[U-Boot] [PATCH 1/2][v3]powerpc/usb:Define CONFIG_USB_MAX_CONTROLLER_COUNT for all 85xx socs
CONFIG_USB_MAX_CONTROLLER_COUNT macro recently defined for initializing all USB controllers on a given platform. This macro is defined for all 85xx socs
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com --- Change for v3: - corrected macro mistake in fdt.c file ifdef CONFIG_USB_MAX_CONTROLLER_COUNT --> ifndef CONFIG_USB_MAX_CONTROLLER_COUNT
arch/powerpc/cpu/mpc8xxx/fdt.c | 6 ++++-- arch/powerpc/include/asm/config_mpc85xx.h | 26 +++++++++++++++++++++++++- 2 files changed, 29 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index eb7cbbc..9273745 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -15,7 +15,9 @@ #include <phy.h> #include <hwconfig.h>
-#define FSL_MAX_NUM_USB_CTRLS 2 +#ifndef CONFIG_USB_MAX_CONTROLLER_COUNT +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 +#endif
#if defined(CONFIG_MP) && (defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx)) static int ft_del_cpuhandle(void *blob, int cpuhandle) @@ -128,7 +130,7 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) char str[5]; int i, j;
- for (i = 1; i <= FSL_MAX_NUM_USB_CTRLS; i++) { + for (i = 1; i <= CONFIG_USB_MAX_CONTROLLER_COUNT; i++) { int mode_idx = -1, phy_idx = -1; snprintf(str, 5, "%s%d", "usb", i); if (hwconfig(str)) { diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 946ea97..4cc12ee 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -133,6 +133,7 @@ #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" @@ -153,6 +154,7 @@ #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 @@ -162,6 +164,7 @@ #elif defined(CONFIG_P1012) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM @@ -178,6 +181,7 @@ #elif defined(CONFIG_P1013) #define CONFIG_MAX_CPUS 1 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 2 @@ -196,6 +200,7 @@ #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_IFC_A002769 @@ -210,6 +215,7 @@ #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 2 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_QMAN_NUM_PORTALS 3 #define CONFIG_SYS_BMAN_NUM_PORTALS 3 #define CONFIG_SYS_FM_MURAM_SIZE 0x10000 @@ -228,6 +234,7 @@ #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_A005125 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2
#elif defined(CONFIG_P1021) #define CONFIG_MAX_CPUS 2 @@ -243,6 +250,7 @@ #define MAX_QE_RISC 1 #define QE_NUM_OF_SNUM 28 #define CONFIG_SYS_FSL_ERRATUM_A005125 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1
#elif defined(CONFIG_P1022) #define CONFIG_MAX_CPUS 2 @@ -250,6 +258,7 @@ #define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 @@ -263,6 +272,7 @@ #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 2 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_QMAN_NUM_PORTALS 3 #define CONFIG_SYS_BMAN_NUM_PORTALS 3 #define CONFIG_SYS_FM_MURAM_SIZE 0x10000 @@ -280,6 +290,7 @@ #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 @@ -289,6 +300,7 @@ #elif defined(CONFIG_P1025) #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_TSECV2 #define CONFIG_FSL_PCIE_DISABLE_ASPM @@ -307,6 +319,7 @@ #define CONFIG_SYS_FSL_NUM_LAWS 12 #define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 #define CONFIG_SYS_FSL_SEC_COMPAT 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_ESDHC_A001 @@ -326,7 +339,7 @@ #define CONFIG_SYS_FSL_RMU #define CONFIG_SYS_FSL_SRIO_MSG_UNIT_NUM 2 #define CONFIG_SYS_FSL_ERRATUM_A005125 - +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #elif defined(CONFIG_PPC_P2041) /* also supports P2040 */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ @@ -338,6 +351,7 @@ #define CONFIG_SYS_NUM_FM1_DTSEC 5 #define CONFIG_SYS_NUM_FM1_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 32 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" @@ -381,6 +395,7 @@ #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_NMG_CPU_A011 #define CONFIG_SYS_FSL_ERRATUM_USB14 @@ -413,6 +428,7 @@ #define CONFIG_SYS_NUM_FM1_10GEC 1 #define CONFIG_SYS_NUM_FM2_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,p4080-pcie" @@ -460,6 +476,7 @@ #define CONFIG_SYS_NUM_FM1_DTSEC 5 #define CONFIG_SYS_NUM_FM1_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 32 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" @@ -495,6 +512,7 @@ #define CONFIG_SYS_NUM_FM2_DTSEC 5 #define CONFIG_SYS_NUM_FM2_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.4" @@ -519,6 +537,7 @@ #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_FSL_DSP_M2_RAM_ADDR 0xb0000000 #define CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT 0xff600000 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 @@ -535,6 +554,7 @@ #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_FSL_DSP_DDR_ADDR 0x40000000 #define CONFIG_SYS_FSL_DSP_M2_RAM_ADDR 0xb0000000 #define CONFIG_SYS_FSL_DSP_M3_RAM_ADDR 0xc0000000 @@ -581,6 +601,7 @@ #define CONFIG_SYS_FSL_SRDS_4 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_SYS_NUM_FMAN 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_PME_CLK 0 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 @@ -615,6 +636,7 @@ #define CONFIG_SYS_FSL_SRDS_2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_SYS_NUM_FMAN 1 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_FM1_CLK 0 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 @@ -637,6 +659,7 @@ #define CONFIG_SYS_NUM_FM1_DTSEC 6 #define CONFIG_SYS_NUM_FM1_10GEC 2 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 #define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9 #define CONFIG_SYS_FSL_SRIO_IB_WIN_NUM 5 @@ -671,6 +694,7 @@ #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 5 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_PME_PLAT_CLK_DIV 2 #define CONFIG_SYS_PME_CLK CONFIG_PME_PLAT_CLK_DIV #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0
Change for v3:
Applied to 85xx/next branch, pending merge to master.
York
Ramneek Mehresh
York Sun
