[U-Boot] [PATCH 3/5] libfdt: update fdt.h from upstream dtc
upstream dtc commit feafcd972cb744750a65728440c99526e6199a6d "dtc/libfdt: introduce fdt types for annotation by endian checkers".
Signed-off-by: Kim Phillips kim.phillips@freescale.com Cc: Jerry Van Baren gvb.uboot@gmail.com --- include/fdt.h | 42 +++++++++++++++++++++--------------------- 1 file changed, 21 insertions(+), 21 deletions(-)
diff --git a/include/fdt.h b/include/fdt.h index c51212e..f9612ed 100644 --- a/include/fdt.h +++ b/include/fdt.h @@ -4,45 +4,45 @@ #ifndef __ASSEMBLY__
struct fdt_header { - uint32_t magic; /* magic word FDT_MAGIC */ - uint32_t totalsize; /* total size of DT block */ - uint32_t off_dt_struct; /* offset to structure */ - uint32_t off_dt_strings; /* offset to strings */ - uint32_t off_mem_rsvmap; /* offset to memory reserve map */ - uint32_t version; /* format version */ - uint32_t last_comp_version; /* last compatible version */ + fdt32_t magic; /* magic word FDT_MAGIC */ + fdt32_t totalsize; /* total size of DT block */ + fdt32_t off_dt_struct; /* offset to structure */ + fdt32_t off_dt_strings; /* offset to strings */ + fdt32_t off_mem_rsvmap; /* offset to memory reserve map */ + fdt32_t version; /* format version */ + fdt32_t last_comp_version; /* last compatible version */
/* version 2 fields below */ - uint32_t boot_cpuid_phys; /* Which physical CPU id we're + fdt32_t boot_cpuid_phys; /* Which physical CPU id we're booting on */ /* version 3 fields below */ - uint32_t size_dt_strings; /* size of the strings block */ + fdt32_t size_dt_strings; /* size of the strings block */
/* version 17 fields below */ - uint32_t size_dt_struct; /* size of the structure block */ + fdt32_t size_dt_struct; /* size of the structure block */ };
struct fdt_reserve_entry { - uint64_t address; - uint64_t size; + fdt64_t address; + fdt64_t size; };
struct fdt_node_header { - uint32_t tag; + fdt32_t tag; char name[0]; };
struct fdt_property { - uint32_t tag; - uint32_t len; - uint32_t nameoff; + fdt32_t tag; + fdt32_t len; + fdt32_t nameoff; char data[0]; };
#endif /* !__ASSEMBLY */
#define FDT_MAGIC 0xd00dfeed /* 4: version, 4: total size */ -#define FDT_TAGSIZE sizeof(uint32_t) +#define FDT_TAGSIZE sizeof(fdt32_t)
#define FDT_BEGIN_NODE 0x1 /* Start node: full name */ #define FDT_END_NODE 0x2 /* End node */ @@ -51,11 +51,11 @@ struct fdt_property { #define FDT_NOP 0x4 /* nop */ #define FDT_END 0x9
-#define FDT_V1_SIZE (7*sizeof(uint32_t)) -#define FDT_V2_SIZE (FDT_V1_SIZE + sizeof(uint32_t)) -#define FDT_V3_SIZE (FDT_V2_SIZE + sizeof(uint32_t)) +#define FDT_V1_SIZE (7*sizeof(fdt32_t)) +#define FDT_V2_SIZE (FDT_V1_SIZE + sizeof(fdt32_t)) +#define FDT_V3_SIZE (FDT_V2_SIZE + sizeof(fdt32_t)) #define FDT_V16_SIZE FDT_V3_SIZE -#define FDT_V17_SIZE (FDT_V16_SIZE + sizeof(uint32_t)) +#define FDT_V17_SIZE (FDT_V16_SIZE + sizeof(fdt32_t))
/* adding a ramdisk needs 0x44 bytes in version 2008.10 */ #define FDT_RAMDISK_OVERHEAD 0x80
Kim Phillips
