[U-Boot] [PATCH] README.mips: update known issues and TODOs
From: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- doc/README.mips | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/doc/README.mips b/doc/README.mips index 85dea40..f4f770b 100644 --- a/doc/README.mips +++ b/doc/README.mips @@ -16,11 +16,6 @@ Toolchains Known Issues ------------
- * Little endian build problem - - If use non-ELDK toolchains, -EB will be set to CPPFLAGS. Therefore all - objects will be generated in big-endian format. - * Cache incoherency issue caused by do_bootelf_exec() at cmd_elf.c
Cache will be disabled before entering the loaded ELF image without @@ -55,3 +50,9 @@ TODOs * Due to cache initialization issues, the DRAM on board must be initialized in board specific assembler language before the cache init code is run -- that is, initialize the DRAM in lowlevel_init(). + + * get rid of CONFIG_MANUAL_RELOC + + * centralize/share more CPU code of MIPS32, MIPS64 and XBurst + + * support Qemu Malta
