Pull request efi-2025-01-rc2-2
Dear Tom,
The following changes since commit a7a96a37cbd875994bc8d25adb0536bf00e4a30e:
Merge https://source.denx.de/u-boot/custodians/u-boot-riscv (2024-11-06 10:44:33 -0600)
https://source.denx.de/u-boot/custodians/u-boot-efi.git efi-2025-01-rc2-2
for you to fetch changes up to 70b78d52937b5f18afbbc4257bd3b89b0e75a186:
test: efi: boot: Add a test for the efi bootmeth (2024-11-09 10:01:47 +0100)
Gitlab CI showed no issues: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/23260
---------------------------------------------------------------- Pull request efi-2025-01-rc2-2
Documentation:
* correct title and author of rst2pdf generated pdf * describe CONFIG_DEBUG_SBI_CONSOLE * remove vile language
UEFI
* correct printf codes in mkeficapsule * add an EFI test app * move default filename to a function * move get_efi_pxe_arch() to efi_helper * allow reporting the host defaults in efidebug * drop sandbox PXE architecture
Other:
* do not reserve extra 16 KiB of stack in lmb * disable the sandbox virtio blk device * provide -N command line flag to control EFI default boot file name on the sandbox * provide a unit test for the efi bootmeth
---------------------------------------------------------------- Heinrich Schuchardt (3): tools: mkeficapsule: use %zd to print ssize_t. doc: conf.py: correct title and author of generated pdf doc: qemu-riscv: describe CONFIG_DEBUG_SBI_CONSOLE
Moritz Fischer (1): efi_loader: Change efi_dp_from_mem() to use size
Simon Glass (11): lmb: Drop extra 16KB of stack space efi_loader: Add a test app sandbox: Add a -N flag to control on-host behaviour efi: Move default filename to a function efi_loader: Move get_efi_pxe_arch() to efi_helper efi_loader: Allow reporting the host defaults sandbox: Report host default-filename in native mode efi_loader: Drop sandbox PXE architecture sandbox: virtio: Disable the sandbox virtio blk device test: efi: boot: Set up an image suitable for EFI testing test: efi: boot: Add a test for the efi bootmeth
mason1920 (1): doc: remove vile language
arch/Kconfig | 3 +- arch/sandbox/cpu/start.c | 10 +++++ arch/sandbox/dts/test.dts | 2 +- arch/sandbox/include/asm/state.h | 1 + boot/bootmeth_efi.c | 29 ++------------ cmd/efidebug.c | 25 ++++++++++++ doc/board/emulation/qemu-riscv.rst | 5 +++ doc/conf.py | 8 +--- doc/develop/devicetree/control.rst | 2 +- include/efi.h | 34 ++++++++++++++++ include/efi_default_filename.h | 56 -------------------------- include/efi_loader.h | 2 +- lib/efi_loader/Kconfig | 10 +++++ lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_bootbin.c | 1 - lib/efi_loader/efi_bootmgr.c | 10 +++-- lib/efi_loader/efi_device_path.c | 7 ++-- lib/efi_loader/efi_helper.c | 71 +++++++++++++++++++++++++++++++++ lib/efi_loader/testapp.c | 56 ++++++++++++++++++++++++++ lib/lmb.c | 2 - test/boot/bootdev.c | 18 ++++++++- test/boot/bootflow.c | 76 ++++++++++++++++++++++++++++++++++-- test/py/tests/bootstd/flash1.img.xz | Bin 0 -> 4924 bytes test/py/tests/test_ut.py | 53 ++++++++++++++++++++++--- tools/mkeficapsule.c | 4 +- 25 files changed, 372 insertions(+), 114 deletions(-) delete mode 100644 include/efi_default_filename.h create mode 100644 lib/efi_loader/testapp.c create mode 100644 test/py/tests/bootstd/flash1.img.xz
On Sat, Nov 09, 2024 at 11:09:54AM +0100, Heinrich Schuchardt wrote:
Dear Tom,
