[U-Boot] [RESPIN PATCH v2 02/11] x86: bios: Synchronize stack between real and protected mode
PCI option rom may use different SS during its execution, so it is not safe to assume esp pointed to the same location in the protected mode.
Signed-off-by: Jian Luo jian.luo4@boschrexroth.de Signed-off-by: Bin Meng bmeng.cn@gmail.com
--- Changes in v2 respin: - Use *protected* mode instead of 'protect mode' - Correct typo of 'read mode'
Changes in v2: - Add comments for the changes in the assembly codes
arch/x86/lib/bios_asm.S | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/arch/x86/lib/bios_asm.S b/arch/x86/lib/bios_asm.S index 4faa70e..9dbf969 100644 --- a/arch/x86/lib/bios_asm.S +++ b/arch/x86/lib/bios_asm.S @@ -246,6 +246,9 @@ __interrupt_handler_16bit = PTR_TO_REAL_MODE(.) push %fs push %gs
+ /* Save real mode SS */ + movw %ss, %cs:__realmode_ss + /* Clear DF to not break ABI assumptions */ cld
@@ -258,12 +261,29 @@ __interrupt_handler_16bit = PTR_TO_REAL_MODE(.)
enter_protected_mode
+ /* + * Now we are in protected mode. We need compute the right ESP based + * on saved real mode SS otherwise interrupt_handler() won't get + * correct parameters from the stack. + */ + movzwl %cs:__realmode_ss, %ecx + shll $4, %ecx + addl %ecx, %esp + /* Call the C interrupt handler */ movl $interrupt_handler, %eax call *%eax
+ /* Restore real mode ESP based on saved SS */ + movzwl %cs:__realmode_ss, %ecx + shll $4, %ecx + subl %ecx, %esp + enter_real_mode
+ /* Restore real mode SS */ + movw %cs:__realmode_ss, %ss + /* * Restore all registers, including those manipulated by the C * handler @@ -276,6 +296,9 @@ __interrupt_handler_16bit = PTR_TO_REAL_MODE(.) popal iret
+__realmode_ss = PTR_TO_REAL_MODE(.) + .word 0 + .globl asm_realmode_code_size asm_realmode_code_size: .long . - asm_realmode_code
Changes in v2:
Bin Meng
