[U-Boot] [PATCH] pci: layerscape: remove multiple definitions of SVR
SVR values for various nxp SOCs are defined in asm/arch/soc.h we can use these values in any peripheral driver. we need not to redefine these values in peripheral driver, as this becomes difficult to manage (add or change new values)
Signed-off-by: Pankaj Bansal pankaj.bansal@nxp.com --- drivers/pci/pcie_layerscape.c | 11 ++++++----- drivers/pci/pcie_layerscape.h | 9 +-------- drivers/pci/pcie_layerscape_fixup.c | 9 +++++---- 3 files changed, 12 insertions(+), 17 deletions(-)
diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index db1375a1ce..d8a7b7c865 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017 NXP + * Copyright 2017, 2019 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. * Layerscape PCIe driver */ @@ -15,6 +15,7 @@ #if defined(CONFIG_FSL_LSCH2) || defined(CONFIG_FSL_LSCH3) || \ defined(CONFIG_ARM) #include <asm/arch/clock.h> +#include <asm/arch/soc.h> #endif #include "pcie_layerscape.h"
@@ -56,7 +57,7 @@ static int ls_pcie_ltssm(struct ls_pcie *pcie) uint svr;
svr = get_svr(); - if (((svr >> SVR_VAR_PER_SHIFT) & SVR_LS102XA_MASK) == SVR_LS102XA) { + if ((SVR_DEV(svr) & SVR_LS102XA_MASK) == SVR_LS102XA) { state = ctrl_readl(pcie, LS1021_PEXMSCPORTSR(pcie->idx)); state = (state >> LS1021_LTSSM_STATE_SHIFT) & LTSSM_STATE_MASK; } else { @@ -149,7 +150,7 @@ static void ls_pcie_setup_atu(struct ls_pcie *pcie) uint svr;
svr = get_svr(); - if (((svr >> SVR_VAR_PER_SHIFT) & SVR_LS102XA_MASK) == SVR_LS102XA) { + if ((SVR_DEV(svr) & SVR_LS102XA_MASK) == SVR_LS102XA) { offset = LS1021_PCIE_SPACE_OFFSET + LS1021_PCIE_SPACE_SIZE * pcie->idx; } @@ -172,7 +173,7 @@ static void ls_pcie_setup_atu(struct ls_pcie *pcie) idx = PCIE_ATU_REGION_INDEX1 + 1;
/* Fix the pcie memory map for LS2088A series SoCs */ - svr = (svr >> SVR_VAR_PER_SHIFT) & 0xFFFFFE; + svr = SVR_SOC_VER(svr); if (svr == SVR_LS2088A || svr == SVR_LS2084A || svr == SVR_LS2048A || svr == SVR_LS2044A || svr == SVR_LS2081A || svr == SVR_LS2041A) { @@ -502,7 +503,7 @@ static int ls_pcie_probe(struct udevice *dev) * for LS2088A series SoCs */ svr = get_svr(); - svr = (svr >> SVR_VAR_PER_SHIFT) & 0xFFFFFE; + svr = SVR_SOC_VER(svr); if (svr == SVR_LS2088A || svr == SVR_LS2084A || svr == SVR_LS2048A || svr == SVR_LS2044A || svr == SVR_LS2081A || svr == SVR_LS2041A) { diff --git a/drivers/pci/pcie_layerscape.h b/drivers/pci/pcie_layerscape.h index ddfbba6538..9a19993568 100644 --- a/drivers/pci/pcie_layerscape.h +++ b/drivers/pci/pcie_layerscape.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2017 NXP + * Copyright 2017, 2019 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. * Layerscape PCIe driver */ @@ -111,14 +111,7 @@ #define PCIE_CS2_OFFSET 0x1000 /* For PCIe without SR-IOV */
#define SVR_LS102XA 0 -#define SVR_VAR_PER_SHIFT 8 #define SVR_LS102XA_MASK 0x700 -#define SVR_LS2088A 0x870900 -#define SVR_LS2084A 0x870910 -#define SVR_LS2048A 0x870920 -#define SVR_LS2044A 0x870930 -#define SVR_LS2081A 0x870918 -#define SVR_LS2041A 0x870914
/* LS1021a PCIE space */ #define LS1021_PCIE_SPACE_OFFSET 0x4000000000ULL diff --git a/drivers/pci/pcie_layerscape_fixup.c b/drivers/pci/pcie_layerscape_fixup.c index 089e031724..9a09852981 100644 --- a/drivers/pci/pcie_layerscape_fixup.c +++ b/drivers/pci/pcie_layerscape_fixup.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017 NXP + * Copyright 2017, 2019 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. * Layerscape PCIe driver */ @@ -16,6 +16,7 @@ #ifdef CONFIG_ARM #include <asm/arch/clock.h> #endif +#include <asm/arch/soc.h> #include "pcie_layerscape.h"
#if defined(CONFIG_FSL_LSCH3) || defined(CONFIG_FSL_LSCH2) @@ -83,7 +84,7 @@ static void fdt_pcie_set_msi_map_entry(void *blob, struct ls_pcie *pcie, pcie->dbi_res.start); if (nodeoffset < 0) { #ifdef CONFIG_FSL_PCIE_COMPAT /* Compatible with older version of dts node */ - svr = (get_svr() >> SVR_VAR_PER_SHIFT) & 0xFFFFFE; + svr = SVR_SOC_VER(get_svr()); if (svr == SVR_LS2088A || svr == SVR_LS2084A || svr == SVR_LS2048A || svr == SVR_LS2044A || svr == SVR_LS2081A || svr == SVR_LS2041A) @@ -137,7 +138,7 @@ static void fdt_pcie_set_iommu_map_entry(void *blob, struct ls_pcie *pcie, pcie->dbi_res.start); if (nodeoffset < 0) { #ifdef CONFIG_FSL_PCIE_COMPAT /* Compatible with older version of dts node */ - svr = (get_svr() >> SVR_VAR_PER_SHIFT) & 0xFFFFFE; + svr = SVR_SOC_VER(get_svr()); if (svr == SVR_LS2088A || svr == SVR_LS2084A || svr == SVR_LS2048A || svr == SVR_LS2044A || svr == SVR_LS2081A || svr == SVR_LS2041A) @@ -228,7 +229,7 @@ static void ft_pcie_rc_fix(void *blob, struct ls_pcie *pcie) pcie->dbi_res.start); if (off < 0) { #ifdef CONFIG_FSL_PCIE_COMPAT /* Compatible with older version of dts node */ - svr = (get_svr() >> SVR_VAR_PER_SHIFT) & 0xFFFFFE; + svr = SVR_SOC_VER(get_svr()); if (svr == SVR_LS2088A || svr == SVR_LS2084A || svr == SVR_LS2048A || svr == SVR_LS2044A || svr == SVR_LS2081A || svr == SVR_LS2041A)
Hi Pankaj,
-----Original Message----- From: Pankaj Bansal Sent: 2019年10月14日 16:56 To: Priyanka Jain priyanka.jain@nxp.com; Xiaowei Bao xiaowei.bao@nxp.com; Tom Rini trini@konsulko.com; Z.q. Hou zhiqiang.hou@nxp.com Cc: u-boot@lists.denx.de; Pankaj Bansal pankaj.bansal@nxp.com Subject: [PATCH] pci: layerscape: remove multiple definitions of SVR
- Copyright 2017 NXP
- Copyright 2017, 2019 NXP
- Copyright 2014-2015 Freescale Semiconductor, Inc.
- Layerscape PCIe driver
svr = get_svr();
SVR_LS102XA) {
- if ((SVR_DEV(svr) & SVR_LS102XA_MASK) == SVR_LS102XA) { state = ctrl_readl(pcie, LS1021_PEXMSCPORTSR(pcie->idx)); state = (state >> LS1021_LTSSM_STATE_SHIFT) &
svr = get_svr();
SVR_LS102XA) {
- if ((SVR_DEV(svr) & SVR_LS102XA_MASK) == SVR_LS102XA) { offset = LS1021_PCIE_SPACE_OFFSET + LS1021_PCIE_SPACE_SIZE * pcie->idx; }
- svr = SVR_SOC_VER(svr); if (svr == SVR_LS2088A || svr == SVR_LS2084A || svr == SVR_LS2048A || svr == SVR_LS2044A || svr == SVR_LS2081A || svr == SVR_LS2041A) { @@ -502,7 +503,7
- svr = SVR_SOC_VER(svr); if (svr == SVR_LS2088A || svr == SVR_LS2084A || svr == SVR_LS2048A || svr == SVR_LS2044A || svr == SVR_LS2081A || svr == SVR_LS2041A) { diff --git
Keep in mind that LS1021A (armv7) also uses this driver and it will result in build error when removed them.
Thanks, Zhiqiang
if (svr == SVR_LS2088A || svr == SVR_LS2084A || svr == SVR_LS2048A || svr == SVR_LS2044A || svr == SVR_LS2081A || svr == SVR_LS2041A) @@ -137,7svr = SVR_SOC_VER(get_svr());
if (svr == SVR_LS2088A || svr == SVR_LS2084A || svr == SVR_LS2048A || svr == SVR_LS2044A || svr == SVR_LS2081A || svr == SVR_LS2041A) @@ -228,7svr = SVR_SOC_VER(get_svr());
if (svr == SVR_LS2088A || svr == SVR_LS2084A || svr == SVR_LS2048A || svr == SVR_LS2044A || svr == SVR_LS2081A || svr == SVR_LS2041A)svr = SVR_SOC_VER(get_svr());
-- 2.17.1
-----Original Message----- From: Z.q. Hou Sent: Tuesday, 15 October, 2019 08:59 AM To: Pankaj Bansal pankaj.bansal@nxp.com; Priyanka Jain priyanka.jain@nxp.com; Xiaowei Bao xiaowei.bao@nxp.com; Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de Subject: RE: [PATCH] pci: layerscape: remove multiple definitions of SVR
Hi Pankaj,
svr = get_svr();
SVR_LS102XA) {
LTSSM_STATE_MASK;
svr = get_svr();
SVR_LS102XA) {
Oh! Then I will keep this code as it is and add LX2160A SVR (and it's various personalities) in the pcie_layerscape.h
Thanks, Zhiqiang
#if defined(CONFIG_FSL_LSCH3) || defined(CONFIG_FSL_LSCH2) @@ -83,7 +84,7 @@ static void fdt_pcie_set_msi_map_entry(void *blob, struct +ls_pcie *pcie, pcie->dbi_res.start); if (nodeoffset < 0) { #ifdef CONFIG_FSL_PCIE_COMPAT /* Compatible with older version of dts node */
-- 2.17.1
Pankaj Bansal
Z.q. Hou
