[U-Boot] [PATCH] configs: imx6qdl: Remove imx6qdl_icore_nand_defconfig
imx6qdl_icore_nand_defconfig is no longer used, since it was the recreated for quad and dl separately. "imx6q: engicam: Use SPL_LOAD_FIT for MMC boards" (sha1: 3d409153502f25a1ea3b8b4e9940148b7871273d)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/imx6qdl_icore_nand_defconfig | 49 ------------------------------------ 1 file changed, 49 deletions(-) delete mode 100644 configs/imx6qdl_icore_nand_defconfig
diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig deleted file mode 100644 index 5e142272d6..0000000000 --- a/configs/imx6qdl_icore_nand_defconfig +++ /dev/null @@ -1,49 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_SYS_TEXT_BASE=0x17800000 -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_TARGET_MX6Q_ENGICAM=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_WATCHDOG_SUPPORT=y -# CONFIG_CMD_BMODE is not set -CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" -CONFIG_BOOTDELAY=3 -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_SPL=y -CONFIG_SPL_DMA_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="icorem6qdl> " -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:2m(spl),2m(uboot),1m(env),8m(kernel),1m(dtb),-(rootfs)" -CONFIG_CMD_UBI=y -CONFIG_OF_LIST="imx6q-icore imx6dl-icore" -CONFIG_ENV_IS_IN_NAND=y -CONFIG_SYS_I2C_MXC=y -CONFIG_NAND=y -CONFIG_NAND_MXS=y -CONFIG_PHYLIB=y -CONFIG_PHY_SMSC=y -CONFIG_FEC_MXC=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_IMX6=y -CONFIG_MXC_UART=y -CONFIG_IMX_THERMAL=y -CONFIG_VIDEO=y -CONFIG_VIDEO_IPUV3=y
Jagan Teki
