[PATCH v2 1/1] doc: exception command
Create man-page for exception command.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: add missing exception.rst --- doc/usage/exception.rst | 68 +++++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 69 insertions(+) create mode 100644 doc/usage/exception.rst
diff --git a/doc/usage/exception.rst b/doc/usage/exception.rst new file mode 100644 index 0000000000..412a03ba0f --- /dev/null +++ b/doc/usage/exception.rst @@ -0,0 +1,68 @@ +exception command +================= + +Synopsis +-------- + +:: + + exception <type> + +Description +----------- + +The exception command is used to test the handling of exceptions like undefined +instructions, segmentation faults or alignment faults. + +type + type of exception to be generated. The available types are architecture + dependent. Use 'help exception' to determine which are available. + + **ARM:** + + breakpoint + prefetch abort + + unaligned + data abort + + undefined + undefined instruction + + **RISC-V:** + + unaligned + load address misaligned + + undefined + undefined instruction + + **Sandbox:** + + sigsegv + illegal memory access + + undefined + undefined instruction + + **x86:** + + undefined + undefined instruction + +Examples +-------- + +:: + + => exception undefined + + Illegal instruction + pc = 0x56076dd1a0f9, pc_reloc = 0x540f9 + + resetting ... + +Return value +------------ + +The return value $? is always set to 0 (true). diff --git a/doc/usage/index.rst b/doc/usage/index.rst index f75bd08237..83cfbafd90 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -19,6 +19,7 @@ Shell commands button conitrace echo + exception exit false for -- 2.29.2
