[U-Boot] [PATCH v3] mx6ull: Handle the CONFIG_MX6ULL cases correctly
Since commit 051ba9e082f7 ("Kconfig: mx6ull: Deselect MX6UL from CONFIG_MX6ULL") CONFIG_MX6ULL does not select CONFIG_MX6UL anymore, so take this into consideration in all the checks for CONFIG_MX6UL.
This fixes a boot regression.
Reported-by: Stefan Agner stefan@agner.ch Signed-off-by: Fabio Estevam fabio.estevam@nxp.com Reviewed-by: Stefan Agner stefan@agner.ch Tested-by: Breno Lima breno.lima@nxp.com Tested-by: Peng Fan peng.fan@nxp.com --- Changes since v2: - Also fix include/configs/imx6_spl.h (Stefano)
arch/arm/include/asm/arch-mx6/imx-regs.h | 23 +++++++++++++---------- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 2 +- arch/arm/include/asm/arch-mx6/mx6ul-ddr.h | 2 +- arch/arm/include/asm/mach-imx/iomux-v3.h | 4 ++-- arch/arm/include/asm/mach-imx/regs-lcdif.h | 19 +++++++++++++------ arch/arm/mach-imx/mx6/Kconfig | 2 +- arch/arm/mach-imx/mx6/ddr.c | 2 +- drivers/gpio/mxc_gpio.c | 4 ++-- include/configs/imx6_spl.h | 3 ++- include/configs/mx6_common.h | 7 ++++--- 10 files changed, 40 insertions(+), 28 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 7736b6a..4be7aab 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -17,7 +17,7 @@ #define GPU_2D_ARB_END_ADDR 0x02203FFF #define OPENVG_ARB_BASE_ADDR 0x02204000 #define OPENVG_ARB_END_ADDR 0x02207FFF -#elif (defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) +#elif (defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) #define CAAM_ARB_BASE_ADDR 0x00100000 #define CAAM_ARB_END_ADDR 0x00107FFF #define GPU_ARB_BASE_ADDR 0x01800000 @@ -46,7 +46,8 @@ #define MXS_BCH_BASE (APBH_DMA_ARB_BASE_ADDR + 0x04000)
/* GPV - PL301 configuration ports */ -#if (defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) || \ +#if (defined(CONFIG_MX6SX) || \ + defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || \ defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL)) #define GPV2_BASE_ADDR 0x00D00000 #define GPV3_BASE_ADDR 0x00E00000 @@ -88,7 +89,7 @@ #define QSPI0_AMBA_END 0x6FFFFFFF #define QSPI1_AMBA_BASE 0x70000000 #define QSPI1_AMBA_END 0x7FFFFFFF -#elif defined(CONFIG_MX6UL) +#elif (defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) #define WEIM_ARB_BASE_ADDR 0x50000000 #define WEIM_ARB_END_ADDR 0x57FFFFFF #define QSPI0_AMBA_BASE 0x60000000 @@ -109,7 +110,8 @@ #endif
#if (defined(CONFIG_MX6SLL) || defined(CONFIG_MX6SL) || \ - defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) + defined(CONFIG_MX6SX) || \ + defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) #define MMDC0_ARB_BASE_ADDR 0x80000000 #define MMDC0_ARB_END_ADDR 0xFFFFFFFF #define MMDC1_ARB_BASE_ADDR 0xC0000000 @@ -262,7 +264,7 @@ #define MMDC_P0_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x30000) /* i.MX6SL/SLL */ #define RNGB_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) -#ifdef CONFIG_MX6UL +#if (defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) #define ENET2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x34000) #else /* i.MX6SX */ @@ -288,7 +290,7 @@ #define IP2APB_PERFMON3_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4C000) #endif #define IP2APB_TZASC1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x50000) -#ifdef CONFIG_MX6UL +#if (defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) #define QSPI0_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x60000) #define UART6_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x7C000) #elif defined(CONFIG_MX6SX) @@ -337,7 +339,7 @@ #define PWM6_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xA8000) #define PWM7_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xAC000) #define PWM8_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xB0000) -#elif defined(CONFIG_MX6ULL) +#elif (defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) #define AIPS3_CONFIG_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x7C000) #define DCP_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x80000) #define RNGB_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x84000) @@ -354,7 +356,8 @@ #define MX6SX_LCDIF1_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x20000) #define MX6SX_WDOG3_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x88000)
-#if !(defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) || \ +#if !(defined(CONFIG_MX6SX) || \ + defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || \ defined(CONFIG_MX6SLL) || defined(CONFIG_MX6SL)) #define IRAM_SIZE 0x00040000 #else @@ -573,7 +576,7 @@ struct src { #define IOMUXC_GPR12_LOS_LEVEL (0x1f << 4)
struct iomuxc { -#if (defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) +#if (defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) u8 reserved[0x4000]; #endif u32 gpr[14]; @@ -700,7 +703,7 @@ struct cspi_regs { #define MXC_CSPICON_SSPOL 12 /* SS polarity */ #define MXC_CSPICON_CTL 20 /* inactive state of SCLK */ #if defined(CONFIG_MX6SLL) || defined(CONFIG_MX6SL) || \ - defined(CONFIG_MX6DL) || defined(CONFIG_MX6UL) + defined(CONFIG_MX6DL) || defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) #define MXC_SPI_BASE_ADDRESSES \ ECSPI1_BASE_ADDR, \ ECSPI2_BASE_ADDR, \ diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h index 2a8d443..19d2f1d 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -16,7 +16,7 @@ #ifdef CONFIG_MX6SX #include "mx6sx-ddr.h" #else -#ifdef CONFIG_MX6UL +#if defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) #include "mx6ul-ddr.h" #else #ifdef CONFIG_MX6SL diff --git a/arch/arm/include/asm/arch-mx6/mx6ul-ddr.h b/arch/arm/include/asm/arch-mx6/mx6ul-ddr.h index ed11c4b..518b812 100644 --- a/arch/arm/include/asm/arch-mx6/mx6ul-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6ul-ddr.h @@ -7,7 +7,7 @@ #ifndef __ASM_ARCH_MX6UL_DDR_H__ #define __ASM_ARCH_MX6UL_DDR_H__
-#ifndef CONFIG_MX6UL +#if !(defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) #error "wrong CPU" #endif
diff --git a/arch/arm/include/asm/mach-imx/iomux-v3.h b/arch/arm/include/asm/mach-imx/iomux-v3.h index ad35e01..ed75e9c 100644 --- a/arch/arm/include/asm/mach-imx/iomux-v3.h +++ b/arch/arm/include/asm/mach-imx/iomux-v3.h @@ -127,7 +127,7 @@ typedef u64 iomux_v3_cfg_t;
#define PAD_CTL_ODE (1 << 11)
-#if defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) +#if defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) #define PAD_CTL_SPEED_LOW (0 << 6) #else #define PAD_CTL_SPEED_LOW (1 << 6) @@ -253,7 +253,7 @@ if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) { \ imx_iomux_v3_setup_pad(MX6Q_##def); #define SETUP_IOMUX_PADS(x) \ imx_iomux_v3_setup_multiple_pads(x, ARRAY_SIZE(x)) -#elif defined(CONFIG_MX6UL) +#elif defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) #define IOMUX_PADS(x) MX6_##x #define SETUP_IOMUX_PAD(def) \ imx_iomux_v3_setup_pad(MX6_##def); diff --git a/arch/arm/include/asm/mach-imx/regs-lcdif.h b/arch/arm/include/asm/mach-imx/regs-lcdif.h index 4de401b..c6cf03b 100644 --- a/arch/arm/include/asm/mach-imx/regs-lcdif.h +++ b/arch/arm/include/asm/mach-imx/regs-lcdif.h @@ -19,8 +19,11 @@ struct mxs_lcdif_regs { mxs_reg_32(hw_lcdif_ctrl) /* 0x00 */ mxs_reg_32(hw_lcdif_ctrl1) /* 0x10 */ -#if defined(CONFIG_MX28) || defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) || \ - defined(CONFIG_MX7) || defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL) + +#if defined(CONFIG_MX28) || defined(CONFIG_MX6SX) || \ + defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL) || \ + defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || \ + defined(CONFIG_MX7) mxs_reg_32(hw_lcdif_ctrl2) /* 0x20 */ #endif mxs_reg_32(hw_lcdif_transfer_count) /* 0x20/0x30 */ @@ -55,8 +58,10 @@ struct mxs_lcdif_regs { #endif mxs_reg_32(hw_lcdif_data) /* 0x1b0/0x180 */ mxs_reg_32(hw_lcdif_bm_error_stat) /* 0x1c0/0x190 */ -#if defined(CONFIG_MX28) || defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) || \ - defined(CONFIG_MX7) || defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL) +#if defined(CONFIG_MX28) || defined(CONFIG_MX6SX) || \ + defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL) || \ + defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || \ + defined(CONFIG_MX7) mxs_reg_32(hw_lcdif_crc_stat) /* 0x1a0 */ #endif mxs_reg_32(hw_lcdif_lcdif_stat) /* 0x1d0/0x1b0 */ @@ -64,8 +69,10 @@ struct mxs_lcdif_regs { mxs_reg_32(hw_lcdif_debug0) /* 0x1f0/0x1d0 */ mxs_reg_32(hw_lcdif_debug1) /* 0x200/0x1e0 */ mxs_reg_32(hw_lcdif_debug2) /* 0x1f0 */ -#if defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) || defined(CONFIG_MX7) || \ - defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL) +#if defined(CONFIG_MX6SX) || \ + defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL) || \ + defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || \ + defined(CONFIG_MX7) mxs_reg_32(hw_lcdif_thres) mxs_reg_32(hw_lcdif_as_ctrl) mxs_reg_32(hw_lcdif_as_buf) diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 18e1e67..2552a50 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -8,7 +8,7 @@ config MX6_SMP bool
config MX6 - select ARM_ERRATA_743622 if !MX6UL + select ARM_ERRATA_743622 if !MX6UL && !MX6ULL bool default y imply CMD_FUSE diff --git a/arch/arm/mach-imx/mx6/ddr.c b/arch/arm/mach-imx/mx6/ddr.c index 0cf391e..52a9a25 100644 --- a/arch/arm/mach-imx/mx6/ddr.c +++ b/arch/arm/mach-imx/mx6/ddr.c @@ -631,7 +631,7 @@ void mx6sx_dram_iocfg(unsigned width, } #endif
-#ifdef CONFIG_MX6UL +#if defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) void mx6ul_dram_iocfg(unsigned width, const struct mx6ul_iomux_ddr_regs *ddr, const struct mx6ul_iomux_grp_regs *grp) diff --git a/drivers/gpio/mxc_gpio.c b/drivers/gpio/mxc_gpio.c index c480eba..cfa620b 100644 --- a/drivers/gpio/mxc_gpio.c +++ b/drivers/gpio/mxc_gpio.c @@ -47,12 +47,12 @@ static unsigned long gpio_ports[] = { #if defined(CONFIG_MX27) || defined(CONFIG_MX53) || defined(CONFIG_MX6) || \ defined(CONFIG_MX7) [4] = GPIO5_BASE_ADDR, -#ifndef CONFIG_MX6UL +#if !(defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) [5] = GPIO6_BASE_ADDR, #endif #endif #if defined(CONFIG_MX53) || defined(CONFIG_MX6) || defined(CONFIG_MX7) -#ifndef CONFIG_MX6UL +#if !(defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) [6] = GPIO7_BASE_ADDR, #endif #endif diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index cdb3a37..dd48120 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -55,7 +55,8 @@ # endif #endif
-#if defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL) || defined(CONFIG_MX6SL) +#if defined(CONFIG_MX6SX) || defined(CONFIG_MX6SL) || \ + defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) #define CONFIG_SPL_BSS_START_ADDR 0x88200000 #define CONFIG_SPL_BSS_MAX_SIZE 0x100000 /* 1 MB */ #define CONFIG_SYS_SPL_MALLOC_START 0x88300000 diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 5fb85a1..59e6dae 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -7,7 +7,7 @@ #ifndef __MX6_COMMON_H #define __MX6_COMMON_H
-#ifndef CONFIG_MX6UL +#if !(defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)) #ifndef CONFIG_SYS_L2CACHE_OFF #define CONFIG_SYS_L2_PL310 #define CONFIG_SYS_PL310_BASE L2_PL310_BASE @@ -37,8 +37,9 @@ #define CONFIG_REVISION_TAG
/* Boot options */ -#if (defined(CONFIG_MX6SX) || defined(CONFIG_MX6SL) || \ - defined(CONFIG_MX6UL) || defined(CONFIG_MX6SLL)) +#if defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL) || \ + defined(CONFIG_MX6SX) || \ + defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) #define CONFIG_LOADADDR 0x82000000 #ifndef CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_TEXT_BASE 0x87800000
Changes since v2:
- defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || \ defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL))
- defined(CONFIG_MX6SX) || \
- defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL))
- defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) || \ defined(CONFIG_MX6SLL) || defined(CONFIG_MX6SL))
- defined(CONFIG_MX6DL) || defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL)
- defined(CONFIG_MX6SL) || defined(CONFIG_MX6SLL) || \
- defined(CONFIG_MX7) mxs_reg_32(hw_lcdif_ctrl2) /* 0x20 */
- defined(CONFIG_MX7) mxs_reg_32(hw_lcdif_crc_stat) /* 0x1a0 */
- defined(CONFIG_MX7) mxs_reg_32(hw_lcdif_thres) mxs_reg_32(hw_lcdif_as_ctrl) mxs_reg_32(hw_lcdif_as_buf)
config MX6
- select ARM_ERRATA_743622 if !MX6UL && !MX6ULL bool default y imply CMD_FUSE
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Changes since v2:
config MX6
Tested on a custom i.MX6ULL board.
Tested-by: Jörg Krause joerg.krause@embedded.rocks
Hi Stefano,
Do you plan to submit a pull request for Tom to pick this one up?
It fixes a boot regression on mx6ull, so just wanted to make sure we don't miss it for the final 2018.01 release.
Thanks
On 08/01/2018 12:35, Fabio Estevam wrote:
Hi Stefano,
Yes, I have to pick up some other pacthes (Stefan's for example) and then I will send my PR.
Stefano
Fabio Estevam
Fabio Estevam
Jörg Krause
Stefano Babic
