[U-Boot] [PATCH] miniarm-rk3288: set isp/vop qos priority level
isp-camera image will be broken when enter dual screen display mode. We set isp qos high to solve this problem.
Signed-off-by: Nickey Yang nickey.yang@rock-chips.com ---
board/rockchip/miniarm_rk3288/miniarm-rk3288.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/board/rockchip/miniarm_rk3288/miniarm-rk3288.c b/board/rockchip/miniarm_rk3288/miniarm-rk3288.c index 79541a3..7b90be5 100644 --- a/board/rockchip/miniarm_rk3288/miniarm-rk3288.c +++ b/board/rockchip/miniarm_rk3288/miniarm-rk3288.c @@ -5,3 +5,26 @@ */
#include <common.h> +#include <asm/io.h> + +/* cpu axi qos priority */ +#define CPU_AXI_QOS_PRIORITY_LEVEL(h, l) \ + ((((h) & 3) << 2) | ((l) & 3)) + +int rk_board_late_init(void) +{ + /* read latency configure */ + writel(0x34, 0xffac0000 + 0x14); + writel(0x34, 0xffac0080 + 0x14); + + /* set isp qos to highest priority */ + writel(CPU_AXI_QOS_PRIORITY_LEVEL(2, 2), 0xffad0908); + writel(CPU_AXI_QOS_PRIORITY_LEVEL(2, 2), 0xffad0108); + writel(CPU_AXI_QOS_PRIORITY_LEVEL(2, 2), 0xffad0188); + + /* set vop qos to highest priority */ + writel(CPU_AXI_QOS_PRIORITY_LEVEL(2, 2), 0xffad0008); + writel(CPU_AXI_QOS_PRIORITY_LEVEL(2, 2), 0xffad0408); + + return 0; +}
Hi Nickey,
What is this register? Can you please define a struct for it in a header file in arch/arm/include/asm/arch-rockchip/ ?
1.9.1
Nickey Yang
