[PATCH v3 0/2] reset: Add a managed API
This is the 4th of a few series that are re-rolls of Jean-Jacques' earlier efforts. The goal is to facilitate porting drivers from the Linux kernel.
This particular series is about reset controllers. It adds a managed API, close to that of Linux. The main difference is that bulk and reset_ctl are handled with different functions.
Changes in v3: - Rebase on latest master and fix merge conflicts. - Other changes in individual patches.
Changes in v2: - Fix test build failing because of missing function prototypes and includes. - Drop NULL checks from the reset core. For now let drivers handle them. We can always add the checks back if we think they are a better idea. - Rebase on latest master.
Jean-Jacques Hiblot (2): drivers: reset: Add a managed API to get reset controllers from the DT test: reset: Add tests for the managed API
arch/sandbox/include/asm/reset.h | 3 + drivers/reset/reset-uclass.c | 118 ++++++++++++++++++++++++- drivers/reset/sandbox-reset-test.c | 51 +++++++++-- drivers/reset/sandbox-reset.c | 19 ++++ include/reset.h | 135 ++++++++++++++++++++++++++++- test/dm/reset.c | 60 +++++++++++++ 6 files changed, 375 insertions(+), 11 deletions(-)
-- 2.28.0
Add managed functions to get a reset_ctl from the device-tree, based on a name or an index. Also add a managed functions to get a reset_ctl_bulk (array of reset_ctl) from the device-tree.
When the device is unbound, the reset controllers are automatically released and the data structure is freed.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Pratyush Yadav p.yadav@ti.com ---
Notes: Changes in v3:
- Include linux/err.h instead of linux/errno.h because it includes the definition of ERR_PTR(), which we use in the inline variants of the functions. Fixes build on various platforms.
- Drop the include of dm.h because it spits out a build warning.
- Fix some a small merge conflict.
drivers/reset/reset-uclass.c | 118 ++++++++++++++++++++++++++++-- include/reset.h | 135 ++++++++++++++++++++++++++++++++++- 2 files changed, 248 insertions(+), 5 deletions(-)
diff --git a/drivers/reset/reset-uclass.c b/drivers/reset/reset-uclass.c index 5e38ce5c06..e7e407ca35 100644 --- a/drivers/reset/reset-uclass.c +++ b/drivers/reset/reset-uclass.c @@ -11,6 +11,7 @@ #include <reset.h> #include <reset-uclass.h> #include <dm/devres.h> +#include <dm/lists.h>
static inline struct reset_ops *reset_dev_ops(struct udevice *dev) { @@ -100,13 +101,14 @@ int reset_get_by_index_nodev(ofnode node, int index, index > 0, reset_ctl); }
-int reset_get_bulk(struct udevice *dev, struct reset_ctl_bulk *bulk) +static int __reset_get_bulk(struct udevice *dev, ofnode node, + struct reset_ctl_bulk *bulk) { int i, ret, err, count; - + bulk->count = 0;
- count = dev_count_phandle_with_args(dev, "resets", "#reset-cells"); + count = ofnode_count_phandle_with_args(node, "resets", "#reset-cells"); if (count < 1) return count;
@@ -116,7 +118,7 @@ int reset_get_bulk(struct udevice *dev, struct reset_ctl_bulk *bulk) return -ENOMEM;
for (i = 0; i < count; i++) { - ret = reset_get_by_index(dev, i, &bulk->resets[i]); + ret = reset_get_by_index_nodev(node, i, &bulk->resets[i]); if (ret < 0) goto bulk_get_err;
@@ -134,6 +136,11 @@ bulk_get_err: return ret; }
+int reset_get_bulk(struct udevice *dev, struct reset_ctl_bulk *bulk) +{ + return __reset_get_bulk(dev, dev_ofnode(dev), bulk); +} + int reset_get_by_name(struct udevice *dev, const char *name, struct reset_ctl *reset_ctl) { @@ -246,6 +253,109 @@ int reset_release_all(struct reset_ctl *reset_ctl, int count) return 0; }
+static void devm_reset_release(struct udevice *dev, void *res) +{ + reset_free(res); +} + +struct reset_ctl *devm_reset_control_get_by_index(struct udevice *dev, + int index) +{ + int rc; + struct reset_ctl *reset_ctl; + + reset_ctl = devres_alloc(devm_reset_release, sizeof(struct reset_ctl), + __GFP_ZERO); + if (unlikely(!reset_ctl)) + return ERR_PTR(-ENOMEM); + + rc = reset_get_by_index(dev, index, reset_ctl); + if (rc) + return ERR_PTR(rc); + + devres_add(dev, reset_ctl); + return reset_ctl; +} + +struct reset_ctl *devm_reset_control_get(struct udevice *dev, const char *id) +{ + int rc; + struct reset_ctl *reset_ctl; + + reset_ctl = devres_alloc(devm_reset_release, sizeof(struct reset_ctl), + __GFP_ZERO); + if (unlikely(!reset_ctl)) + return ERR_PTR(-ENOMEM); + + rc = reset_get_by_name(dev, id, reset_ctl); + if (rc) + return ERR_PTR(rc); + + devres_add(dev, reset_ctl); + return reset_ctl; +} + +struct reset_ctl *devm_reset_control_get_optional(struct udevice *dev, + const char *id) +{ + struct reset_ctl *r = devm_reset_control_get(dev, id); + + if (IS_ERR(r)) + return NULL; + + return r; +} + +static void devm_reset_bulk_release(struct udevice *dev, void *res) +{ + struct reset_ctl_bulk *bulk = res; + + reset_release_all(bulk->resets, bulk->count); +} + +struct reset_ctl_bulk *devm_reset_bulk_get_by_node(struct udevice *dev, + ofnode node) +{ + int rc; + struct reset_ctl_bulk *bulk; + + bulk = devres_alloc(devm_reset_bulk_release, + sizeof(struct reset_ctl_bulk), + __GFP_ZERO); + if (unlikely(!bulk)) + return ERR_PTR(-ENOMEM); + + rc = __reset_get_bulk(dev, node, bulk); + if (rc) + return ERR_PTR(rc); + + devres_add(dev, bulk); + return bulk; +} + +struct reset_ctl_bulk *devm_reset_bulk_get_optional_by_node(struct udevice *dev, + ofnode node) +{ + struct reset_ctl_bulk *bulk; + + bulk = devm_reset_bulk_get_by_node(dev, node); + + if (IS_ERR(bulk)) + return NULL; + + return bulk; +} + +struct reset_ctl_bulk *devm_reset_bulk_get(struct udevice *dev) +{ + return devm_reset_bulk_get_by_node(dev, dev_ofnode(dev)); +} + +struct reset_ctl_bulk *devm_reset_bulk_get_optional(struct udevice *dev) +{ + return devm_reset_bulk_get_optional_by_node(dev, dev_ofnode(dev)); +} + UCLASS_DRIVER(reset) = { .id = UCLASS_RESET, .name = "reset", diff --git a/include/reset.h b/include/reset.h index 4fac4e6a20..cde2c4b4a8 100644 --- a/include/reset.h +++ b/include/reset.h @@ -7,7 +7,7 @@ #define _RESET_H
#include <dm/ofnode.h> -#include <linux/errno.h> +#include <linux/err.h>
/** * A reset is a hardware signal indicating that a HW module (or IP block, or @@ -84,6 +84,98 @@ struct reset_ctl_bulk { };
#if CONFIG_IS_ENABLED(DM_RESET) + +/** + * devm_reset_control_get - resource managed reset_get_by_name() + * @dev: device to be reset by the controller + * @id: reset line name + * + * Managed reset_get_by_name(). For reset controllers returned + * from this function, reset_free() is called automatically on driver + * detach. + * + * Returns a struct reset_ctl or IS_ERR() condition containing errno. + */ +struct reset_ctl *devm_reset_control_get(struct udevice *dev, const char *id); + +/** + * devm_reset_control_get_optional - resource managed reset_get_by_name() that + * can fail + * @dev: The client device. + * @id: reset line name + * + * Managed reset_get_by_name(). For reset controllers returned + * from this function, reset_free() is called automatically on driver + * detach. + * + * Returns a struct reset_ctl or a dummy reset controller if it failed. + */ +struct reset_ctl *devm_reset_control_get_optional(struct udevice *dev, + const char *id); + +/** + * devm_reset_control_get - resource managed reset_get_by_index() + * @dev: The client device. + * @index: The index of the reset signal to request, within the client's + * list of reset signals. + * + * Managed reset_get_by_index(). For reset controllers returned + * from this function, reset_free() is called automatically on driver + * detach. + * + * Returns a struct reset_ctl or IS_ERR() condition containing errno. + */ +struct reset_ctl *devm_reset_control_get_by_index(struct udevice *dev, + int index); + +/** + * devm_reset_bulk_get - resource managed reset_get_bulk() + * @dev: device to be reset by the controller + * + * Managed reset_get_bulk(). For reset controllers returned + * from this function, reset_free() is called automatically on driver + * detach. + * + * Returns a struct reset_ctl or IS_ERR() condition containing errno. + */ +struct reset_ctl_bulk *devm_reset_bulk_get(struct udevice *dev); + +/** + * devm_reset_bulk_get_optional - resource managed reset_get_bulk() that + * can fail + * @dev: The client device. + * + * Managed reset_get_bulk(). For reset controllers returned + * from this function, reset_free() is called automatically on driver + * detach. + * + * Returns a struct reset_ctl or NULL if it failed. + */ +struct reset_ctl_bulk *devm_reset_bulk_get_optional(struct udevice *dev); + +/** + * devm_reset_bulk_get_by_node - resource managed reset_get_bulk() + * @dev: device to be reset by the controller + * @node: ofnode where the "resets" property is. Usually a sub-node of + * the dev's node. + * + * see devm_reset_bulk_get() + */ +struct reset_ctl_bulk *devm_reset_bulk_get_by_node(struct udevice *dev, + ofnode node); + +/** + * devm_reset_bulk_get_optional_by_node - resource managed reset_get_bulk() + * that can fail + * @dev: device to be reset by the controller + * @node: ofnode where the "resets" property is. Usually a sub-node of + * the dev's node. + * + * see devm_reset_bulk_get_optional() + */ +struct reset_ctl_bulk *devm_reset_bulk_get_optional_by_node(struct udevice *dev, + ofnode node); + /** * reset_get_by_index - Get/request a reset signal by integer index. * @@ -265,7 +357,48 @@ static inline int reset_release_bulk(struct reset_ctl_bulk *bulk) { return reset_release_all(bulk->resets, bulk->count); } + #else +static inline struct reset_ctl *devm_reset_control_get(struct udevice *dev, + const char *id) +{ + return ERR_PTR(-ENOTSUPP); +} + +static inline struct reset_ctl *devm_reset_control_get_optional(struct udevice *dev, + const char *id) +{ + return NULL; +} + +static inline struct reset_ctl *devm_reset_control_get_by_index(struct udevice *dev, + int index) +{ + return ERR_PTR(-ENOTSUPP); +} + +static inline struct reset_ctl_bulk *devm_reset_bulk_get(struct udevice *dev) +{ + return ERR_PTR(-ENOTSUPP); +} + +static inline struct reset_ctl_bulk *devm_reset_bulk_get_optional(struct udevice *dev) +{ + return NULL; +} + +static inline struct reset_ctl_bulk *devm_reset_bulk_get_by_node(struct udevice *dev, + ofnode node) +{ + return ERR_PTR(-ENOTSUPP); +} + +static inline struct reset_ctl_bulk *devm_reset_bulk_get_optional_by_node(struct udevice *dev, + ofnode node) +{ + return NULL; +} + static inline int reset_get_by_index(struct udevice *dev, int index, struct reset_ctl *reset_ctl) {
The tests are basically the same as for the regular API. Except that the reset are initialized using the managed API, and no freed manually.
- s/DM_TESTF/UT_TESTF/g
arch/sandbox/include/asm/reset.h | 3 ++ drivers/reset/sandbox-reset-test.c | 51 ++++++++++++++++++++++--- drivers/reset/sandbox-reset.c | 19 ++++++++++ test/dm/reset.c | 60 ++++++++++++++++++++++++++++++ 4 files changed, 127 insertions(+), 6 deletions(-)
diff --git a/arch/sandbox/include/asm/reset.h b/arch/sandbox/include/asm/reset.h index c4205eabef..40d3e61c11 100644 --- a/arch/sandbox/include/asm/reset.h +++ b/arch/sandbox/include/asm/reset.h @@ -11,9 +11,12 @@ struct udevice;
int sandbox_reset_query(struct udevice *dev, unsigned long id); +int sandbox_reset_is_requested(struct udevice *dev, unsigned long id);
int sandbox_reset_test_get(struct udevice *dev); +int sandbox_reset_test_get_devm(struct udevice *dev); int sandbox_reset_test_get_bulk(struct udevice *dev); +int sandbox_reset_test_get_bulk_devm(struct udevice *dev); int sandbox_reset_test_assert(struct udevice *dev); int sandbox_reset_test_assert_bulk(struct udevice *dev); int sandbox_reset_test_deassert(struct udevice *dev); diff --git a/drivers/reset/sandbox-reset-test.c b/drivers/reset/sandbox-reset-test.c index 9bc4a7e0de..10e02f1036 100644 --- a/drivers/reset/sandbox-reset-test.c +++ b/drivers/reset/sandbox-reset-test.c @@ -10,66 +10,105 @@ #include <reset.h> #include <asm/io.h> #include <asm/reset.h> +#include <linux/err.h>
struct sandbox_reset_test { struct reset_ctl ctl; struct reset_ctl_bulk bulk; + + struct reset_ctl *ctlp; + struct reset_ctl_bulk *bulkp; };
int sandbox_reset_test_get(struct udevice *dev) { struct sandbox_reset_test *sbrt = dev_get_priv(dev);
+ sbrt->ctlp = &sbrt->ctl; return reset_get_by_name(dev, "test", &sbrt->ctl); }
+int sandbox_reset_test_get_devm(struct udevice *dev) +{ + struct sandbox_reset_test *sbrt = dev_get_priv(dev); + struct reset_ctl *r; + + r = devm_reset_control_get(dev, "not-a-valid-reset-ctl"); + if (!IS_ERR(r)) + return -EINVAL; + + r = devm_reset_control_get_optional(dev, "not-a-valid-reset-ctl"); + if (r) + return -EINVAL; + + sbrt->ctlp = devm_reset_control_get(dev, "test"); + if (IS_ERR(sbrt->ctlp)) + return PTR_ERR(sbrt->ctlp); + + return 0; +} + int sandbox_reset_test_get_bulk(struct udevice *dev) { struct sandbox_reset_test *sbrt = dev_get_priv(dev);
+ sbrt->bulkp = &sbrt->bulk; return reset_get_bulk(dev, &sbrt->bulk); }
+int sandbox_reset_test_get_bulk_devm(struct udevice *dev) +{ + struct sandbox_reset_test *sbrt = dev_get_priv(dev); + struct reset_ctl_bulk *r; + + r = devm_reset_bulk_get_optional(dev); + if (IS_ERR(r)) + return PTR_ERR(r); + + sbrt->bulkp = r; + return 0; +} + int sandbox_reset_test_assert(struct udevice *dev) { struct sandbox_reset_test *sbrt = dev_get_priv(dev);
- return reset_assert(&sbrt->ctl); + return reset_assert(sbrt->ctlp); }
int sandbox_reset_test_assert_bulk(struct udevice *dev) { struct sandbox_reset_test *sbrt = dev_get_priv(dev);
- return reset_assert_bulk(&sbrt->bulk); + return reset_assert_bulk(sbrt->bulkp); }
int sandbox_reset_test_deassert(struct udevice *dev) { struct sandbox_reset_test *sbrt = dev_get_priv(dev);
- return reset_deassert(&sbrt->ctl); + return reset_deassert(sbrt->ctlp); }
int sandbox_reset_test_deassert_bulk(struct udevice *dev) { struct sandbox_reset_test *sbrt = dev_get_priv(dev);
- return reset_deassert_bulk(&sbrt->bulk); + return reset_deassert_bulk(sbrt->bulkp); }
int sandbox_reset_test_free(struct udevice *dev) { struct sandbox_reset_test *sbrt = dev_get_priv(dev);
- return reset_free(&sbrt->ctl); + return reset_free(sbrt->ctlp); }
int sandbox_reset_test_release_bulk(struct udevice *dev) { struct sandbox_reset_test *sbrt = dev_get_priv(dev);
- return reset_release_bulk(&sbrt->bulk); + return reset_release_bulk(sbrt->bulkp); }
static const struct udevice_id sandbox_reset_test_ids[] = { diff --git a/drivers/reset/sandbox-reset.c b/drivers/reset/sandbox-reset.c index 7a6f7f676c..08008d875a 100644 --- a/drivers/reset/sandbox-reset.c +++ b/drivers/reset/sandbox-reset.c @@ -15,6 +15,7 @@
struct sandbox_reset_signal { bool asserted; + bool requested; };
struct sandbox_reset { @@ -23,18 +24,24 @@ struct sandbox_reset {
static int sandbox_reset_request(struct reset_ctl *reset_ctl) { + struct sandbox_reset *sbr = dev_get_priv(reset_ctl->dev); + debug("%s(reset_ctl=%p)\n", __func__, reset_ctl);
if (reset_ctl->id >= SANDBOX_RESET_SIGNALS) return -EINVAL;
+ sbr->signals[reset_ctl->id].requested = true; return 0; }
static int sandbox_reset_free(struct reset_ctl *reset_ctl) { + struct sandbox_reset *sbr = dev_get_priv(reset_ctl->dev); + debug("%s(reset_ctl=%p)\n", __func__, reset_ctl);
+ sbr->signals[reset_ctl->id].requested = false; return 0; }
@@ -107,3 +114,15 @@ int sandbox_reset_query(struct udevice *dev, unsigned long id)
return sbr->signals[id].asserted; } + +int sandbox_reset_is_requested(struct udevice *dev, unsigned long id) +{ + struct sandbox_reset *sbr = dev_get_priv(dev); + + debug("%s(dev=%p, id=%ld)\n", __func__, dev, id); + + if (id >= SANDBOX_RESET_SIGNALS) + return -EINVAL; + + return sbr->signals[id].requested; +} diff --git a/test/dm/reset.c b/test/dm/reset.c index f5f366151f..fc8e9250b0 100644 --- a/test/dm/reset.c +++ b/test/dm/reset.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <dm/device-internal.h> #include <log.h> #include <malloc.h> #include <reset.h> @@ -60,12 +61,39 @@ static int dm_test_reset(struct unit_test_state *uts) ut_assertok(sandbox_reset_test_deassert(dev_test)); ut_asserteq(0, sandbox_reset_query(dev_reset, TEST_RESET_ID));
+ ut_asserteq(1, sandbox_reset_is_requested(dev_reset, TEST_RESET_ID)); ut_assertok(sandbox_reset_test_free(dev_test)); + ut_asserteq(0, sandbox_reset_is_requested(dev_reset, TEST_RESET_ID));
return 0; } DM_TEST(dm_test_reset, UT_TESTF_SCAN_FDT);
+static int dm_test_reset_devm(struct unit_test_state *uts) +{ + struct udevice *dev_reset; + struct udevice *dev_test; + + ut_assertok(uclass_get_device_by_name(UCLASS_RESET, "reset-ctl", + &dev_reset)); + ut_asserteq(0, sandbox_reset_query(dev_reset, TEST_RESET_ID)); + ut_assertok(uclass_get_device_by_name(UCLASS_MISC, "reset-ctl-test", + &dev_test)); + ut_assertok(sandbox_reset_test_get_devm(dev_test)); + + ut_assertok(sandbox_reset_test_assert(dev_test)); + ut_asserteq(1, sandbox_reset_query(dev_reset, TEST_RESET_ID)); + ut_assertok(sandbox_reset_test_deassert(dev_test)); + ut_asserteq(0, sandbox_reset_query(dev_reset, TEST_RESET_ID)); + + ut_asserteq(1, sandbox_reset_is_requested(dev_reset, TEST_RESET_ID)); + ut_assertok(device_remove(dev_test, DM_REMOVE_NORMAL)); + ut_asserteq(0, sandbox_reset_is_requested(dev_reset, TEST_RESET_ID)); + + return 0; +} +DM_TEST(dm_test_reset_devm, UT_TESTF_SCAN_FDT); + static int dm_test_reset_bulk(struct unit_test_state *uts) { struct udevice *dev_reset; @@ -95,3 +123,35 @@ static int dm_test_reset_bulk(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_reset_bulk, UT_TESTF_SCAN_FDT); + +static int dm_test_reset_bulk_devm(struct unit_test_state *uts) +{ + struct udevice *dev_reset; + struct udevice *dev_test; + + ut_assertok(uclass_get_device_by_name(UCLASS_RESET, "reset-ctl", + &dev_reset)); + ut_asserteq(0, sandbox_reset_query(dev_reset, TEST_RESET_ID)); + ut_asserteq(0, sandbox_reset_query(dev_reset, OTHER_RESET_ID)); + + ut_assertok(uclass_get_device_by_name(UCLASS_MISC, "reset-ctl-test", + &dev_test)); + ut_assertok(sandbox_reset_test_get_bulk_devm(dev_test)); + + ut_assertok(sandbox_reset_test_assert_bulk(dev_test)); + ut_asserteq(1, sandbox_reset_query(dev_reset, TEST_RESET_ID)); + ut_asserteq(1, sandbox_reset_query(dev_reset, OTHER_RESET_ID)); + + ut_assertok(sandbox_reset_test_deassert_bulk(dev_test)); + ut_asserteq(0, sandbox_reset_query(dev_reset, TEST_RESET_ID)); + ut_asserteq(0, sandbox_reset_query(dev_reset, OTHER_RESET_ID)); + + ut_asserteq(1, sandbox_reset_is_requested(dev_reset, OTHER_RESET_ID)); + ut_asserteq(1, sandbox_reset_is_requested(dev_reset, TEST_RESET_ID)); + ut_assertok(device_remove(dev_test, DM_REMOVE_NORMAL)); + ut_asserteq(0, sandbox_reset_is_requested(dev_reset, TEST_RESET_ID)); + ut_asserteq(0, sandbox_reset_is_requested(dev_reset, OTHER_RESET_ID)); + + return 0; +} +DM_TEST(dm_test_reset_bulk_devm, UT_TESTF_SCAN_FDT);
Forgot to mention: Travis CI run can be found at https://travis-ci.org/github/prati0100/uboot/builds/725197237
Pratyush Yadav
