[U-Boot] [PATCH v2] arm1176: fix relocation
Fix relocation code for arm1176, do it like other ARM CPU's are doing. Tested only with CONFIG_SKIP_RELOCATE_UBOOT defined and using nand_spl (booting from nand). Test done on s3c6410 based board (not yet supported in main line).
Signed-off-by: Darius Augulis augulis.darius@gmail.com ---
Changes since v1: - Heiko comments fixed
arch/arm/cpu/arm1176/start.S | 143 +++++++++++++++++++++++---------------- arch/arm/cpu/arm1176/u-boot.lds | 15 +++- 2 files changed, 97 insertions(+), 61 deletions(-)
diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 24e5bf4..afdc77b 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -115,44 +115,52 @@ _armboot_start:
/* * These are defined in the board-specific linker script. + * Subtracting _start from them lets the linker put their + * relative position in the executable instead of leaving + * them null. */ -.globl _bss_start -_bss_start: - .word __bss_start
-.globl _bss_end -_bss_end: - .word _end +.globl _bss_start_ofs +_bss_start_ofs: + .word __bss_start - _start
-#if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) -/* IRQ stack memory (calculated at run-time) + 8 bytes */ -.globl IRQ_STACK_START_IN -IRQ_STACK_START_IN: - .word 0x0badc0de +.globl _bss_end_ofs +_bss_end_ofs: + .word _end - _start
-.globl _datarel_start -_datarel_start: - .word __datarel_start +.globl _datarel_start_ofs +_datarel_start_ofs: + .word __datarel_start - _start
-.globl _datarelrolocal_start -_datarelrolocal_start: - .word __datarelrolocal_start +.globl _datarelrolocal_start_ofs +_datarelrolocal_start_ofs: + .word __datarelrolocal_start - _start
-.globl _datarellocal_start -_datarellocal_start: - .word __datarellocal_start +.globl _datarellocal_start_ofs +_datarellocal_start_ofs: + .word __datarellocal_start - _start
-.globl _datarelro_start -_datarelro_start: - .word __datarelro_start +.globl _datarelro_start_ofs +_datarelro_start_ofs: + .word __datarelro_start - _start
-.globl _got_start -_got_start: - .word __got_start +.globl _rel_dyn_start_ofs +_rel_dyn_start_ofs: + .word __rel_dyn_start - _start
-.globl _got_end -_got_end: - .word __got_end +.globl _rel_dyn_end_ofs +_rel_dyn_end_ofs: + .word __rel_dyn_end - _start + +.globl _dynsym_start_ofs +_dynsym_start_ofs: + .word __dynsym_start - _start + +#if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) +/* IRQ stack memory (calculated at run-time) + 8 bytes */ +.globl IRQ_STACK_START_IN +IRQ_STACK_START_IN: + .word 0x0badc0de
/* * the actual reset code @@ -274,9 +282,8 @@ stack_setup:
adr r0, _start ldr r2, _TEXT_BASE - ldr r3, _bss_start - sub r2, r3, r2 /* r2 <- size of armboot */ - add r2, r0, r2 /* r2 <- source end address */ + ldr r3, _bss_start_ofs + add r2, r0, r3 /* r2 <- source end address */ cmp r0, r6 beq clear_bss
@@ -288,24 +295,44 @@ copy_loop: blo copy_loop
#ifndef CONFIG_PRELOADER - /* fix got entries */ - ldr r1, _TEXT_BASE /* Text base */ - mov r0, r7 /* reloc addr */ - ldr r2, _got_start /* addr in Flash */ - ldr r3, _got_end /* addr in Flash */ - sub r3, r3, r1 - add r3, r3, r0 - sub r2, r2, r1 - add r2, r2, r0 - + /* + * fix .rel.dyn relocations + */ + ldr r0, _TEXT_BASE /* r0 <- Text base */ + sub r9, r7, r0 /* r9 <- relocation offset */ + ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ + add r10, r10, r0 /* r10 <- sym table in FLASH */ + ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ + add r2, r2, r0 /* r2 <- rel dyn start in FLASH */ + ldr r3, _rel_dyn_end_ofs /* r3 <- rel dyn end ofs */ + add r3, r3, r0 /* r3 <- rel dyn end in FLASH */ fixloop: - ldr r4, [r2] - sub r4, r4, r1 - add r4, r4, r0 - str r4, [r2] - add r2, r2, #4 + ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ + add r0, r0, r9 /* r0 <- location to fix up in RAM */ + ldr r1, [r2, #4] + and r8, r1, #0xff + cmp r8, #23 /* relative fixup? */ + beq fixrel + cmp r8, #2 /* absolute fixup? */ + beq fixabs + /* ignore unknown type of fixup */ + b fixnext +fixabs: + /* absolute fix: set location to (offset) symbol value */ + mov r1, r1, LSR #4 /* r1 <- symbol index in .dynsym */ + add r1, r10, r1 /* r1 <- address of symbol in table */ + ldr r1, [r1, #4] /* r1 <- symbol value */ + add r1, r1, r9 /* r1 <- relocated sym addr */ + b fixnext +fixrel: + /* relative fix: increase location by offset */ + ldr r1, [r0] + add r1, r1, r9 +fixnext: + str r1, [r0] + add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 - bne fixloop + blo fixloop #endif #endif /* #ifndef CONFIG_SKIP_RELOCATE_UBOOT */
@@ -349,13 +376,11 @@ skip_hw_init:
clear_bss: #ifndef CONFIG_PRELOADER - ldr r0, _bss_start - ldr r1, _bss_end + ldr r0, _bss_start_ofs + ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ mov r4, r7 /* reloc addr */ - sub r0, r0, r3 add r0, r0, r4 - sub r1, r1, r3 add r1, r1, r4 mov r2, #0x00000000 /* clear */
@@ -377,18 +402,20 @@ clbss_l:str r2, [r0] /* clear loop... */
_nand_boot: .word nand_boot #else - ldr r0, _TEXT_BASE - ldr r2, _board_init_r - sub r2, r2, r0 - add r2, r2, r7 /* position from board_init_r in RAM */ + ldr r0, _board_init_r_ofs + adr r1, _start + add lr, r0, r1 +#ifndef CONFIG_SKIP_RELOCATE_UBOOT + add lr, lr, r9 +#endif /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ mov r1, r7 /* dest_addr */ /* jump to it ... */ - mov lr, r2 mov pc, lr
-_board_init_r: .word board_init_r +_board_init_r_ofs: + .word board_init_r - _start #endif
#else /* #if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) */ diff --git a/arch/arm/cpu/arm1176/u-boot.lds b/arch/arm/cpu/arm1176/u-boot.lds index fa640ee..d9ed954 100644 --- a/arch/arm/cpu/arm1176/u-boot.lds +++ b/arch/arm/cpu/arm1176/u-boot.lds @@ -51,11 +51,14 @@ SECTIONS *(.data.rel.ro) }
- __got_start = .; . = ALIGN(4); - .got : { *(.got) } + __rel_dyn_start = .; + .rel.dyn : { *(.rel.dyn) } + __rel_dyn_end = .; + + __dynsym_start = .; + .dynsym : { *(.dynsym) }
- __got_end = .; . = .; __u_boot_cmd_start = .; .u_boot_cmd : { *(.u_boot_cmd) } @@ -65,4 +68,10 @@ SECTIONS __bss_start = .; .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } _end = .; + + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } }
Dear Darius Augulis,
Changes since v1:
Applied, thanks.
Darius Augulis
