[PATCH v3] gpio: Enable hogging support in SPL
Use the CONFIG macros to conditionally build the GPIO hogging support in either the SPL or U-Boot, or both, depending on the configuration. Also call the GPIO hog probe function in the common SPL board initialization as an equivalent to adding it to the U-Boot init sequence functions.
Signed-off-by: Eddie James eajames@linux.ibm.com --- Changes since v2: - change #if to if() in gpio_post_bind
Changes since v1: - remove #if guards around gpio include - change #if to if() in spl board_init_r
common/spl/spl.c | 4 ++++ drivers/gpio/Kconfig | 10 ++++++++++ drivers/gpio/gpio-uclass.c | 8 ++++---- 3 files changed, 18 insertions(+), 4 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 884102bdea..36115e674d 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -20,6 +20,7 @@ #include <serial.h> #include <spl.h> #include <asm/global_data.h> +#include <asm/gpio.h> #include <asm/u-boot.h> #include <nand.h> #include <fat.h> @@ -739,6 +740,9 @@ void board_init_r(gd_t *dummy1, ulong dummy2) } }
+ if (CONFIG_IS_ENABLED(GPIO_HOG)) + gpio_hog_probe_all(); + #if CONFIG_IS_ENABLED(BOARD_INIT) spl_board_init(); #endif diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 305a2dc563..4da2bdc10d 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -57,6 +57,16 @@ config GPIO_HOG is a mechanism providing automatic GPIO request and config- uration as part of the gpio-controller's driver probe function.
+config SPL_GPIO_HOG + bool "Enable GPIO hog support in SPL" + depends on SPL_GPIO_SUPPORT + default n + help + Enable gpio hog support in SPL + The GPIO chip may contain GPIO hog definitions. GPIO hogging + is a mechanism providing automatic GPIO request and config- + uration as part of the gpio-controller's driver probe function. + config DM_GPIO_LOOKUP_LABEL bool "Enable searching for gpio labelnames" depends on DM_GPIO diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 125ae53d61..9075c7235d 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -1432,9 +1432,6 @@ void devm_gpiod_put(struct udevice *dev, struct gpio_desc *desc)
static int gpio_post_bind(struct udevice *dev) { - struct udevice *child; - ofnode node; - #if defined(CONFIG_NEEDS_MANUAL_RELOC) struct dm_gpio_ops *ops = (struct dm_gpio_ops *)device_get_ops(dev); static int reloc_done; @@ -1465,7 +1462,10 @@ static int gpio_post_bind(struct udevice *dev) } #endif
- if (CONFIG_IS_ENABLED(OF_REAL) && IS_ENABLED(CONFIG_GPIO_HOG)) { + if (CONFIG_IS_ENABLED(GPIO_HOG)) { + struct udevice *child; + ofnode node; + dev_for_each_subnode(node, dev) { if (ofnode_read_bool(node, "gpio-hog")) { const char *name = ofnode_get_name(node);
Changes since v2:
Changes since v1:
Signed-off-by: Eddie James eajames@linux.ibm.com Reviewed-by: Simon Glass sjg@chromium.org
Eddie James
