[U-Boot] [PATCH v4 18/36] sf: ramtron: Add support for separate flash driver
Compared to other spi flashes, ramtron has a different probing and implementation on flash ops, hence moved ramtron probe code into ramtron driver.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- Changes for v4: - none Changes for v3: - none Changes for v2: - none
drivers/mtd/spi/Makefile | 5 +- drivers/mtd/spi/ramtron.c | 123 +++++++++++++- drivers/mtd/spi/spi_flash_probe.c | 4 - drivers/mtd/spi/spi_flash_probe_legacy.c | 276 ------------------------------- include/configs/top9000.h | 1 - 5 files changed, 125 insertions(+), 284 deletions(-) delete mode 100644 drivers/mtd/spi/spi_flash_probe_legacy.c
diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index a10c850..2605e57 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -14,7 +14,10 @@ COBJS-$(CONFIG_SPL_SPI_LOAD) += spi_spl_load.o COBJS-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o endif
-COBJS-$(CONFIG_SPI_FLASH) += spi_flash_probe_legacy.o spi_flash_ops.o spi_flash.o +ifdef CONFIG_CMD_SF +COBJS-y += spi_flash.o +endif +COBJS-$(CONFIG_SPI_FLASH) += spi_flash_probe.o spi_flash_ops.o COBJS-$(CONFIG_SPI_FLASH_ATMEL) += atmel.o COBJS-$(CONFIG_SPI_FLASH_EON) += eon.o COBJS-$(CONFIG_SPI_FLASH_GIGADEVICE) += gigadevice.o diff --git a/drivers/mtd/spi/ramtron.c b/drivers/mtd/spi/ramtron.c index 38f9d69..c9701d0 100644 --- a/drivers/mtd/spi/ramtron.c +++ b/drivers/mtd/spi/ramtron.c @@ -214,7 +214,8 @@ static int ramtron_erase(struct spi_flash *flash, u32 offset, size_t len) * nore: we are called here with idcode pointing to the first non-0x7f byte * already! */ -struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, u8 *idcode) +static struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, + u8 *idcode) { const struct ramtron_spi_fram_params *params; struct ramtron_spi_fram *sn; @@ -270,7 +271,7 @@ struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, u8 *idcode) return NULL;
found: - sn = spi_flash_alloc(struct ramtron_spi_fram, spi, params->name); + sn = malloc(sizeof(*sn)); if (!sn) { debug("SF: Failed to allocate memory\n"); return NULL; @@ -285,3 +286,121 @@ found:
return &sn->flash; } + +/* + * The following table holds all device probe functions + * (All flashes are removed and implemented a common probe at + * spi_flash_probe.c) + * + * shift: number of continuation bytes before the ID + * idcode: the expected IDCODE or 0xff for non JEDEC devices + * probe: the function to call + * + * Non JEDEC devices should be ordered in the table such that + * the probe functions with best detection algorithms come first. + * + * Several matching entries are permitted, they will be tried + * in sequence until a probe function returns non NULL. + * + * IDCODE_CONT_LEN may be redefined if a device needs to declare a + * larger "shift" value. IDCODE_PART_LEN generally shouldn't be + * changed. This is the max number of bytes probe functions may + * examine when looking up part-specific identification info. + * + * Probe functions will be given the idcode buffer starting at their + * manu id byte (the "idcode" in the table below). In other words, + * all of the continuation bytes will be skipped (the "shift" below). + */ +#define IDCODE_CONT_LEN 0 +#define IDCODE_PART_LEN 5 +static const struct { + const u8 shift; + const u8 idcode; + struct spi_flash *(*probe) (struct spi_slave *spi, u8 *idcode); +} flashes[] = { + /* Keep it sorted by define name */ +#ifdef CONFIG_SPI_FRAM_RAMTRON + { 6, 0xc2, spi_fram_probe_ramtron, }, +# undef IDCODE_CONT_LEN +# define IDCODE_CONT_LEN 6 +#endif +#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + { 0, 0xff, spi_fram_probe_ramtron, }, +#endif +}; +#define IDCODE_LEN (IDCODE_CONT_LEN + IDCODE_PART_LEN) + +struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int spi_mode) +{ + struct spi_slave *spi; + struct spi_flash *flash = NULL; + int ret, i, shift; + u8 idcode[IDCODE_LEN], *idp; + + spi = spi_setup_slave(bus, cs, max_hz, spi_mode); + if (!spi) { + printf("SF: Failed to set up slave\n"); + return NULL; + } + + ret = spi_claim_bus(spi); + if (ret) { + debug("SF: Failed to claim SPI bus: %d\n", ret); + goto err_claim_bus; + } + + /* Read the ID codes */ + ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); + if (ret) + goto err_read_id; + +#ifdef DEBUG + printf("SF: Got idcodes\n"); + print_buffer(0, idcode, 1, sizeof(idcode), 0); +#endif + + /* count the number of continuation bytes */ + for (shift = 0, idp = idcode; + shift < IDCODE_CONT_LEN && *idp == 0x7f; + ++shift, ++idp) + continue; + + /* search the table for matches in shift and id */ + for (i = 0; i < ARRAY_SIZE(flashes); ++i) + if (flashes[i].shift == shift && flashes[i].idcode == *idp) { + /* we have a match, call probe */ + flash = flashes[i].probe(spi, idp); + if (flash) + break; + } + + if (!flash) { + printf("SF: Unsupported manufacturer %02x\n", *idp); + goto err_manufacturer_probe; + } + + printf("SF: Detected %s with page size ", flash->name); + print_size(flash->sector_size, ", total "); + print_size(flash->size, ""); + if (flash->memory_map) + printf(", mapped at %p", flash->memory_map); + puts("\n"); + + spi_release_bus(spi); + + return flash; + +err_manufacturer_probe: +err_read_id: + spi_release_bus(spi); +err_claim_bus: + spi_free_slave(spi); + return NULL; +} + +void spi_flash_free(struct spi_flash *flash) +{ + spi_free_slave(flash->spi); + free(flash); +} diff --git a/drivers/mtd/spi/spi_flash_probe.c b/drivers/mtd/spi/spi_flash_probe.c index b62ec54..ed5b938 100644 --- a/drivers/mtd/spi/spi_flash_probe.c +++ b/drivers/mtd/spi/spi_flash_probe.c @@ -144,10 +144,6 @@ static const struct spi_flash_params spi_flash_params_table[] = { * (W25Q64DW, W25Q64FV_QPI) * (W25Q128FW, W25Q128FV_QPI) */ - /* - * TODO: - * RAMTRON - */ };
struct spi_flash *spi_flash_validate_ids(struct spi_slave *spi, u8 *idcode) diff --git a/drivers/mtd/spi/spi_flash_probe_legacy.c b/drivers/mtd/spi/spi_flash_probe_legacy.c deleted file mode 100644 index 32ec578..0000000 --- a/drivers/mtd/spi/spi_flash_probe_legacy.c +++ /dev/null @@ -1,276 +0,0 @@ -/* - * SPI flash probing - * - * Copyright (C) 2008 Atmel Corporation - * Copyright (C) 2010 Reinhard Meyer, EMK Elektronik - * Copyright (C) 2013 Jagannadha Sutradharudu Teki, Xilinx Inc. - * - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <fdtdec.h> -#include <malloc.h> -#include <spi.h> -#include <spi_flash.h> - -#include "spi_flash_internal.h" - -DECLARE_GLOBAL_DATA_PTR; - -#ifdef CONFIG_SPI_FLASH_BAR -int spi_flash_bank_config(struct spi_flash *flash, u8 idcode0) -{ - u8 cmd; - u8 curr_bank = 0; - - /* discover bank cmds */ - switch (idcode0) { - case SPI_FLASH_SPANSION_IDCODE0: - flash->bank_read_cmd = CMD_BANKADDR_BRRD; - flash->bank_write_cmd = CMD_BANKADDR_BRWR; - break; - case SPI_FLASH_STMICRO_IDCODE0: - case SPI_FLASH_WINBOND_IDCODE0: - flash->bank_read_cmd = CMD_EXTNADDR_RDEAR; - flash->bank_write_cmd = CMD_EXTNADDR_WREAR; - break; - default: - printf("SF: Unsupported bank commands %02x\n", idcode0); - return -1; - } - - /* read the bank reg - on which bank the flash is in currently */ - cmd = flash->bank_read_cmd; - if (flash->size > SPI_FLASH_16MB_BOUN) { - if (spi_flash_read_common(flash, &cmd, 1, &curr_bank, 1)) { - debug("SF: fail to read bank addr register\n"); - return -1; - } - flash->bank_curr = curr_bank; - } else { - flash->bank_curr = curr_bank; - } - - return 0; -} -#endif - -#ifdef CONFIG_OF_CONTROL -int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) -{ - fdt_addr_t addr; - fdt_size_t size; - int node; - - /* If there is no node, do nothing */ - node = fdtdec_next_compatible(blob, 0, COMPAT_GENERIC_SPI_FLASH); - if (node < 0) - return 0; - - addr = fdtdec_get_addr_size(blob, node, "memory-map", &size); - if (addr == FDT_ADDR_T_NONE) { - debug("%s: Cannot decode address\n", __func__); - return 0; - } - - if (flash->size != size) { - debug("%s: Memory map must cover entire device\n", __func__); - return -1; - } - flash->memory_map = (void *)addr; - - return 0; -} -#endif /* CONFIG_OF_CONTROL */ - -/* - * The following table holds all device probe functions - * - * shift: number of continuation bytes before the ID - * idcode: the expected IDCODE or 0xff for non JEDEC devices - * probe: the function to call - * - * Non JEDEC devices should be ordered in the table such that - * the probe functions with best detection algorithms come first. - * - * Several matching entries are permitted, they will be tried - * in sequence until a probe function returns non NULL. - * - * IDCODE_CONT_LEN may be redefined if a device needs to declare a - * larger "shift" value. IDCODE_PART_LEN generally shouldn't be - * changed. This is the max number of bytes probe functions may - * examine when looking up part-specific identification info. - * - * Probe functions will be given the idcode buffer starting at their - * manu id byte (the "idcode" in the table below). In other words, - * all of the continuation bytes will be skipped (the "shift" below). - */ -#define IDCODE_CONT_LEN 0 -#define IDCODE_PART_LEN 5 -static const struct { - const u8 shift; - const u8 idcode; - struct spi_flash *(*probe) (struct spi_slave *spi, u8 *idcode); -} flashes[] = { - /* Keep it sorted by define name */ -#ifdef CONFIG_SPI_FLASH_ATMEL - { 0, 0x1f, spi_flash_probe_atmel, }, -#endif -#ifdef CONFIG_SPI_FLASH_EON - { 0, 0x1c, spi_flash_probe_eon, }, -#endif -#ifdef CONFIG_SPI_FLASH_GIGADEVICE - { 0, 0xc8, spi_flash_probe_gigadevice, }, -#endif -#ifdef CONFIG_SPI_FLASH_MACRONIX - { 0, 0xc2, spi_flash_probe_macronix, }, -#endif -#ifdef CONFIG_SPI_FLASH_SPANSION - { 0, 0x01, spi_flash_probe_spansion, }, -#endif -#ifdef CONFIG_SPI_FLASH_SST - { 0, 0xbf, spi_flash_probe_sst, }, -#endif -#ifdef CONFIG_SPI_FLASH_STMICRO - { 0, 0x20, spi_flash_probe_stmicro, }, -#endif -#ifdef CONFIG_SPI_FLASH_WINBOND - { 0, 0xef, spi_flash_probe_winbond, }, -#endif -#ifdef CONFIG_SPI_FRAM_RAMTRON - { 6, 0xc2, spi_fram_probe_ramtron, }, -# undef IDCODE_CONT_LEN -# define IDCODE_CONT_LEN 6 -#endif - /* Keep it sorted by best detection */ -#ifdef CONFIG_SPI_FLASH_STMICRO - { 0, 0xff, spi_flash_probe_stmicro, }, -#endif -#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC - { 0, 0xff, spi_fram_probe_ramtron, }, -#endif -}; -#define IDCODE_LEN (IDCODE_CONT_LEN + IDCODE_PART_LEN) - -struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int spi_mode) -{ - struct spi_slave *spi; - struct spi_flash *flash = NULL; - int ret, i, shift; - u8 idcode[IDCODE_LEN], *idp; - - spi = spi_setup_slave(bus, cs, max_hz, spi_mode); - if (!spi) { - printf("SF: Failed to set up slave\n"); - return NULL; - } - - ret = spi_claim_bus(spi); - if (ret) { - debug("SF: Failed to claim SPI bus: %d\n", ret); - goto err_claim_bus; - } - - /* Read the ID codes */ - ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); - if (ret) - goto err_read_id; - -#ifdef DEBUG - printf("SF: Got idcodes\n"); - print_buffer(0, idcode, 1, sizeof(idcode), 0); -#endif - - /* count the number of continuation bytes */ - for (shift = 0, idp = idcode; - shift < IDCODE_CONT_LEN && *idp == 0x7f; - ++shift, ++idp) - continue; - - /* search the table for matches in shift and id */ - for (i = 0; i < ARRAY_SIZE(flashes); ++i) - if (flashes[i].shift == shift && flashes[i].idcode == *idp) { - /* we have a match, call probe */ - flash = flashes[i].probe(spi, idp); - if (flash) - break; - } - - if (!flash) { - printf("SF: Unsupported manufacturer %02x\n", *idp); - goto err_manufacturer_probe; - } - -#ifdef CONFIG_SPI_FLASH_BAR - /* Configure the BAR - disover bank cmds and read current bank */ - ret = spi_flash_bank_config(flash, *idp); - if (ret < 0) - goto err_manufacturer_probe; -#endif - -#ifdef CONFIG_OF_CONTROL - if (spi_flash_decode_fdt(gd->fdt_blob, flash)) { - debug("SF: FDT decode error\n"); - goto err_manufacturer_probe; - } -#endif -#ifndef CONFIG_SPL_BUILD - printf("SF: Detected %s with page size ", flash->name); - print_size(flash->sector_size, ", total "); - print_size(flash->size, ""); - if (flash->memory_map) - printf(", mapped at %p", flash->memory_map); - puts("\n"); -#endif -#ifndef CONFIG_SPI_FLASH_BAR - if (flash->size > SPI_FLASH_16MB_BOUN) { - puts("SF: Warning - Only lower 16MiB accessible,"); - puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); - } -#endif - - spi_release_bus(spi); - - return flash; - -err_manufacturer_probe: -err_read_id: - spi_release_bus(spi); -err_claim_bus: - spi_free_slave(spi); - return NULL; -} - -void *spi_flash_do_alloc(int offset, int size, struct spi_slave *spi, - const char *name) -{ - struct spi_flash *flash; - void *ptr; - - ptr = malloc(size); - if (!ptr) { - debug("SF: Failed to allocate memory\n"); - return NULL; - } - memset(ptr, '\0', size); - flash = (struct spi_flash *)(ptr + offset); - - /* Set up some basic fields - caller will sort out sizes */ - flash->spi = spi; - flash->name = name; - flash->poll_cmd = CMD_READ_STATUS; - - flash->read = spi_flash_cmd_read_fast; - flash->write = spi_flash_cmd_write_multi; - flash->erase = spi_flash_cmd_erase; - - return flash; -} - -void spi_flash_free(struct spi_flash *flash) -{ - spi_free_slave(flash->spi); - free(flash); -} diff --git a/include/configs/top9000.h b/include/configs/top9000.h index 65dabde..a6d6928 100644 --- a/include/configs/top9000.h +++ b/include/configs/top9000.h @@ -120,7 +120,6 @@ #define CONFIG_ATMEL_SPI0 /* SPI used for FRAM is SPI0 */ #define FRAM_SPI_BUS 0 #define FRAM_CS_NUM 0 -#define CONFIG_SPI_FLASH /* RAMTRON FRAM on SPI bus */ #define CONFIG_SPI_FRAM_RAMTRON #define CONFIG_SF_DEFAULT_SPEED 1000000 /* be conservative here... */ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0
