[U-Boot] [PATCH][v2] mtd: nand: fsl_ifc: Fix eccstat array overflow for IFC ver >= 2.0.0
Number of ECC status registers i.e. (ECCSTATx) has been increased in IFC version 2.0.0 due to increase in SRAM size. This is causing eccstat array to over flow.
So, replace eccstat array with u32 variable to make it fail-safe and independent of number of ECC status registers or SRAM size.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Jagdish Gediya jagdish.gediya@nxp.com --- Changes for v2: - Resolve checkpatch error - Give suitable name to variable and do proper initialization.
drivers/mtd/nand/fsl_ifc_nand.c | 32 ++++++++++++-------------------- include/fsl_ifc.h | 4 ++-- 2 files changed, 14 insertions(+), 22 deletions(-)
diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index d1165f7..6eb44c3 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -270,14 +270,9 @@ static int is_blank(struct mtd_info *mtd, struct fsl_ifc_ctrl *ctrl,
/* returns nonzero if entire page is blank */ static int check_read_ecc(struct mtd_info *mtd, struct fsl_ifc_ctrl *ctrl, - u32 *eccstat, unsigned int bufnum) + u32 eccstat, unsigned int bufnum) { - u32 reg = eccstat[bufnum / 4]; - int errors; - - errors = (reg >> ((3 - bufnum % 4) * 8)) & 15; - - return errors; + return (eccstat >> ((3 - bufnum % 4) * 8)) & 15; }
/* @@ -291,7 +286,7 @@ static int fsl_ifc_run_command(struct mtd_info *mtd) struct fsl_ifc_runtime *ifc = ctrl->regs.rregs; u32 timeo = (CONFIG_SYS_HZ * 10) / 1000; u32 time_start; - u32 eccstat[8] = {0}; + u32 eccstat; int i;
/* set the chip select for NAND Transaction */ @@ -321,20 +316,17 @@ static int fsl_ifc_run_command(struct mtd_info *mtd) if (ctrl->eccread) { int errors; int bufnum = ctrl->page & priv->bufnum_mask; - int sector = bufnum * chip->ecc.steps; - int sector_end = sector + chip->ecc.steps - 1; - - for (i = sector / 4; i <= sector_end / 4; i++) { - if (i >= ARRAY_SIZE(eccstat)) { - printf("%s: eccstat too small for %d\n", - __func__, i); - return -EIO; - } + int sector_start = bufnum * chip->ecc.steps; + int sector_end = sector_start + chip->ecc.steps - 1; + u32 *eccstat_regs;
- eccstat[i] = ifc_in32(&ifc->ifc_nand.nand_eccstat[i]); - } + eccstat_regs = ifc->ifc_nand.nand_eccstat; + eccstat = ifc_in32(&eccstat_regs[sector_start / 4]); + + for (i = sector_start; i <= sector_end; i++) { + if (!(i % 4)) + eccstat = ifc_in32(&eccstat_regs[i / 4]);
- for (i = sector; i <= sector_end; i++) { errors = check_read_ecc(mtd, ctrl, eccstat, i);
if (errors == 15) { diff --git a/include/fsl_ifc.h b/include/fsl_ifc.h index 29aa687..4bff019 100644 --- a/include/fsl_ifc.h +++ b/include/fsl_ifc.h @@ -892,8 +892,8 @@ struct fsl_ifc_nand { u32 nand_erattr1; u32 res19[0x10]; u32 nand_fsr; - u32 res20[0x3]; - u32 nand_eccstat[6]; + u32 res20[0x1]; + u32 nand_eccstat[8]; u32 res21[0x1c]; u32 nanndcr; u32 res22[0x2];
As per the IFC hardware manual, Most significant 2 bytes in nand_fsr register are the outcome of NAND READ STATUS command.
So status value need to be shifted and aligned as per the nand framework requirement.
Signed-off-by: Jagdish Gediya jagdish.gediya@nxp.com Reviewed-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- Changes for v2: - Change the waitfunc return value according to semantic enforced by framework.
drivers/mtd/nand/fsl_ifc_nand.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index 6eb44c3..7f487e7 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -701,6 +701,7 @@ static int fsl_ifc_wait(struct mtd_info *mtd, struct nand_chip *chip) struct fsl_ifc_ctrl *ctrl = priv->ctrl; struct fsl_ifc_runtime *ifc = ctrl->regs.rregs; u32 nand_fsr; + int status;
if (ctrl->status != IFC_NAND_EVTER_STAT_OPC) return NAND_STATUS_FAIL; @@ -721,10 +722,10 @@ static int fsl_ifc_wait(struct mtd_info *mtd, struct nand_chip *chip) return NAND_STATUS_FAIL;
nand_fsr = ifc_in32(&ifc->ifc_nand.nand_fsr); + status = nand_fsr >> 24;
/* Chip sometimes reporting write protect even when it's not */ - nand_fsr = nand_fsr | NAND_STATUS_WP; - return nand_fsr; + return status | NAND_STATUS_WP; }
static int fsl_ifc_read_page(struct mtd_info *mtd, struct nand_chip *chip,
Changes for v2:
int status;
- status = nand_fsr >> 24;
You said most significant 2 bytes are the outcome, and you shift 24 bits. Did you intentionally use one byte?
York
Hi York,
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of York Sun Sent: Friday, April 27, 2018 2:31 AM To: Jagdish Gediya jagdish.gediya@nxp.com; u-boot@lists.denx.de Cc: oss@buserror.net Subject: Re: [U-Boot] [PATCH][v2] mtd: nand: fsl_ifc: Fix nand waitfunc return value
Changes for v2:
nand_chip *chip)
int status;
nand_chip *chip)
Even though there are 2 bytes. But NAND sub-system only consume 1 byte because all NAND flash has 1 byte status register.
--pk
On Apr 26, 2018, at 19:58, Prabhakar Kushwaha prabhakar.kushwaha@nxp.com wrote:
<snip>
Then the commit message should describe the position of primary status field, instead of saying two bytes.
York
Hi York,
-----Original Message----- From: York Sun Sent: Friday, April 27, 2018 8:43 AM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: Jagdish Gediya jagdish.gediya@nxp.com; u-boot@lists.denx.de; oss@buserror.net Subject: Re: [U-Boot] [PATCH][v2] mtd: nand: fsl_ifc: Fix nand waitfunc return value
<snip>
status register.
I will send the new revision of the patch.
Thanks, Jagdish
Jagdish Gediya
Prabhakar Kushwaha
York Sun
