[U-Boot] [PATCH] am43xx_evm: Add netboot and related to environment
Signed-off-by: Tom Rini trini@ti.com --- include/configs/am43xx_evm.h | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 7ccbf36..44b6f93 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -168,6 +168,10 @@ "usbroot=/dev/sda2 rw\0" \ "usbrootfstype=ext4 rootwait\0" \ "usbdev=0\0" \ + "rootpath=/export/rootfs\0" \ + "nfsopts=nolock\0" \ + "static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}" \ + "::off\0" \ "ramroot=/dev/ram0 rw\0" \ "ramrootfstype=ext2\0" \ "mmcargs=setenv bootargs console=${console} " \ @@ -178,6 +182,11 @@ "${optargs} " \ "root=${usbroot} " \ "rootfstype=${usbrootfstype}\0" \ + "netargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=/dev/nfs " \ + "nfsroot=${serverip}:${rootpath},${nfsopts} rw " \ + "ip=dhcp\0" \ "bootenv=uEnv.txt\0" \ "loadbootenv=load ${devtype} ${devnum} ${loadaddr} ${bootenv}\0" \ "importbootenv=echo Importing environment from mmc ...; " \ @@ -229,6 +238,13 @@ "bootz ${loadaddr} - ${fdtaddr}; " \ "fi;" \ "fi\0" \ + "netboot=echo Booting from network ...; " \ + "setenv autoload no; " \ + "dhcp; " \ + "tftp ${loadaddr} ${bootfile}; " \ + "tftp ${fdtaddr} ${fdtfile}; " \ + "run netargs; " \ + "bootz ${loadaddr} - ${fdtaddr}\0" \ "findfdt="\ "if test $board_name = AM43EPOS; then " \ "setenv fdtfile am43x-epos-evm.dtb; fi; " \
- "rootpath=/export/rootfs\0" \
- "nfsopts=nolock\0" \
- "static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}" \
"ramroot=/dev/ram0 rw\0" \ "ramrootfstype=ext2\0" \ "mmcargs=setenv bootargs console=${console} " \"::off\0" \
- "netargs=setenv bootargs console=${console} " \
"${optargs} " \
"root=/dev/nfs " \
"bootenv=uEnv.txt\0" \ "loadbootenv=load ${devtype} ${devnum} ${loadaddr} ${bootenv}\0" \ "importbootenv=echo Importing environment from mmc ...; " \"ip=dhcp\0" \
- "netboot=echo Booting from network ...; " \
"dhcp; " \
"run netargs; " \
"findfdt="\ "if test $board_name = AM43EPOS; then " \ "setenv fdtfile am43x-epos-evm.dtb; fi; " \"bootz ${loadaddr} - ${fdtaddr}\0" \
Should we start introducing generic macros in v7_common.h ? that'd let all network enabled platforms to uniformly provide this?
-----Original Message----- From: Menon, Nishanth Sent: Monday, February 16, 2015 4:03 PM To: Cooper Jr., Franklin; u-boot@lists.denx.de Cc: Rini, Tom Subject: Re: [U-Boot] [PATCH] am43xx_evm: Add netboot and related to environment
"ramroot=/dev/ram0 rw\0" \ "ramrootfstype=ext2\0" \ "mmcargs=setenv bootargs console=${console} " \ @@ -178,6 +182,11"::off\0" \
"${optargs} " \
"root=/dev/nfs " \
"bootenv=uEnv.txt\0" \ "loadbootenv=load ${devtype} ${devnum} ${loadaddr} ${bootenv}\0" \ "importbootenv=echo Importing environment from mmc ...; " \ @@"ip=dhcp\0" \
"dhcp; " \
"run netargs; " \
[Franklin] I see no issue with that. We should probably do the same for mmc, usb and probably some other peripherals. It won't really change anything for 335x, 437x and am57x TI evms but users of non TI boards or other TI SOCs may have an issue.
-- Regards, Nishanth Menon
"${optargs} " \
"root=/dev/nfs " \
"dhcp; " \
"run netargs; " \
And at that point adopt some of the generic distro boot command patches that have been posted for am335x to be to ti_armv7_common.h and update that generic framework as needed for netboot, etc?
Nishanth Menon
