[U-Boot] [PATCH 0/2] Fix minor issues with Serval SoC.
This patch series fix different issues with Serval. - first patch fix resets when DDR training fails. - second patch fix the detection of the board.
This patch series is based on u-boot-mips/next.
Horatiu Vultur (2): mips: mscc: serval: Fix reset board: mscc: serval: Fix board detect
arch/mips/mach-mscc/include/mach/ddr.h | 14 ++++++++++++++ arch/mips/mach-mscc/reset.c | 5 +---- board/mscc/serval/serval.c | 2 +- 3 files changed, 16 insertions(+), 5 deletions(-)
In case the ddr training was failing, it couldn't reset, it was just hanging. Therefore reimplement it, so when ddr training is failing it would call _machine_restart, which power downs the DDR and does a force reset.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- arch/mips/mach-mscc/include/mach/ddr.h | 14 ++++++++++++++ arch/mips/mach-mscc/reset.c | 5 +---- 2 files changed, 15 insertions(+), 4 deletions(-)
diff --git a/arch/mips/mach-mscc/include/mach/ddr.h b/arch/mips/mach-mscc/include/mach/ddr.h index 84ecfbd..97dac3e 100644 --- a/arch/mips/mach-mscc/include/mach/ddr.h +++ b/arch/mips/mach-mscc/include/mach/ddr.h @@ -464,6 +464,19 @@ static inline void hal_vcoreiii_ddr_reset_assert(void) ICPU_RESET_MEM_RST_FORCE, BASE_CFG + ICPU_RESET); }
+#if defined(CONFIG_SOC_SERVAL) +static inline void hal_vcoreiii_ddr_failed(void) +{ + register u32 reset; + + pr_err("DDR training failed\n"); + + /* Jump to reset - does not return */ + reset = KSEG0ADDR(_machine_restart); + icache_lock((void *)reset, 128); // Reset while running from cache + asm volatile ("jr %0" : : "r" (reset)); +} +#else // JR2 || ServalT static inline void hal_vcoreiii_ddr_failed(void) { writel(0, BASE_CFG + ICPU_RESET); @@ -471,6 +484,7 @@ static inline void hal_vcoreiii_ddr_failed(void)
panic("DDR init failed\n"); } +#endif /* Serval */ #endif /* JR2 || ServalT || Serval */
/* diff --git a/arch/mips/mach-mscc/reset.c b/arch/mips/mach-mscc/reset.c index a555fc9..95fe0d8 100644 --- a/arch/mips/mach-mscc/reset.c +++ b/arch/mips/mach-mscc/reset.c @@ -28,16 +28,13 @@ void _machine_restart(void) ICPU_RESET_CORE_RST_FORCE, BASE_CFG + ICPU_RESET); #elif defined(CONFIG_SOC_SERVAL) - register unsigned long i; - /* Prevent VCore-III from being reset with a global reset */ writel(ICPU_RESET_CORE_RST_PROTECT, BASE_CFG + ICPU_RESET);
/* Do global reset */ writel(PERF_SOFT_RST_SOFT_CHIP_RST, BASE_DEVCPU_GCB + PERF_SOFT_RST);
- for (i = 0; i < 1000; i++) - ; + mdelay(100);
/* Power down DDR for clean DDR re-training */ writel(readl(BASE_CFG + ICPU_MEMCTRL_CTRL) |
Am 11.04.19 um 13:51 schrieb Horatiu Vultur:
- register u32 reset;
- pr_err("DDR training failed\n");
- /* Jump to reset - does not return */
- reset = KSEG0ADDR(_machine_restart);
- icache_lock((void *)reset, 128); // Reset while running from cache
- asm volatile ("jr %0" : : "r" (reset));
there is no real difference to the current hal_vcoreiii_ddr_failed() except the GPIO toggling. If that toggling is bad on Serval, couldn't you simply wrap it with #if !defined(CONFIG_SOC_SERVAL)?
- mdelay(100);
I guess Gregory open-coded that because mdelay() can't run in the very restricted environment without stack and BSS. If the delay is too short, maybe you should rather increase the iteration count?
When detecting the board, it was reading a register in the GPIO page of the phy and based on that value it was making a decision. The bug was that after the GPIO page for the first phy was set it was not reseted back.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- board/mscc/serval/serval.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/mscc/serval/serval.c b/board/mscc/serval/serval.c index 52faac9..50444e4 100644 --- a/board/mscc/serval/serval.c +++ b/board/mscc/serval/serval.c @@ -49,10 +49,10 @@ static void do_board_detect(void) gd->board_type = BOARD_TYPE_PCB106; else gd->board_type = BOARD_TYPE_PCB105; - mscc_phy_wr(1, 16, 15, 0); } else { gd->board_type = BOARD_TYPE_PCB105; } + mscc_phy_wr(1, 16, 31, 0x0); }
#if defined(CONFIG_MULTI_DTB_FIT)
Daniel Schwierzeck
Horatiu Vultur
