21a5d0..1fedb1bb4b94 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -11,6 +11,9 @@ #define ZYNQ_SERIAL_BASEADDR0 0xFF000000 #define ZYNQ_SERIAL_BASEADDR1 0xFF001000
+#define ZYNQ_I2C_BASEADDR0 0xFF020000 +#define ZYNQ_I2C_BASEADDR1 0xFF030000 + #define ZYNQ_SDHCI_BASEADDR0 0xFF160000 #define ZYNQ_SDHCI_BASEADDR1 0xFF170000
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index d0ec3c066f33..54bca6d47b72 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -119,6 +119,29 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_MAXARGS 64
+#define CONFIG_ZYNQ_I2C0 +#define CONFIG_SYS_I2C_ZYNQ + +/* I2C */ +#if defined(CONFIG_SYS_I2C_ZYNQ) +# define CONFIG_CMD_I2C +# define CONFIG_SYS_I2C +# define CONFIG_SYS_I2C_ZYNQ_SPEED 100000 +# define CONFIG_SYS_I2C_ZYNQ_SLAVE 0 +#endif + +#define CONFIG_ZYNQMP_EEPROM + +/* EEPROM */ +#ifdef CONFIG_ZYNQMP_EEPROM +# define CONFIG_CMD_EEPROM +# define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +# define CONFIG_SYS_I2C_EEPROM_ADDR 0x54 +# define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 +# define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 +# define CONFIG_SYS_EEPROM_SIZE (64 * 1024) +#endif + #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */
Added the SPI driver support for ZynqMP The controller is same as zynq SPI controller
arch/arm/include/asm/arch-zynqmp/hardware.h | 3 +++ include/configs/xilinx_zynqmp.h | 8 ++++++++ 2 files changed, 11 insertions(+)
diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 1fedb1bb4b94..c9dc49d78317 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -11,6 +11,9 @@ #define ZYNQ_SERIAL_BASEADDR0 0xFF000000 #define ZYNQ_SERIAL_BASEADDR1 0xFF001000
+#define ZYNQ_SPI_BASEADDR0 0xFF040000 +#define ZYNQ_SPI_BASEADDR1 0xFF050000 + #define ZYNQ_I2C_BASEADDR0 0xFF020000 #define ZYNQ_I2C_BASEADDR1 0xFF030000
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 54bca6d47b72..df7541b85baf 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -71,6 +71,14 @@ #define CONFIG_CMD_ELF #define CONFIG_MP
+/* SPI */ +#ifdef CONFIG_ZYNQ_SPI +# define CONFIG_SPI_FLASH +# define CONFIG_SPI_FLASH_SST +# define CONFIG_CMD_SPI +# define CONFIG_CMD_SF +#endif + #if defined(CONFIG_ZYNQ_SDHCI0) || defined(CONFIG_ZYNQ_SDHCI1) # define CONFIG_MMC # define CONFIG_GENERIC_MMC
CMD_SPI is never been verified I suppose, if so not required at this point of time.
2.3.5
thanks!
It is enabled on 75 platforms that's why I can't see any problem with it. If something is not verified then it should be verified. If it is completely broken it should be removed.
Thanks, Michal
I do understand that it uses more boards based on their usage and need, I believe zynq_spi mostly for flash related ops, if ie the case CMD_SF enough I guess.
thaks!
Hi Jagan,
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Friday, April 17, 2015 2:11 PM To: Michal Simek Cc: u-boot@lists.denx.de; Tom Rini; Siva Durga Prasad Paladugu Subject: Re: [U-Boot] [PATCH 4/6] zynqmp: Add SPI driver support for ZynqMP
We didn’t need it at this point of time and also not verified. Its mostly flash related ops which we use. Will send v2 for the same.
Regards, Siva
thaks!
Jagan.
Provide an option to write filesystem independend commands.
include/configs/xilinx_zynqmp.h | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index df7541b85baf..94b713bc2b19 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -66,6 +66,7 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_FAT +#define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_MEMORY #define CONFIG_DOS_PARTITION #define CONFIG_CMD_ELF @@ -100,8 +101,8 @@ "kernel_addr=0x80000\0" \ "fdt_addr=0x7000000\0" \ "fdt_high=0x10000000\0" \ - "sdboot=mmcinfo && fatload mmc 0:0 $fdt_addr system.dtb && " \ - "fatload mmc 0:0 $kernel_addr Image && booti $kernel_addr - $fdt_addr\0" + "sdboot=mmcinfo && load mmc 0:0 $fdt_addr system.dtb && " \ + "load mmc 0:0 $kernel_addr Image && booti $kernel_addr - $fdt_addr\0"
#define CONFIG_BOOTARGS "setenv bootargs console=ttyPS0,${baudrate} " \ "earlycon=cdns,mmio,0xff000000,${baudrate}n8"
Enable SDHCI0 for zynqmp. Add empty gpio.h because of sdhci requirement.
There will be gpio driver anyway that's why it should be fine to add empty file.
--- arch/arm/include/asm/arch-zynqmp/gpio.h | 12 ++++++++++++ include/configs/xilinx_zynqmp.h | 2 ++ 2 files changed, 14 insertions(+) create mode 100644 arch/arm/include/asm/arch-zynqmp/gpio.h
diff --git a/arch/arm/include/asm/arch-zynqmp/gpio.h b/arch/arm/include/asm/arch-zynqmp/gpio.h new file mode 100644 index 000000000000..098bbde06f30 --- /dev/null +++ b/arch/arm/include/asm/arch-zynqmp/gpio.h @@ -0,0 +1,12 @@ +/* + * Copyright 2015 Xilinx, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ARCH_ZYNQMP_GPIO_H +#define __ARCH_ZYNQMP_GPIO_H + +/* Empty file - sdhci requires this. */ + +#endif diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 94b713bc2b19..6c608abfb9bb 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -61,6 +61,8 @@ #define CONFIG_SYS_BAUDRATE_TABLE \ { 4800, 9600, 19200, 38400, 57600, 115200 }
+#define CONFIG_ZYNQ_SDHCI0 + /* Command line configuration */ #define CONFIG_CMD_ENV #define CONFIG_CMD_EXT2
Jagan Teki
Michal Simek
