[U-Boot] [PATCH 13/15] rockchip: board: lion-rk3368: update .its file
For the RK3368-uQ7, we can now update the .its file to mark the Trusted Firmware as out 'firmware' bootable and annotate both ATF and U-Boot with an OS-type.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
board/theobroma-systems/lion_rk3368/fit_spl_atf.its | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/theobroma-systems/lion_rk3368/fit_spl_atf.its b/board/theobroma-systems/lion_rk3368/fit_spl_atf.its index 405750f..5cdad3b 100644 --- a/board/theobroma-systems/lion_rk3368/fit_spl_atf.its +++ b/board/theobroma-systems/lion_rk3368/fit_spl_atf.its @@ -17,6 +17,7 @@ description = "U-Boot (64-bit)"; data = /incbin/("../../../u-boot-nodtb.bin"); type = "standalone"; + os = "U-Boot"; arch = "arm64"; compression = "none"; load = <0x00200000>; @@ -25,6 +26,7 @@ description = "ARM Trusted Firmware"; data = /incbin/("../../../bl31-rk3368.bin"); type = "firmware"; + os = "arm-trusted-firmware"; arch = "arm64"; compression = "none"; load = <0x00010000>; @@ -43,8 +45,8 @@ default = "conf"; conf { description = "Theobroma Systems RK3368-uQ7 (Puma) SoM"; - firmware = "uboot"; - loadables = "atf"; + firmware = "atf"; + loadables = "uboot"; fdt = "fdt"; }; };
On 13 September 2017 at 13:29, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Simon Glass sjg@chromium.org
Applied to u-boot-rockchip, thanks!
Philipp Tomsich
