[U-Boot-Users] main clock calculation invalid
Hi all, I'm trying to figure out why the below calculation of my main frequencey clock is not correct.
In the below equation: maindiv2 = 28 maindiv1 = 13 prediv = 23 ps = 0 and CONFIG_SYS_CLK_FREQ is 14745600.
but I get 93622108 instead of 265420800. How is this possible?
here is the equation which is what get_FCLK returns:
return (((maindiv2 + 2) * (maindiv1 + 2) * CONFIG_SYS_CLK_FREQ) / ((prediv + 2) * (1 << ps)));
much thanks. --Jr.
____________________________________________________________ GET FREE 5GB ONLINE STORAGE - Safely store your documents, photos and music online! Visit http://www.inbox.com/storage to find out more!
I'm sorry, but the user's manual for my Z80 processor does not contain any part which matches your description.
What might be missing?
-----Original Message----- From: wd@denx.de Sent: Thu, 19 Apr 2007 17:54:59 +0200 To: ejr@inbox.com Subject: Re: [U-Boot-Users] main clock calculation invalid
I'm not sure what you're missing but my emphasis was on the calculation. This is on an ARM9 LH7A404 chip. Now I might be missing something but even on a 16 bit CPU the calculation result shouldn't change, no?
This is the function, all my printed values are correct before the calculation.
/* return FCLK frequency */ ulong get_FCLK (void) { lh7a40x_csc_t* csc = LH7A404_CSC_PTR; ulong maindiv1, maindiv2, prediv, ps;
/* * FCLK = ((MAINDIV1 +2) * (MAINDIV2 +2) * 14.7456MHz) / * ((PREDIV+2) * (2^PS)) */ maindiv2 = (csc->clkset & CLKSET_MAINDIV2) >> 11; maindiv1 = (csc->clkset & CLKSET_MAINDIV1) >> 7; prediv = (csc->clkset & CLKSET_PREDIV) >> 2; ps = (csc->clkset & CLKSET_PS) >> 16; printf("maindiv2: %d, maindiv1 %d, prediv %d, ps %d\n",maindiv2,maindiv1,prediv,ps); printf("CONFIG_SYS_CLK_FREQ: %d \n",CONFIG_SYS_CLK_FREQ); return ( ((maindiv2 + 2) * (maindiv1 + 2) * CONFIG_SYS_CLK_FREQ) / ((prediv + 2) * (1 << ps))); }
You did not understand my little joke about the old Z80 CPU - what I wanted to pointout was that you completely left out all relevant information, like which architecture and CPU and board you were talking about.
You might have overflows here and there...
It should probably be 14745600L or "UL".
%d is for int, not for ulong.
Same here.
-----Original Message----- From: ejr@inbox.com Sent: Thu, 19 Apr 2007 08:16:01 -0800 To: wd@denx.de Subject: Re: [U-Boot-Users] main clock calculation invalid
I think I see what the problem is but I'm not sure how to fix it in uboot. When I multiply 450 and 14745600, I get a number greater than 32 bits and the MSB is missed.
I could do an alternative calculation to achive the correct result but unless there is a good trick out there I'll do that.
Thanks, --Jr.
Hi Junior,
u-boot-users-bounces@lists.sourceforge.net wrote on Thursday, April 19, 2007 8:52 PM:
You could rearrange your formula:
CONFIG_SYS_CLK_FREQ / ((prediv + 2) * (1 << ps)) * (maindiv2 + 2) * (maindiv1 + 2)
The compiler should do the calculation from left to right.
Regards, Martin
In message 47F3F98010FF784EBEE6526EAAB078D1024F8528@tq-mailsrv.tq-net.de you wrote:
And if in doubt, use parens to define the order of evaluation.
wd@denx.de wrote on Friday, April 20, 2007 10:18 AM:
Ahhh, I always had a strong feeling, that theses parenthesis things would be good for something ... ;-)
Ragards, Martin
Junior
Martin Krause
