[PATCH 1/2] fsl_ifc: fix typo in the NOR CSOR register definition
The name of the define must indicate 'Asynchronous', so 'ASYNC' is more appropriate. AYSNC is probably a typo, and checkpatch script is throwing a warning if this is set in the board include files.
It is save to change this now as none of the existing designs is using it so far, but we will use it in our design it help to make IFC settings more transparent.
Signed-off-by: Aleksandar Gerasimovski aleksandar.gerasimovski@hitachi-powergrids.com --- include/fsl_ifc.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/fsl_ifc.h b/include/fsl_ifc.h index e1e6214..9f243cd 100644 --- a/include/fsl_ifc.h +++ b/include/fsl_ifc.h @@ -140,7 +140,7 @@ #define CSOR_NOR_ADM_SHIFT_SHIFT 13 #define CSOR_NOR_ADM_SHIFT(n) ((n) << CSOR_NOR_ADM_SHIFT_SHIFT) /* Type of the NOR device hooked */ -#define CSOR_NOR_NOR_MODE_AYSNC_NOR 0x00000000 +#define CSOR_NOR_NOR_MODE_ASYNC_NOR 0x00000000 #define CSOR_NOR_NOR_MODE_AVD_NOR 0x00000020 /* Time for Read Enable High to Output High Impedance */ #define CSOR_NOR_TRHZ_MASK 0x0000001C
