[GIT] Pull request: u-boot-clk (26.01.2020)
Dear Tom,
The following changes since commit 40521a6c90d4adfb7f3041033c8cbbeff087a5ca:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriq (2020-01-25 12:20:51 -0500)
git@gitlab.denx.de:u-boot/custodians/u-boot-clk.git
for you to fetch changes up to 2f39ab1649caddf748ef1eff60c40fede5995ced:
clock_imx8mq: Make frac_pll_init() static (2020-01-26 21:57:09 +0100)
---------------------------------------------------------------- Fabien Parent (1): clk: mediatek: use unsigned type for returning the clk rate
Giulio Benetti (4): clk: uclass: clk_get_by_name() must not be available if CONFIG_OF_PLATDATA is enabled clk: imx: pllv3: fix potential 'divide by zero' in sys_get_rate() clk: imx: pllv3: fix potential 'divide by zero' in av_get_rate() clk: imx: pllv3: fix potential 'divide by zero' in av_set_rate()
Pedro Jardim (4): clock_imx8mq: Delete not used init_usb_clk() clock_imx8mq: Make do_imx8m_showclocks() static clock_imx8mq: Remove the function sscg_pll_init() clock_imx8mq: Make frac_pll_init() static
Peng Fan (1): clk: show more error info when uclass_get_device_by_name
Sean Anderson (2): clk: Include missing headers for linux/clk-provider.h clk: Fix error checking of dev_read_addr_ptr
BRANCH: master https://gitlab.denx.de/u-boot/custodians/u-boot-clk/commits/master
Merge tag info: https://gitlab.denx.de/u-boot/custodians/u-boot-clk/-/tags/u-boot-clk-26Jan2...
Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/642125888
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On Mon, Jan 27, 2020 at 09:16:35AM +0100, Lukasz Majewski wrote:
Dear Tom,
Lukasz Majewski
