[PATCH] misc: Port USB251xB/xBi Hi-Speed Hub Controller Driver from Linux
This patch adds a driver for configuration of the Microchip USB251xB/xBi USB 2.0 hub controller series with USB 2.0 upstream connectivity, SMBus configuration interface and two to four USB 2.0 downstream ports.
This is ported from Linux as of Linux kernel commit 5c2b9c61ae5d8 ("usb: usb251xb: add boost-up property support")
Signed-off-by: Marek Vasut marex@denx.de Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Simon Glass sjg@chromium.org --- drivers/misc/Kconfig | 9 + drivers/misc/Makefile | 1 + drivers/misc/usb251xb.c | 605 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 615 insertions(+) create mode 100644 drivers/misc/usb251xb.c
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 7029bb7b5c5..48c968316ad 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -360,6 +360,15 @@ config TEST_DRV model. This should only be enabled for testing as it is not useful for anything else.
+config USB_HUB_USB251XB + tristate "USB251XB Hub Controller Configuration Driver" + depends on I2C + help + This option enables support for configuration via SMBus of the + Microchip USB251x/xBi USB 2.0 Hub Controller series. Configuration + parameters may be set in devicetree or platform data. + Say Y or M here if you need to configure such a device via SMBus. + config TWL4030_LED bool "Enable TWL4030 LED controller" help diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index f22eff601a1..9f25160d29b 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -20,6 +20,7 @@ endif ifdef CONFIG_$(SPL_)DM_I2C ifndef CONFIG_SPL_BUILD obj-$(CONFIG_SANDBOX) += i2c_eeprom_emul.o +obj-$(CONFIG_USB_HUB_USB251XB) += usb251xb.o endif endif ifdef CONFIG_SPL_OF_PLATDATA diff --git a/drivers/misc/usb251xb.c b/drivers/misc/usb251xb.c new file mode 100644 index 00000000000..077edc25045 --- /dev/null +++ b/drivers/misc/usb251xb.c @@ -0,0 +1,605 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Driver for Microchip USB251xB USB 2.0 Hi-Speed Hub Controller + * Configuration via SMBus. + * + * Copyright (c) 2017 SKIDATA AG + * + * This work is based on the USB3503 driver by Dongjin Kim and + * a not-accepted patch by Fabien Lahoudere, see: + * https://patchwork.kernel.org/patch/9257715/ + */ + +#include <common.h> +#include <asm/gpio.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <errno.h> +#include <i2c.h> +#include <linux/delay.h> +#include <linux/utf.h> +#include <power/regulator.h> + +/* Internal Register Set Addresses & Default Values acc. to DS00001692C */ +#define USB251XB_ADDR_VENDOR_ID_LSB 0x00 +#define USB251XB_ADDR_VENDOR_ID_MSB 0x01 +#define USB251XB_DEF_VENDOR_ID 0x0424 + +#define USB251XB_ADDR_PRODUCT_ID_LSB 0x02 +#define USB251XB_ADDR_PRODUCT_ID_MSB 0x03 + +#define USB251XB_ADDR_DEVICE_ID_LSB 0x04 +#define USB251XB_ADDR_DEVICE_ID_MSB 0x05 +#define USB251XB_DEF_DEVICE_ID 0x0BB3 + +#define USB251XB_ADDR_CONFIG_DATA_1 0x06 +#define USB251XB_DEF_CONFIG_DATA_1 0x9B +#define USB251XB_ADDR_CONFIG_DATA_2 0x07 +#define USB251XB_DEF_CONFIG_DATA_2 0x20 +#define USB251XB_ADDR_CONFIG_DATA_3 0x08 +#define USB251XB_DEF_CONFIG_DATA_3 0x02 + +#define USB251XB_ADDR_NON_REMOVABLE_DEVICES 0x09 +#define USB251XB_DEF_NON_REMOVABLE_DEVICES 0x00 + +#define USB251XB_ADDR_PORT_DISABLE_SELF 0x0A +#define USB251XB_DEF_PORT_DISABLE_SELF 0x00 +#define USB251XB_ADDR_PORT_DISABLE_BUS 0x0B +#define USB251XB_DEF_PORT_DISABLE_BUS 0x00 + +#define USB251XB_ADDR_MAX_POWER_SELF 0x0C +#define USB251XB_DEF_MAX_POWER_SELF 0x01 +#define USB251XB_ADDR_MAX_POWER_BUS 0x0D +#define USB251XB_DEF_MAX_POWER_BUS 0x32 + +#define USB251XB_ADDR_MAX_CURRENT_SELF 0x0E +#define USB251XB_DEF_MAX_CURRENT_SELF 0x01 +#define USB251XB_ADDR_MAX_CURRENT_BUS 0x0F +#define USB251XB_DEF_MAX_CURRENT_BUS 0x32 + +#define USB251XB_ADDR_POWER_ON_TIME 0x10 +#define USB251XB_DEF_POWER_ON_TIME 0x32 + +#define USB251XB_ADDR_LANGUAGE_ID_HIGH 0x11 +#define USB251XB_ADDR_LANGUAGE_ID_LOW 0x12 +#define USB251XB_DEF_LANGUAGE_ID 0x0000 + +#define USB251XB_STRING_BUFSIZE 62 +#define USB251XB_ADDR_MANUFACTURER_STRING_LEN 0x13 +#define USB251XB_ADDR_MANUFACTURER_STRING 0x16 +#define USB251XB_DEF_MANUFACTURER_STRING "Microchip" + +#define USB251XB_ADDR_PRODUCT_STRING_LEN 0x14 +#define USB251XB_ADDR_PRODUCT_STRING 0x54 + +#define USB251XB_ADDR_SERIAL_STRING_LEN 0x15 +#define USB251XB_ADDR_SERIAL_STRING 0x92 +#define USB251XB_DEF_SERIAL_STRING "" + +#define USB251XB_ADDR_BATTERY_CHARGING_ENABLE 0xD0 +#define USB251XB_DEF_BATTERY_CHARGING_ENABLE 0x00 + +#define USB251XB_ADDR_BOOST_UP 0xF6 +#define USB251XB_DEF_BOOST_UP 0x00 +#define USB251XB_ADDR_BOOST_57 0xF7 +#define USB251XB_DEF_BOOST_57 0x00 +#define USB251XB_ADDR_BOOST_14 0xF8 +#define USB251XB_DEF_BOOST_14 0x00 + +#define USB251XB_ADDR_PORT_SWAP 0xFA +#define USB251XB_DEF_PORT_SWAP 0x00 + +#define USB251XB_ADDR_PORT_MAP_12 0xFB +#define USB251XB_DEF_PORT_MAP_12 0x00 +#define USB251XB_ADDR_PORT_MAP_34 0xFC +#define USB251XB_DEF_PORT_MAP_34 0x00 /* USB251{3B/i,4B/i,7/i} only */ +#define USB251XB_ADDR_PORT_MAP_56 0xFD +#define USB251XB_DEF_PORT_MAP_56 0x00 /* USB2517/i only */ +#define USB251XB_ADDR_PORT_MAP_7 0xFE +#define USB251XB_DEF_PORT_MAP_7 0x00 /* USB2517/i only */ + +#define USB251XB_ADDR_STATUS_COMMAND 0xFF +#define USB251XB_STATUS_COMMAND_SMBUS_DOWN 0x04 +#define USB251XB_STATUS_COMMAND_RESET 0x02 +#define USB251XB_STATUS_COMMAND_ATTACH 0x01 + +#define USB251XB_I2C_REG_SZ 0x100 +#define USB251XB_I2C_WRITE_SZ 0x10 + +#define DRIVER_NAME "usb251xb" +#define DRIVER_DESC "Microchip USB 2.0 Hi-Speed Hub Controller" + +struct usb251xb { + struct device *dev; + struct i2c_client *i2c; + struct udevice *vdd; + u8 skip_config; + struct gpio_desc gpio_reset; + u32 vendor_id; + u32 product_id; + u32 device_id; + u8 conf_data1; + u8 conf_data2; + u8 conf_data3; + u8 non_rem_dev; + u8 port_disable_sp; + u8 port_disable_bp; + u8 max_power_sp; + u8 max_power_bp; + u8 max_current_sp; + u8 max_current_bp; + u8 power_on_time; + u32 lang_id; + u8 manufacturer_len; + u8 product_len; + u8 serial_len; + s16 manufacturer[USB251XB_STRING_BUFSIZE]; + s16 product[USB251XB_STRING_BUFSIZE]; + s16 serial[USB251XB_STRING_BUFSIZE]; + u8 bat_charge_en; + u32 boost_up; + u8 boost_57; + u8 boost_14; + u8 port_swap; + u8 port_map12; + u8 port_map34; + u8 port_map56; + u8 port_map7; + u8 status; +}; + +struct usb251xb_data { + u16 product_id; + u8 port_cnt; + bool led_support; + bool bat_support; + char product_str[USB251XB_STRING_BUFSIZE / 2]; /* ASCII string */ +}; + +static const struct usb251xb_data usb2422_data = { + .product_id = 0x2422, + .port_cnt = 2, + .led_support = false, + .bat_support = true, + .product_str = "USB2422", +}; + +static const struct usb251xb_data usb2512b_data = { + .product_id = 0x2512, + .port_cnt = 2, + .led_support = false, + .bat_support = true, + .product_str = "USB2512B", +}; + +static const struct usb251xb_data usb2512bi_data = { + .product_id = 0x2512, + .port_cnt = 2, + .led_support = false, + .bat_support = true, + .product_str = "USB2512Bi", +}; + +static const struct usb251xb_data usb2513b_data = { + .product_id = 0x2513, + .port_cnt = 3, + .led_support = false, + .bat_support = true, + .product_str = "USB2513B", +}; + +static const struct usb251xb_data usb2513bi_data = { + .product_id = 0x2513, + .port_cnt = 3, + .led_support = false, + .bat_support = true, + .product_str = "USB2513Bi", +}; + +static const struct usb251xb_data usb2514b_data = { + .product_id = 0x2514, + .port_cnt = 4, + .led_support = false, + .bat_support = true, + .product_str = "USB2514B", +}; + +static const struct usb251xb_data usb2514bi_data = { + .product_id = 0x2514, + .port_cnt = 4, + .led_support = false, + .bat_support = true, + .product_str = "USB2514Bi", +}; + +static const struct usb251xb_data usb2517_data = { + .product_id = 0x2517, + .port_cnt = 7, + .led_support = true, + .bat_support = false, + .product_str = "USB2517", +}; + +static const struct usb251xb_data usb2517i_data = { + .product_id = 0x2517, + .port_cnt = 7, + .led_support = true, + .bat_support = false, + .product_str = "USB2517i", +}; + +static void usb251xb_reset(struct usb251xb *hub) +{ + dm_gpio_set_value(&hub->gpio_reset, 1); + udelay(10); /* >=1us RESET_N asserted */ + dm_gpio_set_value(&hub->gpio_reset, 0); + + /* wait for hub recovery/stabilization */ + udelay(750); /* >=500us after RESET_N deasserted */ +} + +static int usb251xb_connect(struct udevice *dev) +{ + struct usb251xb *hub = dev_get_priv(dev); + char i2c_wb[USB251XB_I2C_REG_SZ]; + int err, i; + + memset(i2c_wb, 0, USB251XB_I2C_REG_SZ); + + if (hub->skip_config) { + dev_info(dev, "Skip hub configuration, only attach.\n"); + i2c_wb[0] = 0x01; + i2c_wb[1] = USB251XB_STATUS_COMMAND_ATTACH; + + usb251xb_reset(hub); + + err = dm_i2c_write(dev, USB251XB_ADDR_STATUS_COMMAND, i2c_wb, 2); + if (err) { + dev_err(dev, "attaching hub failed: %d\n", err); + return err; + } + return 0; + } + + i2c_wb[USB251XB_ADDR_VENDOR_ID_MSB] = (hub->vendor_id >> 8) & 0xFF; + i2c_wb[USB251XB_ADDR_VENDOR_ID_LSB] = hub->vendor_id & 0xFF; + i2c_wb[USB251XB_ADDR_PRODUCT_ID_MSB] = (hub->product_id >> 8) & 0xFF; + i2c_wb[USB251XB_ADDR_PRODUCT_ID_LSB] = hub->product_id & 0xFF; + i2c_wb[USB251XB_ADDR_DEVICE_ID_MSB] = (hub->device_id >> 8) & 0xFF; + i2c_wb[USB251XB_ADDR_DEVICE_ID_LSB] = hub->device_id & 0xFF; + i2c_wb[USB251XB_ADDR_CONFIG_DATA_1] = hub->conf_data1; + i2c_wb[USB251XB_ADDR_CONFIG_DATA_2] = hub->conf_data2; + i2c_wb[USB251XB_ADDR_CONFIG_DATA_3] = hub->conf_data3; + i2c_wb[USB251XB_ADDR_NON_REMOVABLE_DEVICES] = hub->non_rem_dev; + i2c_wb[USB251XB_ADDR_PORT_DISABLE_SELF] = hub->port_disable_sp; + i2c_wb[USB251XB_ADDR_PORT_DISABLE_BUS] = hub->port_disable_bp; + i2c_wb[USB251XB_ADDR_MAX_POWER_SELF] = hub->max_power_sp; + i2c_wb[USB251XB_ADDR_MAX_POWER_BUS] = hub->max_power_bp; + i2c_wb[USB251XB_ADDR_MAX_CURRENT_SELF] = hub->max_current_sp; + i2c_wb[USB251XB_ADDR_MAX_CURRENT_BUS] = hub->max_current_bp; + i2c_wb[USB251XB_ADDR_POWER_ON_TIME] = hub->power_on_time; + i2c_wb[USB251XB_ADDR_LANGUAGE_ID_HIGH] = (hub->lang_id >> 8) & 0xFF; + i2c_wb[USB251XB_ADDR_LANGUAGE_ID_LOW] = hub->lang_id & 0xFF; + i2c_wb[USB251XB_ADDR_MANUFACTURER_STRING_LEN] = hub->manufacturer_len; + i2c_wb[USB251XB_ADDR_PRODUCT_STRING_LEN] = hub->product_len; + i2c_wb[USB251XB_ADDR_SERIAL_STRING_LEN] = hub->serial_len; + memcpy(&i2c_wb[USB251XB_ADDR_MANUFACTURER_STRING], hub->manufacturer, + USB251XB_STRING_BUFSIZE); + memcpy(&i2c_wb[USB251XB_ADDR_SERIAL_STRING], hub->serial, + USB251XB_STRING_BUFSIZE); + memcpy(&i2c_wb[USB251XB_ADDR_PRODUCT_STRING], hub->product, + USB251XB_STRING_BUFSIZE); + i2c_wb[USB251XB_ADDR_BATTERY_CHARGING_ENABLE] = hub->bat_charge_en; + i2c_wb[USB251XB_ADDR_BOOST_UP] = hub->boost_up; + i2c_wb[USB251XB_ADDR_BOOST_57] = hub->boost_57; + i2c_wb[USB251XB_ADDR_BOOST_14] = hub->boost_14; + i2c_wb[USB251XB_ADDR_PORT_SWAP] = hub->port_swap; + i2c_wb[USB251XB_ADDR_PORT_MAP_12] = hub->port_map12; + i2c_wb[USB251XB_ADDR_PORT_MAP_34] = hub->port_map34; + i2c_wb[USB251XB_ADDR_PORT_MAP_56] = hub->port_map56; + i2c_wb[USB251XB_ADDR_PORT_MAP_7] = hub->port_map7; + i2c_wb[USB251XB_ADDR_STATUS_COMMAND] = USB251XB_STATUS_COMMAND_ATTACH; + + usb251xb_reset(hub); + + /* write registers */ + for (i = 0; i < (USB251XB_I2C_REG_SZ / USB251XB_I2C_WRITE_SZ); i++) { + int offset = i * USB251XB_I2C_WRITE_SZ; + char wbuf[USB251XB_I2C_WRITE_SZ + 1]; + + /* The first data byte transferred tells the hub how many data + * bytes will follow (byte count). + */ + wbuf[0] = USB251XB_I2C_WRITE_SZ; + memcpy(&wbuf[1], &i2c_wb[offset], USB251XB_I2C_WRITE_SZ); + + dev_dbg(dev, "writing %d byte block %d to 0x%02X\n", + USB251XB_I2C_WRITE_SZ, i, offset); + + err = dm_i2c_write(dev, offset, wbuf, USB251XB_I2C_WRITE_SZ + 1); + if (err) + goto out_err; + } + + dev_info(dev, "Hub configuration was successful.\n"); + return 0; + +out_err: + dev_err(dev, "configuring block %d failed: %d\n", i, err); + return err; +} + +static int usb251xb_probe(struct udevice *dev) +{ + struct usb251xb *hub = dev_get_priv(dev); + int err; + + if (IS_ENABLED(CONFIG_DM_REGULATOR) && hub->vdd) { + err = regulator_set_enable(hub->vdd, true); + if (err) + return err; + } + + err = usb251xb_connect(dev); + if (err) { + dev_err(dev, "Failed to connect hub (%d)\n", err); + return err; + } + + dev_info(dev, "Hub probed successfully\n"); + + return 0; +} + +static void usb251xb_get_ports_field(struct udevice *dev, + const char *prop_name, u8 port_cnt, + bool ds_only, u8 *fld) +{ + u32 i, port; + int ret; + + for (i = 0; i < port_cnt; i++) { + ret = dev_read_u32_index(dev, prop_name, i, &port); + if (ret) + continue; + if (port >= ds_only ? 1 : 0 && port <= port_cnt) + *fld |= BIT(port); + else + dev_warn(dev, "port %u doesn't exist\n", port); + } +} + +static int usb251xb_of_to_plat(struct udevice *dev) +{ + struct usb251xb_data *data = + (struct usb251xb_data *)dev_get_driver_data(dev); + struct usb251xb *hub = dev_get_priv(dev); + char str[USB251XB_STRING_BUFSIZE / 2]; + const char *cproperty_char; + u32 property_u32 = 0; + int len, err; + + if (dev_read_bool(dev, "skip-config")) + hub->skip_config = 1; + else + hub->skip_config = 0; + + err = gpio_request_by_name(dev, "reset-gpios", 0, &hub->gpio_reset, + GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); + if (err && err != -ENOENT) { + dev_err(dev, "unable to request GPIO reset pin (%d)\n", err); + return err; + } + + if (IS_ENABLED(CONFIG_DM_REGULATOR)) { + err = device_get_supply_regulator(dev, "vdd-supply", + &hub->vdd); + if (err && err != -ENOENT) { + dev_err(dev, "Warning: cannot get power supply\n"); + return err; + } + } + + if (dev_read_u32(dev, "vendor-id", &hub->vendor_id)) + hub->vendor_id = USB251XB_DEF_VENDOR_ID; + + if (dev_read_u32(dev, "product-id", &hub->product_id)) + hub->product_id = data->product_id; + + if (dev_read_u32(dev, "device-id", &hub->device_id)) + hub->device_id = USB251XB_DEF_DEVICE_ID; + + hub->conf_data1 = USB251XB_DEF_CONFIG_DATA_1; + if (dev_read_bool(dev, "self-powered")) { + hub->conf_data1 |= BIT(7); + + /* Configure Over-Current sens when self-powered */ + hub->conf_data1 &= ~BIT(2); + if (dev_read_bool(dev, "ganged-sensing")) + hub->conf_data1 &= ~BIT(1); + else if (dev_read_bool(dev, "individual-sensing")) + hub->conf_data1 |= BIT(1); + } else if (dev_read_bool(dev, "bus-powered")) { + hub->conf_data1 &= ~BIT(7); + + /* Disable Over-Current sense when bus-powered */ + hub->conf_data1 |= BIT(2); + } + + if (dev_read_bool(dev, "disable-hi-speed")) + hub->conf_data1 |= BIT(5); + + if (dev_read_bool(dev, "multi-tt")) + hub->conf_data1 |= BIT(4); + else if (dev_read_bool(dev, "single-tt")) + hub->conf_data1 &= ~BIT(4); + + if (dev_read_bool(dev, "disable-eop")) + hub->conf_data1 |= BIT(3); + + if (dev_read_bool(dev, "individual-port-switching")) + hub->conf_data1 |= BIT(0); + else if (dev_read_bool(dev, "ganged-port-switching")) + hub->conf_data1 &= ~BIT(0); + + hub->conf_data2 = USB251XB_DEF_CONFIG_DATA_2; + if (dev_read_bool(dev, "dynamic-power-switching")) + hub->conf_data2 |= BIT(7); + + if (!dev_read_u32(dev, "oc-delay-us", &property_u32)) { + if (property_u32 == 100) { + /* 100 us*/ + hub->conf_data2 &= ~BIT(5); + hub->conf_data2 &= ~BIT(4); + } else if (property_u32 == 4000) { + /* 4 ms */ + hub->conf_data2 &= ~BIT(5); + hub->conf_data2 |= BIT(4); + } else if (property_u32 == 16000) { + /* 16 ms */ + hub->conf_data2 |= BIT(5); + hub->conf_data2 |= BIT(4); + } else { + /* 8 ms (DEFAULT) */ + hub->conf_data2 |= BIT(5); + hub->conf_data2 &= ~BIT(4); + } + } + + if (dev_read_bool(dev, "compound-device")) + hub->conf_data2 |= BIT(3); + + hub->conf_data3 = USB251XB_DEF_CONFIG_DATA_3; + if (dev_read_bool(dev, "port-mapping-mode")) + hub->conf_data3 |= BIT(3); + + if (data->led_support && dev_read_bool(dev, "led-usb-mode")) + hub->conf_data3 &= ~BIT(1); + + if (dev_read_bool(dev, "string-support")) + hub->conf_data3 |= BIT(0); + + hub->non_rem_dev = USB251XB_DEF_NON_REMOVABLE_DEVICES; + usb251xb_get_ports_field(dev, "non-removable-ports", data->port_cnt, + true, &hub->non_rem_dev); + + hub->port_disable_sp = USB251XB_DEF_PORT_DISABLE_SELF; + usb251xb_get_ports_field(dev, "sp-disabled-ports", data->port_cnt, + true, &hub->port_disable_sp); + + hub->port_disable_bp = USB251XB_DEF_PORT_DISABLE_BUS; + usb251xb_get_ports_field(dev, "bp-disabled-ports", data->port_cnt, + true, &hub->port_disable_bp); + + hub->max_power_sp = USB251XB_DEF_MAX_POWER_SELF; + if (!dev_read_u32(dev, "sp-max-total-current-microamp", &property_u32)) + hub->max_power_sp = min_t(u8, property_u32 / 2000, 50); + + hub->max_power_bp = USB251XB_DEF_MAX_POWER_BUS; + if (!dev_read_u32(dev, "bp-max-total-current-microamp", &property_u32)) + hub->max_power_bp = min_t(u8, property_u32 / 2000, 255); + + hub->max_current_sp = USB251XB_DEF_MAX_CURRENT_SELF; + if (!dev_read_u32(dev, "sp-max-removable-current-microamp", + &property_u32)) + hub->max_current_sp = min_t(u8, property_u32 / 2000, 50); + + hub->max_current_bp = USB251XB_DEF_MAX_CURRENT_BUS; + if (!dev_read_u32(dev, "bp-max-removable-current-microamp", + &property_u32)) + hub->max_current_bp = min_t(u8, property_u32 / 2000, 255); + + hub->power_on_time = USB251XB_DEF_POWER_ON_TIME; + if (!dev_read_u32(dev, "power-on-time-ms", &property_u32)) + hub->power_on_time = min_t(u8, property_u32 / 2, 255); + + if (dev_read_u32(dev, "language-id", &hub->lang_id)) + hub->lang_id = USB251XB_DEF_LANGUAGE_ID; + + if (!dev_read_u32(dev, "boost-up", &hub->boost_up)) + hub->boost_up = USB251XB_DEF_BOOST_UP; + + cproperty_char = dev_read_string(dev, "manufacturer"); + strlcpy(str, cproperty_char ? : USB251XB_DEF_MANUFACTURER_STRING, + sizeof(str)); + hub->manufacturer_len = strlen(str) & 0xFF; + memset(hub->manufacturer, 0, USB251XB_STRING_BUFSIZE); + len = min_t(size_t, USB251XB_STRING_BUFSIZE / 2, strlen(str)); + len = utf8_to_utf16le(str, hub->manufacturer, len); + + cproperty_char = dev_read_string(dev, "product"); + strlcpy(str, cproperty_char ? : data->product_str, sizeof(str)); + hub->product_len = strlen(str) & 0xFF; + memset(hub->product, 0, USB251XB_STRING_BUFSIZE); + len = min_t(size_t, USB251XB_STRING_BUFSIZE / 2, strlen(str)); + len = utf8_to_utf16le(str, hub->product, len); + + cproperty_char = dev_read_string(dev, "serial"); + strlcpy(str, cproperty_char ? : USB251XB_DEF_SERIAL_STRING, + sizeof(str)); + hub->serial_len = strlen(str) & 0xFF; + memset(hub->serial, 0, USB251XB_STRING_BUFSIZE); + len = min_t(size_t, USB251XB_STRING_BUFSIZE / 2, strlen(str)); + len = utf8_to_utf16le(str, hub->serial, len); + + /* + * The datasheet documents the register as 'Port Swap' but in real the + * register controls the USB DP/DM signal swapping for each port. + */ + hub->port_swap = USB251XB_DEF_PORT_SWAP; + usb251xb_get_ports_field(dev, "swap-dx-lanes", data->port_cnt, + false, &hub->port_swap); + + /* The following parameters are currently not exposed to devicetree, but + * may be as soon as needed. + */ + hub->bat_charge_en = USB251XB_DEF_BATTERY_CHARGING_ENABLE; + hub->boost_57 = USB251XB_DEF_BOOST_57; + hub->boost_14 = USB251XB_DEF_BOOST_14; + hub->port_map12 = USB251XB_DEF_PORT_MAP_12; + hub->port_map34 = USB251XB_DEF_PORT_MAP_34; + hub->port_map56 = USB251XB_DEF_PORT_MAP_56; + hub->port_map7 = USB251XB_DEF_PORT_MAP_7; + + return 0; +} + +static const struct udevice_id usb251xb_of_match[] = { + { + .compatible = "microchip,usb2422", + .data = (ulong)&usb2422_data, + }, { + .compatible = "microchip,usb2512b", + .data = (ulong)&usb2512b_data, + }, { + .compatible = "microchip,usb2512bi", + .data = (ulong)&usb2512bi_data, + }, { + .compatible = "microchip,usb2513b", + .data = (ulong)&usb2513b_data, + }, { + .compatible = "microchip,usb2513bi", + .data = (ulong)&usb2513bi_data, + }, { + .compatible = "microchip,usb2514b", + .data = (ulong)&usb2514b_data, + }, { + .compatible = "microchip,usb2514bi", + .data = (ulong)&usb2514bi_data, + }, { + .compatible = "microchip,usb2517", + .data = (ulong)&usb2517_data, + }, { + .compatible = "microchip,usb2517i", + .data = (ulong)&usb2517i_data, + } +}; + +U_BOOT_DRIVER(usb251xb) = { + .name = "usb251xb", + .id = UCLASS_MISC, + .of_match = usb251xb_of_match, + .of_to_plat = usb251xb_of_to_plat, + .probe = usb251xb_probe, + .priv_auto = sizeof(struct usb251xb), +};
The patch is aligned with kernel as you said but I expect this hub will be described on i2c bus which is based on https://lore.kernel.org/all/CAL_JsqJedhX6typpUKbnzV7CLK6UZVjq3CyG9iY_j5DLPqv...
not where Rob would like to see ends.
It is not a problem with the patch from my point of view I just wanted to let you know that based on him it should be handled differently.
Thanks, Michal
Can you include me in that discussion ?
However, it seems the discussion is not about USB251x , but some other hub which is connected over HSIC, not USB, that's likey why Rob wants it described differently than this hub.
If there are no comments, I will apply this soon.
Hi Marek,
sorry for the late comments but I think the driver doesn't work as expected.
Am 10.04.2022 um 06:27 schrieb Marek Vasut:
[snip]
- struct usb251xb_data *data =
- struct usb251xb *hub = dev_get_priv(dev);
- char str[USB251XB_STRING_BUFSIZE / 2];
- const char *cproperty_char;
- u32 property_u32 = 0;
- int len, err;
- if (dev_read_bool(dev, "skip-config"))
- else
- err = gpio_request_by_name(dev, "reset-gpios", 0, &hub->gpio_reset,
- if (err && err != -ENOENT) {
return err;
- if (IS_ENABLED(CONFIG_DM_REGULATOR)) {
&hub->vdd);
return err;
Shouldn't the gpio and regulator request be part of the probe?
- if (dev_read_u32(dev, "vendor-id", &hub->vendor_id))
- if (dev_read_u32(dev, "product-id", &hub->product_id))
- if (dev_read_u32(dev, "device-id", &hub->device_id))
[snip]
- if (dev_read_u32(dev, "language-id", &hub->lang_id))
This doesn't work because the ids are 16 bit [1,2] and the dev_read_u32 function checks the size.
- if (!dev_read_u32(dev, "boost-up", &hub->boost_up))
This looks like a 8 bit value [1].
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv... [2] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Docu...
Regards, Stefan
On 6/13/22 17:39, Stefan Herbrechtsmeier wrote:
Hi Marek,
How come ? It works on my board.
What makes you think that ?
[snip]
The dev_read_u32() is also capable of reading 0xNNNN 16bit value from DT.
What kind of problem are you running into exactly ?
Hi Marek,
Am 13.06.2022 um 18:00 schrieb Marek Vasut:
Hi Marek,
Have you test with 16 bit property data?
It's more a question regarding the device model design:
of_to_plat - convert device tree data to plat
[snip]
Have you test the values from device tree binding documentation:
vendor-id = /bits/ 16 <0xNNNN>; product-id = /bits/ 16 <0xNNNN>;
I get an EOVERFLOW error.
On 6/13/22 19:23, Stefan Herbrechtsmeier wrote:
Hi Marek,
As far as I can tell, you should be able to obtain reference to a regulator here, but not probe the regulator.
[snip]
No, I only tested foo = <0xNNNN>; .
Can you send a fix ?
Am 13.06.2022 um 22:26 schrieb Marek Vasut:
[snip]
[snip]
Should I add a function to the driver or a dev_read_u8/16, ofnode_read_u8/16 and friends function?
[snip]
[snip]
It seems more like you would have to add the _u8 and _u16 variants into common code, alongside the _u32 variant (should be easy) and then use them in this driver (should also be easy), so two patches.
Hi Marek,
Am 14.06.2022 um 09:38 schrieb Marek Vasut:
[snip]
> + if (dev_read_u32(dev, "vendor-id", &hub->vendor_id)) > + hub->vendor_id = USB251XB_DEF_VENDOR_ID; > + > + if (dev_read_u32(dev, "product-id", &hub->product_id)) > + hub->product_id = data->product_id; > + > + if (dev_read_u32(dev, "device-id", &hub->device_id)) > + hub->device_id = USB251XB_DEF_DEVICE_ID; > +
[snip]
> + if (dev_read_u32(dev, "language-id", &hub->lang_id)) > + hub->lang_id = USB251XB_DEF_LANGUAGE_ID; > +
> + if (!dev_read_u32(dev, "boost-up", &hub->boost_up)) > + hub->boost_up = USB251XB_DEF_BOOST_UP;
https://lists.denx.de/pipermail/u-boot/2022-June/486423.html https://lists.denx.de/pipermail/u-boot/2022-June/486424.html
Do you have any comments?
Regards Stefan
Michal Simek
