[U-Boot] [PATCH 3/4] arm: vf610: add enet1 support
This patch contains several changes required for second Ethernet (enet1/RMII1) port on vf610 - ANADIG PLL5 control definitions required for Ethernet RMII1 clock - Secondary Ethernet (enet1) MAC RMII1 base address definition - RMII1 iomux definitions - VF610_PAD_PTA6__RMII0_CLKOUT iomux definition required for internal (e.g. crystal-less) Ethernet clocking.
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com [stefan@agner.ch: regrouped patch] Signed-off-by: Stefan Agner stefan@agner.ch --- arch/arm/include/asm/arch-vf610/crm_regs.h | 4 ++++ arch/arm/include/asm/arch-vf610/imx-regs.h | 1 + arch/arm/include/asm/arch-vf610/iomux-vf610.h | 10 ++++++++++ 3 files changed, 15 insertions(+)
diff --git a/arch/arm/include/asm/arch-vf610/crm_regs.h b/arch/arm/include/asm/arch-vf610/crm_regs.h index 04cc5bc..e17c7d1 100644 --- a/arch/arm/include/asm/arch-vf610/crm_regs.h +++ b/arch/arm/include/asm/arch-vf610/crm_regs.h @@ -187,6 +187,10 @@ struct anadig_reg { #define CCM_CCGR9_FEC0_CTRL_MASK 0x3 #define CCM_CCGR9_FEC1_CTRL_MASK (0x3 << 2)
+#define ANADIG_PLL5_CTRL_BYPASS (1 << 16) +#define ANADIG_PLL5_CTRL_ENABLE (1 << 13) +#define ANADIG_PLL5_CTRL_POWERDOWN (1 << 12) +#define ANADIG_PLL5_CTRL_DIV_SELECT 1 #define ANADIG_PLL2_CTRL_ENABLE (1 << 13) #define ANADIG_PLL2_CTRL_POWERDOWN (1 << 12) #define ANADIG_PLL2_CTRL_DIV_SELECT 1 diff --git a/arch/arm/include/asm/arch-vf610/imx-regs.h b/arch/arm/include/asm/arch-vf610/imx-regs.h index b8c877f..c2f9761 100644 --- a/arch/arm/include/asm/arch-vf610/imx-regs.h +++ b/arch/arm/include/asm/arch-vf610/imx-regs.h @@ -85,6 +85,7 @@ #define ESDHC0_BASE_ADDR (AIPS1_BASE_ADDR + 0x00031000) #define ESDHC1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00032000) #define ENET_BASE_ADDR (AIPS1_BASE_ADDR + 0x00050000) +#define ENET1_BASE_ADDR (AIPS1_BASE_ADDR + 0x00051000)
/* MUX mode and PAD ctrl are in one register */ #define CONFIG_IOMUX_SHARE_CONF_REG diff --git a/arch/arm/include/asm/arch-vf610/iomux-vf610.h b/arch/arm/include/asm/arch-vf610/iomux-vf610.h index f3c201d..88807d8 100644 --- a/arch/arm/include/asm/arch-vf610/iomux-vf610.h +++ b/arch/arm/include/asm/arch-vf610/iomux-vf610.h @@ -22,6 +22,7 @@
enum { VF610_PAD_PTA6__RMII0_CLKIN = IOMUX_PAD(0x0000, 0x0000, 2, __NA_, 0, VF610_ENET_PAD_CTRL), + VF610_PAD_PTA6__RMII0_CLKOUT = IOMUX_PAD(0x0000, 0x0000, 1, __NA_, 0, VF610_ENET_PAD_CTRL), VF610_PAD_PTB4__UART1_TX = IOMUX_PAD(0x0068, 0x0068, 2, 0x0380, 0, VF610_UART_PAD_CTRL), VF610_PAD_PTB5__UART1_RX = IOMUX_PAD(0x006c, 0x006c, 2, 0x037c, 0, VF610_UART_PAD_CTRL), VF610_PAD_PTB10__UART0_TX = IOMUX_PAD(0x0080, 0x0080, 1, __NA_, 0, VF610_UART_PAD_CTRL), @@ -35,6 +36,15 @@ enum { VF610_PAD_PTC6__RMII0_TD1 = IOMUX_PAD(0x00cc, 0x00cc, 1, __NA_, 0, VF610_ENET_PAD_CTRL), VF610_PAD_PTC7__RMII0_TD0 = IOMUX_PAD(0x00D0, 0x00D0, 1, __NA_, 0, VF610_ENET_PAD_CTRL), VF610_PAD_PTC8__RMII0_TXEN = IOMUX_PAD(0x00D4, 0x00D4, 1, __NA_, 0, VF610_ENET_PAD_CTRL), + VF610_PAD_PTC10__RMII1_MDIO = IOMUX_PAD(0x00dc, 0x00dc, 1, __NA_, 0, VF610_ENET_PAD_CTRL), + VF610_PAD_PTC9__RMII1_MDC = IOMUX_PAD(0x00d8, 0x00d8, 1, __NA_, 0, VF610_ENET_PAD_CTRL), + VF610_PAD_PTC11__RMII1_CRS_DV = IOMUX_PAD(0x00e0, 0x00e0, 1, __NA_, 0, VF610_ENET_PAD_CTRL), + VF610_PAD_PTC12__RMII1_RD1 = IOMUX_PAD(0x00e4, 0x00e4, 1, __NA_, 0, VF610_ENET_PAD_CTRL), + VF610_PAD_PTC13__RMII1_RD0 = IOMUX_PAD(0x00e8, 0x00e8, 1, __NA_, 0, VF610_ENET_PAD_CTRL), + VF610_PAD_PTC14__RMII1_RXER = IOMUX_PAD(0x00ec, 0x00ec, 1, __NA_, 0, VF610_ENET_PAD_CTRL), + VF610_PAD_PTC15__RMII1_TD1 = IOMUX_PAD(0x00f0, 0x00f0, 1, __NA_, 0, VF610_ENET_PAD_CTRL), + VF610_PAD_PTC16__RMII1_TD0 = IOMUX_PAD(0x00f4, 0x00f4, 1, __NA_, 0, VF610_ENET_PAD_CTRL), + VF610_PAD_PTC17__RMII1_TXEN = IOMUX_PAD(0x00f8, 0x00f8, 1, __NA_, 0, VF610_ENET_PAD_CTRL), VF610_PAD_PTA24__ESDHC1_CLK = IOMUX_PAD(0x0038, 0x0038, 5, __NA_, 0, VF610_SDHC_PAD_CTRL), VF610_PAD_PTA25__ESDHC1_CMD = IOMUX_PAD(0x003c, 0x003c, 5, __NA_, 0, VF610_SDHC_PAD_CTRL), VF610_PAD_PTA26__ESDHC1_DAT0 = IOMUX_PAD(0x0040, 0x0040, 5, __NA_, 0, VF610_SDHC_PAD_CTRL),
stefan@agner.ch
