[U-Boot] [PATCH v5] socfpga: Modify qts-filter args to allow input for bsp generated files and quartus project directories
The hps_isw_handoff and bsp/generated folders are typically not in the same path.This patch adds support for specifying the different input directories for the bsp and quartus projects.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com Acked-by: Marek Vasut marex@denx.de Acked-by: Chin Liang See clsee@altera.com --- Changes for v2: - Add commit message Changes for v3: - Fix line length issues Changes for v4: - Cleanup/clarify help messages Changes for v5: - Fix line length issues --- arch/arm/mach-socfpga/qts-filter.sh | 76 ++++++++++++++++++++++--------------- 1 file changed, 45 insertions(+), 31 deletions(-)
diff --git a/arch/arm/mach-socfpga/qts-filter.sh b/arch/arm/mach-socfpga/qts-filter.sh index c1640bc..1adfbf7 100755 --- a/arch/arm/mach-socfpga/qts-filter.sh +++ b/arch/arm/mach-socfpga/qts-filter.sh @@ -3,13 +3,15 @@ # # Process iocsr_config_*.[ch] # $1: SoC type -# $2: Input directory -# $3: Output directory +# $2: Input handoff directory +# $3: Input BSP Generated directory +# $4: Output directory # process_iocsr_config() { soc="$1" - in_dir="$2" - out_dir="$3" + in_qts_dir="$2" + in_bsp_dir="$3" + out_dir="$4"
( cat << EOF @@ -26,13 +28,13 @@ EOF
# Retrieve the scan chain lengths grep 'CONFIG_HPS_IOCSR_SCANCHAIN[0-9]+_LENGTH' \ - ${in_dir}/generated/iocsr_config_${soc}.h | tr -d "()" + ${in_bsp_dir}/generated/iocsr_config_${soc}.h | tr -d "()"
echo ""
# Retrieve the scan chain config and zap the ad-hoc length encoding sed -n '/^const/ !b; :next {/^const/ s/(.*)//;p;n;b next}' \ - ${in_dir}/generated/iocsr_config_${soc}.c + ${in_bsp_dir}/generated/iocsr_config_${soc}.c
cat << EOF
@@ -49,8 +51,9 @@ EOF # process_pinmux_config() { soc="$1" - in_dir="$2" - out_dir="$3" + in_qts_dir="$2" + in_bsp_dir="$3" + out_dir="$4"
( cat << EOF @@ -67,7 +70,7 @@ EOF
# Retrieve the pinmux config and zap the ad-hoc length encoding sed -n '/^unsigned/ !b; :next {/^unsigned/ {s/[.*]/[]/;s/unsigned long/const u8/};p;n;b next}' \ - ${in_dir}/generated/pinmux_config_${soc}.c + ${in_bsp_dir}/generated/pinmux_config_${soc}.c
cat << EOF
@@ -84,8 +87,9 @@ EOF # process_pll_config() { soc="$1" - in_dir="$2" - out_dir="$3" + in_qts_dir="$2" + in_bsp_dir="$3" + out_dir="$4"
( cat << EOF @@ -102,7 +106,7 @@ EOF
# Retrieve the pll config and zap parenthesis sed -n '/CONFIG_HPS/ !b; :next {/CONFIG_HPS/ s/[()]//g;/endif/ b;p;n;b next}' \ - ${in_dir}/generated/pll_config.h + ${in_bsp_dir}/generated/pll_config.h
cat << EOF
@@ -126,8 +130,9 @@ grep_sdram_config() { # process_sdram_config() { soc="$1" - in_dir="$2" - out_dir="$3" + in_qts_dir="$2" + in_bsp_dir="$3" + out_dir="$4"
( cat << EOF @@ -144,29 +149,32 @@ EOF
echo "/* SDRAM configuration */" # Retrieve the sdram config, zap broken lines and zap parenthesis - sed -n "/\\$/ {N;s/ \\\n/\t/};p" ${in_dir}/generated/sdram/sdram_config.h | + sed -n "/\\$/ {N;s/ \\\n/\t/};p" \ + ${in_bsp_dir}/generated/sdram/sdram_config.h | sed -n '/CONFIG_HPS/ !b; :next {/CONFIG_HPS/ s/[()]//g;/endif/ b;p;n;b next}' | sort -u | grep_sdram_config
echo "" echo "/* Sequencer auto configuration */" sed -n "/__RW_MGR/ {s/__//;s/ +([^ ]+)$/\t\1/p}" \ - ${in_dir}/hps_isw_handoff/*/sequencer_auto.h | sort -u | grep_sdram_config + ${in_qts_dir}/hps_isw_handoff/*/sequencer_auto.h | + sort -u | grep_sdram_config
echo "" echo "/* Sequencer defines configuration */" sed -n "/^#define [^_]/ {s/__//;s/ +([^ ]+)$/\t\1/p}" \ - ${in_dir}/hps_isw_handoff/*/sequencer_defines.h | sort -u | grep_sdram_config + ${in_qts_dir}/hps_isw_handoff/*/sequencer_defines.h | + sort -u | grep_sdram_config
echo "" echo "/* Sequencer ac_rom_init configuration */" sed -n '/^const.*[/ !b; :next {/^const.*[/ {N;s/\n//;s/alt_u32/u32/;s/[.*]/[]/};/endif/ b;p;n;b next}'\ - ${in_dir}/hps_isw_handoff/*/sequencer_auto_ac_init.c + ${in_qts_dir}/hps_isw_handoff/*/sequencer_auto_ac_init.c
echo "" echo "/* Sequencer inst_rom_init configuration */" sed -n '/^const.*[/ !b; :next {/^const.*[/ {N;s/\n//;s/alt_u32/u32/;s/[.*]/[]/};/endif/ b;p;n;b next}'\ - ${in_dir}/hps_isw_handoff/*/sequencer_auto_inst_init.c + ${in_qts_dir}/hps_isw_handoff/*/sequencer_auto_inst_init.c
cat << EOF
@@ -176,30 +184,36 @@ EOF }
usage() { - echo "$0 [soc_type] [input_dir] [output_dir]" + echo "$0 [soc_type] [input_qts_dir] [input_bsp_dir] [output_dir]" echo "Process QTS-generated headers into U-Boot compatible ones." echo "" - echo " soc_type\t\tType of SoC, either 'cyclone5' or 'arria5'," - echo " input_dir\t\tDirectory with the QTS project." - echo " output_dir\t\tDirectory to store the U-Boot compatible headers." + echo -e " soc_type\t-\tType of SoC, either 'cyclone5' or 'arria5'." + echo -e " input_qts_dir\t-\tDirectory with compiled Quartus project" + echo -e "\t\t\t\tand containing the Quartus project file (QPF)." + echo -e " input_bsp_dir\t-\tDirectory with generated bsp containing" + echo -e "\t\t\t\tthe settings.bsp file." + echo -e " output_dir\t-\tDirectory to store the U-Boot compatible" + echo -e "\t\t\t\theaders." echo "" }
soc="$1" -in_dir="$2" -out_dir="$3" +in_qts_dir="$2" +in_bsp_dir="$3" +out_dir="$4"
-if [ "$#" -ne 3 ] ; then +if [ "$#" -ne 4 ] ; then usage exit 1 fi
-if [ ! -d "${in_dir}" -o ! -d "${out_dir}" -o -z "${soc}" ] ; then +if [ ! -d "${in_qts_dir}" -o ! -d "${in_bsp_dir}" -o \ + ! -d "${out_dir}" -o -z "${soc}" ] ; then usage exit 3 fi
-process_iocsr_config "${soc}" "${in_dir}" "${out_dir}" -process_pinmux_config "${soc}" "${in_dir}" "${out_dir}" -process_pll_config "${soc}" "${in_dir}" "${out_dir}" -process_sdram_config "${soc}" "${in_dir}" "${out_dir}" +process_iocsr_config "${soc}" "${in_qts_dir}" "${in_bsp_dir}" "${out_dir}" +process_pinmux_config "${soc}" "${in_qts_dir}" "${in_bsp_dir}" "${out_dir}" +process_pll_config "${soc}" "${in_qts_dir}" "${in_bsp_dir}" "${out_dir}" +process_sdram_config "${soc}" "${in_qts_dir}" "${in_bsp_dir}" "${out_dir}"
Applied to u-boot-socfpga/master , thanks!
Best regards, Marek Vasut
Dalon Westergreen
