[U-Boot] [PATCH] pico-imx6ul: Add DWARF baseboard support
This add the boot menu option for the DWARF baseboard as well as a specific config file for users which wish to use it as a pre-defined board.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br ---
configs/pico-dwarf-imx6ul_defconfig | 64 +++++++++++++++++++++++++++++ include/configs/pico-imx6ul.h | 6 ++- 2 files changed, 68 insertions(+), 2 deletions(-) create mode 100644 configs/pico-dwarf-imx6ul_defconfig
diff --git a/configs/pico-dwarf-imx6ul_defconfig b/configs/pico-dwarf-imx6ul_defconfig new file mode 100644 index 0000000000..e7af415abd --- /dev/null +++ b/configs/pico-dwarf-imx6ul_defconfig @@ -0,0 +1,64 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_PICO_IMX6UL=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" +CONFIG_BOOTDELAY=3 +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" +CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-dwarf.dtb" +CONFIG_BOUNCE_BUFFER=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_USB_HOST_SUPPORT=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_CMD_BOOTMENU=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DFU=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ul-pico-pi" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_DFU_MMC=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_USB=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 050f69801b..f0dadc4b1e 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -64,9 +64,11 @@ "rootfs part 0 1\0" \
#define BOOTMENU_ENV \ - "bootmenu_0=Boot using PICO-Hobbit baseboard=" \ + "bootmenu_0=Boot using PICO-Dwarf baseboard=" \ + "setenv fdtfile imx6ul-pico-dwarf.dtb\0" \ + "bootmenu_1=Boot using PICO-Hobbit baseboard=" \ "setenv fdtfile imx6ul-pico-hobbit.dtb\0" \ - "bootmenu_1=Boot using PICO-Pi baseboard=" \ + "bootmenu_2=Boot using PICO-Pi baseboard=" \ "setenv fdtfile imx6ul-pico-pi.dtb\0" \
#define CONFIG_SYS_MMC_IMG_LOAD_PART 1
Hi Otavio,
An entry for the board in MAINTAINERS (./board/technexion/pico-imx6ul/MAINTAINERS) is missing. Can you add it, please ?
Best regards, Stefano
- "bootmenu_0=Boot using PICO-Dwarf baseboard=" \
- "bootmenu_1=Boot using PICO-Hobbit baseboard=" \ "setenv fdtfile imx6ul-pico-hobbit.dtb\0" \
- "bootmenu_2=Boot using PICO-Pi baseboard=" \ "setenv fdtfile imx6ul-pico-pi.dtb\0" \
Otavio Salvador
Stefano Babic
