[PATCH] sunxi: Load sun8i secure monitor to SRAM A2
Most sun6i-derived SoCs contain SRAM A2, a secure SRAM area for ARISC SCP firmware. H3 has a smaller SRAM than other SoCs (A31/A33/A23/A83T).
On sun8i SoCs which do not have SRAM B, we can use part of this SRAM for the secure monitor. Follow the design of 64-bit SoCs and use the first part for the monitor, and the last 16 KiB for the SCP firmware. With this change, the monitor no longer needs to reserve a region in DRAM.
Signed-off-by: Samuel Holland samuel@sholland.org --- arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 11 +++++++++++ include/configs/sun8i.h | 7 +++++++ 2 files changed, 18 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index 02ce73954d..d4c795d89c 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -11,7 +11,18 @@ #define SUNXI_SRAM_A1_BASE 0x00000000 #define SUNXI_SRAM_A1_SIZE (16 * 1024) /* 16 kiB */
+#if defined(CONFIG_SUNXI_GEN_SUN6I) && \ + !defined(CONFIG_MACH_SUN8I_R40) && \ + !defined(CONFIG_MACH_SUN8I_V3S) +#define SUNXI_SRAM_A2_BASE 0x00040000 +#ifdef CONFIG_MACH_SUN8I_H3 +#define SUNXI_SRAM_A2_SIZE (48 * 1024) /* 16+32 kiB */ +#else +#define SUNXI_SRAM_A2_SIZE (80 * 1024) /* 16+64 kiB */ +#endif +#else #define SUNXI_SRAM_A2_BASE 0x00004000 /* 16 kiB */ +#endif #define SUNXI_SRAM_A3_BASE 0x00008000 /* 13 kiB */ #define SUNXI_SRAM_A4_BASE 0x0000b400 /* 3 kiB */ #define SUNXI_SRAM_D_BASE 0x00010000 /* 4 kiB */ diff --git a/include/configs/sun8i.h b/include/configs/sun8i.h index 9b4675e4c3..545d27996c 100644 --- a/include/configs/sun8i.h +++ b/include/configs/sun8i.h @@ -12,6 +12,13 @@ * A23 specific configuration */
+/* + * Skip the first 16 KiB of SRAM A2, which is not usable, as only certain bytes + * are writable. Reserve the last 17 KiB for the resume shim and SCP firmware. + */ +#define CONFIG_ARMV7_SECURE_BASE (SUNXI_SRAM_A2_BASE + 16 * 1024) +#define CONFIG_ARMV7_SECURE_MAX_SIZE (SUNXI_SRAM_A2_SIZE - 33 * 1024) + /* * Include common sunxi configuration where most the settings are */
On Sun, 18 Apr 2021 22:21:41 -0500 Samuel Holland samuel@sholland.org wrote:
Hi Samuel,
So this commit message reads a bit more innocent than the patch is, can you amend this? It took me a while to see what it really does ...
For a start, I'd suggest to rename the subject to "Move secure monitor...". And it's good to explain where we come from (SRAM B vs. SRAM A2), but I would like to see an explicit list of SoCs that get changed, because all those different sun8i.h, cpu_sun4i.h and CONFIG_SUN8I parts are super confusing to the casual reader.
Maybe something along the lines of: So far for the H3, A23, and A33 SoCs, we use DRAM to hold the secure monitor. And while those SoCs do not have the secure SRAM B like older SoCs, there is enough (secure) SRAM A2 to put the monitor code and data in there instead ....
Regardless of that, the patch is nice, I always disliked reserving a small piece of DRAM somewhere in the middle of it. If I see this correctly, this just leaves the R40 using DRAM for the secure monitor (with V3s and A83T not using PSCI)?
Cheers, Andre
- !defined(CONFIG_MACH_SUN8I_R40) && \
- !defined(CONFIG_MACH_SUN8I_V3S)
- A23 specific configuration
- Skip the first 16 KiB of SRAM A2, which is not usable, as only certain bytes
- are writable. Reserve the last 17 KiB for the resume shim and SCP firmware.
- Include common sunxi configuration where most the settings are
I was about to merge this, but this breaks the build of R40 and V3s boards: arm: + Bananapi_M2_Ultra +u-boot.lds:51: undefined symbol `SUNXI_SRAM_A2_SIZE' referenced in expression +make[1]: *** [u-boot] Error 1 +make: *** [sub-make] Error 2 ...
I fixed it by protecting the parts in sun8i.h with #ifdef SUNXI_SRAM_A2_SIZE, please yell if you disagree: https://source.denx.de/u-boot/custodians/u-boot-sunxi/-/commit/488397ea3801a...
Otherwise I will send a PR soonish.
Cheers, Andre
Andre,
This looks fine. Thanks for taking care of it.
Cheers, Samuel
Cheers, Andre
Andre Przywara
Samuel Holland
