[U-Boot] [PATCH] net/designware: add support of max-speed device tree property
This property allows to specify fastest connection mode supported by the MAC (as opposed to features of the phy).
There are situations when phy may handle faster modes than the MAC (or even it's particular implementation or even due to CPU being too slow).
This property is a standard one in Linux kernel these days and some boards do already use it in their device tree descriptions.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Cc: Joe Hershberger joe.hershberger@gmail.com --- drivers/net/designware.c | 14 +++++++++++++- drivers/net/designware.h | 1 + 2 files changed, 14 insertions(+), 1 deletion(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 39c7279..66dc701 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -406,7 +406,7 @@ static int _dw_free_pkt(struct dw_eth_dev *priv) static int dw_phy_init(struct dw_eth_dev *priv, void *dev) { struct phy_device *phydev; - int mask = 0xffffffff; + int mask = 0xffffffff, ret;
#ifdef CONFIG_PHY_ADDR mask = 1 << CONFIG_PHY_ADDR; @@ -419,6 +419,11 @@ static int dw_phy_init(struct dw_eth_dev *priv, void *dev) phy_connect_dev(phydev, dev);
phydev->supported &= PHY_GBIT_FEATURES; + if (priv->max_speed) { + ret = phy_set_supported(phydev, priv->max_speed); + if (ret) + return ret; + } phydev->advertising = phydev->supported;
priv->phydev = phydev; @@ -601,6 +606,7 @@ static int designware_eth_probe(struct udevice *dev) priv->mac_regs_p = (struct eth_mac_regs *)iobase; priv->dma_regs_p = (struct eth_dma_regs *)(iobase + DW_DMA_BASE_OFFSET); priv->interface = pdata->phy_interface; + priv->max_speed = pdata->max_speed;
dw_mdio_init(dev->name, priv->mac_regs_p); priv->bus = miiphy_get_dev_by_name(dev->name); @@ -635,6 +641,7 @@ static int designware_eth_ofdata_to_platdata(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); const char *phy_mode; + const fdt32_t *cell;
pdata->iobase = dev_get_addr(dev); pdata->phy_interface = -1; @@ -646,6 +653,11 @@ static int designware_eth_ofdata_to_platdata(struct udevice *dev) return -EINVAL; }
+ pdata->max_speed = 0; + cell = fdt_getprop(gd->fdt_blob, dev->of_offset, "max-speed", NULL); + if (cell) + pdata->max_speed = fdt32_to_cpu(*cell); + return 0; }
diff --git a/drivers/net/designware.h b/drivers/net/designware.h index 4b9ec39..ed6344c 100644 --- a/drivers/net/designware.h +++ b/drivers/net/designware.h @@ -223,6 +223,7 @@ struct dw_eth_dev { char rxbuffs[RX_TOTAL_BUFSIZE] __aligned(ARCH_DMA_MINALIGN);
u32 interface; + u32 max_speed; u32 tx_currdescnum; u32 rx_currdescnum;
Alexey Brodkin
