[PATCH] mtd: remove drivers/mtd/mw_eeprom.c
drivers/mtd/mw_eeprom.c contains code that never worked. mw_eeprom_write() and mw_eeprom_read() have incorrect loop conditions:
while (len <= 2) {
CONFIG_MW_EEPROM is not set anywhere. So let's simply drop the module.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/mtd/Makefile | 1 - drivers/mtd/mw_eeprom.c | 238 ---------------------------------------- 2 files changed, 239 deletions(-) delete mode 100644 drivers/mtd/mw_eeprom.c
diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index 318788c5e2..6d77ebfaa5 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -11,7 +11,6 @@ mtd-$(CONFIG_ALTERA_QSPI) += altera_qspi.o mtd-$(CONFIG_FLASH_CFI_DRIVER) += cfi_flash.o mtd-$(CONFIG_FLASH_CFI_MTD) += cfi_mtd.o mtd-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o -mtd-$(CONFIG_MW_EEPROM) += mw_eeprom.o mtd-$(CONFIG_FLASH_PIC32) += pic32_flash.o mtd-$(CONFIG_ST_SMI) += st_smi.o mtd-$(CONFIG_STM32_FLASH) += stm32_flash.o diff --git a/drivers/mtd/mw_eeprom.c b/drivers/mtd/mw_eeprom.c deleted file mode 100644 index 9837733bee..0000000000 --- a/drivers/mtd/mw_eeprom.c +++ /dev/null @@ -1,238 +0,0 @@ -/* Three-wire (MicroWire) serial eeprom driver (for 93C46 and compatibles) */ - -#include <common.h> -#include <eeprom.h> -#include <asm/ic/ssi.h> -#include <linux/delay.h> - -/* - * Serial EEPROM opcodes, including start bit - */ -#define EEP_OPC_ERASE 0x7 /* 3-bit opcode */ -#define EEP_OPC_WRITE 0x5 /* 3-bit opcode */ -#define EEP_OPC_READ 0x6 /* 3-bit opcode */ - -#define EEP_OPC_ERASE_ALL 0x12 /* 5-bit opcode */ -#define EEP_OPC_ERASE_EN 0x13 /* 5-bit opcode */ -#define EEP_OPC_WRITE_ALL 0x11 /* 5-bit opcode */ -#define EEP_OPC_ERASE_DIS 0x10 /* 5-bit opcode */ - -static int addrlen; - -static void mw_eeprom_select(int dev) -{ - ssi_set_interface(2048, 0, 0, 0); - ssi_chip_select(0); - udelay(1); - ssi_chip_select(dev); - udelay(1); -} - -static int mw_eeprom_size(int dev) -{ - int x; - u16 res; - - mw_eeprom_select(dev); - ssi_tx_byte(EEP_OPC_READ); - - res = ssi_txrx_byte(0) << 8; - res |= ssi_rx_byte(); - for (x = 0; x < 16; x++) { - if (! (res & 0x8000)) { - break; - } - res <<= 1; - } - ssi_chip_select(0); - - return x; -} - -int mw_eeprom_erase_enable(int dev) -{ - mw_eeprom_select(dev); - ssi_tx_byte(EEP_OPC_ERASE_EN); - ssi_tx_byte(0); - udelay(1); - ssi_chip_select(0); - - return 0; -} - -int mw_eeprom_erase_disable(int dev) -{ - mw_eeprom_select(dev); - ssi_tx_byte(EEP_OPC_ERASE_DIS); - ssi_tx_byte(0); - udelay(1); - ssi_chip_select(0); - - return 0; -} - - -u32 mw_eeprom_read_word(int dev, int addr) -{ - u16 rcv; - u16 res; - int bits; - - mw_eeprom_select(dev); - ssi_tx_byte((EEP_OPC_READ << 5) | ((addr >> (addrlen - 5)) & 0x1f)); - rcv = ssi_txrx_byte(addr << (13 - addrlen)); - res = rcv << (16 - addrlen); - bits = 4 + addrlen; - - while (bits>0) { - rcv = ssi_rx_byte(); - if (bits > 7) { - res |= rcv << (bits - 8); - } else { - res |= rcv >> (8 - bits); - } - bits -= 8; - } - - ssi_chip_select(0); - - return res; -} - -int mw_eeprom_write_word(int dev, int addr, u16 data) -{ - u8 byte1=0; - u8 byte2=0; - - mw_eeprom_erase_enable(dev); - mw_eeprom_select(dev); - - switch (addrlen) { - case 6: - byte1 = EEP_OPC_WRITE >> 2; - byte2 = (EEP_OPC_WRITE << 6)&0xc0; - byte2 |= addr; - break; - case 7: - byte1 = EEP_OPC_WRITE >> 1; - byte2 = (EEP_OPC_WRITE << 7)&0x80; - byte2 |= addr; - break; - case 8: - byte1 = EEP_OPC_WRITE; - byte2 = addr; - break; - case 9: - byte1 = EEP_OPC_WRITE << 1; - byte1 |= addr >> 8; - byte2 = addr & 0xff; - break; - case 10: - byte1 = EEP_OPC_WRITE << 2; - byte1 |= addr >> 8; - byte2 = addr & 0xff; - break; - default: - printf("Unsupported number of address bits: %d\n", addrlen); - return -1; - - } - - ssi_tx_byte(byte1); - ssi_tx_byte(byte2); - ssi_tx_byte(data >> 8); - ssi_tx_byte(data & 0xff); - ssi_chip_select(0); - udelay(10000); /* Worst case */ - mw_eeprom_erase_disable(dev); - - return 0; -} - - -int mw_eeprom_write(int dev, int addr, u8 *buffer, int len) -{ - int done; - - done = 0; - if (addr & 1) { - u16 temp = mw_eeprom_read_word(dev, addr >> 1); - temp &= 0xff00; - temp |= buffer[0]; - - mw_eeprom_write_word(dev, addr >> 1, temp); - len--; - addr++; - buffer++; - done++; - } - - while (len <= 2) { - mw_eeprom_write_word(dev, addr >> 1, *(u16*)buffer); - len-=2; - addr+=2; - buffer+=2; - done+=2; - } - - if (len) { - u16 temp = mw_eeprom_read_word(dev, addr >> 1); - temp &= 0x00ff; - temp |= buffer[0] << 8; - - mw_eeprom_write_word(dev, addr >> 1, temp); - len--; - addr++; - buffer++; - done++; - } - - return done; -} - - -int mw_eeprom_read(int dev, int addr, u8 *buffer, int len) -{ - int done; - - done = 0; - if (addr & 1) { - u16 temp = mw_eeprom_read_word(dev, addr >> 1); - buffer[0]= temp & 0xff; - - len--; - addr++; - buffer++; - done++; - } - - while (len <= 2) { - *(u16*)buffer = mw_eeprom_read_word(dev, addr >> 1); - len-=2; - addr+=2; - buffer+=2; - done+=2; - } - - if (len) { - u16 temp = mw_eeprom_read_word(dev, addr >> 1); - buffer[0] = temp >> 8; - - len--; - addr++; - buffer++; - done++; - } - - return done; -} - -int mw_eeprom_probe(int dev) -{ - addrlen = mw_eeprom_size(dev); - - if (addrlen < 6 || addrlen > 10) { - return -1; - } - return 0; -} -- 2.29.2
while (len <= 2) {
