[U-Boot] [PATCH v3 1/3] net: Adds Fast Ethernet Controller driver for Armada100
This patch adds support for Fast Ethernet Controller driver for Armada100 series.
Signed-off-by: Ajay Bhargav ajay.bhargav@einfochips.com --- Changes for v2: - removed random MAC generation - driver init function changed to register as per new naming convention - code cleanup (Thanks to Wolfgang, Marek & Mike for tips) Changes for v3: - code cleanup
arch/arm/include/asm/arch-armada100/armada100.h | 1 + drivers/net/Makefile | 1 + drivers/net/armada100_fec.c | 759 +++++++++++++++++++++++ drivers/net/armada100_fec.h | 232 +++++++ include/netdev.h | 1 + 5 files changed, 994 insertions(+), 0 deletions(-) create mode 100644 drivers/net/armada100_fec.c create mode 100644 drivers/net/armada100_fec.h
diff --git a/arch/arm/include/asm/arch-armada100/armada100.h b/arch/arm/include/asm/arch-armada100/armada100.h index d5d125a..3d567eb 100644 --- a/arch/arm/include/asm/arch-armada100/armada100.h +++ b/arch/arm/include/asm/arch-armada100/armada100.h @@ -59,6 +59,7 @@ #define ARMD1_MPMU_BASE 0xD4050000 #define ARMD1_APMU_BASE 0xD4282800 #define ARMD1_CPU_BASE 0xD4282C00 +#define ARMD1_FEC_BASE 0xC0800000
/* * Main Power Management (MPMU) Registers diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 819b197..34b4322 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -28,6 +28,7 @@ LIB := $(obj)libnet.o COBJS-$(CONFIG_DRIVER_3C589) += 3c589.o COBJS-$(CONFIG_PPC4xx_EMAC) += 4xx_enet.o COBJS-$(CONFIG_ALTERA_TSE) += altera_tse.o +COBJS-$(CONFIG_ARMADA100_FEC) += armada100_fec.o COBJS-$(CONFIG_DRIVER_AT91EMAC) += at91_emac.o COBJS-$(CONFIG_DRIVER_AX88180) += ax88180.o COBJS-$(CONFIG_BCM570x) += bcm570x.o diff --git a/drivers/net/armada100_fec.c b/drivers/net/armada100_fec.c new file mode 100644 index 0000000..9362fe1 --- /dev/null +++ b/drivers/net/armada100_fec.c @@ -0,0 +1,759 @@ +/* + * (C) Copyright 2011 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2010 + * Marvell Semiconductor <www.marvell.com> + * Contributor: Mahavir Jain mjain@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <net.h> +#include <malloc.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/types.h> +#include <asm/byteorder.h> +#include <linux/err.h> +#include <linux/mii.h> +#include <asm/io.h> +#include <asm/arch/armada100.h> +#include "armada100_fec.h" + +#define PHY_ADR_REQ 0xFF /* Magic number to read/write PHY address */ + +#ifdef DEBUG +static int eth_dump_regs(struct eth_device *dev) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + unsigned int i = 0; + + printf("\noffset: phy_adr, value: 0x%x\n", readl(®s->phyadr)); + printf("offset: smi, value: 0x%x\n", readl(®s->smi)); + for (i = 0x400; i <= 0x4e4; i += 4) + printf("offset: 0x%x, value: 0x%x\n", + i, readl(ARMD1_FEC_BASE + i)); + return 0; +} +#endif + +static int armdfec_phy_timeout(u32 *reg, u32 flag, int cond) +{ + u32 timeout = PHY_WAIT_ITERATIONS; + u32 reg_val; + + while (--timeout) { + reg_val = readl(reg); + if (cond && (reg_val & flag)) + break; + else if (!cond && !(reg_val & flag)) + break; + udelay(PHY_WAIT_MICRO_SECONDS); + } + return !timeout; +} + +static int smi_reg_read(const char *devname, u8 phy_addr, u8 phy_reg, + u16 *value) +{ + struct eth_device *dev = eth_get_dev_by_name(devname); + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + u32 val, reg_data; + + if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) { + reg_data = readl(®s->phyadr); + *value = (u16) (reg_data & 0x1f); + return 0; + } + + /* check parameters */ + if (phy_addr > PHY_MASK) { + printf("Err..(%s) Invalid phy address: 0x%X\n", + __func__, phy_addr); + return -EINVAL; + } + if (phy_reg > PHY_MASK) { + printf("Err..(%s) Invalid register offset: 0x%X\n", + __func__, phy_reg); + return -EINVAL; + } + + /* wait for the SMI register to become available */ + if (armdfec_phy_timeout(®s->smi, SMI_BUSY, FALSE)) { + printf("Error (%s) PHY busy timeout\n", __func__); + return -1; + } + + writel((phy_addr << 16) | (phy_reg << 21) | SMI_OP_R, ®s->smi); + + /* now wait for the data to be valid */ + if (armdfec_phy_timeout(®s->smi, SMI_R_VALID, TRUE)) { + val = readl(®s->smi); + printf("Err (%s) PHY Read timeout, val=0x%x\n", __func__, val); + return -1; + } + val = readl(®s->smi); + *value = val & 0xffff; + + return 0; +} + +static int smi_reg_write(const char *devname, + u8 phy_addr, u8 phy_reg, u16 value) +{ + struct eth_device *dev = eth_get_dev_by_name(devname); + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + + if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) { + clrsetbits_le32(®s->phyadr, 0x1f, value & 0x1f); + return 0; + } + + /* check parameters */ + if (phy_addr > PHY_MASK) { + printf("Err..(%s) Invalid phy address\n", __func__); + return -EINVAL; + } + if (phy_reg > PHY_MASK) { + printf("Err..(%s) Invalid register offset\n", __func__); + return -EINVAL; + } + + /* wait for the SMI register to become available */ + if (armdfec_phy_timeout(®s->smi, SMI_BUSY, FALSE)) { + printf("Error (%s) PHY busy timeout\n", __func__); + return -1; + } + + writel((phy_addr << 16) | (phy_reg << 21) | SMI_OP_W | (value & 0xffff), + ®s->smi); + return 0; +} + +/* + * Abort any transmit and receive operations and put DMA + * in idle state. AT and AR bits are cleared upon entering + * in IDLE state. So poll those bits to verify operation. + */ +static void abortdma(struct eth_device *dev) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + int delay; + int maxretries = 40; + u32 tmp; + + while (maxretries--) { + writel(SDMA_CMD_AR | SDMA_CMD_AT, ®s->sdma_cmd); + udelay(100); + + delay = 10; + while (delay--) { + tmp = readl(®s->sdma_cmd); + if (!(tmp & (SDMA_CMD_AR | SDMA_CMD_AT))) + break; + udelay(10); + } + if (delay) + break; + } + + if (maxretries <= 0) + printf("%s : DMA Stuck\n", __func__); +} + +static inline u32 nibble_swapping_32_bit(u32 x) +{ + return (((x) & 0xf0f0f0f0) >> 4) | (((x) & 0x0f0f0f0f) << 4); +} + +static inline u32 nibble_swapping_16_bit(u32 x) +{ + return (((x) & 0x0000f0f0) >> 4) | (((x) & 0x00000f0f) << 4); +} + +static inline u32 flip_4_bits(u32 x) +{ + return (((x) & 0x01) << 3) | (((x) & 0x002) << 1) + | (((x) & 0x04) >> 1) | (((x) & 0x008) >> 3); +} + +/* + * This function will calculate the hash function of the address. + * depends on the hash mode and hash size. + * Inputs + * mach - the 2 most significant bytes of the MAC address. + * macl - the 4 least significant bytes of the MAC address. + * Outputs + * return the calculated entry. + */ +static u32 hash_function(u32 mach, u32 macl) +{ + u32 hashresult; + u32 addrh; + u32 addrl; + u32 addr0; + u32 addr1; + u32 addr2; + u32 addr3; + u32 addrhswapped; + u32 addrlswapped; + + addrh = nibble_swapping_16_bit(mach); + addrl = nibble_swapping_32_bit(macl); + + addrhswapped = flip_4_bits(addrh & 0xf) + + ((flip_4_bits((addrh >> 4) & 0xf)) << 4) + + ((flip_4_bits((addrh >> 8) & 0xf)) << 8) + + ((flip_4_bits((addrh >> 12) & 0xf)) << 12); + + addrlswapped = flip_4_bits(addrl & 0xf) + + ((flip_4_bits((addrl >> 4) & 0xf)) << 4) + + ((flip_4_bits((addrl >> 8) & 0xf)) << 8) + + ((flip_4_bits((addrl >> 12) & 0xf)) << 12) + + ((flip_4_bits((addrl >> 16) & 0xf)) << 16) + + ((flip_4_bits((addrl >> 20) & 0xf)) << 20) + + ((flip_4_bits((addrl >> 24) & 0xf)) << 24) + + ((flip_4_bits((addrl >> 28) & 0xf)) << 28); + + addrh = addrhswapped; + addrl = addrlswapped; + + addr0 = (addrl >> 2) & 0x03f; + addr1 = (addrl & 0x003) | (((addrl >> 8) & 0x7f) << 2); + addr2 = (addrl >> 15) & 0x1ff; + addr3 = ((addrl >> 24) & 0x0ff) | ((addrh & 1) << 8); + + hashresult = (addr0 << 9) | (addr1 ^ addr2 ^ addr3); + hashresult = hashresult & 0x07ff; + return hashresult; +} + +/* + * This function will add an entry to the address table. + * depends on the hash mode and hash size that was initialized. + * Inputs + * mach - the 2 most significant bytes of the MAC address. + * macl - the 4 least significant bytes of the MAC address. + * skip - if 1, skip this address. + * rd - the RD field in the address table. + * Outputs + * address table entry is added. + * 0 if success. + * -ENOSPC if table full + */ +static int add_del_hash_entry(struct armdfec_device *darmdfec, u32 mach, + u32 macl, u32 rd, u32 skip, int del) +{ + struct addr_table_entry_t *entry, *start; + u32 newhi; + u32 newlo; + u32 i; + u8 *last; + + newlo = (((mach >> 4) & 0xf) << 15) + | (((mach >> 0) & 0xf) << 11) + | (((mach >> 12) & 0xf) << 7) + | (((mach >> 8) & 0xf) << 3) + | (((macl >> 20) & 0x1) << 31) + | (((macl >> 16) & 0xf) << 27) + | (((macl >> 28) & 0xf) << 23) + | (((macl >> 24) & 0xf) << 19) + | (skip << HTESKIP) | (rd << HTERDBIT) + | HTEVALID; + + newhi = (((macl >> 4) & 0xf) << 15) + | (((macl >> 0) & 0xf) << 11) + | (((macl >> 12) & 0xf) << 7) + | (((macl >> 8) & 0xf) << 3) + | (((macl >> 21) & 0x7) << 0); + + /* + * Pick the appropriate table, start scanning for free/reusable + * entries at the index obtained by hashing the specified MAC address + */ + start = (struct addr_table_entry_t *) (darmdfec->htpr); + entry = start + hash_function(mach, macl); + for (i = 0; i < HOP_NUMBER; i++) { + if (!(entry->lo & HTEVALID)) { + break; + } else { + /* if same address put in same position */ + if (((entry->lo & 0xfffffff8) == (newlo & 0xfffffff8)) + && (entry->hi == newhi)) + break; + } + if (entry == start + 0x7ff) + entry = start; + else + entry++; + } + + if (((entry->lo & 0xfffffff8) != (newlo & 0xfffffff8)) && + (entry->hi != newhi) && del) + return 0; + + if (i == HOP_NUMBER) { + if (!del) { + printf("%s: table section is full\n", __FILE__); + return -ENOSPC; + } else { + return 0; + } + } + + /* + * Update the selected entry + */ + if (del) { + entry->hi = 0; + entry->lo = 0; + } else { + entry->hi = newhi; + entry->lo = newlo; + } + + last = (u8 *) entry; + last = last + sizeof(*entry); + + return 0; +} + +/* + * Create an addressTable entry from MAC address info + * found in the specifed net_device struct + * + * Input : pointer to ethernet interface network device structure + * Output : N/A + */ +static void update_hash_table_mac_address(struct armdfec_device *darmdfec, + u8 *oaddr, u8 *addr) +{ + u32 mach; + u32 macl; + + /* Delete old entry */ + if (oaddr) { + mach = (oaddr[0] << 8) | oaddr[1]; + macl = (oaddr[2] << 24) | (oaddr[3] << 16) | + (oaddr[4] << 8) | oaddr[5]; + add_del_hash_entry(darmdfec, mach, macl, 1, 0, HASH_DELETE); + } + + /* Add new entry */ + mach = (addr[0] << 8) | addr[1]; + macl = (addr[2] << 24) | (addr[3] << 16) | (addr[4] << 8) | addr[5]; + add_del_hash_entry(darmdfec, mach, macl, 1, 0, HASH_ADD); +} + +/* Address Table Initialization */ +static void init_hashtable(struct eth_device *dev) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + memset(darmdfec->htpr, 0, HASH_ADDR_TABLE_SIZE); + writel((u32)darmdfec->htpr, ®s->htpr); +} + +static int setportconfigext(struct eth_device *dev, int mtu) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + int mtusize; + + /* 64 should work but does not -- dhcp packets NEVER get transmitted. */ + if ((mtu > MAX_PKT_SIZE) || (mtu < 64)) + return -EINVAL; + + /* add source/dest mac addr (12) + pid (2) + crc (4) */ + mtu += ETH_EXTRA_HEADER; + if (mtu <= 1518) + mtusize = PCXR_MFL_1518; + else if (mtu <= 1536) + mtusize = PCXR_MFL_1536; + else if (mtu <= 2048) + mtusize = PCXR_MFL_2048; + else + mtusize = PCXR_MFL_64K; + + /* Extended Port Configuration */ + writel(PCXR_2BSM | /* Two byte suffix aligns IP hdr */ + PCXR_DSCP_EN | /* Enable DSCP in IP */ + mtusize | PCXR_FLP | /* do not force link pass */ + PCXR_TX_HIGH_PRI, /* Transmit - high priority queue */ + ®s->pconf_ext); + + /* subtract source/dest mac addr (12) + pid (2) + crc (4) */ + mtu -= ETH_EXTRA_HEADER; + return 0; +} + +/* + * This detects PHY chip from address 0-31 by reading PHY status + * registers. PHY chip can be connected at any of this address. + */ +static int ethernet_phy_detect(struct eth_device *dev) +{ + u32 val; + u16 tmp, mii_status; + u8 addr; + + for (addr = 0; addr < 32; addr++) { + if (miiphy_read(dev->name, addr, MII_BMSR, &mii_status) != 0) + /* try next phy */ + continue; + + /* invalid MII status. More validation required here... */ + if (mii_status == 0 || mii_status == 0xffff) + /* try next phy */ + continue; + + if (miiphy_read(dev->name, addr, MII_PHYSID1, &tmp) != 0) + /* try next phy */ + continue; + + val = tmp << 16; + if (miiphy_read(dev->name, addr, MII_PHYSID2, &tmp) != 0) + /* try next phy */ + continue; + + val |= tmp; + + if ((val & 0xfffffff0) != 0) + return addr; + } + return -1; +} + +static void armdfec_init_rx_desc_ring(struct armdfec_device *darmdfec) +{ + struct rx_desc *p_rx_desc; + int i; + + /* initialize the Rx descriptors ring */ + p_rx_desc = darmdfec->p_rxdesc; + for (i = 0; i < RINGSZ; i++) { + p_rx_desc->cmd_sts = BUF_OWNED_BY_DMA | RX_EN_INT; + p_rx_desc->buf_size = PKTSIZE_ALIGN; + p_rx_desc->byte_cnt = 0; + p_rx_desc->buf_ptr = darmdfec->p_rxbuf + i * PKTSIZE_ALIGN; + if (i == (RINGSZ - 1)) { + p_rx_desc->nxtdesc_p = darmdfec->p_rxdesc; + } else { + p_rx_desc->nxtdesc_p = (struct rx_desc *) + ((u32) p_rx_desc + ARMDFEC_RXQ_DESC_ALIGNED_SIZE); + p_rx_desc = p_rx_desc->nxtdesc_p; + } + } + darmdfec->p_rxdesc_curr = darmdfec->p_rxdesc; +} + +static int armdfec_init(struct eth_device *dev, bd_t *bd) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + int phy_adr; + + armdfec_init_rx_desc_ring(darmdfec); + + /* Disable interrupts */ + writel(0, ®s->im); + writel(0, ®s->ic); + /* Write to ICR to clear interrupts. */ + writel(0, ®s->iwc); + + /* + * Abort any transmit and receive operations and put DMA + * in idle state. + */ + abortdma(dev); + + /* Initialize address hash table */ + init_hashtable(dev); + + /* SDMA configuration */ + writel(SDCR_BSZ8 | /* Burst size = 32 bytes */ + SDCR_RIFB | /* Rx interrupt on frame */ + SDCR_BLMT | /* Little endian transmit */ + SDCR_BLMR | /* Little endian receive */ + SDCR_RC_MAX_RETRANS, /* Max retransmit count */ + ®s->sdma_conf); + /* Port Configuration */ + writel(PCR_HS, ®s->pconf); /* Hash size is 1/2kb */ + setportconfigext(dev, 1500); + + update_hash_table_mac_address(darmdfec, dev->enetaddr, dev->enetaddr); + + /* Update TX and RX queue descriptor register */ + writel((u32) darmdfec->p_txdesc, ®s->txcdp[TXQ]); + writel((u32) darmdfec->p_rxdesc, ®s->rxfdp[RXQ]); + writel((u32) darmdfec->p_rxdesc_curr, ®s->rxcdp[RXQ]); + + /* Enable Interrupts */ + writel(ALL_INTS, ®s->im); + + /* Enable Ethernet Port */ + setbits_le32(®s->pconf, PCR_EN); + + /* Enable RX DMA engine */ + setbits_le32(®s->sdma_cmd, SDMA_CMD_ERD); + +#ifdef DEBUG + eth_dump_regs(dev); +#endif + +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) + +#if defined(CONFIG_PHY_BASE_ADR) + miiphy_write(dev->name, PHY_ADR_REQ, PHY_ADR_REQ, CONFIG_PHY_BASE_ADR); +#else + /* Search phy address from range 0-31 */ + phy_adr = ethernet_phy_detect(dev); + if (phy_adr < 0) { + printf("Error: PHY not detected at address range 0-31\n"); + return -1; + } else { + debug("PHY detected at addr %d\n", phy_adr); + miiphy_write(dev->name, PHY_ADR_REQ, PHY_ADR_REQ, (u16)phy_adr); + } +#endif + +#if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) + /* Wait up to 5s for the link status */ + for (i = 0; i < 5; i++) { + u16 phy_adr; + + miiphy_read(dev->name, 0xFF, 0xFF, &phy_adr); + /* Return if we get link up */ + if (miiphy_link(dev->name, phy_adr)) + return 0; + udelay(1000000); + } + + printf("No link on %s\n", dev->name); + return -1; +#endif +#endif + return 0; +} + +static void armdfec_halt(struct eth_device *dev) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + + /* Stop RX DMA */ + clrbits_le32(®s->sdma_cmd, SDMA_CMD_ERD); + + /* + * Abort any transmit and receive operations and put DMA + * in idle state. + */ + abortdma(dev); + + /* Disable interrupts */ + writel(0, ®s->im); + writel(0, ®s->ic); + writel(0, ®s->iwc); + + /* Disable Port */ + clrbits_le32(®s->pconf, PCR_EN); +} + +static int armdfec_send(struct eth_device *dev, volatile void *dataptr, + int datasize) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + struct tx_desc *p_txdesc = darmdfec->p_txdesc; + void *p = (void *) dataptr; + int retry = PHY_WAIT_ITERATIONS * PHY_WAIT_MICRO_SECONDS; + u32 cmd_sts; + + /* Copy buffer if it's misaligned */ + if ((u32) dataptr & 0x07) { + if (datasize > PKTSIZE_ALIGN) { + printf("Non-aligned data too large (%d)\n", datasize); + return -1; + } + memcpy(darmdfec->p_aligned_txbuf, p, datasize); + p = darmdfec->p_aligned_txbuf; + } + + p_txdesc->cmd_sts = TX_ZERO_PADDING | TX_GEN_CRC; + p_txdesc->cmd_sts |= TX_FIRST_DESC | TX_LAST_DESC; + p_txdesc->cmd_sts |= BUF_OWNED_BY_DMA; + p_txdesc->cmd_sts |= TX_EN_INT; + p_txdesc->buf_ptr = p; + p_txdesc->byte_cnt = datasize; + + /* Apply send command using high priority TX queue */ + writel((u32) p_txdesc, ®s->txcdp[TXQ]); + writel(SDMA_CMD_TXDL | SDMA_CMD_TXDH | SDMA_CMD_ERD, ®s->sdma_cmd); + + /* + * wait for packet xmit completion + */ + cmd_sts = readl(&p_txdesc->cmd_sts); + while (cmd_sts & BUF_OWNED_BY_DMA) { + /* return fail if error is detected */ + if ((cmd_sts & (TX_ERROR | TX_LAST_DESC)) == + (TX_ERROR | TX_LAST_DESC)) { + printf("Err..(%s) in xmit packet\n", __func__); + return -1; + } + cmd_sts = readl(&p_txdesc->cmd_sts); + if (!(retry--)) { + printf("%s: xmit packet timeout!\n", __func__); + return -1; + } + } + + return 0; +} + +static int armdfec_recv(struct eth_device *dev) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct rx_desc *p_rxdesc_curr = darmdfec->p_rxdesc_curr; + u32 cmd_sts; + u32 timeout = 0; + + /* wait untill rx packet available or timeout */ + do { + if (timeout < PHY_WAIT_ITERATIONS * PHY_WAIT_MICRO_SECONDS) + timeout++; + else { + debug("%s time out...\n", __func__); + return -1; + } + } while (readl(&p_rxdesc_curr->cmd_sts) & BUF_OWNED_BY_DMA); + + if (p_rxdesc_curr->byte_cnt != 0) { + debug("%s: Received %d byte Packet @ 0x%x (cmd_sts= %08x)\n", + __func__, (u32) p_rxdesc_curr->byte_cnt, + (u32) p_rxdesc_curr->buf_ptr, + (u32) p_rxdesc_curr->cmd_sts); + } + + /* + * In case received a packet without first/last bits on + * OR the error summary bit is on, + * the packets needs to be dropeed. + */ + cmd_sts = readl(&p_rxdesc_curr->cmd_sts); + + if ((cmd_sts & (RX_FIRST_DESC | RX_LAST_DESC)) != + (RX_FIRST_DESC | RX_LAST_DESC)) { + printf("Err..(%s) Dropping packet spread on" + " multiple descriptors\n", __func__); + } else if (cmd_sts & RX_ERROR) { + printf("Err..(%s) Dropping packet with errors\n", __func__); + } else { + /* !!! call higher layer processing */ + debug("%s: Sending Received packet to" + " upper layer (NetReceive)\n", __func__); + + /* + * let the upper layer handle the packet, subtract offset + * as two dummy bytes are added in received buffer see + * PORT_CONFIG_EXT register bit TWO_Byte_Stuff_Mode bit. + */ + NetReceive((p_rxdesc_curr->buf_ptr + RX_BUF_OFFSET), + (int) (p_rxdesc_curr->byte_cnt - RX_BUF_OFFSET)); + } + /* + * free these descriptors and point next in the ring + */ + p_rxdesc_curr->cmd_sts = BUF_OWNED_BY_DMA | RX_EN_INT; + p_rxdesc_curr->buf_size = PKTSIZE_ALIGN; + p_rxdesc_curr->byte_cnt = 0; + + writel((u32) p_rxdesc_curr->nxtdesc_p, &darmdfec->p_rxdesc_curr); + + return 0; +} + +int armada100_fec_register(int base_addr) +{ + struct armdfec_device *darmdfec; + struct eth_device *dev; + + darmdfec = malloc(sizeof(struct armdfec_device)); + if (!darmdfec) + goto error; + + memset(darmdfec, 0, sizeof(struct armdfec_device)); + + darmdfec->htpr = memalign(8, HASH_ADDR_TABLE_SIZE); + if (!darmdfec->htpr) + goto error; + + darmdfec->p_rxdesc = memalign(PKTALIGN, + ARMDFEC_RXQ_DESC_ALIGNED_SIZE * RINGSZ + 1); + + if (!darmdfec->p_rxdesc) + goto error; + + darmdfec->p_rxbuf = memalign(PKTALIGN, RINGSZ * PKTSIZE_ALIGN + 1); + if (!darmdfec->p_rxbuf) + goto error; + + darmdfec->p_aligned_txbuf = memalign(8, PKTSIZE_ALIGN); + if (!darmdfec->p_aligned_txbuf) + goto error; + + darmdfec->p_txdesc = memalign(PKTALIGN, sizeof(struct tx_desc) + 1); + if (!darmdfec->p_txdesc) + goto error; + + dev = &darmdfec->dev; + /* Assign ARMADA100 Fast Ethernet Controller Base Address */ + darmdfec->regs = (void *)base_addr; + + /* must be less than NAMESIZE (16) */ + strcpy(dev->name, "armd-fec0"); + + dev->init = armdfec_init; + dev->halt = armdfec_halt; + dev->send = armdfec_send; + dev->recv = armdfec_recv; + + eth_register(dev); + +#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) + miiphy_register(dev->name, smi_reg_read, smi_reg_write); +#endif + return 0; + +error: + free(darmdfec->p_aligned_txbuf); + free(darmdfec->p_rxbuf); + free(darmdfec->p_rxdesc); + free(darmdfec->htpr); + free(darmdfec); + printf("Err.. %s Failed to allocate memory\n", __func__); + return -1; +} diff --git a/drivers/net/armada100_fec.h b/drivers/net/armada100_fec.h new file mode 100644 index 0000000..e2df4fc --- /dev/null +++ b/drivers/net/armada100_fec.h @@ -0,0 +1,232 @@ +/* + * (C) Copyright 2011 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2010 + * Marvell Semiconductor <www.marvell.com> + * Contributor: Mahavir Jain mjain@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __ARMADA100_FEC_H__ +#define __ARMADA100_FEC_H__ + +#ifndef TRUE +#define TRUE 1 +#endif +#ifndef FALSE +#define FALSE 0 +#endif + +#define PORT_NUM 0x0 + +/* RX & TX descriptor command */ +#define BUF_OWNED_BY_DMA (1<<31) + +/* RX descriptor status */ +#define RX_EN_INT (1<<23) +#define RX_FIRST_DESC (1<<17) +#define RX_LAST_DESC (1<<16) +#define RX_ERROR (1<<15) + +/* TX descriptor command */ +#define TX_EN_INT (1<<23) +#define TX_GEN_CRC (1<<22) +#define TX_ZERO_PADDING (1<<18) +#define TX_FIRST_DESC (1<<17) +#define TX_LAST_DESC (1<<16) +#define TX_ERROR (1<<15) + +/* smi register */ +#define SMI_BUSY (1<<28) /* 0 - Write, 1 - Read */ +#define SMI_R_VALID (1<<27) /* 0 - Write, 1 - Read */ +#define SMI_OP_W (0<<26) /* Write operation */ +#define SMI_OP_R (1<<26) /* Read operation */ + +#define HASH_ADD 0 +#define HASH_DELETE 1 +#define HASH_ADDR_TABLE_SIZE 0x4000 /* 16K (1/2K address - PCR_HS == 1) */ +#define HOP_NUMBER 12 + +#define PHY_WAIT_ITERATIONS 1000 /* 1000 iterations * 10uS = 10mS max */ +#define PHY_WAIT_MICRO_SECONDS 10 + +#define ETH_HW_IP_ALIGN 2 /* hw aligns IP header */ +#define ETH_EXTRA_HEADER (6+6+2+4) + /* dest+src addr+protocol id+crc */ +#define MAX_PKT_SIZE 1536 + + +/* Bit definitions of the SDMA Config Reg */ +#define SDCR_BSZ_OFF 12 +#define SDCR_BSZ8 (3<<SDCR_BSZ_OFF) +#define SDCR_BSZ4 (2<<SDCR_BSZ_OFF) +#define SDCR_BSZ2 (1<<SDCR_BSZ_OFF) +#define SDCR_BSZ1 (0<<SDCR_BSZ_OFF) +#define SDCR_BLMR (1<<6) +#define SDCR_BLMT (1<<7) +#define SDCR_RIFB (1<<9) +#define SDCR_RC_OFF 2 +#define SDCR_RC_MAX_RETRANS (0xf << SDCR_RC_OFF) + +/* SDMA_CMD */ +#define SDMA_CMD_AT (1<<31) +#define SDMA_CMD_TXDL (1<<24) +#define SDMA_CMD_TXDH (1<<23) +#define SDMA_CMD_AR (1<<15) +#define SDMA_CMD_ERD (1<<7) + + +/* Bit definitions of the Port Config Reg */ +#define PCR_HS (1<<12) +#define PCR_EN (1<<7) +#define PCR_PM (1<<0) + +/* Bit definitions of the Port Config Extend Reg */ +#define PCXR_2BSM (1<<28) +#define PCXR_DSCP_EN (1<<21) +#define PCXR_MFL_1518 (0<<14) +#define PCXR_MFL_1536 (1<<14) +#define PCXR_MFL_2048 (2<<14) +#define PCXR_MFL_64K (3<<14) +#define PCXR_FLP (1<<11) +#define PCXR_PRIO_TX_OFF 3 +#define PCXR_TX_HIGH_PRI (7<<PCXR_PRIO_TX_OFF) + +/* + * * Bit definitions of the Interrupt Cause Reg + * * and Interrupt MASK Reg is the same + * */ +#define ICR_RXBUF (1<<0) +#define ICR_TXBUF_H (1<<2) +#define ICR_TXBUF_L (1<<3) +#define ICR_TXEND_H (1<<6) +#define ICR_TXEND_L (1<<7) +#define ICR_RXERR (1<<8) +#define ICR_TXERR_H (1<<10) +#define ICR_TXERR_L (1<<11) +#define ICR_TX_UDR (1<<13) +#define ICR_MII_CH (1<<28) + +#define ALL_INTS (ICR_TXBUF_H | ICR_TXBUF_L | ICR_TX_UDR |\ + ICR_TXERR_H | ICR_TXERR_L |\ + ICR_TXEND_H | ICR_TXEND_L |\ + ICR_RXBUF | ICR_RXERR | ICR_MII_CH) + +#define PHY_MASK 0x0000001f + +#define to_darmdfec(_kd) container_of(_kd, struct armdfec_device, dev) +/* Size of a Tx/Rx descriptor used in chain list data structure */ +#define ARMDFEC_RXQ_DESC_ALIGNED_SIZE \ + (((sizeof(struct rx_desc) / PKTALIGN) + 1) * PKTALIGN) + +#define RX_BUF_OFFSET 0x2 +#define RXQ 0x0 /* RX Queue 0 */ +#define TXQ 0x1 /* TX Queue 1 */ + +struct addr_table_entry_t { + u32 lo; + u32 hi; +}; + +/* Bit fields of a Hash Table Entry */ +enum hash_table_entry { + HTEVALID = 1, + HTESKIP = 2, + HTERD = 4, + HTERDBIT = 2 +}; + +struct tx_desc { + u32 cmd_sts; /* Command/status field */ + u16 reserved; + u16 byte_cnt; /* buffer byte count */ + u8 *buf_ptr; /* pointer to buffer for this descriptor */ + struct tx_desc *nextdesc_p; /* Pointer to next descriptor */ +}; + +struct rx_desc { + u32 cmd_sts; /* Descriptor command status */ + u16 byte_cnt; /* Descriptor buffer byte count */ + u16 buf_size; /* Buffer size */ + u8 *buf_ptr; /* Descriptor buffer pointer */ + struct rx_desc *nxtdesc_p; /* Next descriptor pointer */ +}; + +/* + * Armada100 Fast Ethernet controller Registers + * Refer Datasheet Appendix A.22 + */ +struct armdfec_reg { + u32 phyadr; /* PHY Address */ + u32 pad1[3]; + u32 smi; /* SMI */ + u32 pad2[0xFB]; + u32 pconf; /* Port configuration */ + u32 pad3; + u32 pconf_ext; /* Port configuration extend */ + u32 pad4; + u32 pcmd; /* Port Command */ + u32 pad5; + u32 pstatus; /* Port Status */ + u32 pad6; + u32 spar; /* Serial Parameters */ + u32 pad7; + u32 htpr; /* Hash table pointer */ + u32 pad8; + u32 fcsal; /* Flow control source address low */ + u32 pad9; + u32 fcsah; /* Flow control source address high */ + u32 pad10; + u32 sdma_conf; /* SDMA configuration */ + u32 pad11; + u32 sdma_cmd; /* SDMA command */ + u32 pad12; + u32 ic; /* Interrupt cause */ + u32 iwc; /* Interrupt write to clear */ + u32 im; /* Interrupt mask */ + u32 pad13; + u32 *eth_idscpp[4]; /* Eth0 IP Differentiated Services Code + Point to Priority 0 Low */ + u32 eth_vlan_p; /* Eth0 VLAN Priority Tag to Priority */ + u32 pad14[3]; + struct rx_desc *rxfdp[4]; /* Ethernet First Rx Descriptor + Pointer */ + u32 pad15[4]; + struct rx_desc *rxcdp[4]; /* Ethernet Current Rx Descriptor + Pointer */ + u32 pad16[0x0C]; + struct tx_desc *txcdp[2]; /* Ethernet Current Tx Descriptor + Pointer */ +}; + +struct armdfec_device { + struct eth_device dev; + struct armdfec_reg *regs; + struct tx_desc *p_txdesc; + struct rx_desc *p_rxdesc; + struct rx_desc *p_rxdesc_curr; + u8 *p_rxbuf; + u8 *p_aligned_txbuf; + u8 *htpr; /* hash pointer */ +}; + +#endif /* __ARMADA100_FEC_H__ */ diff --git a/include/netdev.h b/include/netdev.h index 6f0a971..e4c09ee 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -94,6 +94,7 @@ int xilinx_emaclite_initialize (bd_t *bis, int base_addr); int sh_eth_initialize(bd_t *bis); int dm9000_initialize(bd_t *bis); int fecmxc_initialize(bd_t *bis); +int armada100_fec_register(int base_addr);
/* Boards with PCI network controllers can call this from their board_eth_init() * function to initialize whatever's on board.
Hi, please don't forget to CC me next time ;-)
u16 *value)
- struct eth_device *dev = eth_get_dev_by_name(devname);
- struct armdfec_device *darmdfec = to_darmdfec(dev);
- struct armdfec_reg *regs = darmdfec->regs;
- u32 val, reg_data;
- if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) {
Do you need this cast?
- /* check parameters */
- if (phy_addr > PHY_MASK) {
Maybe a firm "A100 FEC: Invalid phy address (address = 0x%x)\n" would be better, fix that "Err.." and "Err " globally please.
return -EINVAL;
- if (phy_reg > PHY_MASK) {
__func__, phy_reg);
return -EINVAL;
- /* wait for the SMI register to become available */
- if (armdfec_phy_timeout(®s->smi, SMI_BUSY, FALSE)) {
return -1;
- writel((phy_addr << 16) | (phy_reg << 21) | SMI_OP_R, ®s->smi);
- /* now wait for the data to be valid */
- if (armdfec_phy_timeout(®s->smi, SMI_R_VALID, TRUE)) {
return -1;
- val = readl(®s->smi);
- *value = val & 0xffff;
return -EINVAL;
return -EINVAL;
return -1;
- writel((phy_addr << 16) | (phy_reg << 21) | SMI_OP_W | (value & 0xffff),
®s->smi);
- Abort any transmit and receive operations and put DMA
- in idle state. AT and AR bits are cleared upon entering
- in IDLE state. So poll those bits to verify operation.
- int delay;
- int maxretries = 40;
- u32 tmp;
while (--maxretries) {
That way it won't get negative and you can check below for if (!maxretries)
- while (maxretries--) {
udelay(100);
delay = 10;
while (delay--) {
This will go negative and the check below will be true for -1.Fix this to while (--delay) {
break;
udelay(10);
if (delay)
break;
- if (maxretries <= 0)
See two comments above.
- return (((x) & 0xf0f0f0f0) >> 4) | (((x) & 0x0f0f0f0f) << 4);
- return (((x) & 0x0000f0f0) >> 4) | (((x) & 0x00000f0f) << 4);
- return (((x) & 0x01) << 3) | (((x) & 0x002) << 1)
- This function will calculate the hash function of the address.
- depends on the hash mode and hash size.
- Inputs
- mach - the 2 most significant bytes of the MAC address.
- macl - the 4 least significant bytes of the MAC address.
- Outputs
- return the calculated entry.
- u32 hashresult;
- u32 addrh;
- u32 addrl;
- u32 addr0;
- u32 addr1;
- u32 addr2;
- u32 addr3;
- u32 addrhswapped;
- u32 addrlswapped;
- addrh = nibble_swapping_16_bit(mach);
- addrl = nibble_swapping_32_bit(macl);
- addrhswapped = flip_4_bits(addrh & 0xf)
- addrlswapped = flip_4_bits(addrl & 0xf)
- addrh = addrhswapped;
- addrl = addrlswapped;
- addr0 = (addrl >> 2) & 0x03f;
- addr1 = (addrl & 0x003) | (((addrl >> 8) & 0x7f) << 2);
- addr2 = (addrl >> 15) & 0x1ff;
- addr3 = ((addrl >> 24) & 0x0ff) | ((addrh & 1) << 8);
- hashresult = (addr0 << 9) | (addr1 ^ addr2 ^ addr3);
- hashresult = hashresult & 0x07ff;
- return hashresult;
- This function will add an entry to the address table.
- depends on the hash mode and hash size that was initialized.
- Inputs
- skip - if 1, skip this address.
- rd - the RD field in the address table.
- Outputs
- address table entry is added.
- 0 if success.
- -ENOSPC if table full
- struct addr_table_entry_t *entry, *start;
- u32 newhi;
- u32 newlo;
- u32 i;
- u8 *last;
- newlo = (((mach >> 4) & 0xf) << 15)
| HTEVALID;
- newhi = (((macl >> 4) & 0xf) << 15)
- start = (struct addr_table_entry_t *) (darmdfec->htpr);
- entry = start + hash_function(mach, macl);
- for (i = 0; i < HOP_NUMBER; i++) {
break;
} else {
break;
entry = start;
else
entry++;
- if (((entry->lo & 0xfffffff8) != (newlo & 0xfffffff8)) &&
- if (i == HOP_NUMBER) {
if (!del) {
Unify the error reporting please.
It looks good, just a few nits
Cheers!
- u8 *last;
local var ...
- last = (u8 *) entry;
- last = last + sizeof(*entry);
so what's the point of these two assignments to "last" ?
when it comes to addresses for memory mapped registers, we typically use "unsigned long" rather than "int"
- darmdfec = malloc(sizeof(struct armdfec_device));
- if (!darmdfec)
goto error;
if this first one fails, we jump to:
+error:
- free(darmdfec->p_aligned_txbuf);
- free(darmdfec->p_rxbuf);
- free(darmdfec->p_rxdesc);
- free(darmdfec->htpr);
looks like 4 NULL pointer derefs. so you'll need one specific path for the first malloc(), but the rest are fine. -mike
Ajay Bhargav
Mike Frysinger
