[U-Boot] [PATCH V2] I2C: S3C24X0: Resolve build error for VCMA9
This patch resolves the following build errors for I2C driver in VCMA9:
In file included from s3c24x0_i2c.c:40:0: s3c24x0_i2c.h:38:17: error: field 'id' has incomplete type s3c24x0_i2c.c:70:39: error: 'CONFIG_MAX_I2C_NUM' undeclared here (not in a function) s3c24x0_i2c.c:70:31: warning: 'i2c_bus' defined but not used [-Wunused-variable] s3c24x0_i2c.c:72:12: warning: 'i2c_busses' defined but not used [-Wunused-variable]
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes since V1: - Changes the commit message to add the errors. - changed enum periph_id to int drivers/i2c/s3c24x0_i2c.c | 4 +++- drivers/i2c/s3c24x0_i2c.h | 3 +-- 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index 7ec01ec..769a2ba 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -67,9 +67,11 @@ * variables to live in SRAM */ static unsigned int g_current_bus __attribute__((section(".data"))); +#ifdef CONFIG_OF_CONTROL +static int i2c_busses __attribute__((section(".data"))); static struct s3c24x0_i2c_bus i2c_bus[CONFIG_MAX_I2C_NUM] __attribute__((section(".data"))); -static int i2c_busses __attribute__((section(".data"))); +#endif
#if !(defined CONFIG_EXYNOS4 || defined CONFIG_EXYNOS5) static int GetI2CSDA(void) diff --git a/drivers/i2c/s3c24x0_i2c.h b/drivers/i2c/s3c24x0_i2c.h index 1243bf1..a56d749 100644 --- a/drivers/i2c/s3c24x0_i2c.h +++ b/drivers/i2c/s3c24x0_i2c.h @@ -35,7 +35,6 @@ struct s3c24x0_i2c_bus { int node; /* device tree node */ int bus_num; /* i2c bus number */ struct s3c24x0_i2c *regs; - enum periph_id id; + int id; }; - #endif /* _S3C24X0_I2C_H */
Hello Rajeshwari,
Which U-Boot do you use? I just tried current head of mainline:
[hs@pollux u-boot]$ git log commit fd70aa41468be4324275910f85578cb5be6a0439 Author: angelo sysamfw@gmail.com Date: Fri Nov 23 12:23:39 2012 +0000
m68k/lib: fix serial driver relocation
Fix coldfire serial driver bindings no more relocated to ram after last changes to drivers/serial/serial.c (regression). Serial initialization in ram has to be called after that gd->reloc_off is calculated.
Signed-off-by: Angelo Dureghello sysamfw@gmail.com Cc: Jason Jin jason.jin@freescale.com Acked-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de Tested-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de
and it compiles clean with eldk-5.2:
[hs@pollux u-boot]$ ./MAKEALL VCMA9 Configuring for VCMA9 board... text data bss dec hex filename 523055 15112 296056 834223 cbaaf ./u-boot
--------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- [hs@pollux u-boot]$
bye, Heiko
Hi Heiko,
I built it on latest tree u-boot-samsung. For VCMA9_config I got the the errors.
Regards, Rajeshwari Shinde.
Changes since V1:
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Heiko Schocher
Minkyu Kang
Rajeshwari Birje
Rajeshwari Shinde
