[U-Boot] [PATCH] UEC FIXED PHY: Determine fixed-phy port using UEC interface name.
From 003e7ab2bb1ee6bdc569dd24496809a766284615 Mon Sep 17 00:00:00 2001 From: Richard Retanubun RichardRetanubun@RuggedCom.com Date: Wed, 1 Jul 2009 10:30:18 -0400 Subject: [PATCH] UEC FIXED PHY: Determine fixed-phy port using UEC interface name.
Fixed a misunderstanding in the original implementation, 'devnum' that was used in the cpu/ppc4xx/4xx_enet.c implementation was NOT the PHY's SMI address, rather it was the number of the MAC interface on the CPU. The equivalent of this for uec_phy will be the UEC number stored in mii_info->dev->name. Usage example is updated for uec. --- drivers/qe/uec_phy.c | 36 +++++++++++++++++++----------------- 1 files changed, 19 insertions(+), 17 deletions(-)
diff --git a/drivers/qe/uec_phy.c b/drivers/qe/uec_phy.c index d613f3e..aa4eb5e 100644 --- a/drivers/qe/uec_phy.c +++ b/drivers/qe/uec_phy.c @@ -51,27 +51,28 @@ *--------------------------------------------------------------------*/
/* - * Some boards do not have a PHY for each ethernet port. These ports - * are known as Fixed PHY (or PHY-less) ports. For such ports, set - * the appropriate CONFIG_PHY_ADDR equal to CONFIG_FIXED_PHY and - * then define CONFIG_SYS_FIXED_PHY_PORTS to define what the speed and - * duplex should be for these ports in the board configuration - * file. + * Some boards do not have a PHY for each ethernet port. These ports are known + * as Fixed PHY (or PHY-less) ports. For such ports, set the appropriate + * CONFIG_SYS_UECx_PHY_ADDR equal to CONFIG_FIXED_PHY_ADDR (an unused address) + * When the drver tries to identify the PHYs, CONFIG_FIXED_PHY will be returned + * and the driver will search CONFIG_SYS_FIXED_PHY_PORTS to find what network + * speed and duplex should be for the port. * - * For Example: + * Example board header configuration file: * #define CONFIG_FIXED_PHY 0xFFFFFFFF + * #define CONFIG_SYS_FIXED_PHY_ADDR 0x1E (pick an unused phy address) * - * #define CONFIG_PHY_ADDR CONFIG_FIXED_PHY - * #define CONFIG_PHY1_ADDR 1 - * #define CONFIG_PHY2_ADDR CONFIG_FIXED_PHY - * #define CONFIG_PHY3_ADDR 3 + * #define CONFIG_SYS_UEC1_PHY_ADDR CONFIG_SYS_FIXED_PHY_ADDR + * #define CONFIG_SYS_UEC2_PHY_ADDR 0x02 + * #define CONFIG_SYS_UEC3_PHY_ADDR CONFIG_SYS_FIXED_PHY_ADDR + * #define CONFIG_SYS_UEC4_PHY_ADDR 0x04 * - * #define CONFIG_SYS_FIXED_PHY_PORT(devnum,speed,duplex) \ - * {devnum, speed, duplex}, + * #define CONFIG_SYS_FIXED_PHY_PORT(name,speed,duplex) \ + * {name, speed, duplex}, * * #define CONFIG_SYS_FIXED_PHY_PORTS \ - * CONFIG_SYS_FIXED_PHY_PORT(0,SPEED_100,DUPLEX_FULL) \ - * CONFIG_SYS_FIXED_PHY_PORT(2,SPEED_100,DUPLEX_HALF) + * CONFIG_SYS_FIXED_PHY_PORT("FSL UEC0",SPEED_100,DUPLEX_FULL) \ + * CONFIG_SYS_FIXED_PHY_PORT("FSL UEC2",SPEED_100,DUPLEX_HALF) */
#ifndef CONFIG_FIXED_PHY @@ -83,7 +84,7 @@ #endif
struct fixed_phy_port { - unsigned int devnum; /* ethernet port */ + char name[NAMESIZE]; /* ethernet port name */ unsigned int speed; /* specified speed 10,100 or 1000 */ unsigned int duplex; /* specified duplex FULL or HALF */ }; @@ -592,7 +593,8 @@ static int fixed_phy_read_status (struct uec_mii_info *mii_info) int i = 0;
for (i = 0; i < ARRAY_SIZE(fixed_phy_port); i++) { - if (mii_info->mii_id == fixed_phy_port[i].devnum) { + if (strncmp(mii_info->dev->name, fixed_phy_port[i].name, + strlen(mii_info->dev->name)) == 0) { mii_info->speed = fixed_phy_port[i].speed; mii_info->duplex = fixed_phy_port[i].duplex; mii_info->link = 1; /* Link is always UP */
Richard Retanubun
