U-Boot DM device tree and Linux device tree - what are the differences and why?
I have a custom board that is similar to the i.MX6UL 14x14. One difference is that it has an eMMC rather than a SD card. Most recently I upgraded from u-boot 2019.07 to u-boot 2020.01 and now u-boot cannot detect the eMMC anymore.
For the 2019.07 version I did use CONFIG_FSL_ESDHC=y without CONFIG_DM_MMC. That does not work anymore. Compilation fails with "CONFIG_SYS_FSL_ESDHC_ADDR undefined". What has changed here and why?
Then I tried using CONFIG_FSL_USDHC=y and CONFIG_DM_MMC=y. I simply used the device tree from the Linux kernel which works just fine for the kernel. But it does not work for u-boot. It's hard to understand why. Why would the u-boot device tree be different than the kernel device tree? If that is even the issue.
It's an eMMC with 8-bit bus. Here are the definitions that work perfectly well for the Linux kernel:
&usdhc2 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usdhc2>; bus-width = <8>; max-frequency = <200000000>; vmmc-supply = <&sw2_reg>; mmc-ddr-1_8v; cap-mmc-highspeed; non-removable; keep-power-in-suspend; status = "okay"; };
pinctrl_usdhc2: usdhc2grp { fsl,pins = < MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x1b0d9 /* eMMC_CLK */ MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x1b0d9 /* eMMC_CMD */ MX6UL_PAD_NAND_ALE__USDHC2_RESET_B 0x1b0d9 /* eMMC_RST */ MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x1b0d9 /* eMMC_DAT0 */ MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x1b0d9 /* eMMC_DAT1 */ MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x1b0d9 /* eMMC_DAT2 */ MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x1b0d9 /* eMMC_DAT3 */ MX6UL_PAD_NAND_DATA04__USDHC2_DATA4 0x1b0d9 /* eMMC_DAT4 */ MX6UL_PAD_NAND_DATA05__USDHC2_DATA5 0x1b0d9 /* eMMC_DAT5 */ MX6UL_PAD_NAND_DATA06__USDHC2_DATA6 0x1b0d9 /* eMMC_DAT6 */ MX6UL_PAD_NAND_DATA07__USDHC2_DATA7 0x1b0d9 /* eMMC_DAT7 */ >; };
Every time the eMMC is probed e.g 'mmc dev 1' it takes about a second and then the response is 'MMC: no card present'.
I appreciate the help.
Thank you, Rudi
I solved the problem with u-boot not recognizing the eMMC. The device tree is working now for u-boot.
However, i.MX6 is using SPL which is loaded into OCRAM. If I flash SPL and u-boot to a boot partition on the eMMC the boot ROM loads SPL just fine but then SPL cannot load u-boot from eMMC:
Trying to boot from MMC1 MMC: no card present spl: mmc init failed with error: -123 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
If I enable CONFIG_SPL_DM=y and CONFIG_SPL_DM_MMC=y then I am getting this undefined reference (and a whole slew of other related to DM):
common/built-in.o:(.u_boot_list_2_uclass_2_usb_hub+0x8): undefined reference to `dm_scan_fdt_dev'
Even if I get this to link then the next question of course is if it will fit into the 68k OCRAM that the SoC has (the whole device tree infrastructure has a rather large footprint). It is hard to follow why the DM now is essentially enforced for storage media but does not seem to be tested with SPL.
Once again, I appreciate any pointer to a possible solution.
Rudi
Thank you, Rudi
Hi Rudolf,
On Tue, May 19, 2020 at 1:28 AM Rudolf J Streif rudolf.streif@ibeeto.com wrote:
I had a similar issue on a pico-imx6ul board. I preferred to put the MMC initialization code in SPL rather than relying on DM as in SPL we are very tight in memory.
Please see this commit: https://gitlab.denx.de/u-boot/u-boot/-/commit/9b8d9ec41a6f161d53d32bf71f7933...
Hi Fabio
On 5/19/20 5:23 AM, Fabio Estevam wrote:
Hi Rudolf,
Thank you so much. You pointed me into the right direction. I was able to find a solution for my board.
Much appreciated.
Rudi
Fabio Estevam
Rudolf J Streif
