[PATCH] ARM: rmobile: Increase PHY auto-negotiation timeout to 20s
The ethernet PHY on all known Gen3 boards takes a while to come out of reset, increase the auto-negotiation timeout to prevent it from timing out in case the ethernet is used right after the board was reset.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- include/configs/rcar-gen3-common.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index 8f400ba05a..cf4d3bad2e 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -34,6 +34,9 @@ #define CONFIG_SYS_MAXARGS 64 #define CONFIG_SYS_BAUDRATE_TABLE { 115200, 38400 }
+/* PHY needs a longer autoneg timeout */ +#define PHY_ANEG_TIMEOUT 20000 + /* MEMORY */ #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE
