[U-Boot] [PATCH 7/8 v2] UBIFS: Implement read-only UBIFS support in U-Boot (Part 7)
This patchset adds UBIFS read-only support to U-Boot. The following commands are implemented:
- ubifsmount Mount an UBIFS volume
- ubifsls List a directory of the mounted UBIFS volume
- ubifsload Load a file from the mounted UBIFS volume to memory
The U-Boot UBIFS implementation is largely a direct copy from the current Linux version (2.6.29-rc6). As already done in the UBI version we have an "abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock() ...). This makes it possible to use the original Linux code with very little changes. And by this we can better update to later Linux versions.
I removed some of the Linux features that are not used in the U-Boot version (e.g. garbage-collection, write support).
Signed-off-by: Stefan Roese sr@denx.de CC: Artem Bityutskiy dedekind@infradead.org CC: Adrian Hunter ext-Adrian.Hunter@nokia.com --- Changes in v2: - Now symbolic links are handled correctly
Makefile | 3 +- fs/ubifs/Makefile | 52 ++++ fs/ubifs/ubifs-media.h | 751 ++++++++++++++++++++++++++++++++++++++++++++++++ fs/ubifs/ubifs.c | 684 +++++++++++++++++++++++++++++++++++++++++++ include/linux/math64.h | 85 ++++++ 5 files changed, 1574 insertions(+), 1 deletions(-) create mode 100644 fs/ubifs/Makefile create mode 100644 fs/ubifs/ubifs-media.h create mode 100644 fs/ubifs/ubifs.c create mode 100644 include/linux/math64.h
diff --git a/Makefile b/Makefile index 0f018d4..6c0db7f 100644 --- a/Makefile +++ b/Makefile @@ -222,7 +222,8 @@ LIBS += cpu/ixp/npe/libnpe.a endif LIBS += lib_$(ARCH)/lib$(ARCH).a LIBS += fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a \ - fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a fs/yaffs2/libyaffs2.a + fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a fs/yaffs2/libyaffs2.a \ + fs/ubifs/libubifs.a LIBS += net/libnet.a LIBS += disk/libdisk.a LIBS += drivers/bios_emulator/libatibiosemu.a diff --git a/fs/ubifs/Makefile b/fs/ubifs/Makefile new file mode 100644 index 0000000..8328843 --- /dev/null +++ b/fs/ubifs/Makefile @@ -0,0 +1,52 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2003 +# Pavel Bartusek, Sysgo Real-Time Solutions AG, pba@sysgo.de +# +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libubifs.a + +COBJS-$(CONFIG_CMD_UBIFS) := ubifs.o io.o super.o sb.o master.o lpt.o +COBJS-$(CONFIG_CMD_UBIFS) += lpt_commit.o scan.o lprops.o +COBJS-$(CONFIG_CMD_UBIFS) += tnc.o tnc_misc.o debug.o crc16.o budget.o +COBJS-$(CONFIG_CMD_UBIFS) += log.o orphan.o recovery.o replay.o + +SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) + +all: $(LIB) $(AOBJS) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/fs/ubifs/ubifs-media.h b/fs/ubifs/ubifs-media.h new file mode 100644 index 0000000..b25fc36 --- /dev/null +++ b/fs/ubifs/ubifs-media.h @@ -0,0 +1,751 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Artem Bityutskiy (Битюцкий Артём) + * Adrian Hunter + */ + +/* + * This file describes UBIFS on-flash format and contains definitions of all the + * relevant data structures and constants. + * + * All UBIFS on-flash objects are stored in the form of nodes. All nodes start + * with the UBIFS node magic number and have the same common header. Nodes + * always sit at 8-byte aligned positions on the media and node header sizes are + * also 8-byte aligned (except for the indexing node and the padding node). + */ + +#ifndef __UBIFS_MEDIA_H__ +#define __UBIFS_MEDIA_H__ + +/* UBIFS node magic number (must not have the padding byte first or last) */ +#define UBIFS_NODE_MAGIC 0x06101831 + +/* UBIFS on-flash format version */ +#define UBIFS_FORMAT_VERSION 4 + +/* Minimum logical eraseblock size in bytes */ +#define UBIFS_MIN_LEB_SZ (15*1024) + +/* Initial CRC32 value used when calculating CRC checksums */ +#define UBIFS_CRC32_INIT 0xFFFFFFFFU + +/* + * UBIFS does not try to compress data if its length is less than the below + * constant. + */ +#define UBIFS_MIN_COMPR_LEN 128 + +/* + * If compressed data length is less than %UBIFS_MIN_COMPRESS_DIFF bytes + * shorter than uncompressed data length, UBIFS preferes to leave this data + * node uncompress, because it'll be read faster. + */ +#define UBIFS_MIN_COMPRESS_DIFF 64 + +/* Root inode number */ +#define UBIFS_ROOT_INO 1 + +/* Lowest inode number used for regular inodes (not UBIFS-only internal ones) */ +#define UBIFS_FIRST_INO 64 + +/* + * Maximum file name and extended attribute length (must be a multiple of 8, + * minus 1). + */ +#define UBIFS_MAX_NLEN 255 + +/* Maximum number of data journal heads */ +#define UBIFS_MAX_JHEADS 1 + +/* + * Size of UBIFS data block. Note, UBIFS is not a block oriented file-system, + * which means that it does not treat the underlying media as consisting of + * blocks like in case of hard drives. Do not be confused. UBIFS block is just + * the maximum amount of data which one data node can have or which can be + * attached to an inode node. + */ +#define UBIFS_BLOCK_SIZE 4096 +#define UBIFS_BLOCK_SHIFT 12 + +/* UBIFS padding byte pattern (must not be first or last byte of node magic) */ +#define UBIFS_PADDING_BYTE 0xCE + +/* Maximum possible key length */ +#define UBIFS_MAX_KEY_LEN 16 + +/* Key length ("simple" format) */ +#define UBIFS_SK_LEN 8 + +/* Minimum index tree fanout */ +#define UBIFS_MIN_FANOUT 3 + +/* Maximum number of levels in UBIFS indexing B-tree */ +#define UBIFS_MAX_LEVELS 512 + +/* Maximum amount of data attached to an inode in bytes */ +#define UBIFS_MAX_INO_DATA UBIFS_BLOCK_SIZE + +/* LEB Properties Tree fanout (must be power of 2) and fanout shift */ +#define UBIFS_LPT_FANOUT 4 +#define UBIFS_LPT_FANOUT_SHIFT 2 + +/* LEB Properties Tree bit field sizes */ +#define UBIFS_LPT_CRC_BITS 16 +#define UBIFS_LPT_CRC_BYTES 2 +#define UBIFS_LPT_TYPE_BITS 4 + +/* The key is always at the same position in all keyed nodes */ +#define UBIFS_KEY_OFFSET offsetof(struct ubifs_ino_node, key) + +/* + * LEB Properties Tree node types. + * + * UBIFS_LPT_PNODE: LPT leaf node (contains LEB properties) + * UBIFS_LPT_NNODE: LPT internal node + * UBIFS_LPT_LTAB: LPT's own lprops table + * UBIFS_LPT_LSAVE: LPT's save table (big model only) + * UBIFS_LPT_NODE_CNT: count of LPT node types + * UBIFS_LPT_NOT_A_NODE: all ones (15 for 4 bits) is never a valid node type + */ +enum { + UBIFS_LPT_PNODE, + UBIFS_LPT_NNODE, + UBIFS_LPT_LTAB, + UBIFS_LPT_LSAVE, + UBIFS_LPT_NODE_CNT, + UBIFS_LPT_NOT_A_NODE = (1 << UBIFS_LPT_TYPE_BITS) - 1, +}; + +/* + * UBIFS inode types. + * + * UBIFS_ITYPE_REG: regular file + * UBIFS_ITYPE_DIR: directory + * UBIFS_ITYPE_LNK: soft link + * UBIFS_ITYPE_BLK: block device node + * UBIFS_ITYPE_CHR: character device node + * UBIFS_ITYPE_FIFO: fifo + * UBIFS_ITYPE_SOCK: socket + * UBIFS_ITYPES_CNT: count of supported file types + */ +enum { + UBIFS_ITYPE_REG, + UBIFS_ITYPE_DIR, + UBIFS_ITYPE_LNK, + UBIFS_ITYPE_BLK, + UBIFS_ITYPE_CHR, + UBIFS_ITYPE_FIFO, + UBIFS_ITYPE_SOCK, + UBIFS_ITYPES_CNT, +}; + +/* + * Supported key hash functions. + * + * UBIFS_KEY_HASH_R5: R5 hash + * UBIFS_KEY_HASH_TEST: test hash which just returns first 4 bytes of the name + */ +enum { + UBIFS_KEY_HASH_R5, + UBIFS_KEY_HASH_TEST, +}; + +/* + * Supported key formats. + * + * UBIFS_SIMPLE_KEY_FMT: simple key format + */ +enum { + UBIFS_SIMPLE_KEY_FMT, +}; + +/* + * The simple key format uses 29 bits for storing UBIFS block number and hash + * value. + */ +#define UBIFS_S_KEY_BLOCK_BITS 29 +#define UBIFS_S_KEY_BLOCK_MASK 0x1FFFFFFF +#define UBIFS_S_KEY_HASH_BITS UBIFS_S_KEY_BLOCK_BITS +#define UBIFS_S_KEY_HASH_MASK UBIFS_S_KEY_BLOCK_MASK + +/* + * Key types. + * + * UBIFS_INO_KEY: inode node key + * UBIFS_DATA_KEY: data node key + * UBIFS_DENT_KEY: directory entry node key + * UBIFS_XENT_KEY: extended attribute entry key + * UBIFS_KEY_TYPES_CNT: number of supported key types + */ +enum { + UBIFS_INO_KEY, + UBIFS_DATA_KEY, + UBIFS_DENT_KEY, + UBIFS_XENT_KEY, + UBIFS_KEY_TYPES_CNT, +}; + +/* Count of LEBs reserved for the superblock area */ +#define UBIFS_SB_LEBS 1 +/* Count of LEBs reserved for the master area */ +#define UBIFS_MST_LEBS 2 + +/* First LEB of the superblock area */ +#define UBIFS_SB_LNUM 0 +/* First LEB of the master area */ +#define UBIFS_MST_LNUM (UBIFS_SB_LNUM + UBIFS_SB_LEBS) +/* First LEB of the log area */ +#define UBIFS_LOG_LNUM (UBIFS_MST_LNUM + UBIFS_MST_LEBS) + +/* + * The below constants define the absolute minimum values for various UBIFS + * media areas. Many of them actually depend of flash geometry and the FS + * configuration (number of journal heads, orphan LEBs, etc). This means that + * the smallest volume size which can be used for UBIFS cannot be pre-defined + * by these constants. The file-system that meets the below limitation will not + * necessarily mount. UBIFS does run-time calculations and validates the FS + * size. + */ + +/* Minimum number of logical eraseblocks in the log */ +#define UBIFS_MIN_LOG_LEBS 2 +/* Minimum number of bud logical eraseblocks (one for each head) */ +#define UBIFS_MIN_BUD_LEBS 3 +/* Minimum number of journal logical eraseblocks */ +#define UBIFS_MIN_JNL_LEBS (UBIFS_MIN_LOG_LEBS + UBIFS_MIN_BUD_LEBS) +/* Minimum number of LPT area logical eraseblocks */ +#define UBIFS_MIN_LPT_LEBS 2 +/* Minimum number of orphan area logical eraseblocks */ +#define UBIFS_MIN_ORPH_LEBS 1 +/* + * Minimum number of main area logical eraseblocks (buds, 3 for the index, 1 + * for GC, 1 for deletions, and at least 1 for committed data). + */ +#define UBIFS_MIN_MAIN_LEBS (UBIFS_MIN_BUD_LEBS + 6) + +/* Minimum number of logical eraseblocks */ +#define UBIFS_MIN_LEB_CNT (UBIFS_SB_LEBS + UBIFS_MST_LEBS + \ + UBIFS_MIN_LOG_LEBS + UBIFS_MIN_LPT_LEBS + \ + UBIFS_MIN_ORPH_LEBS + UBIFS_MIN_MAIN_LEBS) + +/* Node sizes (N.B. these are guaranteed to be multiples of 8) */ +#define UBIFS_CH_SZ sizeof(struct ubifs_ch) +#define UBIFS_INO_NODE_SZ sizeof(struct ubifs_ino_node) +#define UBIFS_DATA_NODE_SZ sizeof(struct ubifs_data_node) +#define UBIFS_DENT_NODE_SZ sizeof(struct ubifs_dent_node) +#define UBIFS_TRUN_NODE_SZ sizeof(struct ubifs_trun_node) +#define UBIFS_PAD_NODE_SZ sizeof(struct ubifs_pad_node) +#define UBIFS_SB_NODE_SZ sizeof(struct ubifs_sb_node) +#define UBIFS_MST_NODE_SZ sizeof(struct ubifs_mst_node) +#define UBIFS_REF_NODE_SZ sizeof(struct ubifs_ref_node) +#define UBIFS_IDX_NODE_SZ sizeof(struct ubifs_idx_node) +#define UBIFS_CS_NODE_SZ sizeof(struct ubifs_cs_node) +#define UBIFS_ORPH_NODE_SZ sizeof(struct ubifs_orph_node) +/* Extended attribute entry nodes are identical to directory entry nodes */ +#define UBIFS_XENT_NODE_SZ UBIFS_DENT_NODE_SZ +/* Only this does not have to be multiple of 8 bytes */ +#define UBIFS_BRANCH_SZ sizeof(struct ubifs_branch) + +/* Maximum node sizes (N.B. these are guaranteed to be multiples of 8) */ +#define UBIFS_MAX_DATA_NODE_SZ (UBIFS_DATA_NODE_SZ + UBIFS_BLOCK_SIZE) +#define UBIFS_MAX_INO_NODE_SZ (UBIFS_INO_NODE_SZ + UBIFS_MAX_INO_DATA) +#define UBIFS_MAX_DENT_NODE_SZ (UBIFS_DENT_NODE_SZ + UBIFS_MAX_NLEN + 1) +#define UBIFS_MAX_XENT_NODE_SZ UBIFS_MAX_DENT_NODE_SZ + +/* The largest UBIFS node */ +#define UBIFS_MAX_NODE_SZ UBIFS_MAX_INO_NODE_SZ + +/* + * On-flash inode flags. + * + * UBIFS_COMPR_FL: use compression for this inode + * UBIFS_SYNC_FL: I/O on this inode has to be synchronous + * UBIFS_IMMUTABLE_FL: inode is immutable + * UBIFS_APPEND_FL: writes to the inode may only append data + * UBIFS_DIRSYNC_FL: I/O on this directory inode has to be synchronous + * UBIFS_XATTR_FL: this inode is the inode for an extended attribute value + * + * Note, these are on-flash flags which correspond to ioctl flags + * (@FS_COMPR_FL, etc). They have the same values now, but generally, do not + * have to be the same. + */ +enum { + UBIFS_COMPR_FL = 0x01, + UBIFS_SYNC_FL = 0x02, + UBIFS_IMMUTABLE_FL = 0x04, + UBIFS_APPEND_FL = 0x08, + UBIFS_DIRSYNC_FL = 0x10, + UBIFS_XATTR_FL = 0x20, +}; + +/* Inode flag bits used by UBIFS */ +#define UBIFS_FL_MASK 0x0000001F + +/* + * UBIFS compression algorithms. + * + * UBIFS_COMPR_NONE: no compression + * UBIFS_COMPR_LZO: LZO compression + * UBIFS_COMPR_ZLIB: ZLIB compression + * UBIFS_COMPR_TYPES_CNT: count of supported compression types + */ +enum { + UBIFS_COMPR_NONE, + UBIFS_COMPR_LZO, + UBIFS_COMPR_ZLIB, + UBIFS_COMPR_TYPES_CNT, +}; + +/* + * UBIFS node types. + * + * UBIFS_INO_NODE: inode node + * UBIFS_DATA_NODE: data node + * UBIFS_DENT_NODE: directory entry node + * UBIFS_XENT_NODE: extended attribute node + * UBIFS_TRUN_NODE: truncation node + * UBIFS_PAD_NODE: padding node + * UBIFS_SB_NODE: superblock node + * UBIFS_MST_NODE: master node + * UBIFS_REF_NODE: LEB reference node + * UBIFS_IDX_NODE: index node + * UBIFS_CS_NODE: commit start node + * UBIFS_ORPH_NODE: orphan node + * UBIFS_NODE_TYPES_CNT: count of supported node types + * + * Note, we index arrays by these numbers, so keep them low and contiguous. + * Node type constants for inodes, direntries and so on have to be the same as + * corresponding key type constants. + */ +enum { + UBIFS_INO_NODE, + UBIFS_DATA_NODE, + UBIFS_DENT_NODE, + UBIFS_XENT_NODE, + UBIFS_TRUN_NODE, + UBIFS_PAD_NODE, + UBIFS_SB_NODE, + UBIFS_MST_NODE, + UBIFS_REF_NODE, + UBIFS_IDX_NODE, + UBIFS_CS_NODE, + UBIFS_ORPH_NODE, + UBIFS_NODE_TYPES_CNT, +}; + +/* + * Master node flags. + * + * UBIFS_MST_DIRTY: rebooted uncleanly - master node is dirty + * UBIFS_MST_NO_ORPHS: no orphan inodes present + * UBIFS_MST_RCVRY: written by recovery + */ +enum { + UBIFS_MST_DIRTY = 1, + UBIFS_MST_NO_ORPHS = 2, + UBIFS_MST_RCVRY = 4, +}; + +/* + * Node group type (used by recovery to recover whole group or none). + * + * UBIFS_NO_NODE_GROUP: this node is not part of a group + * UBIFS_IN_NODE_GROUP: this node is a part of a group + * UBIFS_LAST_OF_NODE_GROUP: this node is the last in a group + */ +enum { + UBIFS_NO_NODE_GROUP = 0, + UBIFS_IN_NODE_GROUP, + UBIFS_LAST_OF_NODE_GROUP, +}; + +/* + * Superblock flags. + * + * UBIFS_FLG_BIGLPT: if "big" LPT model is used if set + */ +enum { + UBIFS_FLG_BIGLPT = 0x02, +}; + +/** + * struct ubifs_ch - common header node. + * @magic: UBIFS node magic number (%UBIFS_NODE_MAGIC) + * @crc: CRC-32 checksum of the node header + * @sqnum: sequence number + * @len: full node length + * @node_type: node type + * @group_type: node group type + * @padding: reserved for future, zeroes + * + * Every UBIFS node starts with this common part. If the node has a key, the + * key always goes next. + */ +struct ubifs_ch { + __le32 magic; + __le32 crc; + __le64 sqnum; + __le32 len; + __u8 node_type; + __u8 group_type; + __u8 padding[2]; +} __attribute__ ((packed)); + +/** + * union ubifs_dev_desc - device node descriptor. + * @new: new type device descriptor + * @huge: huge type device descriptor + * + * This data structure describes major/minor numbers of a device node. In an + * inode is a device node then its data contains an object of this type. UBIFS + * uses standard Linux "new" and "huge" device node encodings. + */ +union ubifs_dev_desc { + __le32 new; + __le64 huge; +} __attribute__ ((packed)); + +/** + * struct ubifs_ino_node - inode node. + * @ch: common header + * @key: node key + * @creat_sqnum: sequence number at time of creation + * @size: inode size in bytes (amount of uncompressed data) + * @atime_sec: access time seconds + * @ctime_sec: creation time seconds + * @mtime_sec: modification time seconds + * @atime_nsec: access time nanoseconds + * @ctime_nsec: creation time nanoseconds + * @mtime_nsec: modification time nanoseconds + * @nlink: number of hard links + * @uid: owner ID + * @gid: group ID + * @mode: access flags + * @flags: per-inode flags (%UBIFS_COMPR_FL, %UBIFS_SYNC_FL, etc) + * @data_len: inode data length + * @xattr_cnt: count of extended attributes this inode has + * @xattr_size: summarized size of all extended attributes in bytes + * @padding1: reserved for future, zeroes + * @xattr_names: sum of lengths of all extended attribute names belonging to + * this inode + * @compr_type: compression type used for this inode + * @padding2: reserved for future, zeroes + * @data: data attached to the inode + * + * Note, even though inode compression type is defined by @compr_type, some + * nodes of this inode may be compressed with different compressor - this + * happens if compression type is changed while the inode already has data + * nodes. But @compr_type will be use for further writes to the inode. + * + * Note, do not forget to amend 'zero_ino_node_unused()' function when changing + * the padding fields. + */ +struct ubifs_ino_node { + struct ubifs_ch ch; + __u8 key[UBIFS_MAX_KEY_LEN]; + __le64 creat_sqnum; + __le64 size; + __le64 atime_sec; + __le64 ctime_sec; + __le64 mtime_sec; + __le32 atime_nsec; + __le32 ctime_nsec; + __le32 mtime_nsec; + __le32 nlink; + __le32 uid; + __le32 gid; + __le32 mode; + __le32 flags; + __le32 data_len; + __le32 xattr_cnt; + __le32 xattr_size; + __u8 padding1[4]; /* Watch 'zero_ino_node_unused()' if changing! */ + __le32 xattr_names; + __le16 compr_type; + __u8 padding2[26]; /* Watch 'zero_ino_node_unused()' if changing! */ + __u8 data[]; +} __attribute__ ((packed)); + +/** + * struct ubifs_dent_node - directory entry node. + * @ch: common header + * @key: node key + * @inum: target inode number + * @padding1: reserved for future, zeroes + * @type: type of the target inode (%UBIFS_ITYPE_REG, %UBIFS_ITYPE_DIR, etc) + * @nlen: name length + * @padding2: reserved for future, zeroes + * @name: zero-terminated name + * + * Note, do not forget to amend 'zero_dent_node_unused()' function when + * changing the padding fields. + */ +struct ubifs_dent_node { + struct ubifs_ch ch; + __u8 key[UBIFS_MAX_KEY_LEN]; + __le64 inum; + __u8 padding1; + __u8 type; + __le16 nlen; + __u8 padding2[4]; /* Watch 'zero_dent_node_unused()' if changing! */ + __u8 name[]; +} __attribute__ ((packed)); + +/** + * struct ubifs_data_node - data node. + * @ch: common header + * @key: node key + * @size: uncompressed data size in bytes + * @compr_type: compression type (%UBIFS_COMPR_NONE, %UBIFS_COMPR_LZO, etc) + * @padding: reserved for future, zeroes + * @data: data + * + * Note, do not forget to amend 'zero_data_node_unused()' function when + * changing the padding fields. + */ +struct ubifs_data_node { + struct ubifs_ch ch; + __u8 key[UBIFS_MAX_KEY_LEN]; + __le32 size; + __le16 compr_type; + __u8 padding[2]; /* Watch 'zero_data_node_unused()' if changing! */ + __u8 data[]; +} __attribute__ ((packed)); + +/** + * struct ubifs_trun_node - truncation node. + * @ch: common header + * @inum: truncated inode number + * @padding: reserved for future, zeroes + * @old_size: size before truncation + * @new_size: size after truncation + * + * This node exists only in the journal and never goes to the main area. Note, + * do not forget to amend 'zero_trun_node_unused()' function when changing the + * padding fields. + */ +struct ubifs_trun_node { + struct ubifs_ch ch; + __le32 inum; + __u8 padding[12]; /* Watch 'zero_trun_node_unused()' if changing! */ + __le64 old_size; + __le64 new_size; +} __attribute__ ((packed)); + +/** + * struct ubifs_pad_node - padding node. + * @ch: common header + * @pad_len: how many bytes after this node are unused (because padded) + * @padding: reserved for future, zeroes + */ +struct ubifs_pad_node { + struct ubifs_ch ch; + __le32 pad_len; +} __attribute__ ((packed)); + +/** + * struct ubifs_sb_node - superblock node. + * @ch: common header + * @padding: reserved for future, zeroes + * @key_hash: type of hash function used in keys + * @key_fmt: format of the key + * @flags: file-system flags (%UBIFS_FLG_BIGLPT, etc) + * @min_io_size: minimal input/output unit size + * @leb_size: logical eraseblock size in bytes + * @leb_cnt: count of LEBs used by file-system + * @max_leb_cnt: maximum count of LEBs used by file-system + * @max_bud_bytes: maximum amount of data stored in buds + * @log_lebs: log size in logical eraseblocks + * @lpt_lebs: number of LEBs used for lprops table + * @orph_lebs: number of LEBs used for recording orphans + * @jhead_cnt: count of journal heads + * @fanout: tree fanout (max. number of links per indexing node) + * @lsave_cnt: number of LEB numbers in LPT's save table + * @fmt_version: UBIFS on-flash format version + * @default_compr: default compression algorithm (%UBIFS_COMPR_LZO, etc) + * @padding1: reserved for future, zeroes + * @rp_uid: reserve pool UID + * @rp_gid: reserve pool GID + * @rp_size: size of the reserved pool in bytes + * @padding2: reserved for future, zeroes + * @time_gran: time granularity in nanoseconds + * @uuid: UUID generated when the file system image was created + */ +struct ubifs_sb_node { + struct ubifs_ch ch; + __u8 padding[2]; + __u8 key_hash; + __u8 key_fmt; + __le32 flags; + __le32 min_io_size; + __le32 leb_size; + __le32 leb_cnt; + __le32 max_leb_cnt; + __le64 max_bud_bytes; + __le32 log_lebs; + __le32 lpt_lebs; + __le32 orph_lebs; + __le32 jhead_cnt; + __le32 fanout; + __le32 lsave_cnt; + __le32 fmt_version; + __le16 default_compr; + __u8 padding1[2]; + __le32 rp_uid; + __le32 rp_gid; + __le64 rp_size; + __le32 time_gran; + __u8 uuid[16]; + __u8 padding2[3972]; +} __attribute__ ((packed)); + +/** + * struct ubifs_mst_node - master node. + * @ch: common header + * @highest_inum: highest inode number in the committed index + * @cmt_no: commit number + * @flags: various flags (%UBIFS_MST_DIRTY, etc) + * @log_lnum: start of the log + * @root_lnum: LEB number of the root indexing node + * @root_offs: offset within @root_lnum + * @root_len: root indexing node length + * @gc_lnum: LEB reserved for garbage collection (%-1 value means the LEB was + * not reserved and should be reserved on mount) + * @ihead_lnum: LEB number of index head + * @ihead_offs: offset of index head + * @index_size: size of index on flash + * @total_free: total free space in bytes + * @total_dirty: total dirty space in bytes + * @total_used: total used space in bytes (includes only data LEBs) + * @total_dead: total dead space in bytes (includes only data LEBs) + * @total_dark: total dark space in bytes (includes only data LEBs) + * @lpt_lnum: LEB number of LPT root nnode + * @lpt_offs: offset of LPT root nnode + * @nhead_lnum: LEB number of LPT head + * @nhead_offs: offset of LPT head + * @ltab_lnum: LEB number of LPT's own lprops table + * @ltab_offs: offset of LPT's own lprops table + * @lsave_lnum: LEB number of LPT's save table (big model only) + * @lsave_offs: offset of LPT's save table (big model only) + * @lscan_lnum: LEB number of last LPT scan + * @empty_lebs: number of empty logical eraseblocks + * @idx_lebs: number of indexing logical eraseblocks + * @leb_cnt: count of LEBs used by file-system + * @padding: reserved for future, zeroes + */ +struct ubifs_mst_node { + struct ubifs_ch ch; + __le64 highest_inum; + __le64 cmt_no; + __le32 flags; + __le32 log_lnum; + __le32 root_lnum; + __le32 root_offs; + __le32 root_len; + __le32 gc_lnum; + __le32 ihead_lnum; + __le32 ihead_offs; + __le64 index_size; + __le64 total_free; + __le64 total_dirty; + __le64 total_used; + __le64 total_dead; + __le64 total_dark; + __le32 lpt_lnum; + __le32 lpt_offs; + __le32 nhead_lnum; + __le32 nhead_offs; + __le32 ltab_lnum; + __le32 ltab_offs; + __le32 lsave_lnum; + __le32 lsave_offs; + __le32 lscan_lnum; + __le32 empty_lebs; + __le32 idx_lebs; + __le32 leb_cnt; + __u8 padding[344]; +} __attribute__ ((packed)); + +/** + * struct ubifs_ref_node - logical eraseblock reference node. + * @ch: common header + * @lnum: the referred logical eraseblock number + * @offs: start offset in the referred LEB + * @jhead: journal head number + * @padding: reserved for future, zeroes + */ +struct ubifs_ref_node { + struct ubifs_ch ch; + __le32 lnum; + __le32 offs; + __le32 jhead; + __u8 padding[28]; +} __attribute__ ((packed)); + +/** + * struct ubifs_branch - key/reference/length branch + * @lnum: LEB number of the target node + * @offs: offset within @lnum + * @len: target node length + * @key: key + */ +struct ubifs_branch { + __le32 lnum; + __le32 offs; + __le32 len; + __u8 key[]; +} __attribute__ ((packed)); + +/** + * struct ubifs_idx_node - indexing node. + * @ch: common header + * @child_cnt: number of child index nodes + * @level: tree level + * @branches: LEB number / offset / length / key branches + */ +struct ubifs_idx_node { + struct ubifs_ch ch; + __le16 child_cnt; + __le16 level; + __u8 branches[]; +} __attribute__ ((packed)); + +/** + * struct ubifs_cs_node - commit start node. + * @ch: common header + * @cmt_no: commit number + */ +struct ubifs_cs_node { + struct ubifs_ch ch; + __le64 cmt_no; +} __attribute__ ((packed)); + +/** + * struct ubifs_orph_node - orphan node. + * @ch: common header + * @cmt_no: commit number (also top bit is set on the last node of the commit) + * @inos: inode numbers of orphans + */ +struct ubifs_orph_node { + struct ubifs_ch ch; + __le64 cmt_no; + __le64 inos[]; +} __attribute__ ((packed)); + +#endif /* __UBIFS_MEDIA_H__ */ diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c new file mode 100644 index 0000000..d917863 --- /dev/null +++ b/fs/ubifs/ubifs.c @@ -0,0 +1,684 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * (C) Copyright 2008-2009 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Artem Bityutskiy (Битюцкий Артём) + * Adrian Hunter + */ + +#include "ubifs.h" + +#if !defined(CONFIG_SYS_64BIT_VSPRINTF) +#warning Please define CONFIG_SYS_64BIT_VSPRINTF for correct output! +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* compress.c */ + +/* + * We need a wrapper for gunzip() because the parameters are + * incompatible with the lzo decompressor. + */ +static int gzip_decompress(const unsigned char *in, size_t in_len, + unsigned char *out, size_t *out_len) +{ + unsigned long len = in_len; + return gunzip(out, *out_len, (unsigned char *)in, &len); +} + +/* Fake description object for the "none" compressor */ +static struct ubifs_compressor none_compr = { + .compr_type = UBIFS_COMPR_NONE, + .name = "no compression", + .capi_name = "", + .decompress = NULL, +}; + +static struct ubifs_compressor lzo_compr = { + .compr_type = UBIFS_COMPR_LZO, + .name = "LZO", + .capi_name = "lzo", + .decompress = lzo1x_decompress_safe, +}; + +static struct ubifs_compressor zlib_compr = { + .compr_type = UBIFS_COMPR_ZLIB, + .name = "zlib", + .capi_name = "deflate", + .decompress = gzip_decompress, +}; + +/* All UBIFS compressors */ +struct ubifs_compressor *ubifs_compressors[UBIFS_COMPR_TYPES_CNT]; + +/** + * ubifs_decompress - decompress data. + * @in_buf: data to decompress + * @in_len: length of the data to decompress + * @out_buf: output buffer where decompressed data should + * @out_len: output length is returned here + * @compr_type: type of compression + * + * This function decompresses data from buffer @in_buf into buffer @out_buf. + * The length of the uncompressed data is returned in @out_len. This functions + * returns %0 on success or a negative error code on failure. + */ +int ubifs_decompress(const void *in_buf, int in_len, void *out_buf, + int *out_len, int compr_type) +{ + int err; + struct ubifs_compressor *compr; + + if (unlikely(compr_type < 0 || compr_type >= UBIFS_COMPR_TYPES_CNT)) { + ubifs_err("invalid compression type %d", compr_type); + return -EINVAL; + } + + compr = ubifs_compressors[compr_type]; + + if (unlikely(!compr->capi_name)) { + ubifs_err("%s compression is not compiled in", compr->name); + return -EINVAL; + } + + if (compr_type == UBIFS_COMPR_NONE) { + memcpy(out_buf, in_buf, in_len); + *out_len = in_len; + return 0; + } + + err = compr->decompress(in_buf, in_len, out_buf, (size_t *)out_len); + if (err) + ubifs_err("cannot decompress %d bytes, compressor %s, " + "error %d", in_len, compr->name, err); + + return err; +} + +/** + * compr_init - initialize a compressor. + * @compr: compressor description object + * + * This function initializes the requested compressor and returns zero in case + * of success or a negative error code in case of failure. + */ +static int __init compr_init(struct ubifs_compressor *compr) +{ + ubifs_compressors[compr->compr_type] = compr; + ubifs_compressors[compr->compr_type]->name += gd->reloc_off; + ubifs_compressors[compr->compr_type]->capi_name += gd->reloc_off; + ubifs_compressors[compr->compr_type]->decompress += gd->reloc_off; + return 0; +} + +/** + * ubifs_compressors_init - initialize UBIFS compressors. + * + * This function initializes the compressor which were compiled in. Returns + * zero in case of success and a negative error code in case of failure. + */ +int __init ubifs_compressors_init(void) +{ + int err; + + err = compr_init(&lzo_compr); + if (err) + return err; + + err = compr_init(&zlib_compr); + if (err) + return err; + + ubifs_compressors[UBIFS_COMPR_NONE] = &none_compr; + return 0; +} + +/* + * ubifsls... + */ + +static int filldir(struct ubifs_info *c, const char *name, int namlen, + u64 ino, unsigned int d_type) +{ + struct inode *inode; + char filetime[32]; + + switch (d_type) { + case UBIFS_ITYPE_REG: + printf("\t"); + break; + case UBIFS_ITYPE_DIR: + printf("<DIR>\t"); + break; + case UBIFS_ITYPE_LNK: + printf("<LNK>\t"); + break; + default: + printf("other\t"); + break; + } + + inode = ubifs_iget(c->vfs_sb, ino); + if (IS_ERR(inode)) { + printf("%s: Error in ubifs_iget(), ino=%lld ret=%p!\n", + __func__, ino, inode); + return -1; + } + ctime_r((time_t *)&inode->i_mtime, filetime); + printf("%9lld %24.24s ", inode->i_size, filetime); + ubifs_iput(inode); + + printf("%s\n", name); + + return 0; +} + +static int ubifs_printdir(struct file *file, void *dirent) +{ + int err, over = 0; + struct qstr nm; + union ubifs_key key; + struct ubifs_dent_node *dent; + struct inode *dir = file->f_path.dentry->d_inode; + struct ubifs_info *c = dir->i_sb->s_fs_info; + + dbg_gen("dir ino %lu, f_pos %#llx", dir->i_ino, file->f_pos); + + if (file->f_pos > UBIFS_S_KEY_HASH_MASK || file->f_pos == 2) + /* + * The directory was seek'ed to a senseless position or there + * are no more entries. + */ + return 0; + + if (file->f_pos == 1) { + /* Find the first entry in TNC and save it */ + lowest_dent_key(c, &key, dir->i_ino); + nm.name = NULL; + dent = ubifs_tnc_next_ent(c, &key, &nm); + if (IS_ERR(dent)) { + err = PTR_ERR(dent); + goto out; + } + + file->f_pos = key_hash_flash(c, &dent->key); + file->private_data = dent; + } + + dent = file->private_data; + if (!dent) { + /* + * The directory was seek'ed to and is now readdir'ed. + * Find the entry corresponding to @file->f_pos or the + * closest one. + */ + dent_key_init_hash(c, &key, dir->i_ino, file->f_pos); + nm.name = NULL; + dent = ubifs_tnc_next_ent(c, &key, &nm); + if (IS_ERR(dent)) { + err = PTR_ERR(dent); + goto out; + } + file->f_pos = key_hash_flash(c, &dent->key); + file->private_data = dent; + } + + while (1) { + dbg_gen("feed '%s', ino %llu, new f_pos %#x", + dent->name, (unsigned long long)le64_to_cpu(dent->inum), + key_hash_flash(c, &dent->key)); + ubifs_assert(le64_to_cpu(dent->ch.sqnum) > ubifs_inode(dir)->creat_sqnum); + + nm.len = le16_to_cpu(dent->nlen); + over = filldir(c, (char *)dent->name, nm.len, + le64_to_cpu(dent->inum), dent->type); + if (over) + return 0; + + /* Switch to the next entry */ + key_read(c, &dent->key, &key); + nm.name = (char *)dent->name; + dent = ubifs_tnc_next_ent(c, &key, &nm); + if (IS_ERR(dent)) { + err = PTR_ERR(dent); + goto out; + } + + kfree(file->private_data); + file->f_pos = key_hash_flash(c, &dent->key); + file->private_data = dent; + cond_resched(); + } + +out: + if (err != -ENOENT) { + ubifs_err("cannot find next direntry, error %d", err); + return err; + } + + kfree(file->private_data); + file->private_data = NULL; + file->f_pos = 2; + return 0; +} + +static int ubifs_finddir(struct super_block *sb, char *dirname, + unsigned long root_inum, unsigned long *inum) +{ + int err; + struct qstr nm; + union ubifs_key key; + struct ubifs_dent_node *dent; + struct ubifs_info *c; + struct file *file; + struct dentry *dentry; + struct inode *dir; + + file = kzalloc(sizeof(struct file), 0); + dentry = kzalloc(sizeof(struct dentry), 0); + dir = kzalloc(sizeof(struct inode), 0); + if (!file || !dentry || !dir) { + printf("%s: Error, no memory for malloc!\n", __func__); + err = -ENOMEM; + goto out; + } + + dir->i_sb = sb; + file->f_path.dentry = dentry; + file->f_path.dentry->d_parent = dentry; + file->f_path.dentry->d_inode = dir; + file->f_path.dentry->d_inode->i_ino = root_inum; + c = sb->s_fs_info; + + dbg_gen("dir ino %lu, f_pos %#llx", dir->i_ino, file->f_pos); + + /* Find the first entry in TNC and save it */ + lowest_dent_key(c, &key, dir->i_ino); + nm.name = NULL; + dent = ubifs_tnc_next_ent(c, &key, &nm); + if (IS_ERR(dent)) { + err = PTR_ERR(dent); + goto out; + } + + file->f_pos = key_hash_flash(c, &dent->key); + file->private_data = dent; + + while (1) { + dbg_gen("feed '%s', ino %llu, new f_pos %#x", + dent->name, (unsigned long long)le64_to_cpu(dent->inum), + key_hash_flash(c, &dent->key)); + ubifs_assert(le64_to_cpu(dent->ch.sqnum) > ubifs_inode(dir)->creat_sqnum); + + nm.len = le16_to_cpu(dent->nlen); + if ((strncmp(dirname, (char *)dent->name, nm.len) == 0) && + (strlen(dirname) == nm.len)) { + *inum = le64_to_cpu(dent->inum); + return 1; + } + + /* Switch to the next entry */ + key_read(c, &dent->key, &key); + nm.name = (char *)dent->name; + dent = ubifs_tnc_next_ent(c, &key, &nm); + if (IS_ERR(dent)) { + err = PTR_ERR(dent); + goto out; + } + + kfree(file->private_data); + file->f_pos = key_hash_flash(c, &dent->key); + file->private_data = dent; + cond_resched(); + } + +out: + if (err != -ENOENT) { + ubifs_err("cannot find next direntry, error %d", err); + return err; + } + + if (file) + free(file); + if (dentry) + free(dentry); + if (dir) + free(dir); + + if (file->private_data) + kfree(file->private_data); + file->private_data = NULL; + file->f_pos = 2; + return 0; +} + +static unsigned long ubifs_findfile(struct super_block *sb, char *filename) +{ + int ret; + char *next; + char fpath[128]; + char *name = fpath; + unsigned long root_inum = 1; + unsigned long inum; + + strcpy(fpath, filename); + + /* Remove all leading slashes */ + while (*name == '/') + name++; + + /* + * Handle root-direcoty ('/') + */ + inum = root_inum; + if (!name || *name == '\0') + return inum; + + for (;;) { + /* Extract the actual part from the pathname. */ + next = strchr(name, '/'); + if (next) { + /* Remove all leading slashes. */ + while (*next == '/') + *(next++) = '\0'; + } + + ret = ubifs_finddir(sb, name, root_inum, &inum); + + /* + * Check if directory with this name exists + */ + + /* Found the node! */ + if (!next || *next == '\0') { + if (ret) + return inum; + + break; + } + + root_inum = inum; + name = next; + } + + return 0; +} + +int ubifs_ls(char *filename) +{ + struct ubifs_info *c = ubifs_sb->s_fs_info; + struct file *file; + struct dentry *dentry; + struct inode *dir; + void *dirent = NULL; + unsigned long inum; + int ret = 0; + + c->ubi = ubi_open_volume(c->vi.ubi_num, c->vi.vol_id, UBI_READONLY); + inum = ubifs_findfile(ubifs_sb, filename); + if (!inum) { + ret = -1; + goto out; + } + + file = kzalloc(sizeof(struct file), 0); + dentry = kzalloc(sizeof(struct dentry), 0); + dir = kzalloc(sizeof(struct inode), 0); + if (!file || !dentry || !dir) { + printf("%s: Error, no memory for malloc!\n", __func__); + ret = -ENOMEM; + goto out_mem; + } + + dir->i_sb = ubifs_sb; + file->f_path.dentry = dentry; + file->f_path.dentry->d_parent = dentry; + file->f_path.dentry->d_inode = dir; + file->f_path.dentry->d_inode->i_ino = inum; + file->f_pos = 1; + file->private_data = NULL; + ubifs_printdir(file, dirent); + +out_mem: + if (file) + free(file); + if (dentry) + free(dentry); + if (dir) + free(dir); + +out: + ubi_close_volume(c->ubi); + return ret; +} + +/* + * ubifsload... + */ + +/* file.c */ + +static inline void *kmap(struct page *page) +{ + return page->addr; +} + +static int read_block(struct inode *inode, void *addr, unsigned int block, + struct ubifs_data_node *dn) +{ + struct ubifs_info *c = inode->i_sb->s_fs_info; + int err, len, out_len; + union ubifs_key key; + unsigned int dlen; + + data_key_init(c, &key, inode->i_ino, block); + err = ubifs_tnc_lookup(c, &key, dn); + if (err) { + if (err == -ENOENT) + /* Not found, so it must be a hole */ + memset(addr, 0, UBIFS_BLOCK_SIZE); + return err; + } + + ubifs_assert(le64_to_cpu(dn->ch.sqnum) > ubifs_inode(inode)->creat_sqnum); + + len = le32_to_cpu(dn->size); + if (len <= 0 || len > UBIFS_BLOCK_SIZE) + goto dump; + + dlen = le32_to_cpu(dn->ch.len) - UBIFS_DATA_NODE_SZ; + out_len = UBIFS_BLOCK_SIZE; + err = ubifs_decompress(&dn->data, dlen, addr, &out_len, + le16_to_cpu(dn->compr_type)); + if (err || len != out_len) + goto dump; + + /* + * Data length can be less than a full block, even for blocks that are + * not the last in the file (e.g., as a result of making a hole and + * appending data). Ensure that the remainder is zeroed out. + */ + if (len < UBIFS_BLOCK_SIZE) + memset(addr + len, 0, UBIFS_BLOCK_SIZE - len); + + return 0; + +dump: + ubifs_err("bad data node (block %u, inode %lu)", + block, inode->i_ino); + dbg_dump_node(c, dn); + return -EINVAL; +} + +static int do_readpage(struct ubifs_info *c, struct inode *inode, struct page *page) +{ + void *addr; + int err = 0, i; + unsigned int block, beyond; + struct ubifs_data_node *dn; + loff_t i_size = inode->i_size; + + dbg_gen("ino %lu, pg %lu, i_size %lld", + inode->i_ino, page->index, i_size); + + addr = kmap(page); + + block = page->index << UBIFS_BLOCKS_PER_PAGE_SHIFT; + beyond = (i_size + UBIFS_BLOCK_SIZE - 1) >> UBIFS_BLOCK_SHIFT; + if (block >= beyond) { + /* Reading beyond inode */ + memset(addr, 0, PAGE_CACHE_SIZE); + goto out; + } + + dn = kmalloc(UBIFS_MAX_DATA_NODE_SZ, GFP_NOFS); + if (!dn) { + err = -ENOMEM; + goto error; + } + + i = 0; + while (1) { + int ret; + + if (block >= beyond) { + /* Reading beyond inode */ + err = -ENOENT; + memset(addr, 0, UBIFS_BLOCK_SIZE); + } else { + ret = read_block(inode, addr, block, dn); + if (ret) { + err = ret; + if (err != -ENOENT) + break; + } else if (block + 1 == beyond) { + int dlen = le32_to_cpu(dn->size); + int ilen = i_size & (UBIFS_BLOCK_SIZE - 1); + + if (ilen && ilen < dlen) + memset(addr + ilen, 0, dlen - ilen); + } + } + if (++i >= UBIFS_BLOCKS_PER_PAGE) + break; + block += 1; + addr += UBIFS_BLOCK_SIZE; + } + if (err) { + if (err == -ENOENT) { + /* Not found, so it must be a hole */ + dbg_gen("hole"); + goto out_free; + } + ubifs_err("cannot read page %lu of inode %lu, error %d", + page->index, inode->i_ino, err); + goto error; + } + +out_free: + kfree(dn); +out: + return 0; + +error: + kfree(dn); + return err; +} + +int ubifs_load(char *filename, u32 addr, u32 size) +{ + struct ubifs_info *c = ubifs_sb->s_fs_info; + unsigned long inum; + struct inode *inode; + struct page page; + int err = 0; + int i; + int count; + char link_name[64]; + struct ubifs_inode *ui; + + c->ubi = ubi_open_volume(c->vi.ubi_num, c->vi.vol_id, UBI_READONLY); + inum = ubifs_findfile(ubifs_sb, filename); + if (!inum) { + err = -1; + goto out; + } + + /* + * Read file inode + */ + inode = ubifs_iget(ubifs_sb, inum); + if (IS_ERR(inode)) { + printf("%s: Error reading inode %ld!\n", __func__, inum); + err = PTR_ERR(inode); + goto out; + } + + /* + * Check for symbolic link + */ + ui = ubifs_inode(inode); + if (((inode->i_mode & S_IFMT) == S_IFLNK) && ui->data_len) { + memcpy(link_name, ui->data, ui->data_len); + printf("%s is linked to %s!\n", filename, link_name); + ubifs_iput(inode); + + /* + * Now we have the "real" filename, call ubifs_load() + * again (recursive call) to load this file instead + */ + return ubifs_load(link_name, addr, size); + } + + /* + * If no size was specified or if size bigger than filesize + * set size to filesize + */ + if ((size == 0) || (size > inode->i_size)) + size = inode->i_size; + + count = (size + UBIFS_BLOCK_SIZE - 1) >> UBIFS_BLOCK_SHIFT; + printf("Loading file '%s' to addr 0x%08x with size %d (0x%08x)...\n", + filename, addr, size, size); + + page.addr = (void *)addr; + page.index = 0; + page.inode = inode; + for (i = 0; i < count; i++) { + err = do_readpage(c, inode, &page); + if (err) + break; + + page.addr += PAGE_SIZE; + page.index++; + } + + if (err) + printf("Error reading file '%s'\n", filename); + else + printf("Done\n"); + + ubifs_iput(inode); + +out: + ubi_close_volume(c->ubi); + return err; +} diff --git a/include/linux/math64.h b/include/linux/math64.h new file mode 100644 index 0000000..6d760d7 --- /dev/null +++ b/include/linux/math64.h @@ -0,0 +1,85 @@ +#ifndef _LINUX_MATH64_H +#define _LINUX_MATH64_H + +#include <linux/types.h> + +#if BITS_PER_LONG == 64 + +/** + * div_u64_rem - unsigned 64bit divide with 32bit divisor with remainder + * + * This is commonly provided by 32bit archs to provide an optimized 64bit + * divide. + */ +static inline u64 div_u64_rem(u64 dividend, u32 divisor, u32 *remainder) +{ + *remainder = dividend % divisor; + return dividend / divisor; +} + +/** + * div_s64_rem - signed 64bit divide with 32bit divisor with remainder + */ +static inline s64 div_s64_rem(s64 dividend, s32 divisor, s32 *remainder) +{ + *remainder = dividend % divisor; + return dividend / divisor; +} + +/** + * div64_u64 - unsigned 64bit divide with 64bit divisor + */ +static inline u64 div64_u64(u64 dividend, u64 divisor) +{ + return dividend / divisor; +} + +#elif BITS_PER_LONG == 32 + +#ifndef div_u64_rem +static inline u64 div_u64_rem(u64 dividend, u32 divisor, u32 *remainder) +{ + *remainder = do_div(dividend, divisor); + return dividend; +} +#endif + +#ifndef div_s64_rem +extern s64 div_s64_rem(s64 dividend, s32 divisor, s32 *remainder); +#endif + +#ifndef div64_u64 +extern u64 div64_u64(u64 dividend, u64 divisor); +#endif + +#endif /* BITS_PER_LONG */ + +/** + * div_u64 - unsigned 64bit divide with 32bit divisor + * + * This is the most common 64bit divide and should be used if possible, + * as many 32bit archs can optimize this variant better than a full 64bit + * divide. + */ +#ifndef div_u64 +static inline u64 div_u64(u64 dividend, u32 divisor) +{ + u32 remainder; + return div_u64_rem(dividend, divisor, &remainder); +} +#endif + +/** + * div_s64 - signed 64bit divide with 32bit divisor + */ +#ifndef div_s64 +static inline s64 div_s64(s64 dividend, s32 divisor) +{ + s32 remainder; + return div_s64_rem(dividend, divisor, &remainder); +} +#endif + +u32 iter_div_u64_rem(u64 dividend, u32 divisor, u64 *remainder); + +#endif /* _LINUX_MATH64_H */
Stefan Roese
