[U-Boot] [PATCH] phy: Fix u-boot coruption when fixed-phy is used
When fixed-link phy is used subnode offset is used as phy address. This number is bigger then space allocated for bus structure (allocated via mdio_alloc). bus->phymap[] array has PHY_MAX_ADDR size (32). That's why writing bus->phymap[addr] where addr is < 0 or > PHY_MAX_ADDR is causing write to memory which can caused full U-Boot crash.
The patch is checking if address is in correct range.
search_for_existing_phy() is using this array but there is if check already that's why it shouldn't be a big deal.
--- drivers/net/phy/phy.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index e837eb7688cc..cda4caa8034d 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -656,7 +656,8 @@ static struct phy_device *phy_device_create(struct mii_dev *bus, int addr,
phy_probe(dev);
- bus->phymap[addr] = dev; + if (addr >= 0 && addr < PHY_MAX_ADDR) + bus->phymap[addr] = dev;
return dev; }
phy_probe(dev);
- if (addr >= 0 && addr < PHY_MAX_ADDR)
How about adding some error / warning print in the else path here?
Thanks, Stefan
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index e837eb7688cc..cda4caa8034d 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -656,7 +656,8 @@ static struct phy_device *phy_device_create(struct mii_dev *bus, int addr, phy_probe(dev); - bus->phymap[addr] = dev; + if (addr >= 0 && addr < PHY_MAX_ADDR) + bus->phymap[addr] = dev;
We can add it but I am not quite sure how that error should look like in this case. Because addr is filled by node offset got from sn = fdt_first_subnode(gd->fdt_blob, dev_of_offset(dev));
It means this error/warning will be shown all the time which is also weird.
The solution could be to save link to phy DT node in phy_device structure and then read it on driver not like this int ofnode = phydev->addr; which is done in fixed.c
But anyway still that above fix make sense to make sure that we are not overwriting stuff.
Thanks, Michal
Michal Simek
Stefan Roese
