Hi Tom,
This PR includes the following x86 changes for v2023.01 release:
- Adjust CONFIG_TEXT_BASE for BayTrail based platforms - 2 cosmetic issue fixes
CI result: PASS https://dev.azure.com/bmeng/GitHub/_build/results?buildId=479&view=resul...
The following changes since commit c917865c7fd14420d25388bb3c8c24cb03911caf:
Merge https://source.denx.de/u-boot/custodians/u-boot-marvell (2022-12-12 09:00:58 -0500)
https://source.denx.de/u-boot/custodians/u-boot-x86.git
for you to fetch changes up to 58e2a35f2e81b0114cf05bfd6e96e4d70e47b22c:
x86: cosmetic: Fix a typo in the reserve_arch() comments (2022-12-14 12:04:51 +0800)
---------------------------------------------------------------- Alistair Delva (1): x86: Fix i8259 ifdef include guard
Bin Meng (6): x86: bayleybay: Adjust CONFIG_TEXT_BASE x86: minnowmax: Adjust CONFIG_TEXT_BASE x86: conga-qeval20-qa3-e3845: Adjust CONFIG_TEXT_BASE x86: dfi-bt700: Adjust CONFIG_TEXT_BASE x86: som-db5800-som-6867: Adjust CONFIG_TEXT_BASE x86: cosmetic: Fix a typo in the reserve_arch() comments
arch/x86/cpu/cpu.c | 2 +- arch/x86/include/asm/i8259.h | 4 ++-- configs/bayleybay_defconfig | 2 +- configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 2 +- configs/conga-qeval20-qa3-e3845_defconfig | 2 +- configs/dfi-bt700-q7x-151_defconfig | 2 +- configs/minnowmax_defconfig | 2 +- configs/som-db5800-som-6867_defconfig | 2 +- configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig | 2 +- configs/theadorable-x86-conga-qa3-e3845_defconfig | 2 +- configs/theadorable-x86-dfi-bt700_defconfig | 2 +- 11 files changed, 12 insertions(+), 12 deletions(-)
Regards, Bin
On Wed, Dec 14, 2022 at 02:27:47PM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
