[U-Boot] [PATCH v3 0/9] sunxi: Remove SYS_EXTRA_OPTIONS
Hello everyone,
This a V3 for my patchset that removes the SYS_EXTRA_OPTIONS from all sunxi defconfigs. The values in this variable are converted to Kconfig or simply removed.
Based on u-boot sunxi repository: git://git.denx.de/u-boot-sunxi.git "master" branch, from last commit: 6f72a951cdd07e3f9d214b189762b978cd2acf45
* Changes since V2 *
- Patch 01: Rebased on master branch, add "Allwinner" in config description. - Patch 02-03: Rebased on master branch - Patch 04: Removed this patch as CMD_UNZIP has been removed with commit e9d33e7326 ('cmd: move CONFIG_CMD_UNZIP and CONFIG_CMD_ZIP to Kconfig') - Patch 05-06-07-08: Rebased on master branch - Patch 09: Move the CONS_INDEX definition in drivers/serial and convert CHIP pro and A23 EVB defconfigs.
* Summary of patches *
Patch 1: Convert SUNXI_GMAC config to Kconfig and remove it from all defconfig. Patch 2: Remove AXP209_POWER configuration as this config is already converted in Kconfig (drivers/power). It is automatically chosen when the SoC is sun4i, sun5i or sun7i. Patch 3: Remove CMD_BMP configs from SYS_EXTRA_OPTIONS. Patch 4: Remove SYS_EXTRA_OPTIONS from mk802_defconfig as it contains only USB_EHCI which is already converted to Kconfig. Patch 5, 6: Convert SUNXI_EMAC and CONFIG_RGMII to Kconfig and remove it from all SYS_EXTRA_OPTIONS entries. Patch 7 and 8: Convert CONFIG_SATAPWR and CONFIG_MACPWR to Kconfig. It becomes a string instead of the gpio number so the function sunxi_name_to_gpio is used to do the conversion from string to int. Patch 9: Convert console index (CONS_INDEX) to Kconfig. The default value is 1 except for sun5i which is 2 and sun8i which is 5.
Thank you in advance! Best regards, Mylène
Mylène Josserand (9): sunxi: Move SUNXI_GMAC to Kconfig sunxi: icnova-a20-swac_defconfig: Remove AXP209_POWER sunxi: icnova-a20-swac_defconfig: Remove CMD_BMP from sunxi: mk802_defconfig: Remove SYS_EXTRA_OPTIONS sunxi: Convert SUNXI_EMAC to Kconfig sunxi: Convert CONFIG_RGMII to Kconfig sunxi: Convert CONFIG_SATAPWR to Kconfig sunxi: Convert CONFIG_MACPWR to Kconfig sunxi: Convert CONS_INDEX to Kconfig
board/sunxi/Kconfig | 14 ++++++++++++++ board/sunxi/board.c | 12 +++++++----- configs/A10-OLinuXino-Lime_defconfig | 3 ++- configs/A10s-OLinuXino-M_defconfig | 2 +- configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 4 +++- configs/A20-OLinuXino-Lime_defconfig | 3 ++- configs/A20-OLinuXino_MICRO_defconfig | 3 ++- configs/A20-Olimex-SOM-EVB_defconfig | 4 +++- configs/Ampe_A76_defconfig | 1 - configs/Bananapi_defconfig | 4 +++- configs/Bananapro_defconfig | 4 +++- configs/CHIP_defconfig | 1 - configs/CHIP_pro_defconfig | 2 +- configs/CSQ_CS908_defconfig | 2 +- configs/Colombus_defconfig | 3 ++- configs/Cubieboard2_defconfig | 3 ++- configs/Cubieboard_defconfig | 3 ++- configs/Cubietruck_defconfig | 4 +++- configs/Empire_electronix_d709_defconfig | 1 - configs/Empire_electronix_m712_defconfig | 1 - configs/Hummingbird_A31_defconfig | 3 ++- configs/Itead_Ibox_A20_defconfig | 3 ++- configs/Lamobo_R1_defconfig | 5 ++++- configs/Linksprite_pcDuino3_Nano_defconfig | 4 +++- configs/Linksprite_pcDuino3_defconfig | 3 ++- configs/Linksprite_pcDuino_defconfig | 2 +- configs/Marsboard_A10_defconfig | 2 +- configs/Mele_A1000G_quad_defconfig | 2 +- configs/Mele_A1000_defconfig | 3 ++- configs/Mele_I7_defconfig | 2 +- configs/Mele_M3_defconfig | 2 +- configs/Mele_M5_defconfig | 2 +- configs/Mele_M9_defconfig | 2 +- configs/Orangepi_defconfig | 4 +++- configs/Orangepi_mini_defconfig | 4 +++- configs/Sinlinx_SinA31s_defconfig | 2 +- configs/Sinovoip_BPI_M2_defconfig | 3 ++- configs/Sinovoip_BPI_M3_defconfig | 2 +- configs/Wits_Pro_A20_DKT_defconfig | 3 ++- configs/ba10_tv_box_defconfig | 2 +- configs/difrnce_dit4350_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/i12-tvbox_defconfig | 3 ++- configs/iNet_D978_rev2_defconfig | 1 - configs/icnova-a20-swac_defconfig | 2 +- configs/inet86dz_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/jesurun_q5_defconfig | 3 ++- configs/mixtile_loftq_defconfig | 4 +++- configs/mk802_defconfig | 1 - configs/orangepi_plus2e_defconfig | 2 +- configs/orangepi_plus_defconfig | 3 ++- configs/polaroid_mid2407pxe03_defconfig | 1 - configs/polaroid_mid2809pxe04_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - configs/sun8i_a23_evb_defconfig | 1 - drivers/net/Kconfig | 17 +++++++++++++++++ drivers/serial/Kconfig | 10 ++++++++++ include/configs/sunxi-common.h | 4 ---- 65 files changed, 124 insertions(+), 69 deletions(-)
Move the SUNXI_GMAC config option to Kconfig, remove it from SYS_EXTRA_OPTIONS and rename it into SUN7I_GMAC.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/A20-OLinuXino-Lime2_defconfig | 3 ++- configs/A20-OLinuXino-Lime_defconfig | 3 ++- configs/A20-OLinuXino_MICRO_defconfig | 3 ++- configs/A20-Olimex-SOM-EVB_defconfig | 3 ++- configs/Bananapi_defconfig | 3 ++- configs/Bananapro_defconfig | 3 ++- configs/CSQ_CS908_defconfig | 2 +- configs/Colombus_defconfig | 3 ++- configs/Cubieboard2_defconfig | 3 ++- configs/Cubietruck_defconfig | 3 ++- configs/Hummingbird_A31_defconfig | 3 ++- configs/Itead_Ibox_A20_defconfig | 3 ++- configs/Lamobo_R1_defconfig | 3 ++- configs/Linksprite_pcDuino3_Nano_defconfig | 3 ++- configs/Linksprite_pcDuino3_defconfig | 3 ++- configs/Mele_A1000G_quad_defconfig | 2 +- configs/Mele_I7_defconfig | 2 +- configs/Mele_M3_defconfig | 2 +- configs/Mele_M5_defconfig | 2 +- configs/Mele_M9_defconfig | 2 +- configs/Orangepi_defconfig | 3 ++- configs/Orangepi_mini_defconfig | 3 ++- configs/Sinlinx_SinA31s_defconfig | 2 +- configs/Sinovoip_BPI_M2_defconfig | 3 ++- configs/Wits_Pro_A20_DKT_defconfig | 3 ++- configs/i12-tvbox_defconfig | 3 ++- configs/icnova-a20-swac_defconfig | 3 ++- configs/mixtile_loftq_defconfig | 3 ++- drivers/net/Kconfig | 5 +++++ 29 files changed, 54 insertions(+), 28 deletions(-)
diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 0d38f65c50..33e552b133 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -9,7 +9,7 @@ CONFIG_USB0_VBUS_DET="PH5" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -22,6 +22,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_DFU_RAM=y CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index dea2e6b6f2..8de1c1a635 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -7,7 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -16,6 +16,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 703aee13c3..3fa869a7ed 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -10,7 +10,7 @@ CONFIG_VIDEO_VGA=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -19,6 +19,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index fbc4fe0e52..28c9781480 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -12,7 +12,7 @@ CONFIG_USB0_VBUS_DET="PH5" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -22,6 +22,7 @@ CONFIG_SPL=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 8fccea8103..926bb10d95 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -8,7 +8,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -18,4 +18,5 @@ CONFIG_SPL=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index dda7080d9d..f8f7b458fa 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -10,7 +10,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -20,5 +20,6 @@ CONFIG_SPL=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO4_VOLT=2500 CONFIG_USB_EHCI_HCD=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 953ec253c0..a6fcbf5ecf 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -6,7 +6,6 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-cs908" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -15,6 +14,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index ac283a2070..1e7d4982c0 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -16,7 +16,7 @@ CONFIG_VIDEO_LCD_PANEL_I2C_SCL="PA24" CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -25,5 +25,6 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index ca3c991405..a298f0a275 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -7,7 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -16,4 +16,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 4ac1285338..c06f1c90df 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -12,7 +12,7 @@ CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPH(12)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(12)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -24,6 +24,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DFU_RAM=y CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index c1cbbc829a..d5de518456 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -8,7 +8,7 @@ CONFIG_VIDEO_VGA_VIA_LCD=y CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -17,5 +17,6 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 7d0b8ed64b..9ab5314f7c 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -7,7 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -16,4 +16,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index d37fa02f3a..ba41535e65 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -8,7 +8,7 @@ CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -17,4 +17,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 0663c46bb1..e2eb887709 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -9,7 +9,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -18,4 +18,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index e116345b74..f589fa2a8c 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -7,7 +7,7 @@ CONFIG_DRAM_ZQ=122 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -16,4 +16,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index 8f03835375..5b1b5f5d7c 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -7,7 +7,6 @@ CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mele-a1000g-quad" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -16,6 +15,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 572b5219cc..b60969787c 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -6,7 +6,6 @@ CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-i7" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -15,6 +14,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 31e8aaf551..06b7949ba4 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -9,7 +9,6 @@ CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -18,4 +17,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 6993894526..0c26868e28 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -9,7 +9,6 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m5" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -18,4 +17,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index a9dc159063..dc7901f9af 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -6,7 +6,6 @@ CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-m9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -15,6 +14,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 6faad87e7e..906ce91c7d 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -11,7 +11,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -20,4 +20,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 0224ee74be..75ea41fe51 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -13,7 +13,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -22,4 +22,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 54c975a2b2..7f815a32cb 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -10,7 +10,6 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sina31s" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -19,5 +18,6 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index dbff2344bb..d123fad96b 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -6,7 +6,7 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -15,6 +15,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_ALDO2_VOLT=1800 CONFIG_AXP_DLDO1_VOLT=3000 diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 6385a79ca4..5c2b340205 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -12,7 +12,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -21,4 +21,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 8c35fe6b86..3daec37448 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -6,7 +6,7 @@ CONFIG_DRAM_CLK=384 CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,MACPWR=SUNXI_GPH(21)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -15,4 +15,5 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 5ef0e47b4e..e2fb111d0c 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -13,7 +13,7 @@ CONFIG_VIDEO_LCD_POWER="PH22" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP" +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,CMD_BMP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_UNZIP=y @@ -23,4 +23,5 @@ CONFIG_CMD_UNZIP=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index ec6a4381ac..2dd107596a 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -7,7 +7,7 @@ CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPA(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -16,5 +16,6 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 70e36611ea..1989890c3e 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -161,6 +161,11 @@ config RTL8169 This driver supports Realtek 8169 series gigabit ethernet family of PCI/PCIe chipsets/adapters.
+config SUN7I_GMAC + bool "Enable Allwinner GMAC Ethernet support" + help + Enable the support for Sun7i GMAC Ethernet controller + config SUN8I_EMAC bool "Allwinner Sun8i Ethernet MAC support" depends on DM_ETH
Remove the AXP209_POWER option from SYS_EXTRA_OPTIONS. As this configuration already exists on Kconfig, we just need to remove it from defconfig.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/icnova-a20-swac_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index e2fb111d0c..4c9e4afd25 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -13,7 +13,7 @@ CONFIG_VIDEO_LCD_POWER="PH22" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,CMD_BMP" +CONFIG_SYS_EXTRA_OPTIONS="CMD_BMP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_UNZIP=y
This configuration is not necessary in a defconfig file so it is removed from the SYS_EXTRA_OPTIONS.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/icnova-a20-swac_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 4c9e4afd25..38636ddda8 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -13,7 +13,6 @@ CONFIG_VIDEO_LCD_POWER="PH22" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CMD_BMP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_UNZIP=y
The USB_EHCI configuration is already set in this defconfig using kconfig's config. This configuration in SYS_EXTRA_OPTIONS must be removed and so the SYS_EXTRA_OPTIONS.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/mk802_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 0bd957b2d5..da9728ae9e 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -4,7 +4,6 @@ CONFIG_MACH_SUN4I=y CONFIG_USB2_VBUS_PIN="PH12" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
Convert the SUNXI_EMAC config to Kconfig. Remove it from SYS_EXTRA_OPTIONS from many sunxi defconfig and renamed it into SUN4I_EMAC to not confuse it with SUN8I_EMAC.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/A10-OLinuXino-Lime_defconfig | 3 ++- configs/A10s-OLinuXino-M_defconfig | 2 +- configs/Cubieboard_defconfig | 3 ++- configs/Linksprite_pcDuino_defconfig | 2 +- configs/Marsboard_A10_defconfig | 2 +- configs/Mele_A1000_defconfig | 3 ++- configs/ba10_tv_box_defconfig | 2 +- configs/jesurun_q5_defconfig | 3 ++- drivers/net/Kconfig | 6 ++++++ 9 files changed, 18 insertions(+), 8 deletions(-)
diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 9368c6d4b7..d24c357952 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -9,7 +9,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -17,6 +17,7 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN4I_EMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 6adb5bc9a4..f04fd5696d 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -9,7 +9,6 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=1 CONFIG_USB1_VBUS_PIN="PB10" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -17,5 +16,6 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN4I_EMAC=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 0389d4c3c7..fadf201478 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -7,7 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -15,4 +15,5 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index 8b310fa5c2..93f5b6e7e9 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -6,7 +6,6 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pcduino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -14,4 +13,5 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 34e78f1e8c..6b8bd1ad20 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -4,7 +4,6 @@ CONFIG_MACH_SUN4I=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-marsboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -12,5 +11,6 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN4I_EMAC=y CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 5047ba4b21..a65198a42c 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -7,7 +7,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(15)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(15)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -15,4 +15,5 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index c9a9e8e89a..c3bf21d543 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -9,7 +9,6 @@ CONFIG_USB2_VBUS_PIN="PH12" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-ba10-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -17,5 +16,6 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index c009fff224..1e7fbc3382 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -7,7 +7,7 @@ CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(19)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(19)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -15,5 +15,6 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 1989890c3e..7f4b93f24c 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -166,6 +166,12 @@ config SUN7I_GMAC help Enable the support for Sun7i GMAC Ethernet controller
+config SUN4I_EMAC + bool "Allwinner Sun4i Ethernet MAC support" + depends on DM_ETH + help + This driver supports the Allwinner based SUN4I Ethernet MAC. + config SUN8I_EMAC bool "Allwinner Sun8i Ethernet MAC support" depends on DM_ETH
Convert CONFIG_RGMII to Kconfig. Thanks to that, it is possible to update defconfig files of SYS_EXTRA_OPTIONS accordingly and remove it when it is possible.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/A20-OLinuXino-Lime2_defconfig | 3 ++- configs/A20-Olimex-SOM-EVB_defconfig | 3 ++- configs/Bananapi_defconfig | 3 ++- configs/Bananapro_defconfig | 3 ++- configs/Colombus_defconfig | 2 +- configs/Cubietruck_defconfig | 3 ++- configs/Hummingbird_A31_defconfig | 2 +- configs/Lamobo_R1_defconfig | 3 ++- configs/Linksprite_pcDuino3_Nano_defconfig | 3 ++- configs/Orangepi_defconfig | 3 ++- configs/Orangepi_mini_defconfig | 3 ++- configs/Sinovoip_BPI_M2_defconfig | 2 +- configs/Wits_Pro_A20_DKT_defconfig | 2 +- configs/mixtile_loftq_defconfig | 3 ++- drivers/net/Kconfig | 6 ++++++ 15 files changed, 30 insertions(+), 14 deletions(-)
diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 33e552b133..375f091149 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -9,7 +9,7 @@ CONFIG_USB0_VBUS_DET="PH5" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -22,6 +22,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_DFU_RAM=y CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 28c9781480..efd7f716c4 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -12,7 +12,7 @@ CONFIG_USB0_VBUS_DET="PH5" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -22,6 +22,7 @@ CONFIG_SPL=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 926bb10d95..d08cffe8e9 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -8,7 +8,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -18,5 +18,6 @@ CONFIG_SPL=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index f8f7b458fa..42357e31c7 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -10,7 +10,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -20,6 +20,7 @@ CONFIG_SPL=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO4_VOLT=2500 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index 1e7d4982c0..1359281ff4 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_PANEL_I2C_SCL="PA24" CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -25,6 +24,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index c06f1c90df..9c401025c6 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -12,7 +12,7 @@ CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(12)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(12)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -24,6 +24,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DFU_RAM=y CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index d5de518456..6f9b103207 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -8,7 +8,6 @@ CONFIG_VIDEO_VGA_VIA_LCD=y CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -17,6 +16,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index ba41535e65..5357032196 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -8,7 +8,7 @@ CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -17,5 +17,6 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index e2eb887709..731c10be1c 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -9,7 +9,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -18,5 +18,6 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 906ce91c7d..6490286837 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -11,7 +11,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -20,5 +20,6 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 75ea41fe51..8a7721f10a 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -13,7 +13,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -22,5 +22,6 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index d123fad96b..a2cadbc271 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -6,7 +6,6 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -15,6 +14,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_ALDO2_VOLT=1800 diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 5c2b340205..a2f204d0bf 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -12,7 +12,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -21,5 +20,6 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 2dd107596a..591f48169d 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -7,7 +7,7 @@ CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPA(21)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPA(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -16,6 +16,7 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 7f4b93f24c..c2dfec87e2 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -149,6 +149,12 @@ config PCH_GBE This MAC is present in Intel Platform Controller Hub EG20T. It supports 10/100/1000 Mbps operation.
+config RGMII + bool "Enable RGMII" + help + Enable the support of the Reduced Gigabit Media-Independent + Interface (RGMII). + config RTL8139 bool "Realtek 8139 series Ethernet controller driver" help
Convert the CONFIG_SATAPWR into kconfig. Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some defconfigs.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- board/sunxi/Kconfig | 7 +++++++ board/sunxi/board.c | 7 ++++--- configs/A10-OLinuXino-Lime_defconfig | 2 +- configs/A20-OLinuXino-Lime2_defconfig | 2 +- configs/A20-OLinuXino-Lime_defconfig | 2 +- configs/A20-OLinuXino_MICRO_defconfig | 2 +- configs/A20-Olimex-SOM-EVB_defconfig | 2 +- configs/Cubieboard2_defconfig | 2 +- configs/Cubieboard_defconfig | 2 +- configs/Cubietruck_defconfig | 2 +- configs/Itead_Ibox_A20_defconfig | 2 +- configs/Lamobo_R1_defconfig | 3 ++- configs/Linksprite_pcDuino3_Nano_defconfig | 2 +- configs/Linksprite_pcDuino3_defconfig | 2 +- configs/Sinovoip_BPI_M3_defconfig | 2 +- configs/orangepi_plus_defconfig | 3 ++- 16 files changed, 27 insertions(+), 17 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 3e0e262473..35328b6a93 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -704,6 +704,13 @@ config VIDEO_LCD_TL059WV5C0
endchoice
+config SATAPWR + string "SATA power pin" + default "" + help + Set the pins used to power the SATA. This takes a string in the + format understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of + port H.
config GMAC_TX_DELAY int "GMAC Transmit Clock Delay Chain" diff --git a/board/sunxi/board.c b/board/sunxi/board.c index b9660128e5..8043a8dbac 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -80,7 +80,7 @@ DECLARE_GLOBAL_DATA_PTR; /* add board specific code here */ int board_init(void) { - __maybe_unused int id_pfr1, ret; + __maybe_unused int id_pfr1, ret, satapwr_pin;
gd->bd->bi_boot_params = (PHYS_SDRAM_0 + 0x100);
@@ -118,8 +118,9 @@ int board_init(void) return ret;
#ifdef CONFIG_SATAPWR - gpio_request(CONFIG_SATAPWR, "satapwr"); - gpio_direction_output(CONFIG_SATAPWR, 1); + satapwr_pin = sunxi_name_to_gpio(CONFIG_SATAPWR); + gpio_request(satapwr_pin, "satapwr"); + gpio_direction_output(satapwr_pin, 1); #endif #ifdef CONFIG_MACPWR gpio_request(CONFIG_MACPWR, "macpwr"); diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index d24c357952..405bd3f2a8 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -6,10 +6,10 @@ CONFIG_DRAM_CLK=480 CONFIG_DRAM_EMR1=4 CONFIG_SYS_CLK_FREQ=912000000 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PC3" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 375f091149..a9c7566d12 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -6,10 +6,10 @@ CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" +CONFIG_SATAPWR="PC3" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 8de1c1a635..b53441c748 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -4,10 +4,10 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PC3" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 3fa869a7ed..c1cd2dd05e 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -7,10 +7,10 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_VIDEO_VGA=y +CONFIG_SATAPWR="PB8" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index efd7f716c4..28091efa36 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -9,10 +9,10 @@ CONFIG_MMC3_PINS="PH" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" +CONFIG_SATAPWR="PC3" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index a298f0a275..72ce3aed3c 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -4,10 +4,10 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PB8" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index fadf201478..081fcd75c7 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -4,10 +4,10 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PB8" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 9c401025c6..987e035a89 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -8,11 +8,11 @@ CONFIG_USB0_VBUS_PIN="PH17" CONFIG_USB0_VBUS_DET="PH22" CONFIG_USB0_ID_DET="PH19" CONFIG_VIDEO_VGA=y +CONFIG_SATAPWR="PH12" CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(12)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 9ab5314f7c..f6b5c1b954 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -4,10 +4,10 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PB8" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 5357032196..955be841e7 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -4,11 +4,12 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH10" +CONFIG_SATAPWR="PB3" CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 731c10be1c..eb8039a10f 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -5,11 +5,11 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=122 CONFIG_USB1_VBUS_PIN="PH11" +CONFIG_SATAPWR="PH2" CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index f589fa2a8c..1a354812b4 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -4,10 +4,10 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_DRAM_ZQ=122 +CONFIG_SATAPWR="PH2" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index aec3f7d4bb..45eadcb443 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -11,9 +11,9 @@ CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_USB0_ID_DET="PH11" CONFIG_USB1_VBUS_PIN="PD24" CONFIG_AXP_GPIO=y +CONFIG_SATAPWR="PD25" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-sinovoip-bpi-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPD(25)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 78be69eec5..3fd3f09627 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -7,9 +7,10 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PG13" +CONFIG_SATAPWR="PG11" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPG(11),MACPWR=SUNXI_GPD(6)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set
Convert the CONFIG_MACPWR to Kconfig and update all the sunxi defconfigs that used it in SYS_EXTRA_OPTIONS.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- board/sunxi/Kconfig | 7 +++++++ board/sunxi/board.c | 7 ++++--- configs/Bananapi_defconfig | 2 +- configs/Bananapro_defconfig | 2 +- configs/Lamobo_R1_defconfig | 2 +- configs/Mele_A1000_defconfig | 2 +- configs/Orangepi_defconfig | 2 +- configs/Orangepi_mini_defconfig | 2 +- configs/i12-tvbox_defconfig | 2 +- configs/jesurun_q5_defconfig | 2 +- configs/mixtile_loftq_defconfig | 2 +- configs/orangepi_plus2e_defconfig | 2 +- configs/orangepi_plus_defconfig | 2 +- 13 files changed, 22 insertions(+), 14 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 35328b6a93..32b2e3e2c0 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -343,6 +343,13 @@ config OLD_SUNXI_KERNEL_COMPAT Set this to enable various workarounds for old kernels, this results in sub-optimal settings for newer kernels, only enable if needed.
+config MACPWR + string "MAC power pin" + default "" + help + Set the pin used to power the MAC. This takes a string in the format + understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of port H. + config MMC0_CD_PIN string "Card detect pin for mmc0" default "PF6" if MACH_SUN8I_A83T || MACH_SUNXI_H3_H5 || MACH_SUN50I diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 8043a8dbac..e2bba9abde 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -80,7 +80,7 @@ DECLARE_GLOBAL_DATA_PTR; /* add board specific code here */ int board_init(void) { - __maybe_unused int id_pfr1, ret, satapwr_pin; + __maybe_unused int id_pfr1, ret, satapwr_pin, macpwr_pin;
@@ -123,8 +123,9 @@ int board_init(void) gpio_direction_output(satapwr_pin, 1); #endif #ifdef CONFIG_MACPWR - gpio_request(CONFIG_MACPWR, "macpwr"); - gpio_direction_output(CONFIG_MACPWR, 1); + macpwr_pin = sunxi_name_to_gpio(CONFIG_MACPWR); + gpio_request(macpwr_pin, "macpwr"); + gpio_direction_output(macpwr_pin, 1); #endif
/* Uses dm gpio code so do this here and not in i2c_init_board() */ diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index d08cffe8e9..99c02a341e 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -3,12 +3,12 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 42357e31c7..8fab56f91f 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_USB1_VBUS_PIN="PH0" CONFIG_USB2_VBUS_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y @@ -10,7 +11,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 955be841e7..3c7e0a0eec 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -3,13 +3,13 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_MMC0_CD_PIN="PH10" CONFIG_SATAPWR="PB3" CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index a65198a42c..ee2362dd7b 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -2,12 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN4I=y +CONFIG_MACPWR="PH15" CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(15)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 6490286837..d469697737 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_VGA=y @@ -11,7 +12,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 8a7721f10a..59ccd33cf2 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_MMC0_CD_PIN="PH10" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 @@ -13,7 +14,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 3daec37448..e6f6f37119 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -3,10 +3,10 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 +CONFIG_MACPWR="PH21" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 1e7fbc3382..6ff9445f8f 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -3,11 +3,11 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=312 +CONFIG_MACPWR="PH19" CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(19)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 591f48169d..6264b3a151 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -2,12 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=251 +CONFIG_MACPWR="PA21" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPA(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_plus2e_defconfig b/configs/orangepi_plus2e_defconfig index 60f4eaa655..3479117104 100644 --- a/configs/orangepi_plus2e_defconfig +++ b/configs/orangepi_plus2e_defconfig @@ -5,10 +5,10 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus2e" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 3fd3f09627..7d631bcb97 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -5,12 +5,12 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PG13" CONFIG_SATAPWR="PG11" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set
Convert the CONS_INDEX configuration to Kconfig. Update sunxi's defconfigs to remove SYS_EXTRA_OPTIONS variable not needed anymore. Default value is 1 except for sun5i (equals 2) and sun8i (equals 5).
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/Ampe_A76_defconfig | 1 - configs/CHIP_defconfig | 1 - configs/CHIP_pro_defconfig | 2 +- configs/Empire_electronix_d709_defconfig | 1 - configs/Empire_electronix_m712_defconfig | 1 - configs/difrnce_dit4350_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/iNet_D978_rev2_defconfig | 1 - configs/inet86dz_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/polaroid_mid2407pxe03_defconfig | 1 - configs/polaroid_mid2809pxe04_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - configs/sun8i_a23_evb_defconfig | 1 - drivers/serial/Kconfig | 10 ++++++++++ include/configs/sunxi-common.h | 4 ---- 22 files changed, 11 insertions(+), 24 deletions(-)
diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index 264135b271..530a60edbb 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -12,7 +12,6 @@ CONFIG_VIDEO_LCD_POWER="PB10" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 3c4ce1921f..d6062f8cf4 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index b7ff53532d..ea19592662 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-ampe-a76" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 9d567e1e54..be0b0bacad 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -8,7 +8,6 @@ CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y CONFIG_USB0_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-r8-chip" -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_DFU=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index df43e5a12d..78fdb0e7d8 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -7,7 +7,7 @@ CONFIG_MACH_SUN5I=y CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y CONFIG_USB0_VBUS_PIN="PB10" CONFIG_DEFAULT_DEVICE_TREE="sun5i-gr8-chip-pro" -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2,SYS_NAND_BLOCK_SIZE=0x40000,SYS_NAND_PAGE_SIZE=4096,SYS_NAND_OOBSIZE=256" +CONFIG_SYS_EXTRA_OPTIONS="SYS_NAND_BLOCK_SIZE=0x40000,SYS_NAND_PAGE_SIZE=4096,SYS_NAND_OOBSIZE=256" CONFIG_ENV_IS_IN_UBI=y CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="uboot-env" diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 93aeaf4047..bf6cd05111 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-d709" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Empire_electronix_m712_defconfig b/configs/Empire_electronix_m712_defconfig index 160f8461a2..3111801b21 100644 --- a/configs/Empire_electronix_m712_defconfig +++ b/configs/Empire_electronix_m712_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-m712" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index 045f87c2c9..af15e933af 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-difrnce-dit4350" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 358a13996a..8e1c9f79a8 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ga10h-v1.1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index d7c2bb7b6e..8f6469de61 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-gt90h-v4" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index b2febab2db..62e4f1b363 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-inet-d978-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index c7753b3a72..7940d971b7 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-inet86dz" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index e25859e48c..581870e003 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-98v-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index 3beba97cdd..d48a50701b 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2407pxe03" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index bbf2819252..72fe096e63 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2809pxe04" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index af094f1b51..beaf8529ad 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 5ad67d7bee..1762fe48d6 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index 0e3bc133ea..d42b597db6 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index b5b7782a60..5b6dfe0d87 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/sun8i_a23_evb_defconfig b/configs/sun8i_a23_evb_defconfig index 296df00043..49ba431452 100644 --- a/configs/sun8i_a23_evb_defconfig +++ b/configs/sun8i_a23_evb_defconfig @@ -8,7 +8,6 @@ CONFIG_USB0_VBUS_DET="axp_vbus_detect" CONFIG_USB1_VBUS_PIN="PH7" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-evb" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index b11f3ff89e..f8ae494369 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -310,6 +310,16 @@ config ATMEL_USART configured in the device tree, and input clock frequency can be got from the clk node.
+config CONS_INDEX + int "UART used for console" + default 2 if MACH_SUN5I + default 5 if MACH_SUN8I + default 1 + help + Configures the console index. + For Allwinner SoC., default values are 2 for SUN5I and 5 for SUN8I. + Otherwise, the index equals 1. + config FSL_LPUART bool "Freescale LPUART support" help diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index e57225c6e3..67e1465b69 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -244,10 +244,6 @@ extern int soft_i2c_gpio_scl; defined CONFIG_SY8106A_POWER #endif
-#ifndef CONFIG_CONS_INDEX -#define CONFIG_CONS_INDEX 1 /* UART0 */ -#endif - #ifdef CONFIG_REQUIRE_SERIAL_CONSOLE #if CONFIG_CONS_INDEX == 1 #ifdef CONFIG_MACH_SUN9I
On Sun, Apr 02, 2017 at 12:59:02PM +0200, Mylène Josserand wrote:
This a V3 for my patchset that removes the SYS_EXTRA_OPTIONS from all sunxi defconfigs. The values in this variable are converted to Kconfig or simply removed.
Based on u-boot sunxi repository: git://git.denx.de/u-boot-sunxi.git "master" branch, from last commit: 6f72a951cdd07e3f9d214b189762b978cd2acf45
Thanks for sending this again.
There was a build breakage for all the non-sunxi boards in your last patch. I've fixed it by adding a depends on ARCH_SUNXI to avoid multiple definitions of CONS_INDEX on the other architectures, and applied it.
Thanks! Maxime
These need to to send-again on top of master-pr, I'm running buildman on top of u-boot/master with sunxi/master changes. Observed errors while applying these 9 patches,
thanks!
I ran buildman on the patches that have been pushed, there's no errors, which errors did you encounter.
The branches are kind of weird too, afaik, there's three of them, master, master-pr (that has been created today), master-next (that has kind of the same patches than master, but doesn't share the same history for some reason) and next (with yet again a different set of patches than master, but definitely not the same than master-next).
Can we agree on *one* branch to push patches too?
Maxime
On Tue, Apr 4, 2017 at 3:11 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
[1] these are buildman issues, I rebased master with sunxi/master and ran the buildman.
Now, re-arranged and squashed few commits and running master-pr, once this is fine I will copy this as master and send the PR. So-that we can apply patches on top of this.
[1] https://www.mail-archive.com/u-boot@lists.denx.de/msg243580.html
thanks!
See the answers from Chen-Yu, those issues are already fixed.
So, where am I supposed to apply patches? master, master-pr, next, master-next? What are those branches for?
Maxime
On Tue, Apr 4, 2017 at 5:04 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
Now master, is up-to-date. Please rebase and send the series again.
thanks!
On Sun, Apr 02, 2017 at 12:59:02PM +0200, Mylène Josserand wrote: > This a V3 for my patchset that removes the SYS_EXTRA_OPTIONS from all > sunxi defconfigs. > The values in this variable are converted to Kconfig or simply removed. > > Based on u-boot sunxi repository: git://git.denx.de/u-boot-sunxi.git > "master" branch, from last commit: 6f72a951cdd07e3f9d214b189762b978cd2acf45
Yet, the patches are in your next branch. Could you *please* give some explanation of what you're doing with these branches?
Thanks, Maxime
On Tue, Apr 18, 2017 at 12:43 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
On Tuesday 04 April 2017 01:42 PM, Maxime Ripard wrote: > Hi, > > On Sun, Apr 02, 2017 at 12:59:02PM +0200, Mylène Josserand wrote: > > This a V3 for my patchset that removes the SYS_EXTRA_OPTIONS from all > > sunxi defconfigs. > > The values in this variable are converted to Kconfig or simply removed. > > > > Based on u-boot sunxi repository: git://git.denx.de/u-boot-sunxi.git > > "master" branch, from last commit: 6f72a951cdd07e3f9d214b189762b978cd2acf45 > > Thanks for sending this again. > > There was a build breakage for all the non-sunxi boards in your last > patch. I've fixed it by adding a depends on ARCH_SUNXI to avoid > multiple definitions of CONS_INDEX on the other architectures, and > applied it.
Patches from -next were unable to merge, so better to send the series again on top of master. The reason for master-pr for sending local branch with buildman setup I would usually create local branches for buildman which will send as PR, but this will remove once PR passed.
Now all clean, we have master and next.
thanks!
On Tue, Apr 04, 2017 at 02:25:09PM +0530, Jagan Teki wrote: > On Tuesday 04 April 2017 01:42 PM, Maxime Ripard wrote: > > Hi, > > > > On Sun, Apr 02, 2017 at 12:59:02PM +0200, Mylène Josserand wrote: > > > This a V3 for my patchset that removes the SYS_EXTRA_OPTIONS from all > > > sunxi defconfigs. > > > The values in this variable are converted to Kconfig or simply removed. > > > > > > Based on u-boot sunxi repository: git://git.denx.de/u-boot-sunxi.git > > > "master" branch, from last commit: 6f72a951cdd07e3f9d214b189762b978cd2acf45 > > > > Thanks for sending this again. > > > > There was a build breakage for all the non-sunxi boards in your last > > patch. I've fixed it by adding a depends on ARCH_SUNXI to avoid > > multiple definitions of CONS_INDEX on the other architectures, and > > applied it. > > These need to to send-again on top of master-pr, I'm running buildman on top > of u-boot/master with sunxi/master changes. Observed errors while applying > these 9 patches,
So, if I was to apply a patch, on which branch should I do it?
Maxime
Jagan Teki
Jagan Teki
Maxime Ripard
Mylène Josserand
