[U-Boot] [PATCH] nios2: remove asm/status_led.h
The file has a wrong inline keyword of __led_toggle(), which causes compilation error. And its content is defined in common status_led.h. So define CONFIG_BOARD_SPECIFIC_LED in board config files and remove this header file.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/include/asm/status_led.h | 31 ------------------------------- include/configs/PK1C20.h | 1 + include/configs/nios2-generic.h | 1 + include/status_led.h | 3 --- 4 files changed, 2 insertions(+), 34 deletions(-) delete mode 100644 arch/nios2/include/asm/status_led.h
diff --git a/arch/nios2/include/asm/status_led.h b/arch/nios2/include/asm/status_led.h deleted file mode 100644 index 20f8d90..0000000 --- a/arch/nios2/include/asm/status_led.h +++ /dev/null @@ -1,31 +0,0 @@ -/* - * (C) Copyright 2004, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#ifndef __ASM_STATUS_LED_H__ -#define __ASM_STATUS_LED_H__ - -typedef unsigned led_id_t; -extern void __led_init (led_id_t mask, int state); -extern void __led_set (led_id_t mask, int state); -inline void __led_toggle (led_id_t mask); - -#endif /* __ASM_STATUS_LED_H__ */ diff --git a/include/configs/PK1C20.h b/include/configs/PK1C20.h index 403fafa..aced85b 100644 --- a/include/configs/PK1C20.h +++ b/include/configs/PK1C20.h @@ -142,6 +142,7 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_LEDPIO_ADDR 0x02120870 /* LED PIO base addr */ #define CONFIG_STATUS_LED /* Enable status driver */ +#define CONFIG_BOARD_SPECIFIC_LED
#define STATUS_LED_BIT 1 /* Bit-0 on PIO */ #define STATUS_LED_STATE 1 /* Blinking */ diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index 69ff3ef..624bd5c 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -68,6 +68,7 @@ #define CONFIG_SYS_ALTERA_PIO_GPIO_NUM LED_PIO_WIDTH
#define CONFIG_STATUS_LED /* Enable status driver */ +#define CONFIG_BOARD_SPECIFIC_LED #define CONFIG_GPIO_LED /* Enable GPIO LED driver */ #define CONFIG_GPIO /* Enable GPIO driver */
diff --git a/include/status_led.h b/include/status_led.h index da9fae9..27e9127 100644 --- a/include/status_led.h +++ b/include/status_led.h @@ -273,9 +273,6 @@ void status_led_set (int led, int state); #elif defined(CONFIG_STXXTC) /* XXX empty just to avoid the error */ /************************************************************************/ -#elif defined(CONFIG_NIOS2) -/* XXX empty just to avoid the error */ -/************************************************************************/ #elif defined(CONFIG_V38B)
# define STATUS_LED_BIT 0x0010 /* Timer7 GPIO */
Thomas Chou
