Please pull u-boot-dm/next
Hi Tom,
This is for the -next branch.
https://source.denx.de/u-boot/custodians/u-boot-dm/-/commit/e87da5704ffa6fc7...
The following changes since commit ea82ed8c2eaee0a0f7dee31016aaee4ce88e9ea7:
Merge branch '2022-06-27-add-armv8-sha1-sha256-support' into next (2022-06-27 13:39:19 -0400)
git://git.denx.de/u-boot-dm.git tags/dm-pull-28jun22
for you to fetch changes up to e87da5704ffa6fc782d93d137fa30a37a5df3566:
armv8: u-boot-spl.lds: mark __image_copy_start as symbol (2022-06-28 03:09:52 +0100)
---------------------------------------------------------------- nman external-symbol improvements Driver model memory-usage reporting patman test-reporting improvements Add bloblist design goals
---------------------------------------------------------------- Alper Nebi Yasak (12): patman: test_util: Fix printing results for failed tests patman: test_util: Handle nonexistent tests while loading tests patman: test_util: Use unittest text runner to print test results patman: test_util: Customize unittest test results for more info patman: test_util: Print test stdout/stderr within test summaries spl: binman: Fix use of undeclared u_boot_any symbols spl: binman: Make TPL_BINMAN_SYMBOLS depend on TPL_FRAMEWORK spl: binman: Declare extern symbols for VPL as well spl: binman: Split binman symbols support from enabling binman spl: binman: Add config options for binman symbols in VPL spl: binman: Check at runtime if binman symbols were filled in spl: binman: Disable u_boot_any symbols for i.MX8M boards
Heinrich Schuchardt (6): sandbox: add function os_printf() sandbox: show error if the device-tree cannot be loaded dm: fix formatting of uclass dump sandbox: raise SANDBOX_RAM_SIZE_MB default to 256 test: fix some pylint errors in test_bind.py sandbox: cast to pointer from integer of different size
Peng Fan (1): armv8: u-boot-spl.lds: mark __image_copy_start as symbol
Sean Anderson (4): sandbox: usb: Fix out-of-bounds read when fd=-1 dm: core: Provide fallbacks for ofnode_conf_read_... dm: core: Use device_foreach_child where possible patman: Fix defaults not propagating to subparsers
Simon Glass (11): bloblist: Describe the design goals dtoc: Update fdt tests to use test_util dm: core: Rename dm_dump_all() dm: core: Sort dm subcommands dm: core: Fix addresses in the dm static command dm: core: Add documentation for the dm command dm: core: Switch the testbus driver to use a new struct dm: core: Support accessing core tags dm: core: Add a way to collect memory usage dm: core: Add a command to show driver model statistics dm: spl: Allow SPL to show memory usage
arch/arm/cpu/armv8/u-boot-spl.lds | 2 +- arch/sandbox/Kconfig | 4 +- arch/sandbox/cpu/cpu.c | 8 +- arch/sandbox/cpu/os.c | 13 + cmd/dm.c | 72 ++-- common/spl/Kconfig | 23 +- common/spl/Kconfig.tpl | 27 +- common/spl/Kconfig.vpl | 25 ++ common/spl/spl.c | 25 +- common/spl/spl_ram.c | 2 +- doc/develop/bloblist.rst | 2 + doc/usage/cmd/dm.rst | 487 ++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + drivers/core/Kconfig | 21 ++ drivers/core/device-remove.c | 4 +- drivers/core/device.c | 86 ++++- drivers/core/devres.c | 2 +- drivers/core/dump.c | 83 ++++- drivers/core/root.c | 53 +++ drivers/core/tag.c | 29 ++ drivers/misc/qfw_sandbox.c | 2 +- drivers/misc/test_drv.c | 6 +- drivers/usb/emul/sandbox_flash.c | 5 +- include/binman_sym.h | 51 ++- include/bloblist.h | 62 +++- include/dm/device.h | 25 ++ include/dm/ofnode.h | 66 ++-- include/dm/root.h | 45 +++ include/dm/tag.h | 32 +- include/dm/test.h | 7 + include/dm/util.h | 11 +- include/os.h | 7 + include/spl.h | 2 + test/dm/core.c | 91 ++++++ test/py/tests/test_bind.py | 345 ++++++++++---------- tools/binman/elf.py | 12 +- tools/binman/elf_test.py | 12 +- tools/binman/ftest.py | 33 +- tools/binman/main.py | 8 +- tools/binman/test/021_image_pad.dts | 2 +- tools/binman/test/024_sorted.dts | 2 +- tools/binman/test/028_pack_4gb_outside.dts | 2 +- tools/binman/test/029_x86_rom.dts | 6 +- tools/binman/test/053_symbols.dts | 2 +- tools/binman/test/149_symbols_tpl.dts | 4 +- tools/binman/test/155_symbols_tpl_x86.dts | 4 +- tools/binman/test/187_symbols_sub.dts | 2 +- tools/binman/test/Makefile | 2 +- tools/binman/test/generated/autoconf.h | 3 + tools/binman/test/u_boot_binman_syms.c | 6 +- tools/binman/test/u_boot_binman_syms_size.c | 6 +- tools/buildman/main.py | 8 +- tools/concurrencytest/concurrencytest.py | 83 ++++- tools/dtoc/main.py | 9 +- tools/dtoc/test_dtoc.py | 6 +- tools/dtoc/test_fdt.py | 29 +- tools/patman/main.py | 8 +- tools/patman/settings.py | 7 +- tools/patman/test_util.py | 150 ++++++--- 59 files changed, 1723 insertions(+), 409 deletions(-) create mode 100644 doc/usage/cmd/dm.rst create mode 100644 tools/binman/test/generated/autoconf.h
Hi Tom,
On Tue, 28 Jun 2022 at 07:41, Simon Glass sjg@chromium.org wrote:
Hi Tom,
Just checking on this one?
On Tue, Jun 28, 2022 at 07:41:16AM -0600, Simon Glass wrote:
Hi Tom,
