[U-Boot] [PATCH v2 1/4] usb: ohci: Do not reuse ed for interrupt endpoints of different devices
When submitting interrupt packets to an endpoint we only link in the ed once to avoid some races surrounding unlinking of periodic endpoints, but we share one ohci_device struct / one set of ed-s for all devices, which means that if we have an interrupt endpoint at endpoint 1 with one device, and a non interrupt endpoint 1 with another device we end up with the same ed linked into both the periodic and async lists, which is not good (tm).
This commit switches over to using separate ohci_device structs, and thus separate ed-s for devices with interrupt endpoints, fixing this.
This fixes e.g. matching a usb storage device and keyboard on the same usb-1 hub not working.
Signed-off-by: Hans de Goede hdegoede@redhat.com Reviewed-by: Marek Vasut marex@denx.de --- drivers/usb/host/ohci-hcd.c | 35 ++++++++++++++++++++++++++++++++++- drivers/usb/host/ohci.h | 4 ++++ 2 files changed, 38 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c index 2f976d2..5364ced 100644 --- a/drivers/usb/host/ohci-hcd.c +++ b/drivers/usb/host/ohci-hcd.c @@ -1478,6 +1478,31 @@ pkt_print(ohci, NULL, dev, pipe, buffer, transfer_len,
+static ohci_dev_t *ohci_get_ohci_dev(ohci_t *ohci, int devnum, int intr) +{ + int i; + + if (!intr) + return &ohci->ohci_dev; + + /* First see if we already have an ohci_dev for this dev. */ + for (i = 0; i < NUM_INT_DEVS; i++) { + if (ohci->int_dev[i].devnum == devnum) + return &ohci->int_dev[i]; + } + + /* If not then find a free one. */ + for (i = 0; i < NUM_INT_DEVS; i++) { + if (ohci->int_dev[i].devnum == -1) { + ohci->int_dev[i].devnum = devnum; + return &ohci->int_dev[i]; + } + } + + printf("ohci: Error out of ohci_devs for interrupt endpoints\n"); + return NULL; +} + /* common code for handling submit messages - used for all but root hub */ /* accesses. */ static int submit_common_msg(ohci_t *ohci, struct usb_device *dev, @@ -1488,6 +1513,7 @@ static int submit_common_msg(ohci_t *ohci, struct usb_device *dev, int maxsize = usb_maxpacket(dev, pipe); int timeout; urb_priv_t *urb; + ohci_dev_t *ohci_dev;
urb = malloc(sizeof(urb_priv_t)); memset(urb, 0, sizeof(urb_priv_t)); @@ -1511,7 +1537,11 @@ static int submit_common_msg(ohci_t *ohci, struct usb_device *dev, return -1; }
- if (sohci_submit_job(ohci, &ohci->ohci_dev, urb, setup) < 0) { + ohci_dev = ohci_get_ohci_dev(ohci, dev->devnum, usb_pipeint(pipe)); + if (!ohci_dev) + return -ENOMEM; + + if (sohci_submit_job(ohci, ohci_dev, urb, setup) < 0) { err("sohci_submit_job failed"); return -1; } @@ -1711,8 +1741,11 @@ static int hc_start(ohci_t *ohci) { __u32 mask; unsigned int fminterval; + int i;
ohci->disabled = 1; + for (i = 0; i < NUM_INT_DEVS; i++) + ohci->int_dev[i].devnum = -1;
/* Tell the controller where the control and bulk lists are * The lists are empty now. */ diff --git a/drivers/usb/host/ohci.h b/drivers/usb/host/ohci.h index 3f9869b..f1526d4 100644 --- a/drivers/usb/host/ohci.h +++ b/drivers/usb/host/ohci.h @@ -367,10 +367,13 @@ typedef struct
#define NUM_TD 64 /* we need more TDs than EDs */
+#define NUM_INT_DEVS 8 /* num of ohci_dev structs for int endpoints */ + typedef struct ohci_device { ed_t ed[NUM_EDS] __aligned(ED_ALIGNMENT); td_t tds[NUM_TD] __aligned(TD_ALIGNMENT); int ed_cnt; + int devnum; } ohci_dev_t;
/* @@ -384,6 +387,7 @@ typedef struct ohci_device { typedef struct ohci { /* this allocates EDs for all possible endpoints */ struct ohci_device ohci_dev __aligned(TD_ALIGNMENT); + struct ohci_device int_dev[NUM_INT_DEVS] __aligned(TD_ALIGNMENT); struct ohci_hcca *hcca; /* hcca */ /*dma_addr_t hcca_dma;*/
Add an ohci_alloc_urb() function, this is a preparation patch for adding interrupt queue support.
Signed-off-by: Hans de Goede hdegoede@redhat.com Reviewed-by: Marek Vasut marex@denx.de --- drivers/usb/host/ohci-hcd.c | 31 +++++++++++++++++++++++-------- 1 file changed, 23 insertions(+), 8 deletions(-)
diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c index 5364ced..17f3ac6 100644 --- a/drivers/usb/host/ohci-hcd.c +++ b/drivers/usb/host/ohci-hcd.c @@ -1505,6 +1505,26 @@ static ohci_dev_t *ohci_get_ohci_dev(ohci_t *ohci, int devnum, int intr)
/* common code for handling submit messages - used for all but root hub */ /* accesses. */ +static urb_priv_t *ohci_alloc_urb(struct usb_device *dev, unsigned long pipe, + void *buffer, int transfer_len, int interval) +{ + urb_priv_t *urb; + + urb = calloc(1, sizeof(urb_priv_t)); + if (!urb) { + printf("ohci: Error out of memory allocating urb\n"); + return NULL; + } + + urb->dev = dev; + urb->pipe = pipe; + urb->transfer_buffer = buffer; + urb->transfer_buffer_length = transfer_len; + urb->interval = interval; + + return urb; +} + static int submit_common_msg(ohci_t *ohci, struct usb_device *dev, unsigned long pipe, void *buffer, int transfer_len, struct devrequest *setup, int interval) @@ -1515,14 +1535,9 @@ static int submit_common_msg(ohci_t *ohci, struct usb_device *dev, urb_priv_t *urb; ohci_dev_t *ohci_dev;
- urb = malloc(sizeof(urb_priv_t)); - memset(urb, 0, sizeof(urb_priv_t)); - - urb->dev = dev; - urb->pipe = pipe; - urb->transfer_buffer = buffer; - urb->transfer_buffer_length = transfer_len; - urb->interval = interval; + urb = ohci_alloc_urb(dev, pipe, buffer, transfer_len, interval); + if (!urb) + return -ENOMEM;
#ifdef DEBUG urb->actual_length = 0;
Applied to u-boot-dm, thanks!
Add support for interrupt queues to the ohci hcd code, bringing it inline with the ehci and musb-new(host) code.
Signed-off-by: Hans de Goede hdegoede@redhat.com Reviewed-by: Marek Vasut marex@denx.de --- Changes in v2: -Fix building of non DM_USB configs --- drivers/usb/host/ohci-hcd.c | 132 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 132 insertions(+)
diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c index 17f3ac6..691ed1c 100644 --- a/drivers/usb/host/ohci-hcd.c +++ b/drivers/usb/host/ohci-hcd.c @@ -1622,6 +1622,91 @@ static int submit_common_msg(ohci_t *ohci, struct usb_device *dev, return 0; }
+#define MAX_INT_QUEUESIZE 8 + +struct int_queue { + int queuesize; + int curr_urb; + urb_priv_t *urb[MAX_INT_QUEUESIZE]; +}; + +static struct int_queue *_ohci_create_int_queue(ohci_t *ohci, + struct usb_device *udev, unsigned long pipe, int queuesize, + int elementsize, void *buffer, int interval) +{ + struct int_queue *queue; + ohci_dev_t *ohci_dev; + int i; + + if (queuesize > MAX_INT_QUEUESIZE) + return NULL; + + ohci_dev = ohci_get_ohci_dev(ohci, udev->devnum, 1); + if (!ohci_dev) + return NULL; + + queue = malloc(sizeof(*queue)); + if (!queue) { + printf("ohci: Error out of memory allocating int queue\n"); + return NULL; + } + + for (i = 0; i < queuesize; i++) { + queue->urb[i] = ohci_alloc_urb(udev, pipe, + buffer + i * elementsize, + elementsize, interval); + if (!queue->urb[i]) + break; + + if (sohci_submit_job(ohci, ohci_dev, queue->urb[i], NULL)) { + printf("ohci: Error submitting int queue job\n"); + urb_free_priv(queue->urb[i]); + break; + } + } + if (i == 0) { + /* We did not succeed in submitting even 1 urb */ + free(queue); + return NULL; + } + + queue->queuesize = i; + queue->curr_urb = 0; + + return queue; +} + +static void *_ohci_poll_int_queue(ohci_t *ohci, struct usb_device *udev, + struct int_queue *queue) +{ + if (queue->curr_urb == queue->queuesize) + return NULL; /* Queue depleted */ + + if (hc_interrupt(ohci) < 0) + return NULL; + + if (queue->urb[queue->curr_urb]->finished) { + void *ret = queue->urb[queue->curr_urb]->transfer_buffer; + queue->curr_urb++; + return ret; + } + + return NULL; +} + +static int _ohci_destroy_int_queue(ohci_t *ohci, struct usb_device *dev, + struct int_queue *queue) +{ + int i; + + for (i = 0; i < queue->queuesize; i++) + urb_free_priv(queue->urb[i]); + + free(queue); + + return 0; +} + #ifndef CONFIG_DM_USB /* submit routines called from usb.c */ int submit_bulk_msg(struct usb_device *dev, unsigned long pipe, void *buffer, @@ -1639,6 +1724,24 @@ int submit_int_msg(struct usb_device *dev, unsigned long pipe, void *buffer, return submit_common_msg(&gohci, dev, pipe, buffer, transfer_len, NULL, interval); } + +struct int_queue *create_int_queue(struct usb_device *dev, + unsigned long pipe, int queuesize, int elementsize, + void *buffer, int interval) +{ + return _ohci_create_int_queue(&gohci, dev, pipe, queuesize, + elementsize, buffer, interval); +} + +void *poll_int_queue(struct usb_device *dev, struct int_queue *queue) +{ + return _ohci_poll_int_queue(&gohci, dev, queue); +} + +int destroy_int_queue(struct usb_device *dev, struct int_queue *queue) +{ + return _ohci_destroy_int_queue(&gohci, dev, queue); +} #endif
static int _ohci_submit_control_msg(ohci_t *ohci, struct usb_device *dev, @@ -2072,6 +2175,32 @@ static int ohci_submit_int_msg(struct udevice *dev, struct usb_device *udev, NULL, interval); }
+static struct int_queue *ohci_create_int_queue(struct udevice *dev, + struct usb_device *udev, unsigned long pipe, int queuesize, + int elementsize, void *buffer, int interval) +{ + ohci_t *ohci = dev_get_priv(usb_get_bus(dev)); + + return _ohci_create_int_queue(ohci, udev, pipe, queuesize, elementsize, + buffer, interval); +} + +static void *ohci_poll_int_queue(struct udevice *dev, struct usb_device *udev, + struct int_queue *queue) +{ + ohci_t *ohci = dev_get_priv(usb_get_bus(dev)); + + return _ohci_poll_int_queue(ohci, udev, queue); +} + +static int ohci_destroy_int_queue(struct udevice *dev, struct usb_device *udev, + struct int_queue *queue) +{ + ohci_t *ohci = dev_get_priv(usb_get_bus(dev)); + + return _ohci_destroy_int_queue(ohci, udev, queue); +} + int ohci_register(struct udevice *dev, struct ohci_regs *regs) { struct usb_bus_priv *priv = dev_get_uclass_priv(dev); @@ -2114,6 +2243,9 @@ struct dm_usb_ops ohci_usb_ops = { .control = ohci_submit_control_msg, .bulk = ohci_submit_bulk_msg, .interrupt = ohci_submit_int_msg, + .create_int_queue = ohci_create_int_queue, + .poll_int_queue = ohci_poll_int_queue, + .destroy_int_queue = ohci_destroy_int_queue, };
#endif
Changes in v2:
Now that the ohci code supports usb interrupt queues we can switch (back) to using an usb interrupt queue for usb-kbd interrupt polling. This greatly reduces u-boot's latency when dealing with usb keyboards.
Signed-off-by: Hans de Goede hdegoede@redhat.com Acked-by: Ian Campbell ijc@hellion.org.uk Reviewed-by: Marek Vasut marex@denx.de --- Changes in v2: -Fix a bunch of typos in the commit msg --- include/configs/sunxi-common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 222e739..2d6b815 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -317,7 +317,7 @@ extern int soft_i2c_gpio_scl; #define CONFIG_CONSOLE_MUX #define CONFIG_PREBOOT #define CONFIG_SYS_STDIO_DEREGISTER -#define CONFIG_SYS_USB_EVENT_POLL +#define CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE #endif
#if !defined CONFIG_ENV_IS_IN_MMC && \
Changes in v2:
Hans de Goede
