[PATCH 1/2] ARM: rmobile: Enable RPC on Salvator-X, ULCB, Ebisu
Enable the RPC Hyperflash driver on R8A7795,R8A7796,R8A77965 Salvator-X,ULCB and R8A77990 Ebisu. Note that to make the HF accessible, mainline ATF is mandatory and must be built with RCAR_RPC_HYPERFLASH_LOCKED=0 . Note that this is intended for development and testing convenience only and must be disabled in deployment for platform security reasons.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- arch/arm/dts/r8a77950-salvator-x-u-boot.dts | 5 +++++ arch/arm/dts/r8a77950-ulcb-u-boot.dts | 5 +++++ arch/arm/dts/r8a77960-salvator-x-u-boot.dts | 5 +++++ arch/arm/dts/r8a77960-ulcb-u-boot.dts | 5 +++++ arch/arm/dts/r8a77965-salvator-x-u-boot.dts | 5 +++++ arch/arm/dts/r8a77965-ulcb-u-boot.dts | 5 +++++ arch/arm/dts/r8a77990-ebisu-u-boot.dts | 5 +++++ arch/arm/dts/r8a77995-draak-u-boot.dts | 5 +++++ configs/r8a77990_ebisu_defconfig | 5 +++++ configs/rcar3_salvator-x_defconfig | 5 +++++ configs/rcar3_ulcb_defconfig | 5 +++++ include/configs/ebisu.h | 12 ++++++++++++ include/configs/salvator-x.h | 12 ++++++++++++ include/configs/ulcb.h | 12 ++++++++++++ 14 files changed, 91 insertions(+)
diff --git a/arch/arm/dts/r8a77950-salvator-x-u-boot.dts b/arch/arm/dts/r8a77950-salvator-x-u-boot.dts index e039e33d59..36c8a44a90 100644 --- a/arch/arm/dts/r8a77950-salvator-x-u-boot.dts +++ b/arch/arm/dts/r8a77950-salvator-x-u-boot.dts @@ -8,6 +8,11 @@ #include "r8a77950-salvator-x.dts" #include "r8a77950-u-boot.dtsi"
+&rpc { + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0x04000000>; + status = "okay"; +}; + &sdhi0 { sd-uhs-sdr12; sd-uhs-sdr25; diff --git a/arch/arm/dts/r8a77950-ulcb-u-boot.dts b/arch/arm/dts/r8a77950-ulcb-u-boot.dts index b7f26c11b1..d3191c55d5 100644 --- a/arch/arm/dts/r8a77950-ulcb-u-boot.dts +++ b/arch/arm/dts/r8a77950-ulcb-u-boot.dts @@ -19,6 +19,11 @@ }; };
+&rpc { + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0x04000000>; + status = "okay"; +}; + &sdhi0 { sd-uhs-sdr12; sd-uhs-sdr25; diff --git a/arch/arm/dts/r8a77960-salvator-x-u-boot.dts b/arch/arm/dts/r8a77960-salvator-x-u-boot.dts index d3b09246f5..439fd6c3ad 100644 --- a/arch/arm/dts/r8a77960-salvator-x-u-boot.dts +++ b/arch/arm/dts/r8a77960-salvator-x-u-boot.dts @@ -8,6 +8,11 @@ #include "r8a77960-salvator-x.dts" #include "r8a77960-u-boot.dtsi"
+&rpc { + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0x04000000>; + status = "okay"; +}; + &sdhi0 { sd-uhs-sdr12; sd-uhs-sdr25; diff --git a/arch/arm/dts/r8a77960-ulcb-u-boot.dts b/arch/arm/dts/r8a77960-ulcb-u-boot.dts index bd1d634574..aab9c95931 100644 --- a/arch/arm/dts/r8a77960-ulcb-u-boot.dts +++ b/arch/arm/dts/r8a77960-ulcb-u-boot.dts @@ -19,6 +19,11 @@ }; };
+&rpc { + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0x04000000>; + status = "okay"; +}; + &sdhi0 { sd-uhs-sdr12; sd-uhs-sdr25; diff --git a/arch/arm/dts/r8a77965-salvator-x-u-boot.dts b/arch/arm/dts/r8a77965-salvator-x-u-boot.dts index d6f0708555..8cbef83b9c 100644 --- a/arch/arm/dts/r8a77965-salvator-x-u-boot.dts +++ b/arch/arm/dts/r8a77965-salvator-x-u-boot.dts @@ -8,6 +8,11 @@ #include "r8a77965-salvator-x.dts" #include "r8a77965-u-boot.dtsi"
+&rpc { + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0x04000000>; + status = "okay"; +}; + &sdhi0 { sd-uhs-sdr12; sd-uhs-sdr25; diff --git a/arch/arm/dts/r8a77965-ulcb-u-boot.dts b/arch/arm/dts/r8a77965-ulcb-u-boot.dts index 954d8b685c..38966bf644 100644 --- a/arch/arm/dts/r8a77965-ulcb-u-boot.dts +++ b/arch/arm/dts/r8a77965-ulcb-u-boot.dts @@ -19,6 +19,11 @@ }; };
+&rpc { + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0x04000000>; + status = "okay"; +}; + &sdhi0 { sd-uhs-sdr12; sd-uhs-sdr25; diff --git a/arch/arm/dts/r8a77990-ebisu-u-boot.dts b/arch/arm/dts/r8a77990-ebisu-u-boot.dts index 0ea0cc9cb1..6afc0be66e 100644 --- a/arch/arm/dts/r8a77990-ebisu-u-boot.dts +++ b/arch/arm/dts/r8a77990-ebisu-u-boot.dts @@ -18,6 +18,11 @@ }; };
+&rpc { + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0x04000000>; + status = "okay"; +}; + &sdhi0 { sd-uhs-sdr12; sd-uhs-sdr25; diff --git a/arch/arm/dts/r8a77995-draak-u-boot.dts b/arch/arm/dts/r8a77995-draak-u-boot.dts index 2f53970809..10fb9cb3b6 100644 --- a/arch/arm/dts/r8a77995-draak-u-boot.dts +++ b/arch/arm/dts/r8a77995-draak-u-boot.dts @@ -7,3 +7,8 @@
#include "r8a77995-draak.dts" #include "r8a77995-u-boot.dtsi" + +&rpc { + reg = <0 0xee200000 0 0x100>, <0 0x08000000 0 0x04000000>; + status = "okay"; +}; diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index efdb8e6eb7..f94d4256f4 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -49,6 +49,11 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_CFI_FLASH=y +CONFIG_RENESAS_RPC_HF=y CONFIG_BITBANGMII=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/rcar3_salvator-x_defconfig b/configs/rcar3_salvator-x_defconfig index 0fbd1e0c82..4537b52c20 100644 --- a/configs/rcar3_salvator-x_defconfig +++ b/configs/rcar3_salvator-x_defconfig @@ -52,6 +52,11 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_CFI_FLASH=y +CONFIG_RENESAS_RPC_HF=y CONFIG_BITBANGMII=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/rcar3_ulcb_defconfig b/configs/rcar3_ulcb_defconfig index 710b2f4a4a..b90b9e12b3 100644 --- a/configs/rcar3_ulcb_defconfig +++ b/configs/rcar3_ulcb_defconfig @@ -52,6 +52,11 @@ CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_RENESAS_SDHI=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_CFI_FLASH=y +CONFIG_RENESAS_RPC_HF=y CONFIG_BITBANGMII=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/include/configs/ebisu.h b/include/configs/ebisu.h index 06cbb03dc6..ee9ddb1336 100644 --- a/include/configs/ebisu.h +++ b/include/configs/ebisu.h @@ -22,4 +22,16 @@
/* Environment in eMMC, at the end of 2nd "boot sector" */
+#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_FLASH_CFI_MTD +#define CONFIG_FLASH_SHOW_PROGRESS 45 +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_MAX_FLASH_BANKS_DETECT 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 +#define CONFIG_SYS_WRITE_SWAPPED_DATA + #endif /* __EBISU_H */ diff --git a/include/configs/salvator-x.h b/include/configs/salvator-x.h index 240df9c63b..db06fa5ffd 100644 --- a/include/configs/salvator-x.h +++ b/include/configs/salvator-x.h @@ -19,4 +19,16 @@
+#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_FLASH_CFI_MTD +#define CONFIG_FLASH_SHOW_PROGRESS 45 +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_MAX_FLASH_BANKS_DETECT 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 +#define CONFIG_SYS_WRITE_SWAPPED_DATA + #endif /* __SALVATOR_X_H */ diff --git a/include/configs/ulcb.h b/include/configs/ulcb.h index 15fb627228..165c82d508 100644 --- a/include/configs/ulcb.h +++ b/include/configs/ulcb.h @@ -19,4 +19,16 @@
+#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_FLASH_CFI_MTD +#define CONFIG_FLASH_SHOW_PROGRESS 45 +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_SYS_FLASH_BANKS_LIST { 0x08000000 } +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_MAX_FLASH_BANKS_DETECT 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 +#define CONFIG_SYS_WRITE_SWAPPED_DATA + #endif /* __ULCB_H */
Enable the fitImage update options on RCar Gen3 boards. This permits easy update of multiple bootloader components.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/r8a77970_eagle_defconfig | 4 ++++ configs/r8a77990_ebisu_defconfig | 11 +++++++++++ configs/r8a77995_draak_defconfig | 11 +++++++++++ configs/rcar3_salvator-x_defconfig | 11 +++++++++++ configs/rcar3_ulcb_defconfig | 11 +++++++++++ 5 files changed, 48 insertions(+)
diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index 55b29b22fc..160d5637b4 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -20,6 +20,7 @@ CONFIG_DEFAULT_FDT_FILE="r8a77970-eagle.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_SPI=y @@ -41,6 +42,9 @@ CONFIG_SYSCON=y CONFIG_BLK=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index f94d4256f4..f5502de1fc 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -17,11 +17,14 @@ CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.2 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a77990-ebisu.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_UPDATE_TFTP=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -41,6 +44,9 @@ CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y @@ -54,6 +60,8 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y CONFIG_RENESAS_RPC_HF=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_BITBANGMII=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y @@ -63,6 +71,9 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_SCIF_CONSOLE=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index b4962300bc..6152bcf471 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -17,11 +17,14 @@ CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.2 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a77995-draak.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_UPDATE_TFTP=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -40,6 +43,9 @@ CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y @@ -56,6 +62,8 @@ CONFIG_CFI_FLASH=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_RENESAS_RPC_HF=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_BITBANGMII=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y @@ -65,6 +73,9 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_SCIF_CONSOLE=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y diff --git a/configs/rcar3_salvator-x_defconfig b/configs/rcar3_salvator-x_defconfig index 4537b52c20..bc6ba7b139 100644 --- a/configs/rcar3_salvator-x_defconfig +++ b/configs/rcar3_salvator-x_defconfig @@ -16,12 +16,15 @@ CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.2 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a77950-salvator-x.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_UPDATE_TFTP=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y +CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -44,6 +47,9 @@ CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y @@ -57,6 +63,8 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y CONFIG_RENESAS_RPC_HF=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_BITBANGMII=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y @@ -69,6 +77,9 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_SCIF_CONSOLE=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y diff --git a/configs/rcar3_ulcb_defconfig b/configs/rcar3_ulcb_defconfig index b90b9e12b3..f654f84ac6 100644 --- a/configs/rcar3_ulcb_defconfig +++ b/configs/rcar3_ulcb_defconfig @@ -17,11 +17,14 @@ CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.2 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="r8a77950-ulcb.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_UPDATE_TFTP=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -44,6 +47,9 @@ CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y CONFIG_RCAR_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_RCAR_IIC=y @@ -57,6 +63,8 @@ CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_CFI_FLASH=y CONFIG_RENESAS_RPC_HF=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_BITBANGMII=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y @@ -66,6 +74,9 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_SCIF_CONSOLE=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_RENESAS_RPC_SPI=y CONFIG_SYSRESET=y CONFIG_TEE=y CONFIG_OPTEE=y
