[PATCH 016/347] FogBugz #516535: Fix QSPI write issues
QSPI driver perform chip select on every flash read/write access. The driver need to disable/enable the QSPI controller while performing chip select. This may cause some data lost especially the QSPI controller is configured to run at slower speed as it may take longer time to access the flash device. This patch prevent the driver from disable/enable the QSPI controller too soon and inadvertently halting any ongoing flash read/write access by ensuring the QSPI controller is always in idle mode after each read/write access.
Signed-off-by: Chee Hong Ang chee.hong.ang@intel.com --- drivers/spi/cadence_qspi_apb.c | 15 ++++++++------- 1 file changed, 8 insertions(+), 7 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 2cdf4c9c9f..5e03495f45 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -858,13 +858,9 @@ cadence_qspi_apb_indirect_read_execute(struct cadence_spi_plat *plat, writel(CQSPI_REG_INDIRECTRD_DONE, plat->regbase + CQSPI_REG_INDIRECTRD);
- /* Check indirect done status */ - ret = wait_for_bit_le32(plat->regbase + CQSPI_REG_INDIRECTRD, - CQSPI_REG_INDIRECTRD_DONE, 0, 10, 0); - if (ret) { - printf("Indirect read clear completion error (%i)\n", ret); - goto failrd; - } + /* Wait til QSPI is idle */ + if (!cadence_qspi_wait_idle(plat->regbase)) + return -EIO;
@@ -1031,6 +1027,11 @@ cadence_qspi_apb_indirect_write_execute(struct cadence_spi_plat *plat,
if (bounce_buf) free(bounce_buf); + + /* Wait til QSPI is idle */ + if (!cadence_qspi_wait_idle(plat->regbase)) + return -EIO; + return 0;
failwr:
"FogBugz #516535:" This commit head is invalid for the upstream patch.
- if (ret) {
goto failrd;
Why would you drop looking at CQSPI_REG_INDIRECTRD_DONE status bit? This gives out a much granular error wrt what operation actually failed.
return -EIO;
- /* Wait til QSPI is idle */
- if (!cadence_qspi_wait_idle(plat->regbase))
return -EIO;
failwr:
Jagan Teki
Jit Loon Lim
Vignesh Raghavendra
